[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Lässt Du das Ding echt die ganze Zeit mit 1.1V laufen?
Oder ist das nur zum testen @renecapo
29° Wasser, 57° die Karte. Das sind 28K Delta. Da würde ich mir doch über Deine 25K gar keine Sorgen machen^^
Immerhin gute 10K weniger als mit auf 100% drehenden Lüfter-Orkan^^
FE vs Tuf
Part 2
Komischerweise verbraucht die FE im Idle nur 6,3W die Tuf 10W.
Wie kann das sein???
Ja, seit Day 1 im System fluppt der Zero-Fan-Modus der KFA.
Lüfter der KFA sind leise im Vergleich zur Gigabyte.
Die Gigabyte Gaming OC hatte neben der Tatsache, dass sie mit höheren RPM startet leider auch ein leichtes Brummen als Unterton.
Dafür kein Spulenfiepen und Spulenrasseln minimal mehr als die KFA.
MediaMarkt und Saturn droppen aktuell scheinbar nur einzelne Karten. Rückgaben der Releasekäufer? Habe heute eine gut genutzte oder besser gesagt "verbrauchte" 4090 als Neuware erhalten, die morgen direkt wieder den Rückweg beschreitet.
Ist bei mir tatsächlich das komplette Gegenteil.
Die Karte wurde mit Sicherheit schon ordentlich durchgenudelt, aber der Zero-Fan-Modus sollte ja trotzdem funktionieren.
Die Lautstärke der Lüfter ist heftig, die Gaming OC war in meinem Fall dagegen flüsterleise.
Kühlleistung ist super, mit angepasster Lüfterkurve kratzt die Karte gerade mal an den 60°C im geschlossenen Gehäuse.
Das der Zero-Fan-Modus überhaupt nicht funktioniert und die Lüfter wie 'ne Boeing 747 klingen geht allerdings garnicht, geht das Spielchen wohl wieder von vorne los. :coffee:
Die Effizienz ist einfach nur noch krank. PUBG 1680x1000 low Settings, 240FPS Limit, 60W und die Lüfter der Karte 0 RPM. :ROFLMAO:
EDIT: ich spiele hier halt seit 30-40 minuten mit 0 RPM ... WTF!
@pajonk
Also mit Ada hab ich zum ersten Mal seit zwei Generationen null Entscheidungsschwierigkeiten gehabt. Die FE hat mich so dermaßen geflasht, dass alles andere nicht mehr nötig war. Wird dir jetzt auch nicht weiterhelfen aber die FE ist schon etwas Besonderes wie ich finde. Die TUF ist aber durchaus auch gelungen, gerade was den Metalframe und die gute Kühlung angeht.
Am Ende des Tages musst du für dich abwägen was geeigneter bzw. besser ist. Auf den ersten Blick deines Posts tendierst du m.E. aber mehr zur TUF.
@pajonk
Am Ende des Tages musst du für dich abwegen was geeigneter bzw. besser ist. Auf den ersten Blick deines Posts tendierst du m.E. aber mehr zur TUF.
War die FE Deine erste Karte?
FE vs Tuf
Part 2
Der VRM der Karten ist anders, die minimale Leistungsaufnahme bei denen der FE ist niedriger als bei der TUF.
Mal bissel OT:
Wollte mal bei Dying Light 2 (Epic Store Version) mit dem neuen DLC die FPS etc auslesen mit dem Afterburner wie immer halt, leider klappt das überhaupt nicht in dem Game, keinerlei Reaktion auf den Shortcut.
Fraps geht auch nicht. Alternativen? 🤔
Ja aber in meiner engeren Auswahl war die TUF, KFA2 und eben die FE. Die TUF hatte ich schon im Warenkorb aber aufgrund diverser coil whine Berichten n Ticken gezögert. Hätte sie vermutlich bekommen aber das Schicksal hat entschieden, dass es dann doch zuerst eine FE wird. Direkt verliebt, geheiratet und glücklich :fresse:
Der Thread hier hat aber echt gut zur Entscheidung beigetragen. Bzgl Lüfter hatte ich etwas bedenken aber die sind Klasse (y)
Horny! Endlich wird das Spiel released, dachte schon, es kommt nicht mehr raus nach über 10 Jahren in der Entwicklung. (y)
Neues Futter für die 4090 incoming. 20fps für die 4k gamer in da hood. (y)
:o
:o
Also wenn die das auf ein Grafiklevel ala Cyberpunk bringen oder RDR2 würde ich das Spiel wohl auch nochmal durchzocken 😍
Alt+R wenn Du das Performance-Overlay im Nvidia-Experience aktiviert hast.
