@Teslahun what's your polling rate in hwinfo64? aquacomputer devices send sensor data with a 1000ms polling rate, so when you set 1s in hwinfo64 settings it should read lower numbers.
these devices don't cause latency since the only data they send is sensor data. this isn't a device communicating and interacting with the rest of your system, it runs independently, so it simply can't cause system latency and therefore fps drops. except maybe when sth with the USB bus is wrong.
means, the problem is on some other hardware / software. doesn't really help, yep, but it's not the hf or octo :)
since you're talking about fps dips: did you try running your games in which you experience fps drops without an overlay? or an overlay not containing data from hwinfo64 but e.g. afterburner? does it feel better then or are the hickups still there?
edit: more info. profiling time = the time you see there is just the time it needs to read the sensors. it's no latency indicator. but from where the stutters (I've interpreted your "dips" now more or less as stuttering) originate...? I don't know, sry
Thanx for the reply !
My polling rate is the default 2000ms . 1000 did not help, 5000 either.
I already disabled the RTSS GPU power report sensor and still see some stutters , when hwinfo +msi AB ios running , just like in this video :
Ah mist hab kühler gelesen und an radi gedacht.
Stimmt den cpu kühler hatte ich n paar Jahre nicht auf.
afterwards, I'm now thinking that the idea with changing polling rate was a silly one, in which way should this affect the readout delay... :d no matter, "possibly more synced, worth a try", I just thought, maybe :d
after a bit of reading it seems that there are only some specific sensor readings that can cause performance drops. maybe creating profiles via .reg files (hwinfo64 doesn't allow saving and loading real profiles iirc, so you would have to export your default settings and a setting for only the entries needed in your overlay) works for you, and disabling monitoring for every sensor you don't need brings positive results (y) like somehow creating a minimal profile, with only the info really needed tracked by hwinfo? since for me it looks like only the overlay is causing it for you?
Keine Ahnung ob es da Unterschiede gibt, aber die anderen Sensoren von Alphacool (z.B. Eiszapfen) sind mit -40°C bis +125°C angegeben.
wunderbar, thx euch beiden 👍 VRMs prüfen sollte dann ohne weiteres machbar sein.
Welchen Durchflussmesser könnt ihr empfehlen? Habe kein highflow System. Sollte ohne bewegliche Teile auskommen.
Ich weiß nicht, ob es gute dfm ohne bewegliche Teile gibt, grundsätzlich aber sind die aquacomputer High Flow teile recht genau und es gibt wohl keine wirkliche (zumindest bezahlbare) Alternative.
@Pyrocrack auch, wenn immer wieder mal über diese art geräte gelästert und ihnen schlechte funktion bescheinigt wurde: ich hatte den hier mal. während des ersetzens durch einen high flow LT, der dann kurze zeit mal gleichzeitig montiert war, hatte sich gezeigt, dass er erstaunlich genau gearbeitet hat (nur 2-5L abweichung). als halbwegs brauchbares schätzeisen reicht sowas mMn allemal; hat aber glaube ich ein rad als bewegliches teil.
für bessere und zuverlässlichere braucht's meist wieder zustzl. hw wie zB einen quadro/octo/aquaero o.ä.. wieviel willst du für sowas investieren oder was existiert ggf. schon?
Ich habe nen alten Flowmeter mit sogar Rubinlagerung, leider hängt der immer mal gerne kurz ab und zu. Da muss ich wohl mal die Nieten aufbohren und den reinigen. Den hatte ich sogar mal ausgelitert, aber muss ich wohl mal wieder alles neu machen. Der braucht auch noch extra Elektronik zur auswertung, so und so viele Pulse pro Liter.
mps flow 100: Messbereich ca. 20 - 100 Liter pro Stunde (Art. 53130), das schaffe ich nie mit der
aquastream XT, ach pro Stunde Moment ist noch früh :LOL:
.. k.A. der hier hat -50 +90
hat jemand irgendwo mal eine info gesehen, welchen temperaturbereich die abkönnen...?
Die gehen wohl alle so bis +125°C, wenn du mehr brauchst gibts dann Platin oder Thermoelement-Sensoren.
Nabend,
DIe AC Produkte,HFN, LS Quadro usw werden ja auf dem MB Usb Anschluss angeschlossen.
Wenn ich 2 dieser Geräte an einem Anschluss anstecke, funktioniert das unten (4Pin)
Eingesteckte Geräte nicht.
