[Sammelthread] ASRock Fatal1ty X370 Gaming K4
(lt. Berichten bereits EOL!)
- Spezifikationen:
Gaming ArmorPower
  • Hi-Density Power Connectors (24 pin and 8 pin)
Memory
  • 15μ Gold Contact in DIMM Slots
VGA Card
  • 15μ Gold Contact in VGA PCIe Slot (PCIE2)
Internet
  • Intel® LAN
Cooling
  • XXL Aluminum Alloy Heatsink
Audio
  • Creative Sound Blaster™ Cinema 3
Unique FeatureASRock USB 3.1
  • ASRock USB 3.1 Type-A Port (10 Gb/s)
  • ASRock USB 3.1 Type-C Port (10 Gb/s)
ASRock Super Alloy
  • Premium 45A Power Choke
  • Nichicon 12K Black Caps (100% Japan made high quality conductive polymer capacitors)
  • I/O Armor
  • Matte Black PCB
  • High Density Glass Fabric PCB
  • 2oz Copper PCB
ASRock Steel Slots
ASRock Ultra M.2 (PCIe Gen3 x4 & SATA3)
ASRock Full Spike Protection (for all USB, Audio, LAN Ports)
ASRock Live Update & APP Shop
CPU
  • Supports AMD Socket AM4 A-Series APUs (Bristol Ridge) and Ryzen Series CPUs (Summit Ridge)
  • IR Digital PWM
  • 12 Power Phase design
  • Supports 95W Water Cooling
Chipset
  • AMD Promontory X370
Memory
  • Dual Channel DDR4 Memory Technology
  • 4 x DDR4 DIMM Slots
  • AMD Ryzen series CPUs support DDR4 2933+(OC)2667/2400/2133 ECC & non-ECC, un-buffered memory*
  • AMD 7th Gen A-Series APUs support DDR4 2400/2133 ECC & non-ECC, un-buffered memory*
  • Max. capacity of system memory: 64GB**
*Please refer to Memory Support List on ASRock's website for more information.
**Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® 32-bit OS. For Windows® 64-bit OS with 64-bit CPU, there is no such limitation.
BIOS
  • 128Mb AMI UEFI Legal BIOS with GUI support
  • Supports "Plug and Play"
  • ACPI 5.1 compliance wake up events
  • Supports jumperfree
  • SMBIOS 2.3 support
  • CPU, VCORE_NB, DRAM, VPPM, PCH 1.05V, +1.8V, VDDP, PROM 2.5V, Voltage Multi-adjustment
Graphics
  • Integrated AMD Radeon™ R-Series Graphics in A-series APU*
  • DirectX 12, Pixel Shader 5.0
  • Max. shared memory 2GB
  • Supports HDMI with max. resolution up to 4K x 2K (4096x2160) @ 24Hz / (3840x2160) @ 30Hz
  • Supports Auto Lip Sync, Deep Color (12bpc), xvYCC and HBR (High Bit Rate Audio) with HDMI Port (Compliant HDMI monitor is required)
  • Supports HDCP with HDMI Port
  • Supports Full HD 1080p Blu-ray (BD) playback with HDMI Port
*Actual support may vary by CPU
Audio
  • 7.1 CH HD Audio with Content Protection (Realtek ALC1220 Audio Codec)
  • Premium Blu-ray Audio support
  • Supports Surge Protection
  • Nichicon Fine Gold Series Audio Caps
  • 120dB SNR DAC with Differential Amplifier
  • TI® NE5532 Premium Headset Amplifier for Front Panel Audio Connector (Supports up to 600 Ohm headsets)
  • Pure Power-In
  • Direct Drive Technology
  • PCB Isolate Shielding
  • Impedance Sensing on Line Out port
  • Individual PCB Layers for R/L Audio Channel
  • Gold Audio Jacks
  • Supports Creative Sound Blaster™ Cinema 3
LAN
  • Gigabit LAN 10/100/1000 Mb/s
  • GigaLAN Intel® I211AT
  • Supports Wake-On-LAN
  • Supports Lightning/ESD Protection
  • Supports Energy Efficient Ethernet 802.3az
  • Supports PXE
SlotsAMD Ryzen series CPUs
  • 2 x PCI Express 3.0 x16 Slots (single at x16 (PCIE2); dual at x8 (PCIE2) / x8 (PCIE4))*
