[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Schau mal auf Seite 859, da war die selbe Frage schonmal.
Danke, aber hat ja keiner bisher bestellt hier oder? Alle finden es hässlich, mit dem Adapter würde meine Gehäusewand wieder zu gehen. Wollte es bestellen aber bekomme immer einen Fehler und die Bestellung könnte nicht abgeschlossen werden. Deswegen hatte ich hier auch nochmal nachgefragt. Das vorgeschlagenen Fasgear gibt es nicht für mein Fractal Design Ion + .
Seit vier Wochen keine Reaktion von CableMod wegen meinem Kabel:rolleyes2:
Ne hier keiner (zumindest hat sich keiner gemeldet) aber in dem Reddit Thread den ich verlinkt habe hatten den Adapter welche und er hat wohl problemlos funktioniert. Einzige Kritik war, dass er halt nicht schön aussieht aber wenn dir das erstmal egal ist bis du ne bessere Lösung findest die dann auch verfügbar ist, sollte das ja für dich passen.
Rechner steht eh unter dem Tisch :shot:
Für mich wäre der Adapter auch ok gewesen, aber mich stört halt, dass man wieder mit den PCI-E Kabeln rumfummeln muss. Für mich war dann das Fasgear die beste Lösung, aber wenn das für dich nicht verfügbar ist hilft das ja alles nicht.
Das verstehe ich, würde es auch wie du gerne machen, aber mein Gehäuse ist etwas zu klein und die Seitenwand soll wieder zu. Viel Auswahl an Kabeln habe ich nicht wegen meinem Netzteil und der Wand und neues Gehäuse wollte ich noch nicht holen.
Da ich mir demnächst evtl. auch ne 4090 holen will würde ich gerne wissen welche Karten denn wenig bis kein Spulenfiepen haben. Oder kann man das so pauschal nicht sagen?
Es ist (ein bisschen) Lotto, aber in dem Thread siehst du die Tendenz aus dem Forum.
Dann würde ich einfach den Adapter holen, du kannst das ja irgendwann nochmal tauschen. Cabelmod hat ja auch so nen 90° Adapter angekündigt, aber da dürfte die Verfügbarkeit weit in Q2/2023 gehen.
Wichtige Hinweise: Damit das 16-Pin-12VHPWR- zu 3x 8-PCIe-Kabel korrekt funktioniert, müssen alle 8-Pin-Stecker mit dem Netzteil verbunden sein. Der Abstand zwischen dem Stecker der Grafikkarte und dem Seitenpaneel muss mindestens 4 bis 4,5 cm betragen. Zudem sollte das Kabel erst im Abstand von 35 mm zum Stecker an der GPU gebogen werden. Schließlich sollte sichergestellt werden, dass der 12+4-Pin-Stecker vollständig und sicher in die Buchse an der Grafikkarte gesteckt wird.
Der Absatz ist einfach so lächerlich, warum soll man erst ab 3,5 cm biegen bei crimped cables, es erschließt sich mir einfach nicht
Habe ich jetzt bestellt (y)
Kfa2 hat kein Spulenfiepen, ist für mich die geilste 4090 derzeit
die manli gallardo = zotac trinity ebenfalls nicht. bin ich schon sehr dankbar für^^
Was hier wieder Panik gemacht wird beim Kabel... Das Problem ist der neue 12V Stecker, die 8-Pin können 300W (die sowieso niemand dauerhaft fährt). Bei einem Singlerail-NT reichen 2 8Pin. Corsair, Seasonic, usw.
Immer dieses Hauptsache viel! Egal obs Sinn hat. NT Watt, VRMs, Phasen, 8 Pins,
Selbst mit gleichzeitig 600W Grafik, 142W CPU, 18W für 3 SSD, 10W Chipsatz, 6W RAM und 4 Watt CPU Kühler bin ich bei 780W - und das tritt nie auf.
Hat hier jemand eine FE auf Wasser umgebaut und mag den unteren/forderen/Slotblenden näheren Lüfter abgeben? :d
Wenn du das gewerblich verkaufen würdest und damit rechnen müsstest, dass du Gewährleistung übernehmen musst. Was würdest du da alles zur Beachtung reinschreiben, damit du möglichst wenige Fälle übernehmen müsstest?
Das ist natürlich Quark.
SH sollte es eigentlich besser wissen.
Bei einem direkten Netzteilkabel hast du immer 600w.
Ob man 2, 3 oder 4 8er Pins nimmt, ist in Abhängigkeit davon, wie viele Rails bei MultiRail ein Netzteil hat.
4 8er Pins bei 2 Rails macht am Ende kein Unterschied zu einem 2 8er Pin Kabel, wenn das NT nur 2 Rails haben sollte.
Danke dir. Lass mich versuchen eine Quelle zu finden. Jemand hatte eine ASUS TUF gehabt, aber dadurch das sein Netzteil nur 3 8xPin Anschlüsse hatte, konnte er bei der Karte nur 450W maximal ziehen lassen. Er war nicht in der Lage mehr Saft der Karte zu geben.
"Bei einem direkten Netzteilkabel hast du immer 600w." Das stimmt natürlich.
Ich will den Mini 4090 ES Wasserkühler von Alphacool verbauen und suche Meinungen, welche 4090 im Referenzdesign die ideale Wahl wäre?
Alle Karten von Inno3D, KFA2 und PNY sind wohl die Kandidaten: KFA2 sieht am besten aus, aber? Die Inno3D kostet direkt 250 Euro weniger.
Ein Delta von 26 Kelvin... Mit einem Mora 420 auch um diese Jahreszeit mit 13900K + 4090 im Gaming kommt man dann schon auf mind. 32-33°C Wassertemp bei 350-450 U/min Noctua A20.
Bist dann mit einer TUF in Sachen GPU Temp 8-10 Kelvin höher und ist garnicht mal so laut. Ob sich dann noch der Aufwand lohnt...
13900K beim zocken kommt auch auf 32-33°C Wasser bei etwa 1000-1150U/min bei den Lüftern mit 360er AIO. Also hat man max. den Lautstärkenvorteil bei der Wakü , aber spätestens dann hört man immer irgendwas fiepen oder rasseln zumindest meiner Erfahrung nach.
Hatte selber den HKV auf der 3090 . Von der Kühlleistung ist dieser eher durchschnittlich gewesen , aber dafür nicht so restriktiv im Durchfluss .
Für Watercool spricht für mich persönlich immer die gute Verarbeitung und das Design sagt mir von denen immer zu .
Hitman 3 hat jetzt Frame Generation bekommen . Persönlich muss ich aber sagen die Entwickler von Hitman haben sich so viel mühe gegeben bei dem Game , dass ich es nativ ohne DLSS spiele und kein RT und kein VRS einfach in der ursprünglichen Version in 4K HDR zocke .
Sieht einfach so schon klasse aus und gefällt mir irgendwie am besten .
Ähnliche Themen
Antworten
7K
Aufrufe
471K