Im Bios ist alles aktiviert.
Laut Anleitung soll 5 wie auch 4 Pin möglich sein.
Übersehe ich hier was bzw gehört das so?
meinst du den internen usb-header? ich bin der meinung, dass die unteren vier pins anders belegt sind, als die oberen vier.
Ja,genau
Müsste ich dann noch mal im Handbuch nachsehen,hatte nur in der Anleitung oben geschaut.
Edit:
Ist gleich
du hast recht, sollten eigentlich beide gehen.
Der fünfte Pin ist ein gemeinsamer Massepin, auf dem das Schirmungsgeflecht des Kabels liegt... Ich habe ganz, ganz dunkel im Hinterkopf dass manche AC Geräte den benötigen.
Im Zweifelsfall könnte man den Pin auf den zweiten Stecker brücken...
Ok,dann also doch noch ein Doppeladapter von Amazon oder gleich n Hubby.
Wie ich das hasse, wenn gerade was geliefert wurde und man braucht dann noch was:grrr:
wenn das wirklich so genutz würde, dann müsste bei allen Geräten, die an einen internen USB2.0 Pfostenstecker angeschlossen werden und nur einen 1x5pin Stecker verwenden, den Hinweis irgendwo stehen haben, dass man immer die oberen Pfosten mit 5pins statt der unteren Pfosten mit 4pins nehmen muss. So ein Hinweis ist mir aber noch nie unter gekommen. Ich habe schon oft 2 Geräte mit 1x5pin Stecker zusammen auf einen USB2.0 Anschluss am Mainboard gesteckt, sprich ein Gerät bekommt nur 4pins.
Mittlerweile nutze ich auch Dupont 2x5 Pfosten um 2 Kabel gleichzeitig einstecken zu können. Habe ich u.a. mit OCTO, Farbwerk und Leakshield bei Aquacomputer Geräten gemacht. Darum glaube ich nicht, dass in der Praxis ein USB2.0 Gerät wirklich den 5. Pin nutzt. Oder ich hatte bislang einfach nur Glück :ROFLMAO:
Das ist einfach Masse. Hab ich noch nie gebraucht bzw. ein Thema mit gehabt.
Manchmal hilft denken mehr als jammern.
3 Hübe Kontaktspray inc.ausbürsten und es funktioniert oben wie unten.
Kühler ist nun gereinigt und mit neuen O-Ringen - jedoch sitzt das kleine Plättchen nicht fest drinnen, sondern kann etwas hin und herrutschen. Das sollte nicht sein nehme ich an? Die O-Ringe habe ich direkt vom Hersteller bekommen...
Edit: Hab jetz die alte Dichtung reingesetzt, gleiches Ergebnis. Die alte Dichtung ist quadratisch, die neue ringförmig. Muss/soll es an der Stelle zu 100% abdichten oder soll da etwas vorbeirinnen können?
Das kann dir an besten der Hersteller beantworten. Aber nach meiner Erfahrung muss das kleine Plättchen - die Jetplate - nicht festsitzen und da darf auch Wasser nebenher gehen. Glaub bei meinen Kühlern ist der O-Ring auch nie zur vollständigen Abdichtung geplant.
Guter Schritt.
Zuletzt hat man viel über nicht ausgelieferte Bestellungen gelesen.
Für den Markt wäre es wünschenswert wenn EK unter neuer Führung bleibt.
Erstmal schlau machen wer LM TEK ist...
Scheint eine neue slowenische Bude zu sein... Die suchen einen Finanzdirektor und einen Supply Chain Manager. Kenntnisse in serbokroatisch wünschenswert laut Stellenausschreibung.
Ich weiß ja nicht... Klingt für mich nicht unbedingt vertrauenserweckend.
Momentan ist nichts mehr bestellbar. Ich hoffe sehr, dass sie wieder auf die Beine kommen. Es ließt sich so, dass sie alles übernehmen aber heute nur der Webshop an der Reihe ist.. sehr undurchsichtig.
Hat die Jemand oder kann mir jemand sagen ob die nen Heatkiller V 4090FE Block+ Magicool 240 slim schaft bzw. der Durchfluss reicht?
Grund würde GPU gerne auf 2 Slots reduzieren hab aber nicht viel Platz Eistation DDC ist glaub schon zu groß.
MfG
