To learn from each other, I would ask for the
driver screenshot in addition to the HWiNFO screenshot in a leaderboard , as well as
any MPT tabs where changes have been made. Also the
3DMark result . Where I'm still undecided: whether the online result of 3DMark should also be linked.
On the subject of proof: If you are familiar with HWiNFO a bit, you can influence the displays without "painting".
Honesty is then simply assumed.
Or can
GPU-Z help with power meter? So far I've never let that go. What is its impact on performance?
Exactly, that's the point too. ^^
The original ranking list is not closed.
