[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Also die Suprim X die ich hier habe, fiept wie erwartet ganz ordentlich, die Lüfter sind aber wirklich angenehm leise :d Stock boost war wie bei allen anderen Karten bisher auch, 2715 - 2730 MHz.
Aber bei dem Aufpreis von 240€ zur FE geht die wieder zurück da hätte sie schon weniger fiepen müssen damit sie bleiben darf, ansonsten aber eine ganz hübsche Karte und schön verarbeitet :d
Mal sehen ob die Gigabyte Gaming OC sich da wirklich besser anstellt...
Teste die doch mal paar Tage mit Hoher Last.
Selbst meine Gigabyte Gaming OC war nicht leise und am fiepen, ist nach 2-3 Tagen mit hoher Last jedoch echt still geworden.
Bisher ist keine der Karten nach "einer Weile mit hoher Last" auch nur annähernd leiser geworden.
Aber vielleicht bekommt sie ja noch eine Chance, weil sie was Lüftergeräusche angeht schon ist wie ich mir das vorstelle... vor allem im Vergleich zur FE :d
Ich weiß nicht wie lange ihr bereits wassergekühlt PCs habt. Bei mir hat es 2005 angefangen. Manchmal läuft alles jahrelang und manchmal eben nicht. zerlegen und reinigen gehört mit zum Handwerk.
Das Argument zum Spülen geht jetzt ein wenig am Thema vorbei. Es geht nicht darum vorher zu spülen. Das schein nicht nötig. Es geht um die spätere Wartung.
seit ca. 20 Jahren (erinnert sich noch wer an das Innovatek Einsteigerset, der Koffer mit dem merkwürdigen Single Radi ohne Schraubtüllen?)
Und nein, so wie bei dir sah das bei mir NOCH NIE aus. Nicht einmal mit den gelösten Weichmachern. Deshalb musste ich wohl so auch noch nie warten und mir half immer nur das Spülen, bis auf 1x mein CPU Kühler. Hab ich wohl Glück gehabt und ja, lass uns das beenden. Kannst ja mit deinen Sachen machen was du willst.
Sollte einer von euch eine ZOTAC GAMING GeForce RTX 4090 AMP Extreme AIRO besitzen und gerade einen Gliedermaßstab oder anderes Messinstrument haben. Ich bräuchte mal die Breite das PCBs ohne die PCIe Steckleiste um abzuschätze wie vie Platz ich zwischen Stromanschluss und Gehäusewand habe.
Die Antwort lautet: 120mm
Von der Slotblendw steht sie also 30mm über. Der Kühler ist nochmal 15mm breiter.
Also zwecks Spuelfiepsen bei SuprimX kann ich sagen seit dem ich mein 850watt NT auswechseln musste zwecks RMA und es gegen ein Gigabyte 1000Watt NT mit nativen 16pin anschluss hat sich mein Spulenfiepsen halbiert
Ich habe früher die leute immer absolut belächelt wenn sie das behauptet haben aber ich habe es live bei mir gemerkt und es stimmt komplett hätte ich nie gedacht
Was halt gegen diese These spricht ist, dass mit demselben Netzteil zwei verschiedene 4090 komplett unterschiedlich laufen. Die eine fiept wie verrückt, die andere gar nicht. Weder meine FE noch die PNY haben gefiept, bzw. wenn dann ganz leise. Die Strix hingegen war eine einzige Unverschämtheit. Daher habe ich einen Netzteiltausch gar nicht erst in Erwägung gezogen.
Möchte Deine Erfahrung aber nicht in Abrede stellen, wo auch immer Ströme fließen, gibt es so viele Einflussfaktoren, wer weiß schon was am Ende immer die Ursache für so eine Fieporgie ist.
Wenn man sich den hieisgen Overclocking-Thread anschaut dann gibt es schon eine klare Tendenz dass die meisten Premium-Karten wie Asus oder Suprim X eher Richtung 3.100 gehen, während die "billigen" Modelle mit den 3 GHz kämpfen. https://www.hardwareluxx.de/communi...4090-overclocking-und-modding-thread.1325294/
Wer in dem Test dort keine 5.600 unter Luft schafft hat schon eine mega Gurke erwischt.
