Chrisch
Legende
- Ort
- Münsterland
- Laptop
- Fujitsu Lifebook U727
- AMD Ryzen 7 9800X3D @ 5.50GHz
- ASRock B650E Taichi
- Custom Wakü - 280 & 360 Rad. intern / Heatkiller IV Pro / Laing D5 etc.
- 48GB Patriot Viper XTREME 5 @ DDR5-6400 C30
- Inno3D RTX 4090 iChill Frostbite
- LG 27GL850-B & Acer Predator XB241H
- Lexar NM790 2TB / KC3000 1TB & 2TB / Kingston A2000 500GB NVMe
- Hyte Y60
- Fractal ION+ 860W Platinum
- Keyboard
- Kingston HyperX Alloy Origins
- Mouse
- Logitech G502 X Lightspeed
- Windows 11
[blockquote]
Spezifikationen Spezifikationen
CPU
(Quelle: AwardFabrik.de)
DownloadsDownloads
Bios Downloads
[/blockquote]
CPU
- Intel® Socket 1366 Core™ i7 Processor Extreme Edition/Core™ i7 Processor
- Supports Intel® Dynamic Speed Technology
- Supports 4.8GT/s & 6.4GT/s QuickPath Interconnection
- Northbridge:
- Intel® X58 Express chipset - Southbridge:
- Intel® ICH10R
- 6 x DIMM, Max. 24 GB, DDR3 2200(O.C.)/2133(O.C.)/2000(O.C.)/1800(O.C.)/1600/1333/1066 Non-ECC,Un-buffered Memory
Triple channel memory architecture
- Supports Intel® Extreme Memory Profile (XMP)
- *Hyper DIMM support is subject to the physical characteristics of individual CPUs.
- 4 x PCIe 2.0 x16 , support x16; x16/x16; x16/x8/x8 and x8/x8/x8/x8 configurations
- 1 x PCIe x4
- 1 x PCI 2.2
- Support NVIDIA 3-Way SLI™ / ATI CrossFireX™ Technology
- * We recommend that you use full tower chassis for building a 3-Way SLI system.
- Intel ICH10R controller
- 6 xSATA 3 Gb/s ports
- Intel Matrix Storage Technology Support RAID 0,1,5,10 - JMicron® JMB363 PATA and SATA controller
- 1 xExternal SATA 3.0 Gb/s port (SATA On-the-Go)
- 1 xSATA 3.0 Gb/s port - Marvell® PCIe SATA 6Gb/s controller
- 2 xSATA 6.0 Gb/s ports
- 8-Channel High Definition Audio CODEC
- Blu-ray audio layer Content Protection
- Supports Jack-Detection, Multi-streaming, Front Panel Jack-Retasking
- Supports 1 Optical S/PDIF out port at back I/O
- Gigabit Intel® LAN
- 1 x IEEE 1394a connector
- 1 x S/PDIF Out connector
- 8 x ProbeIt Measurement Points
- 3 x Thermal sensor connectors
- 1 x 24-pin ATX Power connector
- 2 x 8-pin ATX 12V Power connectors
- 1 x En/Dis-able Clr CMOS header
- 1 x LN2 Mode Header
- 1 x START (Power On) button
- 1 x RESET button
- 2 x EZ Plug connectors (4-pin Molex Power connectors)
- 1 x OC Station header
- 1 x RC Bluetooth header
- 1 x Go Button
- 1 x BIOS Switch button
- 1 x ROG light connector
- 1 x CD Audio in
- 1 x Audio front panel
- 1 x System panel connector
- 1 x FAN1 Connector for optional fan-thermal module
- 1 x PS/2 Keyboard port (purple)
- 1 x Clr CMOS switch
- 1 x Optical S/PDIF out port
- 1 x External SATA port
- 1 x LAN (RJ45) port
- 1 x ROG Connect On/Off switch
- 1 x RC Bluetooth switch
- 2 x USB 3.0/2.0 ports (Blue)
- 7 x USB 2.0/1.1 ports (1 port also for ROG Connect)
- 8-channel Audio I/O
- CPU Level Up
- MemOK!
- Onboard Switches: Power / Reset / Clr CMOS (at rear)
- ASUS MyLogo3
- ASUS Fan Xpert
- ASUS EZ Flash 2
- ASUS CrashFree BIOS 3
- Q-Fan Plus
- ROG BIOS Wallpaper
- ASUS Q-Connector
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- 1 x ROG Connect cable
- 1 x ProbeIt cable set
- 1 x 3-Way SLI Bridge
- 1 x SLI Cable
- 1 x CrossFire Cable
- 1 x 2 in 1 ASUS Q-Connector Kit
- 3 x 2-in-1 SATA signal cables
- 1 x 2-in-1 SATA 6G cables
- 1 x 2-port USB2.0 + ESATA module
- 1 x I/O Shield
- 1 x Thermal Sensor Cable Pack
- 1 x Cable Ties Pack
- 1 x ROG theme label
- 1 x 12-in-1 ROG Cable Label
- 1 x Optional Fan-Thermal Module
- 1 x Bluetooth Module Accessory Card
- Bluetooth V2.0/V2.1+EDR
- RC Bluetooth On/Off Switch
DownloadsDownloads
Bios Downloads
- Bios 0402
- First release Bios - Bios 0531
- RAM-Performance verbessert
- Besseres OC-Verhalten unter Kälte - Bios 0602
- FIX SATA 6G device may experience S3 resume failure when using Intel i7 965 CPU - Bios 0704
- Added additional memory options (tRFC settings) to improve overclocking
- Enable support for "Subzero Booster" for improved LN2 overclocking capabilities
- Enabled additional CPU support for CPU Level Up functionality
- Improved 3D performance at stock settings
[/blockquote]
