[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
120€ ist eigentlich echt wenig wenn man gedanklich mal Material und Steuern abzieht, das ist locker ne halbe Stunde anspruchsvolle Arbeit wenn man es ordentlich macht (was er tut).
Ja, aber an seiner Stelle hat er keine Wahl...
Ausser, er findet jmd, der es für weniger macht
K.A. wie hoch die Wahrscheinlichkeit ist, genau diesen Stecker zu kommen. Ich könnte es selbst machen
Ich hab zb nach einem bestimmten 8-Pin-Molex gesucht und nichts Befriedigendes gefunden. Entweder waren die Versandkosten abnorm hoch oder ab zb 1.000 Stück Mindestabnahme :(
Mein normales Kabel betrifft es anscheinend nicht
War ja auch nicht ernst gemeint von mir, wollte nur dem Luxx zuvorkommen, da ich schon die Kommentare kommen sah. :o
Zur Info:
Kriswichs hat 119EUR vorgeschlagen und schlägt auch vor eine "verbesserte" Version (H++) der 12VHPWR Buchse draufzuballern.
PCB Solder überlegt noch (vermute ich mal).
Elitkon ist wie gesagt raus, repariert nichts mehr.
Pics und Nachweise an cablemod übermittelt.
Zu H++:
Wenn du einfach nur den Header austauschen lässt, hast du ja keinen Mehrwert gegenüber dem originalen Header. Selbst wenn die neue Headerversion etwas bessere Qualität hat, bleibt das eigentliche Problem(der 12VHpwR Kabelstecker) immer noch vorhanden. Dafür wurde ich keine 100€ ausgeben.
Frag ihn doch mal, ob er dir auch ein fest angelötetes Stromversorgungskabel auf deiner Grafikkarte anbringen kann, mit zu deinem NT passender Kabellänge und miniFit NTsteckern dran. Mit den kompakten MDPC-x AWG17 Kabeln, ist das mit etwas modifizieren problemlos auch in den kleine 1mm großen Lötlöchern des 12VHpwR Lötraster möglich. So wie ich es auch schon mal auf der Leiterplatte eines WinkelAdapter gemacht habe.
IMG_20240110_033921495.jpgIMG_20240117_215038054.jpgIMG_20240117_213949919.jpgIMG_20240118_033918388.jpgIMG_20240118_033558220.jpg
Vorteil des fest angelöteten Stromversorgungskabel:
-Kein WinkelAdapter mehr nötig, weil das Kabel im 90° Winkel von der Leiterplatte weck führt.
-nur noch Ein relativ kleiner Kontaktwiderstand(der am miniFit NTstecker) im Stromversorgungskabel vorhanden.
-Du kannst ganz auf die elenden microFit 12VHPWR Stecker verzichten.
Nachteil:
Das Stromversorgungskabel passt nicht an alle NTs. Wobei der Wechsel auf eine andere NT-Stecker-Polung oder NT-Steckergehäuse, auch nicht sehr lange dauert. Man braucht ja nur die Kontakte entriegeln, und in ein anderes passendes miniFit Steckergehäuse stecken.
Klingt eher nach einer dicken Wertabminderung wenn ich direkt an das Board nen Kabel löten lasse statt der Buchse, auch wenn es von einem Lötpro kommt? :unsure:
Gute Methode um den Wiederverkaufswert auf nahe Null zu reduzieren.
Und er muss dann ja auch Gewährleistung drauf geben. Find den Preis auch fair.
Ich verstehe immer noch nicht warum Leute so einen 90° Adapter etc verwenden und einen Defekt riskieren wollen wenn es doch Kabel gibt die solche Adapter überflüssig machen (habe selber solch ein kabel in benutzung ohne probleme)
16Pin nativ Kabel
2/3x8pin auf 1x 16Pin (beim 2/3x 8pin auf 1x 16Pin gibt man einfach bei der Bestellung sein NT an und sie fertigen es von Hand passend für das angegebene NT und die hatten noch NICHT 1 DEFEKT !!!!! mit ihren Kabeln etc)
Kann Jeder für sich entscheiden, wie man es machen will :) Würde ich in der "Not" (keine Buchse zur Hand) nicht anders machen :fresse:
Die 120€ finde ich in @Slipknot Fall gerade noch angemessen (vorausgesetzt mit Gewährleistung). Für mich, der seit Jahrzehnten lötet, wäre das schon arg viel
Aber woher bekomme ich die richtige (neue) Buchse, zum Non-Scalperpreis...?
