[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Asus XOC Bios
@Dwayne_Johnson wenn ich da sehe, wie schnell der physische speicher vollgestopft wird und oft dauerhaft am füllmengen-anschlag arbeitet, liegst mit deiner vermutung dass es das 8000er setting sein könnte wahrscheinlich richtig. selbst der virtuelle speicher wird ja noch zustzl. komplett vollgerammelt, das wird schon daran liegen :d
hier ein gpu seitig gebremstes setting / 2750 @ 1V, aber VRAM +1500:
Troloololooollllooo jetzt bin ich auch dran. (y)
Habe mich schon gewundert, wieso gestern die 95°C am Gehäuse des Steckers noch keine Probleme machen. Heute roch es komisch, dann mal nachgeschaut. Ging auch nicht sofort runter, musste mit einer Zange das Teil aushebeln (y)
Kann mir das aber nicht erkären im Endeffekt, da ich am PC seit Monaten nichts mehr gebastelt habe. Passiert ist es nun bei Guardians of the Galaxy bei ca. 400-500W ingame, meist 460-480W.
So, wer repariert noch das Teil außer Kriswichs? :o
Finde ich irgendwie trotzdem cool, fast wien Ferrari wo der Motor abfackelt. (y) Wobei, beim Ferrari würde ich mich vermutlich tatsächlich ärgern. :o
Was für ein Adapter/Kabel ist das?
Ya ist der Cablemod Stecker.(y)
Mal schauen ob CableMod auf Ejakulanz :o m8 und Reparaturkosten ersetzt, meine irgendwo in einem Forum darüber was gelesen zu haben.
Erst wartet ihr alle Ewigkeiten, bis eure Cablemod-Adapter etc. angekommen sind und dann sowas. Vom Preis möchte ich gar nicht erst reden. Würde mir schlicht verar... vorkommen.
Motor?
War nur der „Zündkerzenstecker vom Ferrari“
Würde mich da auch ärgern, weil vergoldet. :o
Wer außer Kriswichs repariert sowas? Ich meine, da müsste es noch nen Service geben, mir fallt der Name von dem Laden gerade nicht ein.
Habe den Tausch noch aufgespart (wollte ja nichts am eigentlich funktionierenden System anfassen), da ein Test kurz nach Einbau vor fast 1 Jahr mit 600W keine Probleme ergab, Temps lagen afaik bei 55°C. (y)
Gestern mal nen Grapschtest gem8 und sofort Finger "verbrannt", dann 95°C gemessen. (y)
Warum das jetzt so raufgeballert ist, dunno. Zwischendurch gabs nen Umbau, der ist aber auch schon Monate her, musste heute sogar das Gehäuse entstauben, vorallem was unter dem Gehäuse lag. ^^
So mal Elitkon angeschrieben wegen Angebot. (y)
Cyberpunk hat auch nochmal das System frieren lassen.
Jetzt ist aber mal gut mit den Bugs....
Dabei hab ich schon Raytracing wegen den Nachladen Rucklern abgeschaltet.
Mal morgen die 3D Mark Teile durchlaufen lassen und vielleicht müsste dann auch mal ein neuer CPU Kühler her.
Wobei die CPU nie zu warm wird. Maximal 95°C.
Der defekten 12VHPWR Header muß ja eh aus der Grafikkarte ausgelötet werden. Da würde ich mir gleich ein Stromversorgungskabel fest an der Grafikkarte einlöten lassen.
Glaubst du immer noch das sind Bugs? Da stimmt was mit deinem System nicht wenn jetzt schon 2 Games das System einfrieren lassen. Cyberpunk hat bei mir in 150+ Stunden noch nie so ein Problem gehabt.
Das weiß ich nicht mehr, aber ob 40 oder 55°C, es ist beides für Kunststoff völlig unproblematisch. Ich spiele mich aktuell mit dem Gedanken nach der Reparatur nen Tempsensor an den Adapter (v1.1) zu kleben und nen Alarm auf 65°C zu setzen. Auch 65°C sind noch lange kein Thema für Kunststoff. Nahe an den Kontakten hat es sicher noch ein paar Grad moar, ist aber auch noch kein Problem.
Ich hatte ja eben 95°C gemessen, vermute mal an den Kontakten wird es an die 100°C gehabt haben. Das ist der Bereich wo Kunststoff schmilzt (eigentlich bei ca. 85-90°C) . Weiß jetzt ned welches Material da verwendet wird, PVC? PP? PE? Was anderes? Jedenfalls kam es zu einer "leichten" Schmelze, das heißt, ich konnte Stecker und Buchse noch von einander trennen, wenn auch mit Hebel über Zange, Teile vom Stecker sind aber nun in der Buchse und damit ist die Buchse blockiert.
Habe auch noch gestern eine Anfrage an Kriswichs geschickt, aber bisher noch keine Meldung erhalten wegen Angebot. Cablemod hingegen möchte moar pics von Stecker und Buchse und PSU, S/N und Rechnung der Graka. Mal schauen was dabei rauskommt. oO
Elitkon repariert nichts mehr.
Weiß ned wo das Problem ist, erst gestern 75°C an der Oberfläche des Adapters (v1.0, 1.1 liegt hier auch noch rum) gemessen bei 450-480W. Bleibt somit drin. (y)
Sorry, ich muss das mal aus der Versenkung holen. Das war dein Kommentar als die Meldung kam, dass Cablemod alle auffordert sämtliche Versionen des Winkeladapters sofort auszubauen... Manchmal darf man auch darauf hören, wenn ein Hersteller zur Weltmeisterschaft im Zurückrudern antritt.
Ich hoffe natürlich, dass dir der Schaden beglichen wird.
Wo ist denn genau der Fehler beim 90° Adapter ?
Bei den meisten Kabel von den NT Hersteller klappt es ja wohl.
Liegt es an der Platine oder Lötqualität ?
Ok danke für die Mühe, mir war das zu mühsam danach zu suchen. Dann waren es 75°C bei 450-480W. Eigentlich auch noch tolerabel. Man sieht aber, dass da wohl eine Zunahme der Temp in der Zwischenzeit stattfand, das kam wohl schleichend über Wochen oder sogar Monate hinweg.
Ich habe aber irgendwann 2023 eine Messung bei 600W gemacht. Ich meine da 55°C gemessen zu haben, aber so sicher kann ich das auch nicht sagen. Weiß auch nicht, ob ich die Zahl hier rausgeballert habe. Die Suche hat auf die Schnelle nichts ergeben. Weiß nicht mehr genau, wann ich da gemessen habe, aber sicher weit vor Weihnachten mit dem Rückruf. Ob es kurz nach Einbau war oder kurz nachdem die ersten geschmolzenen Stecker aufgetaucht sind? Für mich war das jedenfalls kein Thema mehr nach der Messung.
Ist auch die Frage, wenn cablemod zum Rückruf auffordert, was dann mit der Garantie ist, die beim Kaufabschluss ja von beiden Seiten anerkannt wurde?
Der Fehler ist auf Seite der Buchse, die auf der Graka gelötet ist.
Dass nen NT-Kabel mit dem cablemod-Adapter verschmolzen wäre, kam noch nicht vor?
Nicht so häufig zumindest. Dann war es eher, wenn das Kabel nicht richtig gesteckt wurde soweit mir bekannt.
Sorry, wenn ich das so sage, aber ich könnte verstehen, wenn er sowas liest und dir kein Angebot macht. Man könnte ihn auch einfach beim richtigen Namen nennen. :rolleyes:
Ähnliche Themen