Also ich würde keine Handvoll Karten verallgemeinern. Meine Zotac Trinity outperformt anscheinend auch die meisten Strix & Suprim X, bedeutet also nichts.
Natürlich kommt es auch immer auf die Karte selber an aber die Suprim X ist ja leider bekannt das die Extremes Fiepsen hat bei der 4090 (mich stört das eh nicht wegen meines Headsets und ich es so nicht mitbekomme) aber ich wollte es einfach mal wissen ob an dem Mythos was dran ist oder nicht weil ich jetzt das NT gewechselt habe und in meinem Fall hat es was gebracht
Das gebe ich dir voll Recht Nvidia hat ein Sehr starkes Binning bei ihren GPU´s betrieben (4090) und der rest ging dann an ASUS der ja nach dem EVGA ausstieg zur neuen Nr.1 aufgestiegen ist auch wenn es nur innofiziell ist und den rest bekommen die ganzen anderen Partner daher kann immer mal ein Golden Sample dabei sein
Siehe hier eine Manli Galardo hatte jemand im OC Forum mit über >3150Mhz wo hingegen andere Asus und Gigabyte teiweile keine 3100 geschafft haben
Entschuldige, wenn du das als Angriff aufgenommen hast. Es liegt mir fern hier aggressiv zu sein. Ich verstehe nur nicht, warum in einem Enthusiasten-Forum nicht ganz klar gegen solche Beschneidungen ausgeteilt wird. auch wenn man selbst keine Probleme hat, so ist es doch viel flexibler. Immerhin lesen es die Hersteller hier tatsächlich.
Aber ich kann natürlich auch nicht erwarten, dass alle meiner Meinung sind. Ich bin aber erstaunt über das Verständnis für den Hersteller
Was sind denn das wieder für Theorien? Quelle? Wieso war EVGA die "Nummer 1"? Wieso soll es Asus jetzt sein? Wer wie was wo?
@klasse08-15: ich versteh grad nicht so wirklich, warum Du so angezickt bist?
1. verlierst Du bei zig Graka-Herstellern die Garantie, sobald Du den Kühler umbaust. Da stehst Du dann nach Umbau auf Wakü sofort ohne Garantie da. Bei den wenigen, die überhaupt einen Kühlerumbau erlauben, läufst Du noch das Risiko, dass Du beim Umbau "Spuren hinterlassen hast", die der Hersteller dann nutzt, um "User-Fehler!" zu rufen und doch wieder die Garantie zu verweigern.
Gegenprobe: Bei einer, die wie die von Inno3D mit nem Wasserblock ab Werk kommt, hast Du eine Graka mit Wakü und Garantie + 2 Jahre Gewährleistung. Insofern sehe ich hier nur einen Vorteil.
2. Echte Hardware-Fehler einer Graka zeigen sich m.E. entweder sehr schnell oder eben gar nicht. Vor allem bei einer Graka mit Wakü-Block, die noch nicht mal bewegliche Teile hat (wie Lüfter), die mit der Zeit ausfallen können. Soll heißen: wenn die Graka 6 Monate läuft, tut sie das im Zweifel bis zum Ablauf der Garantiezeit, wenn man sie nicht anderweitig misshandelt (OC).
3. Wenn Du den Nachteil eines Garantieverlustes stumpf vermeiden willst, wartest Du halt mit dem Bruch des Siegels bis zum Ablauf der Garantiezeit. Wenn sich bei Dir schon vorher so grobe Ablagerungen oder Fremdkörper im Block zeigen - nimm's mir nicht übel - sehe ich da eher 'n Userfehler (z.B. falsche Schläuche, falsches Kühlmittel, kein Filter drin?). Klar, kann passieren, jede Wakü ist am Ende ein Spiel mit dem Risiko, aber da kann der Hersteller nichts für bzw. sowas kann kein Hersteller vermeiden.
4. Das Thema "Garantieverlust" kennt man doch vorher, gerade wenn man schon so lange in der Materie unterwegs ist wie Du? Wenn Dir das so wichtig war, warum hast Du Dich nicht vorher schlau gemacht? Kaufst Du sonst auch nur Grafikkarten, wo der Kühlerumbau erlaubt ist (wohl nicht: hast ja auch 'ne FE).
