siehe einfach bei Asus (HP) nach Bios 0701
Beschreibung Striker Extreme Release BIOS 0701
1. Fixed NB Core voltage setting error when CMOS fail
2. Enable support for Conroe 1333MHz processor
3. Fixed VID incorrect after OC to 1201Mhz(FSB)
4. Added New Micro Code to support new CPU
5. Finetune CPU temperature calculation algorithm
6. Displays "Press TAB to display BIOS POST Message" string even when full screen logo is enabled.
7. Correct incorrect info under Summary screen.
8. Correct "SLI-Ready Memory Detected" display problem at POST
9. Fixed CPU not restore back to original frequncy after CPR
10. Add help string for HPET item.
Gruß Raberduck
Gruß Raberduck
