[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
beste skalierung geht wohl ueber kaelte hier auch.
die FE ist nicht modbar, kein modbios und kein voltmod (ohne hw bruteforce hack um das passwort zu knacken (hat nur einer mit der 3090 gemacht)
3330mhz bei -35c und 1.1v
Hier ein Bild von meinem Kumpel, hat das gleiche Kabel wie ich bestellt, um den Nvida Adapter nicht nehmen zu müssen...
Er hat ne Asus Tuf OC, und guckt euch mal das Kabel an... Fängt an, leichte Hitze-Donuts auf dem Stecker zu bilden, oder was soll das sein???
Ich checke mein Kabel auch gleich...
Die schwarzen Punkte sind die Anspritzpunkte der Spritzgussform.
Welche Alternativen zum 4 fach Nvidia Adapter Monster gibt es zur Zeit eigentlich so, sprich universell für jedes Netzteil?
Cablemod ist mir bekannt und natürlich die Hersteller eigenen Sachen wie von Be Quiet, aber sonst noch?
"DONUTS" stammem von der Spritzguss Maschine :p
Ich danke euch erstmal für das Feedback! Ja, das hatte ich auch schon im Verdacht! Aber dennoch waren die "Donuts" oder Punkte am Anfang nicht so deutlich zu erkennen...
Zum Beispiel den Adapter Amazon
Wenn jemand viel geld hat bedeutet das im umkehrschluss, dass dafür viele andere zu wenig bekommen haben.
Man liest hier ja echt viel Quatsch den Tag über. Aber diese Aussage schießt echt mal wieder den Vogel ab. Sowas musst du im Suff geschrieben haben hoffe ich.
Es gibt einige Noname Adapter bei Amazon und Aliexpress. Der Stecker und der Adapter an sich ist ja nicht neu. Wirklich Marke gibt es aktuell eher wenig.
Das hat aber nichts damit zu tun das eventuell das Kabel einen Defekt hat. Man sollte das Thema nicht schlimmer betrachten als es ist :)
Ich hab das Video jetzt nur überflogen, was ich dabei verstanden habe ist, dass nVidia im Falle von verschmorten GPU-Anschlüssen bei Verwendung von Drittanbieter Adapterkabel wahrscheinlich die Garantieleistung verweigern wird. Right?
Noch mal, es ist derzeit grob fahrlässig andere Kabel bzw. Adapter zu nutzen als den beigelegten Nvidia Adapter (der Adapter als solcher war und ist nie das Problem gewesen) oder als einzige Alternative die von den Netzteilherstellern für ihre Netzteile angebotenen optionalen Kabel, freigegeben für ihre jeweiligen Modelle. Wer eine 600 Watt Karte hat und den Adapter nutzt, bitte auch alle vier Anschlüsse am Adapter belegen, auch wenn er die 600 Watt nicht nutzt, alle anderen eben drei. Mir fehlen hier schlicht die Worte, dass die Leute diese auf Amazon und Co. angebotenen China Dinger einfach so verbauen bzw. vertrauen und meinen jetzt könnte das Problem nicht mehr auftauchen, unglaublich was hier abgeht, auf den Adapter schimpfen und dann so ein Zeug verbauen.
Ich wollte mir auch den 90° Adapter holen, bleibe aber wohl erstmal beim mitgelieferten Adapter und warte ab, ob nvidia dazu noch Stellung nehmen wird.
Habe letztens aus Neugier mal, nach einer mehrstündigen Gaming Session, nachgeschaut und mal ans Adapterende gepackt und rausgezogen. Super kühl und alles wie Day One, und das trotz starker Beugung im Meshify 2 Compact.
Verstehe immer noch nicht, wie diese Brandgeschichte zu Stande kommen kann. Scheint in meinen Augen bisher total willkürlich abzulaufen.
Leute Leute. Macht euch doch nicht so einen Kopf. Immer dann wenn dieses Thema wieder von unseren Panikmachern erwähnt wird, brauch jeder eine Alternative. Nutzt doch einfach was dabei ist und gut. Oder besorgt euch das direkte Kabel vom NT Hersteller sofern es eins gibt.
Ich habe bis vor 3 Tagen noch den Adapter benutzt und nutze jetzt das BQ Kabel. Weder BQ Kabel noch Adapter haben irgendwelche Defekte gezeigt.
Es hat schon einen Grund warum man nicht mehr viel liest von dieser Sache. Das muss ja immer wieder mal erwähnt werden, man könnte es ja vergessen.
