[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Erster Power bedingter Shutoff 🙃
Asus Strix 4090 mit 5800X3D und Wakü/2SSDs an einem BeQuiet 850 Straight Power Platinum.
Cyberpunk 4K @ alles Max ohne DLSS
570 Watt laut Afterburner Overlay kurz vorm Ende.
Und jetzt kommt es: Asus 1000W XOC Bios :LOL:
Beim Galax 666W Bios ist es kein Thema gewesen…also das Ding peakt dann doch höher mit dem 1000W Bios.
Hatte kurz einen Herz-Stillstand als danach kein Video Signal mehr kam…lag aber zum Glück am Oled TV - an/aus und alles lief wieder.
Sonst ist das XOC Bios spitze. Läuft bei mir mit 3075-3090Mhz vs 3045MHz@Galax666w. Effective Clocks sind 3060-3077Mhz in Cyberpunk…also quasi null Clock Stretching.
Auch der Idle Black Screen / nvlddmkm Fehler tritt nicht auf in „Performance Mode normal“.
Liegt also an den kalten VRAM temps in Kombination mit den Down-Clocks vom VRAM, da beim XOC Bios immer die vollen MHz am VRAM Anliegen. Der Chip taktet brav runter auf 405Mhz.
Einzige Wermutstropfen:
KEIM Temperatur Limit —> Ausfall der Wakü und Tschüss 2000€ GPU!
Idle Stromverbrauch aufgrund der VRAM MHz 50-55 Watt anstelle 25-30Watt im Desktop. Aber immerhin keine 65Watt wie im „Performance Mode Maximum“. 4k@120Hz mit HDR und Gsync.
Passt auf jeden Fall auf mit den Temperaturen und dem fehlenden Limit, falls ihr es probieren wollt!!!
Hitman 3 hat jetzt Frame Generation bekommen . Persönlich muss ich aber sagen die Entwickler von Hitman haben sich so viel mühe gegeben bei dem Game , dass ich es nativ ohne DLSS spiele und kein RT und kein VRS einfach in der ursprünglichen Version in 4K HDR zocke .
Sieht einfach so schon klasse aus und gefällt mir irgendwie am besten .
Mir gefällt RT besser, gerade im Wolkenkratzer und in der Mansion. Gibt so viele reflektierende Oberflächen. Wieder ein Punkt für die 4090.
War ein richtig geiles Game mit dem Update vom 19. Januar.
Hatte es noch einmal im Sale für 48€ geholt gehabt, nachdem ich es auch retourniert hatte.
Schade, dass die den Launch vermasselt haben, war echt ein cooles Game. Aber ein 2. Teil wird wohl nicht mehr kommen, nachdem das Game wohl keinen Break-Even-Point mehr erreichen wird :fresse:
Auf RayTracing habe ich verzichtet, da das Game kein Frame Generation bietet. AMD ist leider Kooperationspartner.
Das Game hat so eine hohe Beleuchtungsqualität inkl. Schatten, dass man gar kein RayTracing braucht. Und RayTracing Reflection auf Medium sieht schlechter aus als die Space-Screen-Reflections.
Selbst mit einem 13900K kommt man mit RayTracing nicht weit... gibt immer wieder Stellen, wo es hier und da einbricht.
Gespielt habe ich am CX65 in 4K (alles Anschlag) ohne RT mit HDR.
Das HDR habe ich mit Reshade levels.fx getunt, ansonsten hat das Game einen durchgehenden Grauschleier.
Hoffentlich denkt Crytek an Frame Generation bei Crysis 4.
Nvidia Reflex sollte Pflicht und damit Standard sein.
Gleich gehts mit Dead Space weiter :bigok:
Was meinst du genau mit "Frame Generation"? DLSS3?
Hat jemand von euch das Hitman 3 Update mit Frame Generation getestet?
Was ganz merkwürdig ist, das wenn ich mit der RTX 4090 Frame Generation einschalte absolut nichts passiert an den FPS
In der ersten Map von Hitman 3 habe ich mit Dlss Quality 50 FPS.
Schalte ich nun Frame Generation an, bleibt es immer noch bei 50FPS und es fühlt sich auch genauso an.
Fps habe ich mit MSI Afterburner und Nvidia Overlay getestet. Da sind die FPS gleich.
Plague Tale mit Dlss 3 habe ich die doppelten FPS , da klappts.
