[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
die kabelpeitsche ist sowas von gewöhnungsbedürftig.. aber hey.. damit funktionierts.. meine ist jetzt allerdings auch zum ersten mal in der buchse
und war noch originalverpackt (kam mal irgendwann als ersatz von asus mit drei monaten wartezeit und in der zeit hat das dings von cablemod ja zumindest oberhalb des schreibtisches funktioniert).
btw,
dass bei meinem kabel einiges kaputt ist, habe ich nur beiläufig bemerkt als ich an die nvme wollte. beim spielen gucke ich da sowas von nie hin.. und dann spiele ich auch noch sowas von selten..
tobi
Hab auch seit Beginn (vor ca. 10 Monaten) das Cablemod Kabel. Lief anfangs problemlos. In den letzten ~2 Monaten gab es zunehmend Probleme mit Blackscreen, Lüfter auf 100% und es half nur PC reset. Vor ~ 2 Wochen habe ich das Kabel 1x ausgesteckt und wieder neu eingesteckt. Seit dem keinen einzigen Crash mehr gehabt. Stecker ist vollkommen intakt, keine Auffälligkeiten, nichts verschmort. Wohl nur die Sense-Pins schuld.
Fragt man sich echt, was in dem shice Stecker vor sich geht...
@RediMischa Hört sich genau nach dem Problem an warum die das Kabel geändert haben. Würde ich mir auch nie neue Version anfordern an deiner Stelle.
Ja, mal schauen ob ich die anschreibe (soll wohl ewig dauern) oder ob ich gleich ein neues kaufe.
Ich finde die GXT 4090 ist enttäuschend viel zu schnell und keine Konkurrenz :ROFLMAO:
btw,
tobi
Die Schmelzberichte die ich mit Kabelpeitsche gesehen habe waren allesamt auf unvollständiges Einstecken zurückzuführen, daher hängt sie auch bei mir noch im System, obwohl ich schon seit Monaten das "richtige" Kabel für mein Corsair-NT habe. War einfach zu faul da groß umzustecken. Funktioniert aber echt zuverlässig und die Spannung für die GPU ist immer noch ziemlich genau 12V.
Ein 12VHPwR Stecker hat weniger mechanische und elektrische LeistungsReserven, als zB. die klassische 2x8pin Anbindung. Das liegt an dem kleineren Rasterformat der 12VHPwR. Daher sollte man sich wenigstens an die mechanischen Vorgaben des 12VHPwR Steckerherstellers halt. Das tun aber leider nicht alle Kabelhersteller, weil manche Anwender mehr wert auf die Optik als auf die Funktion legen. Frei nach dem Motto, was der Markt verlangt wird auch angeboten. Leider lagen oder liegen auch immer noch 4fach Kabelpeitschen bei den Grafikkarten als Originalzubehör bei, die die mechanischen Vorgaben des Steckerherstellers nicht beachten. Bisher hab ich auch noch keinen WinkelAdapter gesehen, die die Vorgaben des Steckerherstellers erfüllen. Selbst die scheinbar hochwertigen Wireview Winkeladapter sind betroffen. Nebei verringert ein zusätzliche Zwischenadapter, bei dem ohnehin auf Kannte genähten 12VHPWR Standard, die elektrischen LeistungenReserven noch weiter.
Das mit der fehlenden Konkurrenz ist vor allem für den Verbraucher schlecht.
Das mit dem Verbrauchen kriegt die Karte allein hin wenn man nicht aufpasst.
Ist aber interessant mit dem höher, weiter, schneller. Obwohl es keine schnellere Alternative gibt, ist das Kärtchen schon fast wieder langweilig geworden.
Und ich darfs nicht laut sagen, aber gebraucht hätte ich das Ding maximal für 1-2 Spiele. Es läuft bei mir einfach zuviel oldschool Zeug. Es gibt Tage da stellt die 4090 nur EGA dar (Commander Keen oder Bio Menace in der Dosbox). An guten Tagen darf es auch mal Doom oder Dark Forces rendern. Dafür aber wenigstens mit VRR Unterstützung :fresse:
Leider ja. Und wenn das stimmt mit dem Rückzug von AMD im High End Bereich wird die 5090 sicher 2500€ kosten bei 30% Mehrleistung.
Und wenn es ganz hart kommt, bringt Nvidia eine 4090ti als 5090 raus. /:
Die hier nach 14 Tagen dann vom halben Thread gekauft wurde …
Klar kauf ich den Scheiß höchstwahrscheinlich wieder :fresse: Außer es kommt mal wieder eine starke 80er Karte. Die 4080 hat sich zum Launch halt kaum gelohnt im Vergleich zur 4090
Was genau wird denn nicht eingehalten an Spezifikationen?
12VHPwR Buchsenkontakte sind nicht fürs fest einlöten auf einer Leiterplatte konzipiert. Ist und bleibt halt ein Kabelsteckerkontakt, der etwas beweglich sein muss, damit er richtg funktionsfähig bleibt. Darann ändert auch nichts, wenn man sich ne einlötbare Version herstellen lässt. Somit sind alle 12VHPWR LeiterplattenAdapter von Hause aus schon nicht mehr in der 12VHPWR Spezifikationen.
Der Cinebench 2024 scheint noch Optimierung zu brauchen.
Wenn ich im "Ausbalanciert" Modus teste (was ja eigentlich die einzig sinnvolle Option bei einem Raptor Lake System sein sollte) habe ich nur eine GPU-Kernlast von ~92%. Score dann ~33xxx
Wenn ich im "Höchstleistungs" Modus teste bekomme ich eine GPU Kernlast von ~98%. Score dann ~35xxx
Irgendwie scheinte die 4090 den Test nicht so anstrengend zu finden als dass man sich da strecken müsste.
Habt ihr auch schon gesehen, dass man über den Cablemod Configurator 90° Kabel zusammenstellen kann?
Echt teuer der shice. :d
Anscheinend werden die neuen Kabel erst Ende September asugeliefert.
Ich warte mal auf die normalen vorkonfigurierten Kabel, da diese immer günstiger sind.
...hach ich schmelze dahin! Oder der Stecker?
Die einundrölfzigste Steckerdiskussion in diesem Thread... :rolleyes2:
Ähnliche Themen
Antworten
7K
Aufrufe
441K
