[Sammelthread] ASRock Fatal1ty X370 Gaming K4
(lt. Berichten bereits EOL!)
- Spezifikationen:
Gaming ArmorPower
  • Hi-Density Power Connectors (24 pin and 8 pin)
Memory
  • 15μ Gold Contact in DIMM Slots
VGA Card
  • 15μ Gold Contact in VGA PCIe Slot (PCIE2)
Internet
  • Intel® LAN
Cooling
  • XXL Aluminum Alloy Heatsink
Audio
  • Creative Sound Blaster™ Cinema 3
Unique FeatureASRock USB 3.1
  • ASRock USB 3.1 Type-A Port (10 Gb/s)
  • ASRock USB 3.1 Type-C Port (10 Gb/s)
ASRock Super Alloy
  • Premium 45A Power Choke
  • Nichicon 12K Black Caps (100% Japan made high quality conductive polymer capacitors)
  • I/O Armor
  • Matte Black PCB
  • High Density Glass Fabric PCB
  • 2oz Copper PCB
ASRock Steel Slots
ASRock Ultra M.2 (PCIe Gen3 x4 & SATA3)
ASRock Full Spike Protection (for all USB, Audio, LAN Ports)
ASRock Live Update & APP Shop
CPU
  • Supports AMD Socket AM4 A-Series APUs (Bristol Ridge) and Ryzen Series CPUs (Summit Ridge)
  • IR Digital PWM
  • 12 Power Phase design
  • Supports 95W Water Cooling
Chipset
  • AMD Promontory X370
Memory
  • Dual Channel DDR4 Memory Technology
  • 4 x DDR4 DIMM Slots
  • AMD Ryzen series CPUs support DDR4 2933+(OC)2667/2400/2133 ECC & non-ECC, un-buffered memory*
  • AMD 7th Gen A-Series APUs support DDR4 2400/2133 ECC & non-ECC, un-buffered memory*
  • Max. capacity of system memory: 64GB**
*Please refer to Memory Support List on ASRock's website for more information.
**Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® 32-bit OS. For Windows® 64-bit OS with 64-bit CPU, there is no such limitation.
BIOS
  • 128Mb AMI UEFI Legal BIOS with GUI support
  • Supports "Plug and Play"
  • ACPI 5.1 compliance wake up events
  • Supports jumperfree
  • SMBIOS 2.3 support
  • CPU, VCORE_NB, DRAM, VPPM, PCH 1.05V, +1.8V, VDDP, PROM 2.5V, Voltage Multi-adjustment
Graphics
  • Integrated AMD Radeon™ R-Series Graphics in A-series APU*
  • DirectX 12, Pixel Shader 5.0
  • Max. shared memory 2GB
  • Supports HDMI with max. resolution up to 4K x 2K (4096x2160) @ 24Hz / (3840x2160) @ 30Hz
  • Supports Auto Lip Sync, Deep Color (12bpc), xvYCC and HBR (High Bit Rate Audio) with HDMI Port (Compliant HDMI monitor is required)
  • Supports HDCP with HDMI Port
  • Supports Full HD 1080p Blu-ray (BD) playback with HDMI Port
*Actual support may vary by CPU
Audio
  • 7.1 CH HD Audio with Content Protection (Realtek ALC1220 Audio Codec)
  • Premium Blu-ray Audio support
  • Supports Surge Protection
  • Nichicon Fine Gold Series Audio Caps
  • 120dB SNR DAC with Differential Amplifier
  • TI® NE5532 Premium Headset Amplifier for Front Panel Audio Connector (Supports up to 600 Ohm headsets)
  • Pure Power-In
  • Direct Drive Technology
  • PCB Isolate Shielding
  • Impedance Sensing on Line Out port
  • Individual PCB Layers for R/L Audio Channel
  • Gold Audio Jacks
  • Supports Creative Sound Blaster™ Cinema 3
LAN
  • Gigabit LAN 10/100/1000 Mb/s
  • GigaLAN Intel® I211AT
  • Supports Wake-On-LAN
  • Supports Lightning/ESD Protection
  • Supports Energy Efficient Ethernet 802.3az
  • Supports PXE
SlotsAMD Ryzen series CPUs
  • 2 x PCI Express 3.0 x16 Slots (single at x16 (PCIE2); dual at x8 (PCIE2) / x8 (PCIE4))*