Ich löte auch seit Jahrzehnten. Nur halt keine Grafikkarten. :fresse:
Meine "Buchse" steht seit ein paar Jahren auch fest und wird (hoffentlich) bis zu meinem Lebensende dieselbe bleiben. Bezahlen musste ich dafür auch nix, aber irgendwie kommt das auf die Dauer trotzdem teuer. :d
So möge auch deine Buchse niemals durchbrennen oder in Kontakt mit einem Kurzen kommen! ;)
Im Moment schaut das angelötete Stromversorgungskabel vielleicht noch nach einem übertrieben Elefanten aus. Aber in ein paar Monaten werden mit Sicherheit auch immer mehr 12VHPwR Header auf den ganzen 4090 soweit angelaufen sein, das selbst mit einem nativen NT-Kabel Problem auftreten können.
Den zertifizierten ReparaturAnbieter(Herstellergarantie bleibt erhalten) ist das natürlich egal. Zumal so ein Austausch des Headers, mit entsprechendem "Werkzeug" schnell verdientes Geld ist(da keine Fehlersuche nötig).
Meiner Meinung nach ist so ein Headeraustausch aber keine dauerhafte Lösung, sondern nur die Wiederherstellung des originalen Kompromiss. Der da lautet; kompakter StromversorgungsStecker, mit zu wenig Reserven.
Jeder Stecker ist immer ein Kompromiss. Daher sollten wenigstens genug Reserven im Steckersystem vorhanden sein, das auch auf Dauer keine Probleme entstehen können. Wer dann auch noch auf die glorreiche Idee kommt, nicht nur einen sondern zwei oder sogar drei knapp an ihrer Leistungsgrenze betrieben Stecker in Reihe zu verwenden, braucht sich nicht wundern, wenn sich auch die Ausfallwahrscheinlichkeit im gleichen Verhältnis erhöht.
Meiner Meinung nach ist daher die einzige dauerhafte Lösung, den 12VHPwR Header von der 4090 zu entfernen, und ein Stromversorgungskabel direkt ein zu löten. Zusammen mit drei oder vier 8pin NTsteckern(miniFit Kontakte), halbiert sich die mögliche Ausfallrate mindestens, gegenüber dem nativen Anschlusskabel. Und man bekommt nebenbei auch noch ne steifere elektrische Anbindung zwischen Grafikkarte und NT, mit all den positiven Auswirkungen beim Übertakten oder Undervolting...
Troloololooollllooo jetzt bin ich auch dran. (y)
Habe mich schon gewundert, wieso gestern die 95°C am Gehäuse des Steckers noch keine Probleme machen. Heute roch es komisch, dann mal nachgeschaut. Ging auch nicht sofort runter, musste mit einer Zange das Teil aushebeln (y)
Kann mir das aber nicht erkären im Endeffekt, da ich am PC seit Monaten nichts mehr gebastelt habe. Passiert ist es nun bei Guardians of the Galaxy bei ca. 400-500W ingame, meist 460-480W.
So, wer repariert noch das Teil außer Kriswichs? :o
Alter Falter ich hoffe, es entwickelt sich zu deinen Gunsten.
Ansonsten, was hast du gegen KrisFix? So ein Schaden sollte doch in den 200 Euro pauschal enthalten sein.
Kannst es natürlich auch bei Nvidia versuchen, die waren eigentlich mal sehr kulant.
Hatte damals 2x eine 2080 RTX bei denen umtauschen lassen, weil die bei Devision2 kaputt ging.
@Thread
Von meiner Seite gibt es nun zu berichten das SeaSonic keine Zicken machte und mir ein komplett neues NT + ein Seasonic 12VHWPR geschickt haben.
Kundenservice wie man ihn sich vorstellt. Das NT war schon fast 4 Jahre alt. Ganz großes Lob. :bigok:
Dann zu Mindfactory, diese haben jetzt wieder die Karte bekommen und nun heißt es warten, ich hoffe sie schicken diese zu MSI und die Karte wird dann dort repariert.
Auf jeden Fall zieht sich das hin, erster Reparaturversuch + Rücksendung und wieder Rücksendung, 1 Monat ist vergangen. Wenn ich jetzt nicht noch ne 4090 hätte, wäre es ziemlich unenetspannt.