Neuester Nvidia Treiber ist auch drauf, an was kann das liegen??
Hab zig Einstellungen versucht. Mit DLSS , dann ohne, dann nur Frame Generation. Es bleibt konstant die FPS egal was ich einstelle.
Sogar wenn ich im CPU Limit bin müsste aber doch Frame Generation ein unterschied machen? Die FPS sind 1:1 das selbe wie mit nur DLSS 2
Ich hab jetzt nur den Hitman Benchmark Dubai (alles Ultra oder High mit RT) zum Testen genommen… in 8K :o
8K
18.44 FPS ohne FrameGen
28,84 FPS mit Frame Gen
Auf 4K ist da aber was in der Tat faul.
Bist also nicht der Einzige :)
Ok ganz komisch.
Habe mal OHNE RT getestet.
Da habe ich auf 5120x1440 110-120 FPS
Mit Frame Generation das selbe Problem....keine Veränderung der FPS.....mega strange
Kann schon jemand von Deadspace berichten? Reviews schwärmen ja, aber ne unabhängige Erfahrung vorallem wie's um die Technik bestellt ist würde mich interessieren. Es soll ja auch teilweise wieder Shader Lade-Ruckler geben, merkt man die? Bei Calisto Protocol war das ja die völlige Katastrophe.
Ich kann leider noch nicht testen, muss warten bis meine Frau heimkommt wegen Kinderbetreuung :d
Also Dead Space ist ja mal Klasse.
Mit Cru erstmal die 4096×2160 Auflösung gekillt .
Dann 1.78×DL DSR Glättung 15%
Ingame dann 5120×2880 DLSS Qualität Körnung aus Rest max Out.
Bring ne Menge die Auflösung höher zu setzen.
Nachricht gelöscht
Und da sagt nochmal einer man braucht 1000-1200W für n Stock 4090 System. Lol, und du reißt die Bude mit nem 1000W Bios auf :fresse:
850 Platinum waren für die 3090 Strix @ 480W und die 4090 Strix @ 600W null problem…der 5800X3D braucht halt auch nicht viel. 135W+600W gibt immernoch 115W für den Rest an DAUERlast Reserve. 920W(?) spitze kann das BeQuiet und in Games und FurMark+Prime95 war das nie ein Problem.
8-) 😇
Aber das XOC hat halt „Special Souce“ dabei und peak anscheind härter.
ORIGNAL POST WURDE GELÖSCHT; hier trotzdem noch meine Antwort darauf:
? 1000W Bios an einem 850W Netzteil ohne schaden spricht doch eher dafür. Wie oben erläutert läufts Stock wunderbar bis 600W GPU Last. Mit nem 13900KS vielleicht nicht…aber da würd ich dann auch eher 1200W einbauen.
- leise
- hübsch
- günstig
- 12VHPWR
Meine Checklist ist erfüllt.
Ich lass n 13900KS+4090 mit nem 750er Netzteil laufen. Läuft. Auch mit OC. Hab aber schon n 1000W Netzteil hier, hab vor die 4090 zu flashen.
@nebu3 Ich hatte das 1000W Bios auch mal getestet, Performance war gut und mir gefiel auch die PT Skala. Also 35% = 350Watt, 65%=650W usw.
Leider wie auch bei dir Taktet der Vram nicht runter und sorgt daher für hohen Idle Verbrauch. Zu spielen sicher ein schönes Ding, aber im Alltag fahre ich mit dem Galax HOF Bios doch deutlich besser.
hat jemand link zu dem asus xoc bios ?
Gibt es eine Übersicht, welches BIOS auf welche Karte passt? Und welches BIOS lässt eine frei programmierbare Lüfterkurve zu (also mit Werten niedriger 30%)? 600W oder 1000W BIOS benötige ich persönlich nicht, lieber ein effizientes :-)
Technik Test ist gewünscht? Bitteschön:
Warum wollen denn alle eine FE und nicht die Custom Modelle?