AMD 7th A-Series APUs
  • 1 x PCI Express 3.0 x16 Slot (single at x8 (PCIE2))*
  • 4 x PCI Express 2.0 x1 Slots
  • Supports AMD Quad CrossFireX™ and CrossFireX™**
  • Supports NVIDIA® Quad SLI™ and SLI™**
  • 1 x M.2 Socket (Key E), supports type 2230 WiFi/BT module
*Supports NVMe SSD as boot disks
**This feature is only supported with Ryzen Series CPUs (Summit Ridge).
Storage
  • 6 x SATA3 6.0 Gb/s Connectors, support RAID (RAID 0, RAID 1 and RAID 10), NCQ, AHCI and Hot Plug
  • 1 x Ultra M.2 Socket (M2_1), supports M Key type 2230/2242/2260/2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen3 x4 (32 Gb/s) (with Ryzen Series CPU) or Gen3 x2 (16 Gb/s) (with A-Series APU)*
  • 1 x M.2 Socket (M2_2), supports M Key type 2230/2242/2260/2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen2 x2 (10 Gb/s)*
*Supports ASRock U.2 Kit Supports NVMe SSD as boot disks
Connector
  • 1 x COM Port Header
  • 1 x TPM Header
  • 1 x Power LED and Speaker Header
  • 1 x AMD Fan LED Header
  • 2 x RGB LED Headers*
  • 1 x CPU Fan Connector (4-pin)**
  • 1 x CPU Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)***
  • 2 x Chassis Fan Connectors (4-pin) (Smart Fan Speed Control)****
  • 1 x Chassis Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)****
  • 1 x 24 pin ATX Power Connector (Hi-Density Power Connector)
  • 1 x 8 pin 12V Power Connector (Hi-Density Power Connector)
  • 1 x Front Panel Audio Connector
  • 1 x AMD LED Fan USB Header
  • 2 x USB 2.0 Headers (Support 4 USB 2.0 ports) (Supports ESD Protection)
  • 2 x USB 3.0 Headers (Support 4 USB 3.0 ports) (Supports ESD Protection)
  • 1 x Dr. Debug with LED
*Supports up to 12V/3A, 36W LED Strip
**The CPU Fan Connector supports the CPU fan of maximum 1A (12W) fan power.
***The CPU Optional/Water Pump Fan supports the water cooler fan of maximum 1.5A (18W) fan power.
****The Chassis Optional/Water Pump Fan supports the water cooler fan of maximum 1.5A (18W) fan power.
Rear Panel I/O
  • 2 x Antenna Ports
  • 1 x PS/2 Mouse Port
  • 1 x PS/2 Keyboard Port
  • 1 x HDMI Port
  • 1 x Optical SPDIF Out Port
  • 1 x USB 3.1 Type-A Port (10 Gb/s) (Supports ESD Protection)
  • 1 x USB 3.1 Type-C Port (10 Gb/s) (Supports ESD Protection)
  • 6 x USB 3.0 Ports (Supports ESD Protection)* 1 x Fatal1ty Mouse Port (USB 3.0) is included
  • 1 x RJ-45 LAN Port with LED (ACT/LINK LED and SPEED LED)
  • HD Audio Jacks: Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone (Gold Audio Jacks)
Software and UEFI
Software
  • ASRock F-Stream
  • ASRock RGB LED
  • ASRock Key Master
  • ASRock APP Charger
  • ASRock XFast LAN*
UEFI
  • ASRock Full HD UEFI
  • ASRock Instant Flash
  • ASRock Internet Flash
  • ASRock Crashless BIOS
  • ASRock Easy RAID Installer
*These utilities can be downloaded from ASRock Live Update & APP Shop.
