[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Echt ist das so? Dachte Kühler ist immer besser? Naja, ich bin eh der undervolter :-). Vielleicht lasse ich sie auch erstmal so. Aber wie es scheint kommt Asus nicht aus der Hufe. Seit 2 Tagen steht da Versand elektronisch angekündigt.
Ja ist so. Hab ich 80 Grad am Speicher geht +1600, isse richtig kalt nicht mal +1500. Das Problem haben mehrere.
Die Idle Temperatur ist sehr gut (1° Delta), aber unter Last mit Kombustor ist sie unterirdisch. Ich werde am WE das ganze nochmal demontieren (was immer eine Riesenfreude ist mit HardTubes) und schau, was da falsch läuft.
EK ist wen es um Performance geht auch nicht die beste Wahl er ist vielleicht der schönste aber nicht der Leistungsfähigste!
Da zu kommt wen ihr über 500W an das Wasser abgeben wollt gehört nur das Beste als Wärmeleitmittel auf die GPU !
Und das ist keine Paste gerade oben raus trennen sich Spreu vom Weizen!
Bei der Leistungsaufnahme gehört meiner Meinung nach Liquid drauf würde überhaupt gar nicht auf die Idee kommen Paste zu verwenden.
Gibt auch extra Schutzlack gegen Kurzschluss wen man zwei linke Hände hat.
@Grestorn
hier mal ein Paar Vergleichswerte falls Du den Thread nicht bereits kennst ;)
Danke für den Link. Werde am Wochenende vielleicht auch mal ein paar Daten einwerfen!
Fand mein Delta mit dem EK Block jetzt auch nicht überragend, allerdings im Vergleich scheint das üblich zu sein.
Und das ist keine Paste gerade oben Rum trennen sich Spreu vom Weizen!
Bei der Leistungsaufnahme gehört Liquid drauf .
Bei der Leistungsaufnahme würde ich gar nicht auf die Idee kommen Paste zu verwenden.
Diese Ansprüche hab ich ja gar nicht. Ich bin nicht auf OC-Jagd. Aber wenn ich lese, dass die Leute mit Kombustor unter 45° GPU Core haben und ich klar über 50° bin, dann finde ich das nicht ok. Und die Hotspot Temperaturen sind jenseits von Gut und Böse.
Beim Zocken ist aber alles im grünen Bereich.
Ich bin auch nicht auf OC Jagd aber wen ich die Karte auseinander baue um bessere Temps zu bekommen dann mach ich das auch gleich richtig.
Gibts dazu irgendwelche Tests?
Brauchen wir jetzt Kühler oder Blöcke mit Heizelementen im RAM-Bereich? :ROFLMAO:
Na ja ich würde sagen unter Wasser kommen wir gar nicht so tief das es Gift wird für den Ram.
Heute is wohl Zotac 4090 Trinity Tag .. und die kommt auch schon auf Gute 10 Seiten und Zotac schafft es auch im gegensatz zu Asus mehr von den besseren Zotac Karten zu droppen
die AMP kommt nun schon auf 7 Seiten während die Strix noch mit 2 Seiten dahin dümpelt .. aber die Gigabyte Xtreme trifft es glaub ich am härtesten mit nur 2 Karten Dropps
während die kleinere Master auf zumindest 9 Karten kommt
Mal eine Frage an die Raytracing, DSSL2 und 3 Fans:
In Crysis 3 remastered fiel mir im letzten Level (in der Nähe der Mind-Carier) auf, dass sich die Umgebungsbeleuchtung plötzlich ändert, wenn man sich bewegt. Plötzlich erscheint alles rot verfärbt.
Habt Ihr das auch mit der 4090er oder hat Crytek einfach wieder nur 💩 programmiert?
Hast Du mit Auto HDR gespielt?
3° sind aber kein Beinbrech, ist zwar ein alter Test, trotzdem kann man ungefähr abschätzen, wo die Reise hin geht.
Mein CableMod Custom Kabel ist heut auch aus China per FedEx angekommen (80cm ModMesh 4x 8pin vom Fractal Ion2 auf 12VHPWR, am 28.10.22 bestellt)
Sieht soweit erstmal ganz vernünftig verarbeitet aus, vorallem auch die Stecker.
Die zwei Sens Leitungen hätten sie aber ruhig in einem Sleeve verstecken können, statt den Klingeldraht über die gesamte Strecke einzeln mitzuführen.
Einbau mach ich aber erst am Wochenende, wenn ich auch bereit bin für einen Lichtbogen :fresse:
CableMod Custom Kabel funktioniert. Hat auch überall ein dezentes "Klick" gemacht, PL ist auch noch aufdrehbar, sollte also passen.
Wann hattest du bestellt bei Cablemod? Ich warte immer noch...
Na ENDLICH 👏
Hat jetzt locker 1,5 Monate gedauert.
Mein CableMod Kabel sieht gut aus, aber funktioniert nicht o_O
Mechanisch passt es gut in mein Seasonic GX850, aber beim booten bleibt die rote LED an der TUF an und am Mainboard bei der VGA LED hängen. Mit der Seasonic Adapter Peitsche funktioniert es. Gleiche Ports am Netzteil gewählt.
Bei meinem original Seasonic Kabeln sind die Ports unten rechts wo die Sense-Pins enden leer. Fand ich komisch.
Jemand ne Idee was ich prüfen könnte?
ich habe heute eine Frostbite 4090 bei nbb bestellt, Geld ist bereits abgebucht, Auftragsbestätung erhalten, im Kundenkonto war der letzte Status Versandabwicklung. Gerade wollte ich nochmal reinschauen und jetzt wird die Bestellung überhaupt nicht mehr angezeigt.
Ist das dort normal, war das bei euch auch?
danke
Anhang anzeigen 820762 Anhang anzeigen 820760 Anhang anzeigen 820761
Bin der Meinung @Scrush hatte das auch leider.
EDIT: Vermute mal, dass die beiden Sense an den PSU-seitigen Steckern im falschen PIN-Slot sind
na klasse. du jetzt auch mit einem nicht funktionierenden?
melde das mal asap cablemod. ich soll ein neues bekommen mit prio. hoffe der meldet sich morgen..
aber ich glaube hier hatte schonmal jemand ebenfalls seasonix focus und ein cablemod und es ging.
bei mir ebenfalls TUF und das modmesh (ohne configurator) bestellt
Welchen Block würdest du nehmen?
Und du willst LM statt Paste nehmen?
Einfach später nochmal gucken, ist wohl kein Grund zur Beunruhigung, du hast ja schließlich die AB per Mail bekommen oder nicht?
Ähnliche Themen
Antworten
7K
Aufrufe
463K
