jign
Semiprofi
DFI BLOOD IRON P35-T2RL
***sammelthread***
***sammelthread***
P35 T2R
I. Allgemeine Infos zum Chipsatz- Unterstützt Core2Duo/Quad (65nm/45nm) (1066Mhz/1333Mhz)
- Heatspreader auf der Northbridge
- Southbridge ICH9R
- Unterstützt PCIe 2.0 für Grafikkarten
- Unterstützt PCIe 1.0 für andere Erweiterungskarten
- Unterstützt DDR2 und DDR3 (wahlweise oder gemischt)
II. Technische Details zum Board [DFI BLOOD IRON P35-T2RL]
CPU
# LGA 775 socket for: - Intel® CoreTM2 Quad, Intel® CoreTM2 Extreme, Intel® CoreTM2 Duo, Intel® Pentium® D or Intel® Pentium® 4
# Supports Intel Enhanced Memory 64 Technology (EMT64T)
# Supports Enhanced Intel SpeedStep Technology (EIST)
# Supports Intel Hyper-Threading Technology
# Supports 1333*/1066/800MHz system bus speed *Available only on CPUs that support 1333MHz FSB
Chipset
# Intel® chipset - Northbridge: Intel® P35 Express chipset (with Intel® Fast Memory Access technology) - Southbridge: Intel® ICH9R
Memory
# Four 240-pin DDR2 DIMM sockets
# Supports DDR2 667/800 MHz DIMMs
# Supports dual channel (128-bit wide) memory interface
# Supports up to 8GB system memory
# Delivers up to 12.8Gb/s bandwidth
# Supports unbuffered x8 and x16 DIMMs
Expansion Slots
# 1 PCI Express x16 slot
# 2 PCI Express x1 slots
# 3 PCI slots
BIOS
# Award BIOS
# 8Mbit flash memory
Power Management
# ACPI and OS Directed Power Management
# ACPI STR (Suspend to RAM) function
# Wake-On-PS/2 Keyboard/Mouse
# Wake-On-USB Keyboard/Mouse
# Wake-On-LAN
# Wake-On-Ring
# RTC timer to power-on the system
# AC power failure recovery
Hardware Monitor
# Monitors CPU/system/Northbridge temperature and overheat alarm
# Monitors Vcore/Vdimm/Vnb/VCC5/12V/V5sb/Vbat voltages
# Monitors the speed of the cooling fans
# CPU Overheat Protection function monitors CPU temperature and fan during system boot-up
- automatic shutdown upon system overheat
Audio
# Realtek ALC885 High Definition audio CODEC
# 8-channel audio output
# DAC SNR/ADC SNR of 106dB/101dB
# Full-rate lossless content protection technology
# Optical S/PDIF-out and coaxial RCA S/PDIF-out interfaces
LAN
# Marvell 88E8053 PCIE Gigabit LAN
# Fully compliant to IEEE 802.3 (10BASE-T),
802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
IDE
# JMicron JMB368 PCI Express to PATA host controller
# Supports up to 2 UltraDMA 33/66/100Mbps IDE devices
Serial ATA with RAID
# 6 SATA ports
# SATA speed up to 3Gb/s
# RAID 0, RAID 1, RAID 0+1 and RAID 5
Rear Panel I/O Ports
# 1 mini-DIN-6 PS/2 mouse port
# 1 mini-DIN-6 PS/2 keyboard port
# 1 optical S/PDIF-out port
# 1 coaxial RCA S/PDIF-out port
# 6 USB 2.0/1.1 ports
# 1 RJ45 LAN port
# Center/subwoofer, rear R/L and side R/L jacks
# Line-in, line-out (front R/L) and mic-in jacks
I/O Connectors
# 3 connectors for 6 additional external USB 2.0 ports
# 1 connector for an external COM port
# 1 front audio connector for line-out and mic-in jacks
# 1 CD-in internal audio connector
# 1 connector for IrDA interface
# 6 Serial ATA ports
# 1 40-pin IDE connector
# 1 floppy connector
# 1 24-pin ATX power connector
# 1 8-pin 12V power connector
# 1 front panel connector
# 3 fan connectors
PCB
# 4 layers, ATX form factor
# 24.4cm (9.6") x 30.5cm (12")
III. Tipps/Tricks und Problemlösungen
IV. Sonstiges
V. Impressionen
VI. Layout [DFI BLOOD IRON P35-T2RL]
VII. OC Liste
VIII.RAM Liste
IX. Downloads/Links
VII. OC Liste
VIII.RAM Liste
I. Offizielle Hersteller Seite: klick
II. BIOS: klick
III. Beta BIOS:
IV. Geizhalslink: klick
Hinzugefügter Post:
Habe leider noch nicht viel über das board gehört, interessiere mich aber sehr für die OC Eigenschaften. Also owner an die Front und lasst was hören, vorallem was den MaxFSB betrifft dieser interessiert mich brennend.