Support CD
  • Drivers, Utilities, AntiVirus Software (Trial Version), Google Chrome Browser and Toolbar
Accessories
  • Quick Installation Guide, Support CD, I/O Shield
  • 4 x SATA Data Cables
  • 1 x ASRock SLI_HB_Bridge_2S Card
  • 3 x Screws for M.2 Sockets
Hardware Monitor
  • Temperature Sensing: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
  • Fan Tachometer: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
  • Quiet Fan (Auto adjust chassis fan speed by CPU temperature): CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
  • Fan Multi-Speed Control: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
  • Voltage monitoring: +12V, +5V, +3.3V, CPU Vcore, VCORE_NB, DRAM, PCH 1.05V, +1.8V, VDDP
Form Factor
  • ATX Form Factor: 12.0-in x 9.6-in, 30.5 cm x 24.4 cm
OS
  • Microsoft® Windows® 10 64-bit*
*For the updated Windows® 10 driver, please visit ASRock's website for details.
Certifications
  • FCC, CE
  • ErP/EuP ready (ErP/EuP ready power supply is required)
[td]
Quelle: ASRock-Webseite
- RAM Kompatibilität:
Liste der geprüften RAM-Riegel des Herstellers
weitere KITs von Forenmitgliedern:
G.Skill Flare X 16GB Kit (8GBx2) 3200MhzF4-3200C14D-16GFX@3200Mhz (XMP-Profile)
G.Skill Trident Z 32GB Kit (16GBx2) 3200MhzF4-3200C14D-32GTZ@2933Mhz 18-16-16-16-40 1.35V
G.Skill Trident Z 16GB Kit (8GBx2) 3200MhzF4-3200C14D-16GTZ@2933Mhz (XMP-Profile)
G.Skill Trident Z 16GB Kit (8GBx2) 3600MhzF4-3600C15D-16GTZ@3200Mhz 14-14-14-14-34 1.36V
G.Skill RipJaws V 16GB Kit (8GBx2) 3600MhzF4-3600C16D-16GVK@2933Mhz 14-14-14-14-34 1.35V
Crucial Ballistix Tactical 16GB Kit (8GBx2) 2666MhzBLT2C8G4D26AFTA@2666Mhz (XMP-Profile)
Crucial Ballistix Sport LT 16GB Kit (8GBx2) 2400MhzBLS2C8G4D240FSE@2933Mhz 20-20-20-20-48 1.35V
Tipps von "paui":
CAS-Timing:
Es können nur gerade Zahlen dort eingegeben werden.
Sobald man eine 15 einstellt wird diese aufgerundet. Also entweder 14 oder 16 aber keine 15 CAS.
RAM-Stabilität:
Die SOC Spannung erhöhen z.b. auf 1,1V oder 1,2V und überall immer LLC auf Level3
Bei SingleRank Modulen den Bankgroupswap auf disabled stellen.
Die Spannung auf 1,360V für 1,352V unter Last für den ram setzen, VTT_DDR ist immer die Hälfte davon!
Als Beispiel beim G.Skill F4-3600C15D-16GTZ:
3200MHz bei 14-14-14-14-34 mit 1,36V, Bankgroupswap disabled, SOC 1,112V
(wenn es nicht läuft, dann auf 2933MHz da läuft er definitiv stabil)
- BIOS-Versionen:
BIOS-Download von der Herstellerseite
BIOS-Download (auch alte Versionen) bei Computertechnik JZelectronic
V4.70 - Enhance compatibility for Raven CPU with Intel WiFi.
V4.60 - 1.Update AMD AGESA to PinnaclePI-AM4_1.0.0.1a. 2.Improve M.2 SSD compatibility.
V4.50 - Update AGESA for upcoming processors.
Wenn man eine Version unter V3.50 auf eine Versionen über V3.50 flashen möchte, muss man einen Zwischenschritt auf V3.50 machen!
V3.50 - Bridge BIOS
V3.40 - 1.Sync the H/W Monitor and Dr.Debug code Temp source to tCTL 2. Gray out Instant Flash when fTPM is enabled.