5. Alles was ich zum Thema "selbst dran rumfrickeln" hier von inno3D wahrgenommen habe, spricht dafür, dass sie da entspannt sind. Sprich, die Aussage hier im Forum war "Kannst gern selbst nachschauen & wenn Du das machst, halten wir Dir das nicht entgegen". Dass Du dann den Vorwurf erhebst, dass man ja eigentlich ihre Arbeit macht (Alternative wäre doch: RMA/Einschicken, Warten & währenddessen gar keine Graka haben), verstehe ich auch nicht. Genau das willst Du doch sogar selbst: ohne Sorge vor Garantieverlust bei irgendwelchen Themen selbst dran rumfrickeln können?
Mir haben sie übrigens auch eine andere Slotblende für meine 4090 Frostbite geschickt, die ich (natürlich) selbst umbauen darf.
6. Habe inno3d auch selbst bisher als kulant wahrgenommen. Support ist schnell, hilfsbereit und hat mir jedenfalls genau das gegeben, was ich wollte.
Ich verstehe ja, dass man mal Frust ablassen darf und viele Hersteller (oder auch Händler) sich nicht ideal verhalten. Hier kann ich aber leider keinen wirklich gerechtfertigten Kritikpunkt sehen. Ich erwarte jedenfalls von nicht von einem Hersteller, dass die sagen "mach' was Du willst, wenn's schief geht machen wir im Zweifel das Portemonnaie auf".
Aber nur meine 2 Cent.
Das war noch nie ein Geheimniss das EVGA "DER Nr1" Premium Nvidia Partner war damit haben sie sogar selber geworden und kein andere Hersteller hat das bis auf EVGA gemacht deswegen hatte EVGA auch immer ein vorrecht auf Chip bestellungen bzw Binning (auch wenn das EVGA ihr untergang war inkl der Gier) und seit dem EVGA weg ist hat ASUS den platz eingenommen weil auch NVIDIA ein neues Aushängeschild brauch und will weil Jenson eben Maximalen gewinn einstreichen will und da reicht eben seine FE nicht und dazu brauch er auch einen Premium partner auch wenn das Offiziell nie gesagt wird ich weiß das auch nur von jemand sehr hohem aus der Industrie und auch das ist nur logisch weil das in jedem Industrie zweig so ist siehe Automobiel branche VW/AUDI hat Porsche und Lamborghini (Bugatti) auch wenn es nur noch zu 45% dazu gehört
Und so ist das eben auch bei Nvidia nur macht das ASUS eben viel schlauer als EVGA bzw macht ASUS nicht die selben fehler
Das war noch nie ein Geheimniss das EVGA "DER Nr1" Premium Nvidia Partner war damit haben sie sogar selber geworden und kein andere Hersteller hat das bis auf EVGA gemacht deswegen hatte EVGA auch immer ein vorrecht auf Chip bestellungen bzw Binning (auch wenn das EVGA ihr untergang war inkl der Gier) und seit dem EVGA weg ist hat ASUS den platz eingenommen weil auch NVIDIA ein neues Aushängeschild brauch und will weil Jenson eben Maximalen gewinn einstreichen will und da reicht eben seine FE nicht und dazu brauch er auch einen Premium partner auch wenn das Offiziell nie gesagt wird ich weiß das auch nur von jemand sehr hohem aus der Industrie und auch das ist nur logisch weil das in jemandem Industrie zweig so ist siehe Automobiel branche VW/AUDI hat Porsche und Lamborghini (Bugatti auch wenn es nur noch zu 45% dazu gehört)
Nochmal: Quelle? Sonst ist das alles Bullshit, ganz einfach. Ich sag ja nicht dass es nicht so ist, aber zumindest hätte ich dazu dann gerne mal n Statement von NVidia gesehen.
Das wirst du nie bekommen alleine schon aus dem Genannten grund des Maximalen Gewinns seitens Nvidia weil wenn sie das Offiziell machen würden und sagen ASUS ist unsere neue NR.1 besteht die chance (auch wenn ich das für sehr unwahrscheinlich halte) das der eine oder andere Boardpartner sagt schön ASUS bekommt die Filet stücke und wir den "Rest" da lassen wir es sein und machen eben nur AMD karten
daher läuft das alles innofiziell und Nvidia kann schön abstreiten und sagen NEINNNNN alle bekommen das gleiche und keiner ist Böse
Hä wenn dem so wäre , warum war generell EVGA bei Verfügbarkeit immer so spät dran?
