[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
So, ich hatte ja vorhin schon geschrieben da ich wissen wollte, warum bei Afterburner bei mir nur 93,8 % power Limit angezeigt wird habe mehrmals eine Neuinstallation des Grafikkartentreibersdurchgeführt das hat nichts gebracht dann habe ich mir gedacht benutze ich mal den Bio Switch Der Stand auf Gaming also hab ich da 93,8 % power Limit kann ich mit ein Reset auf 100 % machen aber er geht immer wieder auf 93,8 %, wenn man das Programm schließt oder einen Neustart macht das ist der Gaming Modus der geht bis 108 power Limit dann hab ich mal den silent Modus ausprobiert und da gehen die 100 % und da habe ich ein power Limit von 115 % so und die Grafikkarte neu verschweißt haben, die hier die BIOS Version vertauscht laut gpu z ist silent BIOS mit der 45 am Ende und die 46 Gaming an die sie eine Suprim X Nutzern, gib mir da mal Info
Lg
Lg
Das ist ein ganz schön langer Satz 😂
Habe jetzt mal Frame Generation mit Plague Requiem genutzt. Überzeugt mich leider nicht.
Hatte im NVCP auf 59 FPS den Limitter eingestellt um auf 118 FPS zu kommen. (Wegen interpolierter Bilder)
Beim 4K 120HZ wirkt das Bild dann sehr hakelig als wenn Gsync nicht greift??
Habe jetzt wieder auf DLSS Quality Mode umgestellt mit 100FPS Limit im NVCP. Fühl sich alles flüssiger an und sieht auch weicher aus. Ich denke FG macht nur Sinn wenn man schon ca. 100FPS als Grundlage nativ hat und auf 200 will. Wie es schon Hardware Unboxed sagte.
Die Chipgüte variiert ja Extreme bei der 4090.
Ich hatte jetzt bereits 3 Strix eine TUF und 2 Suprim X und ne weitere Strix ist unterwegs gerade bei der Strix hab ich jetzt 2 Modelle die keine 3GHz gepackt haben und eine die Default 2985 MHz in ihrer Default Curve bei 1,1Volt drin hat und geht auf über 3.1GHz die andere geht nur bis 2970MHz und Default bei 1,1Volt gerade mal 2805Mhz. Die TUF liegt iwo dazwischen und die Suprime lagen beide bei ~2900 in der Curve.
Da reden wir von über 180MHz von einer Strix zur anderen …
Wie sehen denn eure Default Curves im Afterburner aus bei 1,1Volt?
Interessant. Meine FE schafft wenn dan grad so die 3000. Drüber wirds dann instabil im Time Spy Extreme. Habt ihr eure Customs echt mit 3,1+ GHz stabil zum Laufen bekommen? Bios Mods oder um Voltage zu erhöhen oder hab ich einfach Pech gehabt (bin trotzdem zufrieden^^)
Lg
Schöner Text :)
Ist aber richtig so.
Die Suprim X hat im Gaming BIOS 480W Standard TDP
480 / 100 * 93,8 ~ 450W
Die kannste jetzt auf 108% erhöhen und kommst dann bei 520W raus.
Sieht sehr krass aus. Und läuft butterweich. Naughty Dog sind aber auch einfach DIE pros.
ja ich freu mich auch schon riesig, obwohl ich schon gefühlt 50x gespielt habe auf The Last of US auf PC
Hat jemand die TUF und kann mir mal dazu sein case sagen und wie gut das mit dem kabel geklappt hat? gerne mit fotos.
brauch anregungen
ich such mir nen wolf.
Case: Sharkoon TG6M im -->Angebot 59€. Da passt auch die Glasscheibe rein! :xmas:
Das Problem ist das die Karte leider nicht sauber arbeitet, irgendwie gibts wohl ne Art korrektur. Platz 1 hat aktuell auch weniger Takt als ich und trotzdem Platz 1 und 2
Ich kapiere leider immer noch nicht, wie man 700 Punkte mehr bekommen kann. :d
an die Pro´s hier :) ich befasse mich gerade mit dem thema default curve, und muss da mal was wissen . Anscheinend ist die Default Curve nicht im BIOS gespeichert oder ? Weil, wie kommen dann so unterschiedliche Default Curves zu stande der jeweiligen GPU Reihe zb. Suprim
meine default curve sagt bei 1,1v 2870MHZ, bei XY sind 2945MHz usw usw. Weil wenn die Default Curves doch im Bios hinterlegt wäre, mussten es ja 100 verschiedene Bios Version geben. Also könntre man mich hier mal erleuchten bitte.
Kann dir nur sagen das da nix besonderes bei war gute Karte, richtiger Takt… hab danach die beiden Asus getestet und war frustriert … war tatsächlich nicht extrem optimiert mit dem normalen 520watt Bios
Ähnliche Themen
Antworten
7K
Aufrufe
471K