AMD 7th A-Series APUs
  • 1 x PCI Express 3.0 x16 Slot (single at x8 (PCIE2))*
  • 4 x PCI Express 2.0 x1 Slots
  • Supports AMD Quad CrossFireX™ and CrossFireX™**
  • Supports NVIDIA® Quad SLI™ and SLI™**
  • 1 x M.2 Socket (Key E), supports type 2230 WiFi/BT module
*Supports NVMe SSD as boot disks
**This feature is only supported with Ryzen Series CPUs (Summit Ridge).
Storage
  • 6 x SATA3 6.0 Gb/s Connectors, support RAID (RAID 0, RAID 1 and RAID 10), NCQ, AHCI and Hot Plug
  • 1 x Ultra M.2 Socket (M2_1), supports M Key type 2230/2242/2260/2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen3 x4 (32 Gb/s) (with Ryzen Series CPU) or Gen3 x2 (16 Gb/s) (with A-Series APU)*
  • 1 x M.2 Socket (M2_2), supports M Key type 2230/2242/2260/2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen2 x2 (10 Gb/s)*
*Supports ASRock U.2 Kit Supports NVMe SSD as boot disks
Connector
  • 1 x COM Port Header
  • 1 x TPM Header
  • 1 x Power LED and Speaker Header
  • 1 x AMD Fan LED Header
  • 2 x RGB LED Headers*
  • 1 x CPU Fan Connector (4-pin)**
  • 1 x CPU Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)***
  • 2 x Chassis Fan Connectors (4-pin) (Smart Fan Speed Control)****
  • 1 x Chassis Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)****
  • 1 x 24 pin ATX Power Connector (Hi-Density Power Connector)
  • 1 x 8 pin 12V Power Connector (Hi-Density Power Connector)
  • 1 x Front Panel Audio Connector
  • 1 x AMD LED Fan USB Header
  • 2 x USB 2.0 Headers (Support 4 USB 2.0 ports) (Supports ESD Protection)
  • 2 x USB 3.0 Headers (Support 4 USB 3.0 ports) (Supports ESD Protection)
  • 1 x Dr. Debug with LED
*Supports up to 12V/3A, 36W LED Strip
**The CPU Fan Connector supports the CPU fan of maximum 1A (12W) fan power.
***The CPU Optional/Water Pump Fan supports the water cooler fan of maximum 1.5A (18W) fan power.
****The Chassis Optional/Water Pump Fan supports the water cooler fan of maximum 1.5A (18W) fan power.
Rear Panel I/O
  • 2 x Antenna Ports
  • 1 x PS/2 Mouse Port
  • 1 x PS/2 Keyboard Port
  • 1 x HDMI Port
  • 1 x Optical SPDIF Out Port
  • 1 x USB 3.1 Type-A Port (10 Gb/s) (Supports ESD Protection)
  • 1 x USB 3.1 Type-C Port (10 Gb/s) (Supports ESD Protection)
  • 6 x USB 3.0 Ports (Supports ESD Protection)* 1 x Fatal1ty Mouse Port (USB 3.0) is included
  • 1 x RJ-45 LAN Port with LED (ACT/LINK LED and SPEED LED)
  • HD Audio Jacks: Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone (Gold Audio Jacks)
Software and UEFI
Software
  • ASRock F-Stream
  • ASRock RGB LED
  • ASRock Key Master
  • ASRock APP Charger
  • ASRock XFast LAN*
UEFI
  • ASRock Full HD UEFI
  • ASRock Instant Flash
  • ASRock Internet Flash
  • ASRock Crashless BIOS
  • ASRock Easy RAID Installer
*These utilities can be downloaded from ASRock Live Update & APP Shop.
Support CD
  • Drivers, Utilities, AntiVirus Software (Trial Version), Google Chrome Browser and Toolbar
Accessories
  • Quick Installation Guide, Support CD, I/O Shield
  • 4 x SATA Data Cables
  • 1 x ASRock SLI_HB_Bridge_2S Card
  • 3 x Screws for M.2 Sockets
Hardware Monitor
  • Temperature Sensing: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
  • Fan Tachometer: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
  • Quiet Fan (Auto adjust chassis fan speed by CPU temperature): CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
  • Fan Multi-Speed Control: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
  • Voltage monitoring: +12V, +5V, +3.3V, CPU Vcore, VCORE_NB, DRAM, PCH 1.05V, +1.8V, VDDP
Form Factor
  • ATX Form Factor: 12.0-in x 9.6-in, 30.5 cm x 24.4 cm
OS
  • Microsoft® Windows® 10 64-bit*
*For the updated Windows® 10 driver, please visit ASRock's website for details.
