[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Erstmal ein dickes Danke an alle, die sich dem Thema annehmen. Zwar sicherlich auch aus eigenem Interesse, aber ich gehöre ja schon zu denen, die das mit dem Brummkreisel bei der FE etwas mehr stört.
Neue Entwicklung bei mir: Anhand der eingesendeten Videos sieht NVidia einen RMA Fall als gerechtfertig an. Ich soll unter zig Auflagen und vorher einzusendenden Dokumenten / Screenshots / Fotos den entsprechend Fall eröffnen. Ich werde das auch tun weil ich sehen möchte, ob die Ersatzkarte (bzw. die "reparierte" Karte) nun besser ist oder nicht. ich gehe allerdings zu 100% (nicht zu 99) davon aus, dass auch der Ersatz, egal ob neu oder nicht, ebenso brummen wird. Dazu sind einfach die Erfahrungen hier bzw. die Videos im Netz zu eindeutig.
Aber ich bin überhaupt erstmal überrascht, dass die sich das weiter anschauen wollen. Also packen wir's an.
Na da bin ich mal gespannt wie die das hinbekommen wollen... Ich denke, dass Ergebniss wird so sein wie Du es vermutest. Aber der Vorteil ist, dass auch endlich mal bei Nvidia selbst jemand hört wie das Ding brummt. Scheint wohl nie außerhalb eines offenen Benches mit Nebengeräuschen passiert zu sein.
Auch wenn sie jetzt keine Lösung finden könnte es aber ein GEdankenanstoss sein die nächste Revision darauf hingehend zu optimieren.
Dann brauchst Du ja nur noch eine Ersatzkarte...
Und ich muss jetzt meine Wände neu streichen und einen neuen Tower besorgen damit ich die Videos dann, je nach Ergebnis, in meinem Namen senden kann :-)
Edit: Ih denke, dass die Karten unterschiedlich laut sind liegt evtl. daran wie die Finnen geneigt sind. Sonst gibt es ja keine Unterschiede???
Hahaha. Kann mir zwar nicht vorstellen, dass da nur ein armer Hansel sämtliche RMA bearbeitet, aber zumindest noch ein paar Wochen warten solltest Du. :d
Aber danke nochmal, jedenfalls hatten sie ihren Effekt.
das ASUS/Seasonic cablemod cable was versendet wurde und nicht ging ist wohl laut cablemod eins für EVGA PSU´s gewesen?
holy macceroni.
Ich warte erstmal Dein Ergebnis ab bis ich was in die Wege leite.... Bin auf jeden Fall neugierig...
dann haben die die evga kabel in eine asus/ss tüte gepackt? das ist natürlich nicht gerade unkritisch :d
ja eben. außer die evga nts haben die gleichen stecker wie ss?
sieht schon passend aus
dann ergibt das defintiv sinn. denn jemand hat ja auch eins und es ging. war dann wohl kein schwarzes oder eins aus einader anderen "charge"
dann hoffen wir mal dass das 2. fix kommt und dann auch richtig ist.
gott sei dank ist nix passiert
Also mein Cablemod funktioniert, ist auch für Seasonic.
Welches Adapterkabel ist denn aktuell für ein BeQuiet Netzteil zu empfehlen? Gibts da irgendwelche die keine Probleme bereitet haben?
welches haste denn bestellt? custom made? fertiges? modmesh oder modflex? schwarz oder bunt?
das was bq verkauft oder halt das cablemod. die qualität ist schon völlig in ordnung bei CM aber halt nur wenn die MA die richtigen kabel in die korrekten verpackungen stecken :fresse:
Meins geht auch. Schwarzes ModFlex 4x8 Pin für Asus/SS. Scheint aber nur das ModMesh zu betreffen.
Hab ein fertiges, schwarzes 3x8 Pin Mod Flex für Seasonic/ Asus erhalten. Wie gesagt alles wunderbar.
flex ist nicht betroffen, nur die mesh laut "joe"
Das wäre das hier oder? Das Produktbild ist etwas irrritierend weil dort nur ein 12 Pin Stecker zu sehen ist.
Wartezeit ist dort aber so wie man hier so liest etwas länger?
ein ende sind 16pin. das sollte 12+4 sein glaube ich.
lieferzeit über den eu store 2-4 wochen
ist aber ein ungesleevtes. sleeved bq gibts nur über dne configurator für deutlich mehr €
Alles klar, danke euch.
Einfach krass wie lahm cablemod ist
Der Versand bei Cablemod ist eh sehr seltsam. Einige kommen, mit FedEx, einige mit DPD, dann noch welche mit GLS und meins kam mit DHL "Express".
An alle mit Block auf der 4090…
Wieviel Temperatur-Differenz zwischen Wasser und GPU-Hotspot habt ihr? Bitte auch die Last in Watt angeben
Da scheinbar die 4090 Käufer hier gerne gebrauch von FAG machen muss man halt in DE die Preise bisschen anheben ^^
Ähnliche Themen
Antworten
7K
Aufrufe
467K