Zur PNY 4090, ich habe etwas UV betrieben. Die Karte scheint sehr stabil bei 0,95 mV mit 2760 Mhz zu laufen, konnte aber gestern auch mit 0,85 mV 3 Stunden Avatar spielen, aber mein Test mit 40 Loops Port Royal auf 4K und max, schaffte diese Einstellung dann nicht, stieg bei Loop 27 aus. Was sich auch sehr gut für die Stabilität eignet ist Portal RTX, einfach mal in den Startbildschirm switchen und ne halbe Stunde so laufen lassen. Wenn es abstürzt dann wars das. die 0,95 mv haben aber alle meine Tests mit Bravour bestanden, also ca. eine Ersparnis zwischen 50 und 90 Watt. Bei 0,85 mV wären dann auch bis zu 100 Watt Ersparnis drin gewesen. Der Crossbartakt liegt normalerweise bei 2310 Mhz, mit UV bei 0,95mV sind es dann 2225 Mhz. Bei exakt gleichem Takt verliere ich dadurch im schlimmsten Fall 1 FPS. So weit, so gut.
Nichts gegen Kriswichs einzuwenden, meine Psyche braucht Verballhornung um die Realität zu verarbeiten. :o
Nvidia/RMA dauert mir zu lange, auch wenn ich etwas Geduld habe. 2-3 Wochen ok, aber nicht 2-3 Monate.
Zwischenstand ist:
CM schweigt noch nachdem ich alle Nachweise geschickt habe. Nachgefragt habe ich noch nicht.
PCB Solder "kann die Anfrage nicht übernehmen".
4090 liegt hier noch rum, ich warte noch auf CM. Die Reparatur hat bei mir aber auch keine Eile, die GTX 980 Ti m8 auch noch ihren Job in älteren Spielen die ich noch nicht durch habe, aktuell C&C Rezastered. Sogar die Prince of Persia The Lost Crown Demo funzt damit auf 97 fps (habe hier den fps limiter), wenn auch mit ca 216W. (y) Nachteile: Kein HDR am DP und kein Gsync, max 100Hz. (y)
Was spricht denn dagegen einfach den ganz normalen Namen zu verwenden? Ich meine, der Mann löst DEIN Problem.
Letztendlich mal eine der seltenen Dienstleistungen die einen Sinn ergeben.
Man muss immer bedenken, dass das Internet ein Dorf ist und man verschiedene Dinge zusammenbringen kann. Wenn ich der Techniker wäre und das lesen würde, könnt ich das sicherlich einer Anfrage zuordnen. Selbst wenns nur lustig und nicht ernst gemeint ist. Das getippte Wort ist immer schwieriger als das gesprochene (kein Unterton, keine Mimik etc.).
Aus dem Grund, dass man heruminterpretieren kann und meist sowieso daneben liegen wird, ist es besser, gar nicht zu interpretieren. (y)
An wichs finde ich jetzt nichts schlimmes dran, bin ja selbst ein profapper. :o (y)
Damals hat die RMA bei Nvidia nicht mal ne Woche gedauert, ich bekam ne neue Karte und hab dann die alte bei erhalt zurückgesendet.
Übrigens, vorhin klingelte DHL, Mindfactory hat mir ohne Kommunikation jetzt einfach ne neue SuprimX als Tauschkarte zugesendet. o_O
Mach jetzt das Angebot fertig und stell die Karte aufs schwarze Brett.
Mit dem aktuellen Super Refresh sind wohl auch die letzten Lovelace Karten auf dem Tisch. Habt ihr euch schon mal überlegt, oder vielleicht auch schon Erfahrung wann ein guter Zeitpunkt ist die 4090 wieder zu verkaufen? Erst zum Release der Nachfolger Karte, oder macht es Sinn sein Exemplar schon vorher zu vermarkten?
Theoretisch würde es schon Sinn machen, die Karte vor der neuen Generation zu verkaufen, aber dann bist paar Monate ohne Karte oder wie?
Und dann muss man zu Release auch eine bekommen... das war ja auch nicht immer so "einfach".
Wir sind hier im Luxx… es wird eine 5090 bestellt und wenn diese sich im Computer befindet, wird die 4090 verkauft.
:ROFLMAO:
Erwischt. Ich habs nämlich genau so mit meiner Hardware immer gehalten. Ich halt mir immer offen Grafik über die CPU ausgeben zu können. Aber ich kriegs nie übers Herz auch nur einen Tag ohne komplette Kiste zu sein. Selbst im Fall von Hardwaredefekten wird sofort alles bestellt was kaputt ist.
Da muss ich echt dran arbeiten.
Oder man holt zur Überbrückung die Reserve-4090 aus dem Schrank und baut die ein. :fresse2:
Falls ich meine 4090 nicht verkauft bekomme, dann geht die in meinem zweit PC in der alten Heimat, der wird halt gefühlt nur 2-3 Tage im Quartal benutzt aber naja :fresse2:
Ähnliche Themen
Antworten
7K
Aufrufe
541K