V3.30 - 1. With JEDEC 2666MHz DDR4 module, default set DDR4 frequency to 2666MHz. Test with SANMAX SMD4-U8G48MH-26VR and SMD4-U16G48MH-26VR.
V3.20 - 1.Update AGESA to 1.0.0.6b. No memory ABL(AGESA Boot Loader) or training changes. 2.Add setup options to select SMART fan temperature source. Change default to monitor external CPU temperature.
V3.10 - Add AMD PBS Primary Video Adapter to control Bristol Ridge CPU display order.
V3.00 - Update AGESA to 1.0.0.6a
V2.50 - Update AGESA to 1.0.0.6
V2.40 - Enhance OC setting for advanced Overclocker
V2.30 - Verbesserte System und Speicher Kompatibilität
V2.20 - Update AGESA Version string SummitPI-AM4 1.0.0.4a
V2.10 - Verbesserte System Kompatibilität
V2.00 - AGESA-Code aktualisiert - Verbesserung für Ryzen 5 & Precision Boost - Taktraten können jetzt in 25MHz-Schritten im BIOS-Setup eingestellt werden
V1.70 - Improve XMP DRAM compatibility & Add Simultaneous Multi-Threading(SMT) item in BIOS setup
V1.60 - Add Instant flash function & Add CPU Frequency Multiplier Change item
V1.50 - Support CPU Frequency Multiplier function
- Übertakten (CPU/RAM):
Laut dem Video von AMD sollte man bei einem Dauerbetrieb die CPU nicht über VCORE 1.425V betreiben.
Oft kann man auch lesen, dass Werte von 1.45V oder gar bis zu 1.5V ok sind. Hier sollte man aber bedenken, dass dies die Lebensdauer der CPU verkürzt werden kann.
Der SoC kann super mit 1.1V betrieben werden. Oft kann man auch lesen, dass 1.2V noch ok sind.
- Testberichte / Reviews:
Altes Startposting:
Hallo!
Sie wie es aussieht scheint kaum wer ein ASRock X370 Gaming K4 zu haben. Entsprechend spärlich sind auch die Infos, die ich bis jetzt so finden konnte...
Weiß jemand, ob die Backplate des ASRock X370 Gaming K4 verschraubt oder verklebt ist? Da ich einen Lüfter mit eigener Backplate holen möchte, wäre dies wirklich gut zu wissen.
Des weiteren wollte ich fragen, ob man bei ASRock X370 Gaming K4 im BIOS die DRAM Timings manuell einstellen kann und natürlich auch die Taktfrequenz?
Optisch und Preislich spricht mich das Mainboard sehr an, technisch kann ich leider nicht beurteilen, wobei die "Werbeaussagen" ja nicht schlecht sind.
Vielen Dank
SneakyPie
Ich habe zwar das X370 SLI, aber der Unterschied wird wohl nicht so groß sein. Habe heute dieses 32GB Kit getestet, aber mehr als 2133 war trotz Bios 2.5, das ja auf AGESA 1.0.0.6 basiert, nicht drin. Speicher wird zurückgeschickt. Hat schon jemand 2x16GB mit mehr als 2400 am laufen?
G.Skill TridentZ F4-3200C14D-32GTZ (2x16Gb) 3066 @ 14,14,14,32,45, 1T ohne viel Aufwand (XMP, Timings etwas verschärft, SOC 1.1V, LLC2)
Mit etwas mehr Zeit im Rücken hab ich gestern und heute nochmal viel probiert.
3200 liefen zwar mit XMP auf dem 2.50er sofort, aber nie stabil.
Ich musste auf CL16,16,16,16,34 2T gehen, RAM Spannung 1.4V, SOC 1.1V . Aber auch dann lief das ganze nur bei Stock CPU Takt (da aber bisher auch stabil). Meine "normale" 3.7GHZ Ryzen Feldundwiesen-Taktung bei 1.35V hat bei Prime aber sofort nen Fehler ausgeworfen.