Hab immer das Gefühl das Palit/Gainward immer die größte Menge an Chips hat .
Asus ist auch gut dabei denke ich , aber auch in vielen Fertigrechner werkeln dann auch oft Gainward/Palit.
Ok dann tu mir (oder eher der Allgemeinheit) bitte einen Gefallen und stell solche wilden Theorien nicht als Fakt hin. Ein "meiner Meinung nach" oder "ich denke dass" reicht schon.
Warum bloß weil Palit und co eben günstig sind und diese Marken eher auf maße setzten und ASUS und EVGA waren schon immer High End karten mit entsprechenden Preis und die laden eben selten in einem Fertig PC sondern kaufen "Meistens" nur Enthusiasten
Nochmal ich würde das nicht "Behaupten" wenn ich das nicht aus erster Hand erfahren hätte 8-)
Binning-Gerüchte waren schon immer Quark bei VGA.
Naja wenn man sich die Video reihe von Gamer Nexxus anschaut bei Kingpin bzw EVGA scheinen die gerüchte schon zu stimmen zwecks Binning und Co
EVGA ist ein kleiner Laden und die Fertigung haben teils andere für die übernommen.
Die haben ihre Karten dann eingesteckt und test´s gemacht und je nach dem wie gut die waren haben die entsprechende BIOS aufgespielt.
Da wurde auch kein max. OC betrieben . Nämlich nur obs dann noch reicht für ne OC oder FTW oder so .
Gibt ja einiges Videos wie es bei EVGA aussieht und wie es bei denen lief im Alltag.
Natürlich ist EVGA nur ein kleiner Laden gewesen aber das spielt keine Rolle weil alle ob ASUS oder Gigabyte und wie sie alle heißen ihre GPU produzieren lassen bei einem Hersteller und es geht auch nicht um Max OC in der Massen Fertigung das hat vlt Vince gemacht wenn eine Kingpin karte kommt die eh sehr selektiert war was er auch selber bestätigt hat in den Videos von Gamer Nexxus das fing beim besonderen PCB an und hat mit der gebinnten GPU geendet
Und ob das binning zu EVGA zeiten schon bei Nvidia stattgefunden hat oder ob das rein bei EVGA war ist natürlich bei so einem "Kleinen" Laden schwer zu sagen aber das es das gab ist und war nie ein Geheimnis bei ASUS und MSI und co nehme ich stark an das die das selber machen und dann eben selektieren Chip A wird eine Strix OC und Chip B eben nur eine Normale TUF
Die Komponenten macht doch Asus selber drauf.
Kann sein das PCB bestellt ist , aber die GPU und VRAM ,VRM , Kondensatoren machen die selber drauf .
Vapor Chamber ist sicher auch bestellt wird dann auch bei Asus selber montiert und geprüft.
EVGA hat das komplett von Jemand anderen machen lassen und machten lediglich Design und QA soweit ich das in Erinnerung habe .
Denke MSI , Gigabtye und Asus sind schon ne andere Hausnummer als EVGA jemals war und denke Nvidia hat sicher bei den Großen mehr abgesetzt.
Gainward/Palit macht auf jedenfall auch viel von der Masse her.
Kann es natürlich nicht genau sagen, weil das nicht mein Bereich ist. Nur ne Einschätzung .
Weltweit gesehen definitiv wobei ich Zotac da auch nicht unterschätzen würde nur weil die Vlt bei uns nicht so bekannt sind sieht das Weltweit bestimmt anders aus
Naja das war auch immer bekannt und ist nix neues siehe Apple macht es genauso
Sicher das es so ist? weil ich war der Meinung das Asus keine eigene Produktion hat weil bis auf ihre OEM Sparte wüsste ich nicht das ASUS noch eine Produktion hat
Das ist schwer zu beurteilen in den USA definitiv nicht weil dort EVGA schon sehr gut GPU´s abgesetzt hat aber Weltweit werden die Großen mehr abgesetzt haben
[/QUOTE]
der Hersteller der GPU kann nicht für Ablagerungen oder „falsche“ Schläuche etc. Logisch.