Certifications
  • FCC, CE
  • ErP/EuP ready (ErP/EuP ready power supply is required)
[td]
Quelle: ASRock-Webseite
- RAM Kompatibilität:
Liste der geprüften RAM-Riegel des Herstellers
weitere KITs von Forenmitgliedern:
G.Skill Flare X 16GB Kit (8GBx2) 3200MhzF4-3200C14D-16GFX@3200Mhz (XMP-Profile)
G.Skill Trident Z 32GB Kit (16GBx2) 3200MhzF4-3200C14D-32GTZ@2933Mhz 18-16-16-16-40 1.35V
G.Skill Trident Z 16GB Kit (8GBx2) 3200MhzF4-3200C14D-16GTZ@2933Mhz (XMP-Profile)
G.Skill Trident Z 16GB Kit (8GBx2) 3600MhzF4-3600C15D-16GTZ@3200Mhz 14-14-14-14-34 1.36V
G.Skill RipJaws V 16GB Kit (8GBx2) 3600MhzF4-3600C16D-16GVK@2933Mhz 14-14-14-14-34 1.35V
Crucial Ballistix Tactical 16GB Kit (8GBx2) 2666MhzBLT2C8G4D26AFTA@2666Mhz (XMP-Profile)
Crucial Ballistix Sport LT 16GB Kit (8GBx2) 2400MhzBLS2C8G4D240FSE@2933Mhz 20-20-20-20-48 1.35V
Tipps von "paui":
CAS-Timing:
Es können nur gerade Zahlen dort eingegeben werden.
Sobald man eine 15 einstellt wird diese aufgerundet. Also entweder 14 oder 16 aber keine 15 CAS.
RAM-Stabilität:
Die SOC Spannung erhöhen z.b. auf 1,1V oder 1,2V und überall immer LLC auf Level3
Bei SingleRank Modulen den Bankgroupswap auf disabled stellen.
Die Spannung auf 1,360V für 1,352V unter Last für den ram setzen, VTT_DDR ist immer die Hälfte davon!
Als Beispiel beim G.Skill F4-3600C15D-16GTZ:
3200MHz bei 14-14-14-14-34 mit 1,36V, Bankgroupswap disabled, SOC 1,112V
(wenn es nicht läuft, dann auf 2933MHz da läuft er definitiv stabil)
- BIOS-Versionen:
BIOS-Download von der Herstellerseite
BIOS-Download (auch alte Versionen) bei Computertechnik JZelectronic
V4.70 - Enhance compatibility for Raven CPU with Intel WiFi.
V4.60 - 1.Update AMD AGESA to PinnaclePI-AM4_1.0.0.1a. 2.Improve M.2 SSD compatibility.
V4.50 - Update AGESA for upcoming processors.
Wenn man eine Version unter V3.50 auf eine Versionen über V3.50 flashen möchte, muss man einen Zwischenschritt auf V3.50 machen!
V3.50 - Bridge BIOS
V3.40 - 1.Sync the H/W Monitor and Dr.Debug code Temp source to tCTL 2. Gray out Instant Flash when fTPM is enabled.
V3.30 - 1. With JEDEC 2666MHz DDR4 module, default set DDR4 frequency to 2666MHz. Test with SANMAX SMD4-U8G48MH-26VR and SMD4-U16G48MH-26VR.
V3.20 - 1.Update AGESA to 1.0.0.6b. No memory ABL(AGESA Boot Loader) or training changes. 2.Add setup options to select SMART fan temperature source. Change default to monitor external CPU temperature.
V3.10 - Add AMD PBS Primary Video Adapter to control Bristol Ridge CPU display order.
V3.00 - Update AGESA to 1.0.0.6a
V2.50 - Update AGESA to 1.0.0.6
V2.40 - Enhance OC setting for advanced Overclocker
V2.30 - Verbesserte System und Speicher Kompatibilität
V2.20 - Update AGESA Version string SummitPI-AM4 1.0.0.4a
V2.10 - Verbesserte System Kompatibilität
V2.00 - AGESA-Code aktualisiert - Verbesserung für Ryzen 5 & Precision Boost - Taktraten können jetzt in 25MHz-Schritten im BIOS-Setup eingestellt werden
V1.70 - Improve XMP DRAM compatibility & Add Simultaneous Multi-Threading(SMT) item in BIOS setup
V1.60 - Add Instant flash function & Add CPU Frequency Multiplier Change item
V1.50 - Support CPU Frequency Multiplier function
- Übertakten (CPU/RAM):
Laut dem Video von AMD sollte man bei einem Dauerbetrieb die CPU nicht über VCORE 1.425V betreiben.
Oft kann man auch lesen, dass Werte von 1.45V oder gar bis zu 1.5V ok sind. Hier sollte man aber bedenken, dass dies die Lebensdauer der CPU verkürzt werden kann.