Da ich bisher am CPU-Takt nur minimal gespielt habe dachte ich mir, OK, RAM @ 3066 passt, zieh ich mal die CPU hinterher. Das ist dann etwas ausgeartet in eine große Testnacht.. war natürlich auch so clever und habe nicht erstmal geschaut was der Proz eigentlich kann,
sondern mit 3066mhz am CPU Takt rumgemacht ^^.
Ergebnis:
mit meinen stabilen Settings für 3066mhz war mehr als 3.7Ghz einfach nicht drin, egal wie ich es angestellt hab.
Dann hab ich mir gesagt: Ok, Ram Takt runter (zumindest auf 2666mhz) und nochmal. Und siehe da, plötzlich 3.9Ghz @ 1.3V stabil. Das kam mir dann doch etwas bekannt vor, beim 6700k hat das XMP Profil ja auch gern die Spannungsversorgung für den RAM sonstwie hoch gezogen.
Also wieder mein 3066er BIOS Profil geladen, SOC von 1.1V auf 0.95V gesenkt.
4 Stunden Prime etc später seh ich das erstmal als stabil und frag mich warum ich das nicht schon früher probiert hab....
SOC Spannung erhöhen scheint dann auch nicht immer das richtige, bei mir hats zumindest nicht wirklich was an der Stabilität geändert wenn ein Setting minimal Instabil lief.
Werd mir evtl. die 3200 nochmal zur Brust nehmen mit den neuen (alten) Erkenntnissen, aber bin erstmal erleichtert, daß mein Ryzen doch mehr als 3,7 schafft :)
endlich laufen bei mir die 3200MHz mit 14-14-14-14-34.
der entscheidende Faktor waren die Command Rate 2, seitdem bekomme ich keine Speicherfehler mehr.
GZ! Bei mir liefen 3200MHz auch MemoryTest-Stable, jedoch hatte ich bei Spielen immer mal wieder Abstürze, die mit jetzt wieder 2933MHz nicht auftreten. Aber ich habe ja auch nicht die Trident Z sondern die RipJaws V.
Edit: ein RAM Riegel war nicht ganz drin. RIP 3 Stunden Haare raufen
Hi, ich brauche mal eure Hilfe.
Habe gestern mein ASRock x370 Gaming K4 erhalten und wollte heute alles mal zusammenbauen, scheitere jedoch schon sehr früh:
Komponenten:
AsRock x370 Gaming K4
Ryzen 1700
Corsair Vengange LPX CMK16GX4M2B3200C16
Noctua Noctua NH-D15 SE-AM4
BeQuiet Straight PowerMSI E8 580W
MSI GeForce 1060 6GB OC
Ich habe alles schön verbaut (RAM in A2 und B2 Slot), schließe den Strom an und starte. Der Dr. Debug zeigt erst 3F an, dann lange 46 und nach ca. 10 Sekunden rebootet der PC. Der Bildschirm bleibt schwarz. Die Fehlercodes sagen mir leider nichts und weder AsRock noch Google ist da wirklich hilfreich. Also habe ich wieder alles zurückgebaut, CPU kontrolliert, RAM entfernt und nur einen in A2 eingesetzt und wieder gestartet mit exakt gleichem Ergebnis. Auch wenn ich nur den ATX 12V Power Connecter, die CPU und den ATX Power Connector anschließe und die Ram Slots leer lasse, komme ich zu der Fehlermeldung.
Hat jemand eine Ahnung was da schiefläuft? Freue mich über Antworten.
LG David
Ich habe mein G.Skill Trident Z (F4-3200C14D-16GTZ) mit dem BIOS 2,50 mit 3200 zu laufen gebracht. XMP eingestellt und dann nachträglich die Werte noch mal eingetragen.
. Kurz mit prime Blend-Test für 30 min.
Hi Leute,
ich habe da paar fragen zwecks OC wie heiß darf die Cpu für 24/7 betrieb sein? Wie hoch darf die Spannung für den 24/7 betrieb sein? Viele reden ja von 1.35 V.
