[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Das FSP ist doch die billigste Marke unter den vier angebotenen. Verstehe deinen Kauf daher nicht so richtig. Würde das Corsair kaufen, das gefällt bei den vier klar am meisten.
Ich habe es noch nicht erhalten und werde berichten.
Sehe es nicht als Billigmarke. Ist auch das Topmodell.
BQ hatte ich vor paar Jahren. War ok, mein Corsair ist auch super. Jetzt mal was anderes.
BeQuiet würde ich auch nicht kaufen. Die Netzgeräte sind von der Verarbeitung und Leistung schon gut, aber das Multi-Rail-System und die proprietären Buchsen sind ein absoluter Fail. Da können Sie ihre Netzgeräte einfach behalten.
Erst wenn das Rail-System auf Single-Rail und die Buchsen im ATX-Standard sind wären diese ein guter Kauf.
Habe einige Seasonic-Netzgeräte und würde immer diese kaufen. Beste Erfahrungen mit vielen Betriebsstunden und auch viel Leistungsaufnahme über viele Betriebsstunden gemacht. Bei Corsair weiß ich nicht warum da keine neue 150-600W ATX 3.0 Buchse am Netzgerät ist, das ist es doch was ATX 3.0 ausmacht. Würde daher zu meinen verlinkten Seasonic ATX 3.0 greifen, auch wenn diese nur die Gold-Zertifizierung haben.
Das ist doch allgemein bekannt. Kann doch nicht immer Belege zu Allgemeinwissen bringen. Hoffe das ist nicht zu flachsig und kurzgehalten.
Naja, zur Zeit hat wohl CWT die beste Plattform. Aber das kann in einem halben Jahr schon wieder anders aussehen. Vielleicht ist dann Seasonic, FSP, etc. wieder. Also deine pauschale Aussage entspricht nicht ganz der Wahrheit.
Vorteil ATX 3.0 sind IMO die Spannungsspitzen bzw. die Reserven. Ob der 12VHPWR am NT mit 1 oder 2 Kabeln angeschlossen ist, ist wohl nicht kriegsentscheidend.
Naja die albernen Adapter ziehen dir ganze vier alte 150W PCIe-8 Buchsen weg. Also da gefällt die einzelne neue Buchse weitaus mehr und hätte sein müssen.
Hast du denn mal Links zu deiner wohl besten aktuell besten Plattform CWT und ihre ATX 3.0 Netzgeräte? Würde mir gerne einiges dazu anschauen wollen.
Die Herstellerkabel von Corsair belegen 2 PCIe Anschlüsse am NT. Von anderen weiß ich es nicht.
kann man die BQs zumindest die größeren nicht selber bei Bedarf von Multi auf Singlerail umstellen ? zumindest meine ich das mein DPP 11 dies Möglichkeit bietet...
Nein das wird nicht gehen. Die Rails sind doch physische Leiter also richtig am PCB in einzelne Leiter verteilt. Leider wie gesagt ein vollkommener Fail von BQ jahrelang. KA wie die überhaupt ihre Netzgeräte verkaufen und wer die kauft.
Das ist bei allen anderen auch so.
Das wäre aber ausserhalb der PCIe-Spezifikation und da werden die enormen Leistungsreserven beansprucht, was auch nicht sein darf. Also 4 * PCIe-8 muss gesteckt sein, nicht 2 * um damit mit den Leistungsreserven durchzukommen.
Du verbreitest hier falsche Informationen. So ein Dark Power kann man mittels OC-Key auf Single-Rail-Modus umstellen. Dann hast du eine 12V Leitung ohne wenn und aber.
jetzt hab ich extra nachgesehen und siehe Zitat aus dem Handbuch zu meinem NT:
Insbesondere geeignet für Overclocking durch vier unabhängige 12V-Leitungen. Der Overclocking-
Key ermöglicht den manuellen Wechsel zwischen vier unabhängigen 12V-Leitungen und einer massiven
12V-Leitung. Hochwertige 105°C Kondensatoren sichern Leistungsfähigkeit und Zuverlässigkeit. LLC- + DC/
DC-Technologie für einen sehr effizienten und stabilen Betrieb.
Overclocking Key:
Der Overclocking Key fasst die einzelnen 12V-Schienen zu einer 12V-Schiene zusammen.
Sie können die Overclocking Funktion mittels des mitgelieferten Jumpers direkt am Netzteil permanent
aktivieren oder Sie aktivieren die Overclocking Funktion mittels des Schalters an dem mitgelieferten Slotblech
nach Bedarf�
Der Overclocking Key wird mit der gekennzeichneten Buchse am Netzteil verbunden.
Wenn Sie die Overclocking Funktion am Slotblech aktivieren, leuchtet am Slotblech-Schalter eine LED.
vielleicht nicht ganz so in die Vollen hauen, wenn man es nicht wirklich weiß :-)
Doch das geht bei BQ mit dem OC Key auf Singlerail.
Na gut dann mache ich mich mal schlau wegen diesem OC Key und der Singlerailschaltung. Das mit den verschiedenen Leitern hatte ich von früher, das war da ganz gewiss so.
Man kann ja nicht alles aktuell wissen. Ist doch gut wenn dann freundlich darauf hingewiesen wird, das dem nicht so ist.
Für ein ganz großes System mit zwei RTX 4090 würde ich noch ein Seasonic Prime TX-1600 ATX 3.0 kaufen:
Das gefällt auch. Mit den zwei ATX 3.0 Buchsen hat man zwei 4090er bereits angeschlossen. Mit den anderen 9 Buchsen könnte man 2 * 4 PCIe8 anschließen, also zwei weitere RTX 4090. Für die Vollast von 600 W würden die 1600 W nicht reichen. Aber die meisten 4090er gehen ja bis max. 450 W und mit Powerlimit-Senkungen könnte man vier 4090er umsetzen.
Es gibt keinen exakten Link dafür. Ich habe mich vor kurzem sehr mit ATX 3.0 Netzteilen beschäftigt und Tests dazu gelesen.
Mir ist aufgefallen, dass nicht wenige Netzteile, die sehr gut abschneiden auf eine CWT Plattform setzen. Zudem habe ich mir die Netzteil TIER Liste angeschaut, die meinen Eindruck bestätigt haben.
Es gibt natürlich auch sehr gute und nicht mehr ganz aktuelle nicht ATX 3.0 Netzteile und wer da gerade auf den Thron sitzt, kann ich nicht beurteilen, weil ich mich mit denen nicht beschäftigt habe.
Doch wie gesagt, in einem halben Jahr sieht es vielleicht wieder anders aus.
Jensen wir kündigen auch :)
Ähnliche Themen