Vielleicht irritiert dich auch der längere Nachlauf der KFA. Sie kühlt runter bis ~33°C und schaltet erst dann in den Zero-Fan-Modus.
Lüfter sind bei meiner KFA ohne Nebengeräusche. Man hört nur den erhöhten Luftstrom.
:o
20 FPS? Aber nicht mit einer 4090...da wird sie wahrscheinlich erst mal so richtig warm!
Das sicher nicht. Ich befürchte eher, dass etwa RT nur irgendwie angeflanscht wird und es dann auch entsprechend eher mau sein wird. :rolleyes2:
Immerhin gibts dann auch noch HDR. (y)
MOAR!
Auf 20fps canst du einen lassen. (y) Lederjacke wird schon dafür sorgen, dass 4k Gamer sich die 5090 holen werden müssen. :o
Ne, nicht installiert, bin selber auf eine Lösung gekommen.
Mit Win+G öffnet sich ja das Xbox Game Menü, dort ist ein FPS Zähler drin.
Hätte ich die FE zuerst gehabt wäre meine ENtscheidung auch leichter. :-)
Zocke gerade uncharted. Das einzige was ich höre ist die FE. Von der tuf hatte ich nichts gehört.
Die Lüfter laufen auf 42 und 39%. Hörst Du die Karte da auch gut?
Ist schon ein nerviges Brummen. Wenn das nicht wäre würde ich zur FE tendieren...
Ich habe das "Problem" gefunden. Der Zero-Fan-Modus wird nicht nur durch die Temperatur, sondern auch durch den Idle Verbrauch gesteuert.
Da ich Wallpaper Engine laufen hatte und somit der Idle Verbrauch höher war wurde der Modus nicht getriggert.
Ich gehe bei der Lautstärke der Lüfter einfach von einem Montagsmodell aus, kann so keinesfalls in Ordnung sein. Sehr, sehr schade, mir gefällt die Karte eigentlich sehr. :shake:
Auf Auto? Wenn ja kann ich mir das ehrlich gesagt nicht vorstellen. Was für n Gehäuse hast du?
Mit einer MSI Trio mit 140mm Tiefe? Das Gehäuse hat eine maximale CPU-Kühlerhöhe von 190mm. Damit ist das ein Gehäuse mit einem der höchsten Clearances überhaupt. Damit hättest du also 5cm Platz für die Biegung, was mehr als ausreichen sollte. Foto?
Ich habe die Gaming oc.
Maße: 340 x 150,2 x 75,2 mm (L x B x H)
Edit: wurde schon beantwortet.
Also aus meinem Gehäuse nehme ich die Karte sogut wie nicht wahr obwohl oben nur ein statt zwei Lüfter drinnen sitzen. Minimales Surren der Spulen in seltenen Situationen. Die Lüfter drehen bei mir kaum auf (oft nur 30%) vor allem seit dem halben UV von 0.95V. Sie sind auch sehr laufruhig und die unterschiedlichen Drehzahlen zwischen beiden Lüftern verhindern sägende Geräusche vorbildlich. Habe ich in dieser Form in der Vergangenheit selten erlebt!
Nein, mit angepasster Lüfterkurve. Die Gaming OC war mit der gleichen Kurve deutlich leiser. Ich habe das O11 Dynamic, Karte ist vertikal verbaut.
Lass die doch Mal auf Auto arbeiten. Denke nicht, dass du das mit einem anderen Hersteller und den selben Werten vergleichen solltest. Was strebst du damit an? Die selben Temps? Wenn angepasste Lüfterkurve, dann auf diese Grafikkarte!
:o
Jau auf das Update hab ich gewartet. Hab Witcher noch nie gespielt.
neues zur 4080
hier auch der sweetspot bzgl PL
Ich glaube ich versuche mal meine TUF bei Computeruniverse umzutauschen. Das Spulenfiepen kann schon sehr extrem sein:
Bei RDR2 mit FSR 2.1 und ca. 120-220FPS auf jeden Fall am stärksten zu hören.
Kannst du dir sparen. Die Ersatz TUF wird mit ziemlich hoher Wahrscheinlichkeit genau so fiepen.
Ähnliche Themen
Antworten
7K
Aufrufe
540K