Ich hatte gerade meinen Ryzen 1700 auf 3,8 ghz mit einem vcore von 1.3125 habe Prime laufen lassen nach 30 min und temps von 70 grad kam ein neustart als kühler dient ein Macho HR-02 rev b,
hey leute, wie hoch ist eure VRM Temperatur?
laut HWiNFO ist meine auf 61°C bei einem Maximum von 78°C
kommt mir ziemlich hoch vor
1600x stock
3033 RAM
Ich sehe da selten mehr als 65°C unter längerer Zeit Vollast - 78°C ist zwar jetzt nicht der Traumwert, aber immer noch gut vertretbar. Zumindest für meine Verhältnisse. Bei >85°C würde ich langsam mal was machen.
Es geht um VRM - Temperaturen, nicht um die CPU... bei VRM gibts keine 20°C Offset. Und HWInfo berücksichtigt auch das, bei den "X" Modellen gibts eine CPU-Temperatur mehr, nämlich die mit 20°C Aufschlag.
Ich habe ein X370 Killer SLI Board und dieses Ram. Leider läuft es trotz Bios 2.50 mit Agesa 1.0.0.6 nur mit 2167. Ich habe gesehen, dass man im Bios das XMP Profil laden und es ggf. modifizieren kann. Welche Werte muß man versuchen zu modifizieren, um das Maximum rauszuholen? Ich wäre schon zufrieden, wenn das Ram mit 2667 erstmal liefe.
Bist du schon weitergekommen?
Ansonsten biete ich dir gern meine Hilfe an :)
Hat eigentlich schon jemand auf dem Gaming K4 es geschafft RAM mit 3200MHz stabil laufen zu lassen?
Oder gar schon RAM-Riegel mit mehr als 3200MHz? Habe 3600er G.Skill und komme stabil nur auf 2933MHz, womit mir das AGESA 1.0.0.6 bis jetzt keine Besserung brachte, obwohl ja bis 4000MHz angeboten wird.
Lief bei mir bisher nicht, 32GB allerdings.
Vor 1.0.0.6 ging nur CL18, max 2933MHz.
Jetzt lief da schon ohne weitere Änderungen CL16.
Die ersten Stunden Prime liefen auch bei 3066 CL14 schon mal durch.
Noch nicht perfekt, die Richtung stimmt aber.
Die 3066er-Einstellubg hatte ich auch und das mit den 14er-Settings. Prime95 hatte nicht zu beanstanden, wie auch Memtest nicht, aber es gab definitiv damit Probleme. Bin auf CL16 zurueck. Man getraut sich aber selber nicht großartig Einstellungen zu machen. Die münden nicht selten in Probleme. Reicht schon CR 1 festzusetzen und er kann keine funktionierende Einstellung finden. Obwohl er es selber schon festlegt. Mich würde mal interessieren, wie stark die Nachteile mit CR2 waeren. Ich habe leider noch keinen ordentlichen RAM-Test gesehen. Der von PCGH im Heft war nur an der Oberflaeche interessant.
habe meine 3600er CL15er G.Skill Module auch bei 3200Mhz bei 14-14-14-34-48-631 1.35V stabil am laufen. wichtig CR2
@cylord: Ja stimmt. Ich meinte gestern, das unsäglich hohe trfc verkürzen zu müssen. Hat direkt alles aus dem Gleichgewicht geworfen.
Hallo in die Runde, gibt es jemanden der die G.Skill FlareX mit XMP Profil auf 3200 laufen hat? Habe nun alles erdenkliche versucht, aber keine Stabilität zu erreichen, maximal möglich sind 2933.
Mich verwirrren auch langsam so einige Gerüchte die man mancherortens über dieses Board liest... Dieses Board hier geht ja EOL und wird durch dieses ersetzt. ASRock > Fatal1ty X370 Gaming X
Angeblich wird die Spannungsversorgung und der Memorysupport verbessert. Was bei Gaming X wegfällt ist USB 3.1. Gibt Stimmen die behaupten dieses Board wir nie mehr als 2933 Ram stabil betreiben können, aber es gibt ja hier im Thread Leute die mehr laufen haben. Allerdings habe die anderen RAM, was ich beim überfliegen gesehen hab.
