[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Die Frage die ich mir auch stelle hat kris-fix wieder einen standart 16 Pin verbaut oder schon die neue Version 12v2x6 wie es nvidia auch tut
Hab ihn mal geschrieben mal sehen was er antwortet
Letztens hat jemand geschrieben , dass er die neuen verbaut. Da wurde auch repariert.
Also bei 600 W Powerlimit @ max. OC + 1,1V @ Speedway Belastungstest bei über 500 Watt Leistungsaufnahme schwankt
es laut Aida bei 11,798-11,813V. Um geringer die Leistungsaufnahme ist umso mehr Spannung liegt drauf.
Idle dann 12,2V. Bei meinem UV Setting 0,975V @ 2700/11000MHZ liege ich bei 12 V beim Gaming.
Das Kabel steckt korrekt drinne seit Dezember 2022 wo ich nochmal neues Board/CPU gekauft habe.
Auch mit 500W nie unter 12V.
Die V wird gerade oben CPU T angezeigt hab die Falsche Zeile zugewiesen in HWinfo
Mal schauen was Corsair sagt bzw. ob da überhaupt was kommt.
Mein Kabel hat definitiv mehr als genug Platz und ist auch gut durchlüftet bei mir. Also grundsätzlich sind die Vorraussetzungen bei mir für solche Hardware gut.
Passt ja gut zur aktuellen Diskussion:
Was ich mich frage: Keine dieser Karten ist älter als zwei Jahre. Warum sollte überhaupt jemand einen Drittanbieter für eine Reparatur dieser Karten wählen? Wo ist der Shitstorm wegen abgelehnten RMA seitens NVidia?
Sorry aber da ist was nicht ganz stimmig.
Was ist denn eigentlich hieraus geworden?
Naja ne RMA über den Händler dauert oft mehrere Monate (warum auch immer) und das unabhängig vom Ergebnis. Ich würde da auch lieber 200€ an Krisfix zahlen und habe nach ein paar Tagen meine Karte wieder. Ich würde da keine Minute überlegen glaube ich.
plus wahrscheinlich auch viele umgebaute, wassergekühlte karten, bei denen die erfolgsaussichten auf RMA gering bis nicht vorhanden sind. ich zB wäre dazu gezwungen, würde es anders nicht regeln lassen können.
Wie wird die Spannung denn gemessen und angezeigt? Ist das ueberhaut ein Wert auf den mal viel geben kann, abseits der extremen, wie hier beschrieben wurde, wie die Spannung deutlich abgefallen ist, bevor es zum Defekt kam. Ich persönlich habe diesen Werten bisher immer einen Pi mal Daumen Charakter zugeschrieben, als eine genaue Messung.
Mit meinem Corsair 1200W komme ich unter Last nicht unter 12,056V.
Bei keinen der Werte die man auslesen kann bin ich unter 12V getestet bei 430-470 W.
Orginal Corsair Kabel.
Mit meinem Corsair 1500W komme ich unter Last nicht unter 11,891V.
Bei keinen der Werte die man auslesen kann bin ich über 12V getestet bei ~420 W.
Original Corsair Kabel.
Ich muss sagen ingame bin ich immer zwischen 12,052-12,115
Bei 500watt+ habe ich jetzt aber auch immer so 11,980-12,010
Single Rail?
Oder Multi?
Ich nutze mein NT im Single Rail.
Wie gesagt 500W stehen die 12 V immer noch sieh Screen Ingame oben.
Ich habe ein HX1000i 2023 und habe ähnliche Werte.
Im Multi-Rail oder Single?
bei meinem HX1200i muss ich Manuell auf Single im ICUE umschalten !
Dann stehen mir auch 100A zur Verfügung auf der 12V.
vielleicht läuft es bei euch im Multirail?
Mein HX1200i ist glaub ich zwar noch ein Model aus 2018 2.4 oder so was aber ich denke das wird trotzdem gleich sein mit dem Umschalten.
Single Rail?
Oder Multi?
Auslieferungszustand -> Multi Rail
Seit ich das Netzteil besitze (~2015) habe ich noch nie das Corsair Link verwendet.
Seit ich das Netzteil besitze (~2015) habe ich noch nie das Corsair Link verwendet. ich hab Corsair Link seit Day One drauf und hab es vergessen das ich auf Single Rail fahre .
Vielleicht ist meine 12V Leitung deswegen Stabil bei über 12V da ich auf Single Rail umgeschaltet habe mit dem Icue.
Out of the Box läuft es ja auch im Multirail.
Nur deswegen hab ich ICUE auch installiert. :bigok:
Manche Netzteile hatten damals auch extra einen Schalter zum switchen von Multi auf Single.
Ich weis jetzt aber auch nicht wie das bei den anderen Herstellern ist.
Wo genau stellst du das um? Finde nichts zum umstellen bzw. dass dieses PSU-Modus Fenster erscheint :unsure:
Hast du das Netzteil Via USB verbunden mit dem Mainboard?
Bei mir ist das NT zusätzlich Via USB mit dem Motherboard verbunden!
Separates Kabel dafür lag dem NT bei.
Dann wie bei meinem Screen zu sehen Geräteeinstellungen .
Ja, das mit dem Link-Kabel anschliessen ist mir schon bewusst. Aber bei mir erscheint das "PSU-Modus (Single/Multi)" nicht.
Bei mir kommt das:
bei den neuen Modellen ist es ein USB-C
Bei mir kommt das:
Das AX1500i ist aber nur auf Wunsch ein Single-Rail-Netzteil, denn über die LINK-Software lässt sich für jeden der zehn 8-Pin-Ports eine individuelle OCP (ab 20 Ampere) aktivieren, die im Test auch zuverlässig beim eingestellten Wert ausgelöst wurde.
Das scheint bei dir noch mal anders zu sein!
Ja, den Test habe ich auch schon durchgekaut. Es wird immer nur erwähnt, dass es Single-/Multi-Rail fähig ist, aber was man dafür genau einstellen soll ist mir schleierhaft. Zumal die Link-Software in dem Test damals auch noch ganz anders aussah 🤔
Jap da war mir auch was mit einer älteren Version!
Musst noch mal Google Bemühen bei mir kann ich das OCP zum Beispiel nicht gezielt einstellen.
Ich habe bei meinem vorgestern neu verbauten HX 1500i gerade heute die Einstellung gesehen. Hast Du die ICue Software installiert? Wird das Netzteil darin angezeigt? Dann ist der unterste der drei Punkte links der für Single/Multi Rail Umschaltung.
Sein AX1500i ist aus 2015 vielleicht wird das nicht mehr richtig supportet mit der neuen Icue Software.
Ich muss ja auch nur Geräteeinstellungen klicken dann öffnet sich das Menü.
Wir beide haben ja das HXI
Ähnliche Themen
Antworten
7K
Aufrufe
445K
