[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Haben hier in letzter Zeit Leute was von Cablemod bekommen? Habe meins immer noch nicht. 31.10 bestellt
Ich habe am 5.11 bestellt - Versand war für den 19.11 geplant. Gestern mal angefragt und es wird jetzt produziert und soll in 2 Wochen verschickt werden.
War ein fertig konfiguriertes Kit für Asus. Nichts selbst zusammen gestelltes.
War wohl meine letzte Bestellung dort.
ich habe heute eine Frostbite 4090 bei nbb bestellt, Geld ist bereits abgebucht, Auftragsbestätung erhalten, im Kundenkonto war der letzte Status Versandabwicklung. Gerade wollte ich nochmal reinschauen und jetzt wird die Bestellung überhaupt nicht mehr angezeigt.
Ist das dort normal, war das bei euch auch?
danke
Gast Bestellung über Paypal? Dann war der Login in den "Account" nur temporär und ist jetzt abgelaufen, kannst in einer der Mails aber den Link benutzen der unten versteckt ist um das Gastkonto in ein echtes Konto umzuwandeln :), außer du hattest schon einen Account auf die gleiche e-Mail Adresse wiedie bei Paypal hinterlegte, dann klappt das nicht :d
Welchen Block würdest du nehmen?
Und du willst LM statt Paste nehmen?
Ich muss sehen welche Karte es wird erstmal !
Am liebsten einen Aquacomputer Kühler da zum Beispiel der RAM bei denen eine 100%Pasung hat und gar keine Pads verwendet und auch die VRM Kühlung seit Jahren Referenz ist .
Ansonsten Alphacool macht inzwischen einen Mega Job sind besser wie Byksi EK von der Leistung und der Preis passt.
Und zu Liquid Metal ja auf jeden Fall wie immer nur das Beste vom Besten.
Gruss
Mein guter Stoff ist immer zur Hand.
Schade diesesmal wohl nur für Strixx von Aquacomputer.
Das wird wohl wieder der Beste Kühler für eine 4090 am Markt werden.
Mein CableMod Kabel kommt auch rasend schnell weiter... ich hoffe einfach mal, dass es nicht in China in den Van geladen wurde :d
na klasse. du jetzt auch mit einem nicht funktionierenden?
melde das mal asap cablemod. ich soll ein neues bekommen mit prio. hoffe der meldet sich morgen..
aber ich glaube hier hatte schonmal jemand ebenfalls seasonix focus und ein cablemod und es ging.
bei mir ebenfalls TUF und das modmesh (ohne configurator) bestellt
Danke für den Beistand, werde ich direkt reklamieren.
Gestern kam meine TUF ja erst von Alphacool zurück. Dachte nach dem Einbau schon die Karte sei jetzt defekt. Zum Glück nur das Kabel und ich habe ja noch Ersatz hier. Trotzdem auf Dauer keine Lösung.
Danke, ja stimmt, hatte anscheinend als Gast bestellt, habe allerdings auch ein Konto dort mit der gleich Mailadresse dort, somit funktioniert der Link nicht. Werd mal den Support dort anscheiben.
Mein CableMod Kabel sieht gut aus, aber funktioniert nicht o_O
Mechanisch passt es gut in mein Seasonic GX850, aber beim booten bleibt die rote LED an der TUF an und am Mainboard bei der VGA LED hängen. Mit der Seasonic Adapter Peitsche funktioniert es. Gleiche Ports am Netzteil gewählt.
Anhang anzeigen 820762 Anhang anzeigen 820760 Anhang anzeigen 820761
Bei meinem original Seasonic Kabeln sind die Ports unten rechts wo die Sense-Pins enden leer. Fand ich komisch.
Jemand ne Idee was ich prüfen könnte?
Deine Sense Pins sind falsch aufgelegt. Habe selber ein Seasonic PX-850 und bei mir schaut das so aus. Zudem sind bei mir alle 8 Buchsen an den Steckern belegt. Funktioniert bei mir einwandfrei.
Da die FE Drops einfach nicht kommen und ich über die Weihnachtstage gerne den neuen Rechner bauen würde, überleg ich mir nun nach einer Zotac Extreme Airo Ausschau zu halten und dafür den Bykski Kühler zu bestellen, weil der EK zumindest bei der FE kaum besser performt und das Doppelte kostet und ich den Bykski auch irgendwie schöner finde.
Hat die Kombi schon jemand so am Laufen und wenn ja, wie schwierig ist die Montage des Kühlers ? Hatte bislang nur Watercool als GPU-Block verwendet.
