[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ich glaube ich versuche mal meine TUF bei Computeruniverse umzutauschen. Das Spulenfiepen kann schon sehr extrem sein:
Bei RDR2 mit FSR 2.1 und ca. 120-220FPS auf jeden Fall am stärksten zu hören.
das ist krass, das hört man sicher aus 5 Meter Entfernung noch? !
@KiLiK kannst es ja hier auch mal posten:
Also aus meinem Gehäuse nehme ich die Karte sogut wie nicht wahr obwohl oben nur ein statt zwei Lüfter drinnen sitzen. Minimales Surren der Spulen in seltenen Situationen. Die Lüfter drehen bei mir kaum auf (oft nur 30%) vor allem seit dem halben UV von 0.95V. Sie sind auch sehr laufruhig und die unterschiedlichen Drehzahlen zwischen beiden Lüftern verhindern sägende Geräusche vorbildlich. Habe ich in dieser Form in der Vergangenheit selten erlebt!
Meine läuft bei UV 0,95 auf ca. 39-40%.
Spulen höre ich gar nicht. Aber das lüfterbrummen nervt doch schon etwas.
Keine Ahnung warum meine auf 39% gehen und deine nur auf 30???
Meine Tuf blieb auch bei minimalen 1000rpm.
Im Gehäuse ist es megakühl...
Hatte ich letzte Woche geschrieben, dass die Karte bei RDR2 am lautesten ist, selbst mit UV.
In anderen Tests ist sie nahezu lautlos - Timespy als Beispiel.
Was lernen wir darauf?! Man muss es einheitlich testen und nicht auf Hören und Sagen.
Da ich aber Ton habe (5.1) am TV oder Kopfhörer verwende, ist es mir egal.
Bei RDR2 ist es lauter, aber nicht nervig.
Da klang die 3090 Strix anders 🫣
Hmm, okay, dann lasse ich mir das nochmal durch den Kopf gehen. Bei anderen Spielen stört es mich nicht sonderlich. Im Bereich von 50-90FPS ist es auch besser. In diesem Bereich spiele ich meistens weil ich DL-DSR nutze.
Weiß nicht, ob man das mal fragen kann ? Habe bei mindfactory bestellt. Seit heute steht Versand wird vorbereitet. Eine Sendungsnummer habe ich auch schon bekommen .Bei DHL steht seit 14:42 Uhr Sendung wurde elektronisch angekündigt. Kann ich denn morgen noch mit dem Versand rechnen oder heute noch? Hat einer Infos und/oder Erfahrungen, da ich bei diesem Unternehmen noch nicht bestellt habe?
Sorry falls es hier nicht reinpasst.
LG
LG
Jetzt um die Uhrzeit bestimmt nicht mehr.
Morgen wohl eher.
Irgendwie kommt mir das bei meiner aber ziemlich extrem vor :unsure:
Mit bloßem Ohr sogar noch lauter als im Video.
Hatte 3 TUFs da, haben sich alle genau so angehört wie deine.
Habe das problem gefunden. Es ist nicht der Motor des Lüfters der so brummt sondern die Luft an den Lamellen. Halte ich meine Hand unten an der Karte wo die Lamellen an das V angeknüft sind wird es leiser. Das ist übel. Wüßte nicht wie man das beheben kann. Die Lamellen sind alle fest und gleichmässig verteilt...
Das liegt vermutlich an einigen Faktoren. Mein Gehäuse ist z.B. für das typische axiale 3 Lüfter System ungeeignet. Da hat sich die Hitze immerzu gestaut. Gut, der 3090 Strix Kühler war jetzt auch nicht so toll (absolut uberhyped die Karte, deswegen war die 4090 Strix auch direkt raus für mich). Mit der FE hingegen scheint der Airflow extrem gut aufzugehen. Zudem kommt das UV und natürlich das jeweilige Spiel. Und ganz wichtig die Zimmertemperatur. Nachdem mein Vermieter meint, dass er aufgrund der Energiekrise die Temps absenken muss, sind es hier aktuell so um die 19-20 Grad. Ich empfinde das als frisch, er eher nicht. Deshalb hat er jetzt meinen Anwalt am Arsch. Mit der 3090 Strix hätte ich das Problem nicht gehabt, die 4090 ist zu effizient bzw. zu kühl...
LG
Hab da erst kürzlich den X3D bestellt. Ist normal bzw. kann vorkommen, dass der Artikel erst am nächsten Tag rausgeht.
Das ist echt seltsam, hast du nen offenen Aufbau bzw. welches Gehäuse?
Ne, ist ein fractal define r6. Ich vermute die Lamellen sind es. wenn ich auf den bereich der karte klopfe höre ich auch die lamellen rasseln. Vielleicht ist es auch normal.
Der hintere Lüfter am PCI Bracket ist super leise. Generell sind beide Lüfter ziemlich leise und wertig. Nur die Lamellen machen das Problem.