Weil die FE die schönste Luftkarte von allen ist… ;)
Wenn ich nicht schon seit fast 18 Jahren Custom-Wakü hätte, wäre die FE längst meine :)
Bin gespannt, was es kosten wird…
Und schade, dass man es auf die Karte stecken muss
Hab seit mehreren Wochen das ElmorLabs PMD USB, dessen Daten man auch am Rechner per Software live auslesen kann
Die Anschlüsse sind noch oldschool PCIe 8-Pin und kann zeitgleich auch die Leistung der CPU lesen
Preis hat leider von $50 auf $60 aufgeschlagen. Dafür ist ein 12VHPWR-Kabel dabei. Aber immer noch ein fairer Preis - insofern es ohne Mängel ist :fresse:
Meins war quasi geschenkt (100% Rückerstattung). Aber ich kann es zum Glück selbst fixen :d
Btw:
Dazu noch den PMD PCIe, dann kann man die Leistung der kompletten Karte auslesen
Zum Auslesen am Rechner braucht man natürlich noch das EVC2SE (hat 3 Ports für div. Geräte) *duck*
Ja, dass 1.000W BIOS geht etwas besser, als das 666er. Ohne EVC ist dieses BIOS aber eher nutzlos. Aber wehe, man macht nur „zarte“ +0,05V mehr VGPU drauf :fire::fresse:
Ich bin bis +0,07V gegangen - also bis 1,17V. Da hatte ich schon etwas Angst um meine TUF, weil der Leistungsmesser an der Steckdose mit Time Spy 1.100W anzeigte :oops: (CPU 13900K @ 6GHz - RAM @ 8GHz/CL36)
Die GPU-Temp war mit unter 50 Grad aber voll im Rahmen. Irgendwie konnte ich trotz diesen +0,07V gerade mal 1-2 Taktstufen (15-30Mhz) rausholen. Das enttäuscht mich schon etwas :rolleyes2:
Entweder bediene ich die Soft falsch oder die Karte will Minusgrade sehen
VRAM kann ich nur +0,1V mehr geben. Also Max 1,5 gesamt
Btw:
Hatte seltsame Peaks in den Kurven, der EVC-Software mit mehr als 3V auf der GPU und mehrere, sporadische Verbindungsabbrüche. Aber auch nur bei einer bestimmten Lage des EVC. Nach der manuellen Abschirmung des Datenkabels war wieder alles ok
Ich hatte das mit dem 1000W Bios übersehen. Daher gelöscht. Das Bios ist gefährlich.
Gestern Abend ein Paar Stunden Dead Space gespielt keine Ruckler läuft sauber .
Nach ca 2 Stunden waren um die 17GB in den Vram geladen.
Endlich Mal ein Spiel was zu Release auch vernünftig läuft und mann seine 4090 auch genießen kann.
LoL du armer, das konntest Du bisher nicht? :d
Calisto zu Release Mist !
The Wichtcher lief auch nicht wirklich gut !
Irgendwie nur halbfertig.
Forspoken die Demo war langweilig usw.
Überhaupt viele Spiele lieblos dahin geklatscht in 2022.
Hatte zu Beginn von Deadspace 3x directx crash. Treiber nochmals drüber gebügelt und jetzt geht's. Kurze frametime spikes gibt's hin und wieder beim Betreten eines neuen Abschnitts und hatte auch nen kurzen Abschnitt irgendwie für mehrere Sekunden ruckeln aber scheint wohl ein DLSS quality Bug zu sein denn das kurzzeitige zurückstellen auf ausgeglichen hat dies behoben.
Läuft sonst sehr smooth.
Die Problemchen sind auch vom EA Community Manager bestätigt.
Callisto Protocol habe ich Gott sei dank nicht zu release gespielt sondern nach den Updates. Von der Performance her läuft Deadspace durch dlss nochmal deutlich runder. Auf jeden Fall sind sich die beiden games sehr ähnlich vom gameplay/ atmo.
Kann es sein, dass Dead Space ein ziemlicher UV Killer ist? Meine Settings liefen monatelang in verschiedenen Games ohne Probleme und im Dead Space Intro crasht es direkt.
Ich hab eher das Problem, dass ich nach ner Weile Ruckler bekomme, das obwohl die Graka und das PT zu teilweise nur 50% ausgelastet ist :rolleyes2:
Ist das bios ein offizielles von asus, welche Karte hat das von Hause den drauf?
Ich glaub nicht, dass das offiziell ist. Welcher Hersteller würde denn das Temp limit deaktivieren, wäre ja Selbstmord da ne Gewährleistung bieten zu müssen.
Also hat jmd. Das bios auf Basis eines asus bios gemodded oder wie läuft das?
Ähnliche Themen
Antworten
6K
Aufrufe
400K
