[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
"Insgesamt zehn potenzielle Modelle der kommenden Geforce RTX 5000 ("Blackwell"), namentlich die Geforce RTX 5090 und 5090 Ti, Geforce RTX 5080 und 5080 Ti, Geforce RTX 5070 und 5070 Ti sowie die Geforce RTX 5060, 5060 Ti, 5050 und 5050 Ti, sind von einem taiwanischen Grafikkartenanbieter bei der Eurasischen Wirtschaftskommission "offiziell" angemeldet worden."
Quelle: https://www.pcgameshardware.de/Graf...ll-zehn-Modelle-in-der-EEC-Datenbank-1427463/
Demnach werden wir lediglich auf eine 5030 verzichten müssen. :d
Hast du den Artikel gelesen?
Die haben einfach alles angemeldet was es möglicherweise geben könnte... Da ist nichts sicher 😁
Sicher nicht, daher oben auch der Smile.
Jetzt muss nur noch Nvidia überredet werden dem zu zu stimmen.
Zwar keine NV, aber ich hab noch nie jmd gesehen, der sowas macht (Kontakt herstellen zu einem Layer aus der "Mitte") :oops: (y)
Gerade Starfield wird doch die gleiche Engine wie Fallout 76 verwenden, halt mal wieder aufgebohrt, damit kriegst du deine 4090 an keine Grenzen 🤣
Dafür sind dann eher das Cyberpunk DLC und Alan Wake 2 besser geeignet, oder etwas später AC Mirage oder CODMW 3.
Ja, ich versuche nur beim Starfield-Hype mitzugrooven.
@Thunderburne hat mich drauf gebracht:)
Obwohl ich eigentlich keine Zeit zum Zocken habe, habe ich mir die Starfield Constellation-Edition bestellt. Interessanterweise enthält diese Edition eine Uhr, die mich daran erinnert, dass ich eigentlich keine Zeit zum Zocken habe... :fire::fresse2:
Dann ist "Tannenzapfen"-Streich :fresse:
Äh??? Ok... :ROFLMAO:
Shot aus Starfield
Skyrim war super Fall Out war Super und auch Starfield wird Kult.
Ich wusste gar nicht, dass der Spiegelmeister Gaunter O'Dim nebenbei noch spanischer Verbandspräsident ist...
Seit ich die Karte unter Wasser habe und den Treiber mal nach einem halben Jahr aktualisiert, hab ich sporadisch 75MHz weniger Takt anliegen.
Hab die custom curve schon neu erstellt, aber gerade wieder.
Sollten eigentlich 2400 sein. Ist das was bekanntes?
Nunja Fallout 76 war/ist/bleibt absoluter Kernschrott und das ist noch gelinde ausgedrückt.
Es ist inzwischen Kult wie schlecht es ist.
Das warr ja auch ein Multiplayer soweit ich mich erinnere.
Das hab ich auch nicht angefasst .
Das bezieh ich nicht mit in die Singleplayer Spiele Bethesda mit ein.
Für mich existiert das nicht. :ROFLMAO:
Das war aber vorher auch schon lange so und ich hatte dieses Phänomen nie?!
Gibt ja schon wieder einen neuen Treiber. Ich probier's mal damit.
@TurricanM3 Hast du darauf geachtet dass alle Tools wie z.B. MSI Tool nicht nur beendet sind, sondern die Standardwerte vor der Treiberinstallation geladen sind?
Wenn nein, einfach mal ausprobieren.
Sorry, wenn schon mal gepostet...
Habe nun den Alu 180° EZDIY 600W Adapter drauf:
In Verbindung mit dem BQ Kabel. Sitzt sehr stramm vom Aufstecken her. Hat aber keine Haltenase, was ich aber wusste und mir egal ist. Nach oben abrutschen kann der nicht.
Ich höre meine Karte aus dem Gehäuse raus fiepen :)
Hat es jemand geschafft seine 4090 Spulen leiser zu bekommen?
- Durch Weglassen der Spulen Wärmeleitpads bei ner Wakü? (Igors Idee im 4090FE HK V Test)
- Bitumenmatten um den WaKühler wickeln? ;)
Auf Curve Undervolting und PT senken habe ich keine Lust (wozu dann so ne Karte kaufen)..
Schönes cleanes System, top. :)
Wenn du kein UV machen willst, was bei Asus Karten gefühlt eh nix bringt, hatte genug hier XD dann kannst du nur versuchen die Pads auf den Spulen wegzulassen aber kann mir kaum vorstellen das es bei den Drecks Spulen was bringt.
Ansonsten fällt mir auch nix ein, hab mir extra ein gedämmtes Gehäuse damals geholt wegen Pumpen und Spulen Lärm, das bringt auch nochmal was. ^^
Der erste Fehler war schon ne Asus Karte für Wakü. :fresse:
So sieht's leider aus. Wenn fiept dann immer. Solche Karten lieber innerhalb der Widerrufsfrist zurück und next please.
Ein M$ exklusives Spiel, welches auf der X nur mit 30 FPS läuft, kann nicht gut programmiert sein. Ich lass mich aber sehr gerne positiv überraschen. 😅
Ähnliche Themen