Habe jetzt nochmal die Tuf eingebaut und es ist eine Wohltat für meinen Kopf. Dieses niederfrequente Brummen macht micht gaga. Also diese FE geht wieder weg. Eventuell bekomme ich ja nochmal eine FE. Zum Glück habe ich nicht beim Scalper gekauft.
Ist interessant wie unterschiedlich die Leute sind . So die perfekte Karte gibt es allem Anschein nicht . Meinungen gehen hier teils stark auseinander .
Ansonsten finde ich den Artikel ziemlich gut.
Schön alles zusammengefasst .
Das Brummen hat jede FE, liegt daran das der hintere Lüfter zu nah an den Lamellen steht.
Hätte NVidia beide Lüfter auf die Unterseite der Karte gebaut, wäre die Karte viel leiser.
Das hört sich ja richtig übel an, noch schlimmer als meine 3090FE damals 🤮
Werde mal RDR2 später mal testen mit meiner Strix.
Das fände ich eh besser wenn der 2. Lüfter auch unten wäre.
Erstens ist Push immer effektiver als Pull, 2tens kann beim basteln am Rechner mal von oben was in den Propeller reinplumpsen, 3. Sähe die Karte dann besser aus, und 4. wäre das brummen nicht.
OK, Coldfinger meint er hat kein brummen?
Jetzt bräuchte ich wohl ein 2tes Model um festzustellen ob meine Karte normal oder besonders laut ist.
Im Gamers Nexus Teardown sieht man schön wie der hintere Lüfter mit nur 4 Schrauben befestigt ist.
Wenn das Kabel nicht zu kurz ist, dann sollte man da locker nen 2-3mm Spacer einfügen können. :unsure:
Das dürfte schon gut was Helfen.
@pajonk also wenn ich deine Eindrücke zusammenfasse, so bist du mit der FE einfach nicht glücklich und die TUF passt besser zu dir. Warum machst du es dir so schwer? Ich habs schon einmal geschrieben: jeder muss das wählen was für ihn am besten passt. Es gibt nicht DIE ideale Lösung.
Wenn man sich entscheiden muss, dann doch eher über den OOB Zustand. Ich geh doch nicht hin und bastel am Lüfter einer 2K € Grafikkarte herum. Passt halt dann einfach nicht. Beim "der 8auer" hat man ja auch gesehen dass einer der Lüfter etwas unrund lief, bei einer Felge hätte man gesagt die hat einen Schlag. Und wenn es sowas ist hilft dir kein Spacer der Welt.
Ich frage mich wie Deine Lüfter auf 30% bleiben.
Bei mir im Gehäuse ist alles kühl. Auch die Tuf dreht nur bis 1000rpm auf
Aber die FE geht auf über 40% undervolted. Der Chip hat ca. 60° und der Ram ca. 70°.
Ab minute 22:20 ist das Geräusch was ich meine.
Das Problem ist, dass ich unbedingt die FE haben wollte :-)
Es liegt aber nicht am unruhigen Lüfter.
Hier ist das Geräusch ab Minute 22:20.
Wenn das aber alle haben ist die Kartte wirklich nichts für mich.
Mal noch kurz zur FE: Dieses "Eiern" ist mir bei meiner auch aufgefallen am hinteren Lüfter. Aber nur wenn die Karte in den 0rpm Modus wechselt und der Lüfter sich gerade ausdreht. Wenn der Lüfter schneller läuft kann man nichts mehr davon sehen aber manchmal vibrieren die Finnen leicht bei 60% Geschwindigkeit oder mehr. Scheint mir so, als wenn die Lüfter einfach ein bisschen zu viel Spiel hätten.
@pajonk
Das ist kein Lagergeräusch.
Das Geräusch kommt definitiv von den Lüfterblättern die zu nah an den Kühlfinnen sind und ab einer bestimmten Drehzahl dann Strömungsabrissgeräusche produzieren.
Du kannst das easy Nachstellen indem du einen anderen Lüfter mal nah an ein Gitter bringst.
Guten Morgen,
der Themenersteller hatte darum gebeten, dass man sich hier hilfsbereit und ohne Anfeindungen austauscht und unterstützt.
Leider ist sein Wunsch und auch jegliche Aufforderung seitens der Moderatoren auf taube Ohren gestoßen.
Aus dem Grund wird dieser Thread eine Pause bis 21.11.2022 bekommen.
Das sollte genug Zeit zur Abkühlung sein wo jeder gerne auch mal in sich gehen kann.
Der Ada Lovelace Laberthread bleibt erstmal offen und nutzbar.
Bei ähnlichem Verhalten kann aber auch eine Schließung folgen.
Guten Morgen,
die Pause ist beendet, hier geht es nun wieder weiter.
Es wäre schön wenn der Austausch hier sachlich und hilfsbereit wird so wie es der Threadstarter möchte und wie es auch in unseren Regeln steht.
Ähnliche Themen
Antworten
7K
Aufrufe
540K