Wenn man so ein typisches Wakü-Problem hat, verliert man jedoch die Garantie, nur weil man mal „durchwischen“ will.
Es geht dabei nicht um die Karte selbst, aber es hat erheblichen Einfluss
[QUOTE="besterino, post: 29696462, member: 135432"]
[/QUOTE]
[/QUOTE]
Dass ein Siegel auf der Karte ist, steht in keinem Angebot. Auch auf den Fotos ist nichts davon zu sehen. Auf dem Karton steht auch nix.
[/QUOTE]
[/QUOTE]
Die Slotblende ist nicht zu wechseln ist, wenn man das Siegel erhalten muss. Der Kühler muss runter. Du hast eine Einzelfreigabe bekommen, um einen Fehler des Herstellers selbst zu beheben. Du bist einfach billiger als das Einschicken. Und es ist n dieser Form besser als ein stänkernder User in einem großen Forum, der wochenlang warten muss. Deswegen wurde dir das „gewährt“.
Übrigens, herzlichen Glückwunsch, dass du „mein Problem“ nicht haben wirst. Sag ich ohne Neid. Aber das du kein Verständnis für meine Position hast, hängt wohl damit zusammen.
[/QUOTE]
[/QUOTE]
Es geht nicht um den Einzelsupport. Ich finde es auch gut, wenn man in Einzelfällen so vorgeht. Du profitierst davon, sei dir gegönnt.
Aber ich habe in diesem Moment kein Problem, denke nur etwas weiter. Es geht darum keine Einschränkungen zu haben, wenn man mal in die Situation kommt.
[/QUOTE]
[/QUOTE]
Ich erwarte das auch nicht. Hier macht der Hersteller es aber genau umgekehrt. Bricht jemand das Siegel und die Karte ist kaputt, ist die Garantie weg. Egal ob man selbst schuld ist oder nicht. Ein guter Support guckt sich die Karte an. Ist jemand mit dem Schraubenzieher über die Platine gesaust, keine Garantie. Ist was verschmort, gibt es Garantie.
Dein Argument ist also hervorragend, um genau meine Position zu verdeutlichen. Nur halt andersherum.
Entschuldigung für die Form. Ich kriege es am iPhone nicht mehr repariert
Ich habe 1998 angefangen.
Mit DP und kein PVC, sondern EPDM / Tygon / Norprene wird man niemals Ablagerungen haben.
Die Komponenten müssen natürlich vor dem Einbau sauber sein, ist meistens bei Neuware der Fall und man kann diese vorher zur Sicherheit einfach durchspülen. Ich weiß auch gar nivht was manche mit diesen dämlichen Siegel haben, das habe ich gleich abgerissen, interessiert mich nicht im geringsten.
Wenn du das Siegel abreißt und nicht drüber nachdenkst, dann ist das natürlich der einfachste Weg. :d Mache ich vielleicht auch so.
@klasse08-15: alles, gut - ich hätte nach meinem bisherigen Eindruck von inno3d noch die Hoffnung, dass die sich vielleicht gar nicht so anstellen, wie sie sich vielleicht anstellen dürften. Ist ja auch bei vielen anderen Herstellern so, dass es dann doch nicht so heiß gegessen wie gekocht wird. :) So'n Siegel ist halt misslich. Aber mich würde jetzt doch mal interessieren, ob Du den Block nicht vielleicht doch "auf" bekommst, ohne das Siegel zu brechen? Und im Zweifel echt: sch*** drauf. :d
Ich verstehe die Sorgen über dieses Siegel aber meistens sind die Hersteller doch eh kulant, oder? Wenn sie halt sehen, dass da irgendwas auf der Platine verbrannt oder verkratz ist wird das Siegel vermutlich noch als Argumentation verwendet, aber ansonsten werden die wohl kaum alle RMA Fälle ablehnen? Zumal wir jetzt auch echt nen eher hypothetischen Case diskutieren.
Es gab Berichte das manche auch erst gar keines hatten und besonders gut ist die Position auch nicht gewählt. Es wäre sicherer für den Hersteller gewesen es über einer Schraube anzubringen.
Ähnliche Themen
Antworten
7K
Aufrufe
424K