Was ist denn da in Shenzhen zwischen dem 16.11. und 24.11 passiert? War scheinbar ein ordentlicher Stau ^^
Bei meinem Versand konnte ich echt nicht meckern. Für 68,63€ inkl. Versand ^^ Bin mal gespannt, ob da noch was und wieviel vorallem vom Kölner Zoll kommt oder nicht.
Warum FedEx von Shanghai nach Belgien und von dort aus erst über Paris nach Köln fliegt/fährt, erschließt sich mir zwar nicht, aber wird schon seine Richtigkeit haben.
  • Danke
Reaktionen: hwk
Ich hatte Bykski Block auf meiner 3090 FTW3 und die Montage war super simpel. Die Anleitungen sind ja eh online, kannst dir also vorher schon ein Bild davon machen.
Da fand ich die Montage des EK-Blocks auf meiner 4090FE tatsächlich "schwieriger" weil die Anleitung zur Demontage des Originalkühlers einige Details weglässt :d
Mich würde interessieren wo hier und bei @Scrush der Fehler liegt
Obwohl ich eigentlich keine 4090 wollte, habe ich sie aufgrund des überraschenden Priority Access nun doch erstmal. :LOL:
Nur mein Gehäuse macht da nicht so mit, aber was nicht passt, wird halt passend gemacht.
Nur mein Gehäuse macht da nicht so mit, aber fürs erste reicht es auch so aus und erstmal gucken was das Thema Spulenfiepen macht.
Libelle einer Wasserwaage bei der 4090 Gallardo von Manli, jetzt ein Meterstab/Zollstock bei Srider`s 4090 Founders. Scheint wohl der neueste Trend zu werden... :LOL:
Jetzt hab ich nochmal eine Frage zur Gewährleistungsübertragung bei Asus. Ich hatte vor ein paar Tagen eine TUF 4080 bestellt und erhalten. Jetzt hab ich aber meine Wunsch 4090 bekommen und einen Interessenten für die 4080. Habe diese direkt im ASUS Webshop gekauft. Was muss getan werden, dass die Gewährleistung auf den Zweitbesitzer übertragen wird, oder hat der diese sowieso automatisch wegen der geseztlichen Gewährleistung, wenn er die Originalrechnung hat, aber halt mit meinem Namen?
danke
Läuft recht gut bei 92%PL
Endlich konnte ich mal ein Corsair 12VHPWR-Kabel bestellen. Auf deren Webseite scheint ja gar nichts mehr reinzukommen. Hab jetzt bei Galaxus zugeschlagen. Zum halben Preis wie bei E-Bay-Angeboten. Anscheinend wird jetzt bei Kabeln auch schon gescalpert.😐
danke
Du musst dieses Formular ausfüllen (Personalnummer würde ich aber weglassen, der Rest reicht vollkommen aud) und dem Käufer mit Originalrechnung geben.
die 92% werden ja auch nicht mal erreicht laut dem Maximalen Powerdraw auf dem Screenshot :d 300.7W ist etwas weit weg von 92% (414W bei 450W als 100%)
Also ich habe das alles und meine RMA wurde von NBB abgewiesen mit dem Hinweis ich solle mich an NVidia wenden. Auf die Frage hin wozu dann dieses Formular kam keine Antwort bisher.
EK ist wen es um Performance geht auch nicht die beste Wahl er ist vielleicht der schönste aber nicht der Leistungsfähigste!
Da zu kommt wen ihr über 500W an das Wasser abgeben wollt gehört nur das Beste als Wärmeleitmittel auf die GPU !
Und das ist keine Paste gerade oben raus trennen sich Spreu vom Weizen!
Bei der Leistungsaufnahme gehört meiner Meinung nach Liquid drauf würde überhaupt gar nicht auf die Idee kommen Paste zu verwenden.
Gibt auch extra Schutzlack gegen Kurzschluss wen man zwei linke Hände hat.
Dafür m8 LM aber nen dickmove und zerstört die Glattheit der Waküoberfläche:
Ich kann nur sagen ich hatte bei der 3090 meinen Block zum 23.12 geliefert bekommen.
November war damals das Ziel. Irgendwie in der hinsicht ganz froh darauf nicht warten zu müssen.
Ich hatte damals vorbestellt.
Watercool HKV Nickel/RGB für Referenz PCB.
Waren die ersten Blöcke die kamen.
Ähnliche Themen
Antworten
7K
Aufrufe
541K
