[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Wollte gerade bestellen. Aber fast 30 Euro für ein kabel? Die werden billiger :-) Noch tut es der Adapter.
man, ich wollte auch gerade bestellen, hab bei Computeruniverse bestellt, aber da geht bisher nix.
Mindfactory hat ab Mitternacht Versandkostenfrei....aber erst ab 100€. 81 Euro mehr ausgeben für was?
Was brauch ich denn noch nicht, ist aber schön? :unsure: :LOL:
Hat jemand die TUF und kann mir mal dazu sein case sagen und wie gut das mit dem kabel geklappt hat? gerne mit fotos.
brauch anregungen
ich such mir nen wolf.
bequiet Darkbase 900 Pro. Passt easy mit dem Kabel. Hat mit großzügiger Biegung des Adapters noch nen cm Platz.
Für ein Foto bin ich gerade zu faul hochzulaufen :).
klar ein fettes monster ist natürlich die einfache lösung :d
ich hätte gerne was schlichtes, kompaktes und lieferbar damit es spätestens samstag da ist :fresse:
sobald cablemod den 90grad adapter bringt, hab ich dann wieder ein "problem"
Heute Morgen um ~ 1:50 ... Saturn schickt allerdings aktuell den Bestand aus Filialen.
Bist auch ein Meister der Screenshots von Bestellbestätigungen, Sendungsverfolgungen, etc. die viel zu klein auf meinem Bildschirm erscheinen.
das brandneue meshify compact ist ohne frontlüfter auf gpu höhe, passend in der länge
aber die breite mit 169mm ist vermutlich zu knapp?
der anschluss ist ja etwas tiefer drin als die breite.
bleiben 1,9 - 3cm? das reicht nicht oder?
Für den Adapter sind das vmtl. zu wenig, der braucht ca. 5cm.
Aber 90° degree adapter sollte gehen oder mit Custom Kabel von ModDIY.
Mit dem Kabel locker
Die Karte auf dem Bild hätte ich gerne :drool:
Ich finde den 90° Adapter persönlich ziemlich hässlich, aber ne Verbesserung gegenüber der Kabelpeitsche. Sieht auch nicht so aus als ob der mit der TUF/Strix gehen würde, weil die nen abgesenkten Anschluss haben.
Nein konnte den Lüfter nur auf einen Festen Wert setzen und auch nur im OC Mod sonst hat die Steuerung verrückt gespielt !
Jedoch hab ich dann das Erlebnis gehabt als ich den Rechner aus hatte und wieder gestartet habe mit AB Profil 50% Lüfter und angefangen. habe zu spielen plötzlich 70 C dann 75C oha noch 0 RPM sofort Ab resetet und der Lüfter lief an das kann es halt nicht sein.
Da zu noch das leichte fiepen schon bei 375 W.
Zu guter Letzt ist die Material Anmutung für mich eine Frechheit für den Preis bei der Master!
Kann ich verstehen. Asus macht Gigabyte vor wie es geht. Selbst Nvidia hat bei der FE kein Plastik-Backstein rausgehauen und die Headpipes kufernfarben gelassen .
Bin Gigabyte Fan aber so langsam stört es mich dass man da keine Weiterentwicklung sieht ... (
der 90 grad adapter wird glaube für die asus karten nicht gehen weil der anschluss nicht bündig dem kühler ist sondern weiter innten liegt, richtig?
dann hat sich das schon erledigt.
hab ne ladung silentwings 4 hier. ins torrent passen die net :d
das asus case müsste ich mir schön saufen. das sieht falsch herum aus :d
wenn der kühler unter dem anschluss hervorsteht, wars das mit dem adapter. cableflopp
Im Suff können die seltsamsten Dinge passieren.
Einfach Flasche aufmachen und so lange trinken bis du ein neues Gehäuse bestellt hast :wink:
So mal ein Bild vom Test im Zweitrechner. Die Festplatten sehen etwas chaotisch aus da der mittlere Festplattenkäfig raus musste. Die Karte ist einfach zu lang.
Ich konnte keinerlei Fiepen vernehmen in sämtlichen Szenarios. Die Karte ist geeignet um am Freitag mit Waküblock in den Hauptrechner zu kommen.
Da es schon dunkel war und mit Blitz fotografiert wurde sieht man die LED Beleuchtung nicht richtig. Die Karte ist schlicht beleuchtet. Lediglich das Inno3d Symbol leuchtet weiß. Sonst nichts weiter.
Ganz interessante Ergebnisse. Jay fährt mit niedrigeren Temperaturen einen niedrigeren OC, bekommt aber trotzdem bessere Ergebnisse im Vergleich zu höheren Taktraten bei wärmerer Karte:
Außerdem bessere OC-Ergebnisse mit GPU-TweakIII im Vergleich zu Afterburner.
Was interessanter ist ist das die FE die Strixx zerlegt!
So, ich hatte ja vorhin schon geschrieben da ich wissen wollte, warum bei Afterburner bei mir nur 93,8 % power Limit angezeigt wird habe mehrmals eine Neuinstallation des Grafikkartentreibersdurchgeführt das hat nichts gebracht dann habe ich mir gedacht benutze ich mal den Bio Switch Der Stand auf Gaming also hab ich da 93,8 % power Limit kann ich mit ein Reset auf 100 % machen aber er geht immer wieder auf 93,8 %, wenn man das Programm schließt oder einen Neustart macht das ist der Gaming Modus der geht bis 108 power Limit dann hab ich mal den silent Modus ausprobiert und da gehen die 100 % und da habe ich ein power Limit von 115 % so und die Grafikkarte neu verschweißt haben, die hier die BIOS Version vertauscht laut gpu z ist silent BIOS mit der 45 am Ende und die 46 Gaming an die sie eine Suprim X Nutzern, gib mir da mal Info
Lg
Lg
Bitte nochmal auf Deutsch und mit Satzzeichen :hmm:
Ähnliche Themen
Antworten
6K
Aufrufe
392K