Richtig so, denn wenn die Adapter ein Problem wären, hätte Nvidia den Verkauf schon längst gestoppt, die FE's werden fröhlich weiter verkauft, denn der Wahnsinn läuft ja jetzt schon Wochen. Asus verkauft weiter mit den original Nvidia Adaptern, eigentlich alle bis auf ich glaube ein Hersteller der prüfen wollte - hier sollte sich jeder mal die einfache Frage stellen, warum!
Wie denn? Das Teil gibt es immer noch nicht zum bestellen…
Aus den FAQ von CableMod:
„Once you’ve signed up, we will send you an email as soon as the adapters are available for purchase. The email you receive will have the purchase link inside, and using the email you signed up with, you’ll be able to purchase the adapter(s) you want. We expect this to happen in roughly 4-6 weeks.“
Keine Schwein weiß wann die ihre Adapter nun tatsächlich releasen, ich gehe zur Zeit von Mitte Dezember aus und dann kommt ja noch die Lieferung von 2-4 Wochen hinzu nach Deutschland. 2023 it is.
Mir geht es eher um den optischen Aspekt, sieht halt furchtbar aus das Adaptermonster 😏
Und von Seasonic gibts für mein Netzteil gar nichts, jedenfalls nichts zum bestellen.
Ein 90 Grad Kabel haben sie ja auch angekündigt, da warte ich jetzt erst mal drauf.
Der 90 grad Adapter würde nichts ändern wenn es am Kabel selbst liegt. Von Nvidia kommt da vermutlich nichts oder sehr wenig. Nvidia ist nicht das Problem. Der Hersteller der das Kabel schlecht produziert hat ist es.
Aber es ist einfacher die schuld bei Nvidia zu suchen.
Grüße, also es wurde ja schon erwähnt, dass die Punkte auf dem Kabel wohl von der Produktion stammen (China Ding-Kabel).
Ich vertraue dem Kabel genauso viel/wenig wie dem beiliegenden Nvidia Adapter, da beide aus China kommen! Ja, auch der "originale" Nvidia Adapter ist ein China Ding!
Dennoch wirkt für mich das "gecrimpte" China Amazon Kabel wertiger als der Nvidia Adapter...
Ich habe auch ein Seasonic Original Kabel geordert, ebenso eins von Cablemod. Bis eines von Beiden ankommt, wird das schon gehen. Btw hab ich ein Seasonic PX-850 Netzteil, Single Rail, da ist es egal ob ich 4 oder 2 Kabel rein Stecke für die Karte
Meine Folgt am Dienstag, ich warte noch auf gute wärmeleitpads 😁
Willst du damit etwa sagen das bei dem Block der über 250€ kostet keine guten Wärmeleitpads dabei sind ? Dann spart man besser 100€ und nimmt ALC.
So ist es. Das ist bei allen Produkten so die gegossen werden. Und es ist auch normal das die sichtbarer werden mit der Zeit :)
Übrigens: wir Kabel im Jahr 2022 und da passt China Billig Ding nichtmehr. Es kommt vieles aus Billig China.
Willst du damit etwa sagen das bei dem Block der fast über 250€ kostet keine guten Wärmeleitpads dabei sind ? Dann spart man besser 100€ und nimmt ALC.
Richtig gute Wärmeleitpads sind eigentlich nie bei einem wb dabei. 😂. Die von Phanteks fühlen sich an wie ein gummiband 😂. Aber eins muss man Phanteks lassen…. Die verwenden auf den rams 0,5er pads, das ist schon gut
Mir geht es hier nicht um eine Schuldfrage, sondern wie es im Falle eines Brandes mit der Garantie ausschaut und da ist nvidia halt für zuständig.
Das ist ein komplett anderes Thema. Aber selbst hier wird Nvidia den Schaden beim Kabelhersteller einfordern. Davon bekommst du aber wenig bis nichts mit. Du bekommst vom Händler dein Geld oder eine neue Karte und gut ist.
Ich habe meistens bisher ALC Blöcke gehabt und die Pads waren immer gut für mein Empfinden. Probleme hatte ich mal mit Bykski, aber diese Blöche nehme ich sowieso nicht mehr.
Meint ihr Nvidia passt bei aktuell steigendem €:$ Kurs die Preise eventuell zeitnah an? Asus macht seine Top Modelle ja bereits billiger (nur unter 1950€ dürfen die denke ich einfach aktuell nicht gehen) und AMD hat Erfahrungsgemäß (bei RDNA2) die Karten ständig dem Kurs aktuell gehalten und so sollte eine 7900XTX bereits für aktuell 1150€ erhältlich sein.....
Edit: Wenn ich bedenke das 3090 MSRP 1499$ Dollar war und wir damals die FE für 1499€ bekommen haben..... Eine 4090 für 1500€ junge das wäre was gewesen :d
Ähnliche Themen
Antworten
7K
Aufrufe
467K