Der SoC kann super mit 1.1V betrieben werden. Oft kann man auch lesen, dass 1.2V noch ok sind.
- Testberichte / Reviews:
Altes Startposting:
Hallo!
Sie wie es aussieht scheint kaum wer ein ASRock X370 Gaming K4 zu haben. Entsprechend spärlich sind auch die Infos, die ich bis jetzt so finden konnte...
Weiß jemand, ob die Backplate des ASRock X370 Gaming K4 verschraubt oder verklebt ist? Da ich einen Lüfter mit eigener Backplate holen möchte, wäre dies wirklich gut zu wissen.
Des weiteren wollte ich fragen, ob man bei ASRock X370 Gaming K4 im BIOS die DRAM Timings manuell einstellen kann und natürlich auch die Taktfrequenz?
Optisch und Preislich spricht mich das Mainboard sehr an, technisch kann ich leider nicht beurteilen, wobei die "Werbeaussagen" ja nicht schlecht sind.
Vielen Dank
SneakyPie
Zen 2 Support nun auch hier seit 2 Tagen offiziell von AsRock:
Hat hier noch jemand das Board und plant ein CPU-Upgrade? Würde mich interessieren.
Ist das die Version, die man auch mit Zen / Zen+ wieder bedenkenlos flashen kann?
:wink:
Bios ist drauf und er hat gebootet :fresse:
Scheint also zu passen ^^
€: Bin bisher sehr begeistert, sogar DDR 3200 läuft endlich stabil :)
(20000% Karhu)
Kann es also auch jedem mit 2000er Ryzen empfehlen!
€2: Auch 3200CL14 ist stabil :wink:
Hallo zusammen,
ich kann ebenfalls bestätigen, dass der RAM-Support auf dem ASRock x370 Gaming K4 im Zusammenspiel mit der neuen AGESA Combo 1004b und einem Ryzen 7 1800X deutlich verbessert wurde.
Nach ca. 2 Jahren im Karton liegend habe ich dieses Board und die CPU in ein zweit System eingebaut und mit 2 x 8 GB Crucial Ballistics Sport LT 3200 CL16 bestückt (Micron E-DIE) und mal aus Spaß das XMP-Profil geladen.
Ich konnte es fast nicht glauben: Der Ram läuft ohne weitere Einstellung auf DDR-3200 stabil. Getestet mit Prime95.
Das war vor zwei Jahren noch nicht mal mit den Flare X 3200 (Samsung B-DIE) möglich. Damals war das höchste der Gefühle DDR-2933.
Und jetzt nur XMP-Profil laden. Ich bin begeistert(y)8-)
Und tatsächlich gibt es für dieses alte Board noch ein neues BIOS- Update: Version 6.0 für das ASROCK fatal1ty X370 gaming X...
Vielleicht probiere ich es am Wochenende aus mit meinem Ryzen 7 1800X. Mein 3200er RAM von Crucial läuft aktuell immer noch mit nur 3000 MHz. Das letzte Mal hat sich ja die RAM- Unterstützung sehr verbessert.
@EndlichwiederAMD Mit Zen 1 werden die neuen BIOS Versionen aber explizit nicht empfohlen. Nicht, dass das System dann schlechter läuft.
@JZ_ wie sieht es aus mit einem Bios Update für die 5000 Ryzen für das K4 der X hat ja ein experimentellen bekommen 6.11.
Hallo zusammen,
Ich habe jetzt, inspiriert durch deinen Post auch das 5.4er BIOS draufgehauen (ebenfalls 1800X hier), leider laufen meine G.Skill RipJaws V (F4-3200C16-8GVKB, afaik mit SK Hynix Chips) immer noch nicht mit den spezifizierten DDR-3200, nach wie vor nur mit DDR-2933 :cautious: Naja, was solls. Upgrade auf Zen 3 sowie ein neues Gigabyte-Board sind eh geplant, sobald die Preise und Verfügbarkeit mal vernünftig werden.
Hat hier schon wer das Update auf 6.12 gemacht?
Habe aktuell noch einen R5 1600X drinne und der 5800X ist unterwegs. Einfach mit der alten 1600X CPU BIOS update auf 6.12 machen und dann den neuen installieren? Manche ASRock Bios Versionen sollte man ja laut Download-Page nicht mit Zen1 verwenden. Kaufe mir zur Not auch ein neues Board aber wollte das alte nicht unnötig abdanken lassen.
MFG
Edit: Oder hat mal wer mit einer Zen1 CPU das 5.5+ bzw 6.0 Bios installiert damit er eine Zen2 CPU einbauen kann? Muss ja nur das BIOS erfolgreich drauf bekommen, muss ja dann nicht mehr booten.