Hier mal noch einige Quellen:
Asrock X370 Gaming K4 will NOT be able to hit above 3000+ ram (3200) due to PCB limitation? : Amd
X370 Gaming K4 - new BIOS with AGESA 1.0.0.6 out ! - ASRock Forums - Page 1
Asrock x370 K4 and Gaming X : Amd
Also was ist dran? Katze im Sack gekauft oder Quatsch?
Daran wäre ich auch interessiert, da ich dieses Board eigentlich in der engeren Auswahl hatte.
Wenn das mit dem Memory-Support stimmt, habe ich den totalen Reinfall erlitten. Habe extra 3600er RAM gekauft gehabt und nun erfahre ich, dass es umsonst war. OK, die haben nie behauptet, dass 3200MHz geht, aber bei einem X370-Board habe ich das einfach angenommen.
Wollte eigentlich das Gigabyte GA-AB350-Gaming 3 kaufen und habe wg. dem X370-Chipsatz und dem Aussehen dann das Gaming K4 von ASRock genommen. Naja, wieder etwas gelernt... nie mehr ASRock und das nächste Mal den ersten Gedanken umsetzen :)
Nach jetzigem Wissenstand würde ich klar von diesem Board abraten.
Ich meine das sagt ja wohl alles:
"I asked Asrock support yesterday what is the difference between x370 k4 and x370 gaming X:
First response from Asrock:
"X370 Gaming K4 includes USB 3.1 type A&C in rear panel, and X370 Gaming X only have USB 3.0. For memory compatibility, X370 Gaming X can support up to 3200 MHz, and X370 Gaming K4 is supported to 2933 MHz."
My response:
"So only difference is usb port. X370 k4 will support higer memory in future with bios updates?"
Their response:
"X370 Gaming X would have better memory compatibility for sure becuase they have different memory hardware design. AMD Agesa code is still improved the memory architecture, X370 Gaming K4 "may" have better performance but not sure if it could support up to 3200. The function need to be tested after the latest Agesa code released.
Now, I'll tell you the difference is USB ports, memory frequency, layout and PCB are all different. Therefore, if you cares about the memory performance, i would recommend you to choose X370 Gaming X."
Another response from Asrock:
"After checking, the VRM between two models is different.
We haven't release any 3200 memory in the list, so not sure what you could certainly guarantee for this function. But if you could find the memory which can actually reach 3200, it would be great news, you could also provide the information for our reference. Please refer to QVL for X370 Gaming K4."
This Asrock support guy seems very confident that K4 won`t reach 3200mhz, he got me worried. Can anyone here confirm that he got 3200mhz with K4. Also for VRM, both models seems to have 12 phase (web page). Probably not a big difference.
I ordered today K4, couple of days before ordered 3200mhz memory. It would be stupid that x370 k4 wouldn`t support 3200mhz memory, I think that every b350 supports that. This is just their cautious response, by some logic it will 100% support 3200mhz?"
Glaube dennoch nicht, dass da was dran ist, da DDR4 einfach viel zu wenig Strom zieht und die Memory VRM mehr als ausreichend ist selbst für 1,5V+ Spannung... wahrscheinlich nur ein gelangweilter, doofer Supportmitarbeiter.
Außerdem wurde in der Technikpresse diesbezüglich noch nix veröffentlicht, das wäre ein gefundenes Fressen für jeden Journalisten.
Ja dann hau mal rein und kläre asrock mal auf welche 3200er Memory kits den mit dem board funktionieren tun .... :)
Ich?
Hab noch nichtmal nen Ryzen, eben weil ich mich für kein Board entscheiden kann :>
guten morgen
ich habe ein problem bei gaming k4. und zwar habe ich mir gebraucht das baord mit cpu usw gekauft. nun habe ich heute mal den pc angemacht nachdem ich alle weitern teile hatte. mein problem ist jetzt, ich bin laut bios im jahr 4465. somit spinnt natürlich mein windows rum. bios update, batterie raus, cmos gelöscht. nichts hat geholfen.
weiß jemand rat?
Nein, du brauchst eine Zeit Maschine oder du stellst im bios das korrekte Datum ein. ;)
