[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
trio wird 10 grad wärmer aufm chip als die suprim
allerdings dreht die trio auch langsamer.. strange :fresse:
asus 4090 tuf und strix im outlet store bei alternate :)
Was bedeutet Outlet Rückläufer ?
Über 200€ mehr als im Asus Shop meine :fresse:
5900x -> 5800x3D
Bericht 1
So habe heute umgerüstet.
Vorteile:
1. Nur 8 Kerne im OSD :-)
2. Nur 8 Kerne per CO einzustellen. Laufen bis jetzt alle auf -30
3. PBO auf 105 71 125 gesetzt
4. Cpu verbraucht weniger Strom als der 5900x beim zocken
5. Plague requiem bricht auf dem Marktplatz nicht mehr in den Framerate so ein wie vorher
6. Weniger Temperatur im Rechner
7. Cpu vorher ca. 110W in Plague jetzt ca. 70W.
Weitere Endrücke folgen.
5900x -> 5800x3D
Bericht 1
Vorteile:
aber hier ist die RTX 4090 das Thema, falscher thread
5900x -> 5800x3D
Bericht 1
Vorteile:
Hey, bin auch grad fertig geworden umzug auf 5950X -> 5800x3d und neues torrent case ;)
fehlt noch die 4090
Nvidia hat die 4090 echt zu stark gemacht, wenn es nichts zu berichten gibt außer Diskussionen über diesen blöden Adapter. Was für ein langweiliges Stück Hardware :d
Solches Verständnis verwundert mich doch etwas, da es hier um ein sicherheitsrelevantes Thema geht (Adapter schmilzt -> Brandgefahr). Bei solchen Fertigungs-Toleranz-Fehlern im Bereich von "kann Brand auslösen" gibt es kein "kann mal vorkommen", sondern "PRODUKTE MÜSSEN OHNE SCHULDHAFTES ZÖGERN (d.h. so schnell wie möglich) ZURÜCKGERUFEN BZW. UMGETAUSCHT WERDEN".
Das stimmt. Doch sind es Einzelfälle und es konnte bisher noch nicht nachgewiesen werden, das es sich um einen Serienfehler handelt. Vor allem weil es auch mehrere Hersteller betrifft.
Außerdem von einem Brand ist hier nirgends die Rede. Durch einen schlechten Kontakt gibt es eine erhöhte Temperatur, mehr nicht. Auch wenn das komplette Plastik wegschmilzt sollten die Kontakte und damit die Ströme immernoch von einander getrennt sein.
Es ist KEIN Kurzschluss von 12V zu Masse wie bei NZXT. Das ist eine ganz andere Hausnummer.
5900x -> 5800x3D
Bericht 1
Vorteile:
Mein Bericht kommt morgen, wenn ich gleichzeitig die 4090FE einbaue.
Frage: Ich konnte meinen 5950X nur maximal mit CO -10 einstellen, geht -30 ganz einfach ohne Probleme beim 5800X3D?
Wir wissen es ist zumindest nur sehr schwer reproduzierbar, selbst mit teilweise extremen Mitteln. Sollte es ein sporadischer Defekt sein ist aus unserer aktuellen Position unmöglich auszuloten wie viele betroffen sind.
Genau das ist vermutlich das Problem...
Und sollte es ein Produktionsfehler/Toleranzfehler sein, so kann NVIDIA auch tausend Adapter zur Weißglut treiben - wenn da keiner der betroffenen drunter ist, werden deren Ingenieure nur sagen "wir können keinen Fehler feststellen".
Erstmal müssen die herausfinden, welche Chargen betroffen sind (soweit überhaupt alle Adapter aus derselben Fabrik kommen - wenn es da mehrere / mehrere Hersteller gibt, ist das Problem direkt mal zichfach problematischer). Erst dann macht testen einen Sinn... nur wie testen mit Chargen, die schon verschickt wurden. Es kann durchaus sein, dass die neuen Chargen nicht betroffen sind, und von den alten ist keine mehr auf Lager zum testen. Deshalb waren die vermutlich auch so scharf drauf, die defekten Adapter zu bekommen^^
Mal ganz abgesehen von dem Problem, dass hier scheinbar auch native Kabel betroffen sind.
Kennt jemand ein paar Games oder Techdemos wie Matrix UE5, welche die Karte ans Limit bringt?
Die 4090 ist so massiv overpowered, die langweilt sich 😅
gta5, rdr2. skalierung auf 200% und die karte sagt adios
ich finds gerade gut dass die karte zu stark ist. ich will sie gar nicht voll nutzen. das ist doch der sinn dahinter :) dann ist ruhe im karton
skyrim mit 16k textures und drölfzich mods
RDR2 4K, Max, mit DLSS langweilt sich die Karte, alternativ DLSS deaktiviert und 8xAA..
Man merkt trotzdem das Game ist in die Jahre gekommen. Gibt es nichts aktuelleres?
naja was willst du denn erreichen?. spiele mit guter grafik gibts genug. aber gute spiele und gute grafik? ....
Bin gerade einfach unentschlossen, mit welchem Game ich demnächst anfangen soll..
Denke das liegt eher am neuen Patch von heute der einige Stellen optimiert hat, vor allem eben den Marktplatz laut Steam Forum.
In welcher Auflösung zockst du?
Ne, den Patch habe ich noch nicht drauf.
Zocke 4k maxed out 120hz VSYNC GSYNC und Framegeneration.
So wie ich gelesen habe machen das die meisten. Der soll angeblich gut gebinned sein. Denke eher es liegt daran, dass er nur bis 4.5 GHZ boostet. Besorg Dir auf jden Fall das hier:
FAlls jemand eine Perle mit HAmmer Grafik zocken will die auch noch die 4090 in die Knie zwingt...
Quantum Break
Cyberpunk maxed auf mit Raytracing Psycho in 4K ohne DLSS, Versuch mal 45 FPS zu erreichen. Go! 😏
Und wenn du es aktueller willst:
Plague Requiem, dreh alles auf in 4K, meine Karte geht hier dann sogar auf 68 Grad.
Auch schön:
The Ascent in 4K, ohne DLSS, mehr als 65Fps wirst du selten sehen, tolle Raytracing Effekte.
5900x -> 5800x3D
Bericht 1
Vorteile:
Wie hast du auf Stabilität getestet bei -30?
Für 4k ist es eben immer noch zu früh. (y)
RIP EVGA :cry:
Rainforest, UE5 Engine mit Raytracing, maxed out in UHD und du denkst du hast ne 3070! ;)
Direkt zum Downaload:
Gabs nicht irgendwo eine kostenlose Demo?
Na toll: Meine Zotac angeschlossen, aktuellen Treiber installiert und festgestellt, dass seit der Treiberinstallation die Lüfter dauerhaft aus sind. Auch bei über 80°C. Da scheint mit dem Treiber noch was nicht zu stimmen oder ich habe die passenden Einstellungen noch nicht gefunden.
Aber schön leise ist es so ohne Lüfter.:fresse2:
Oder ob vielleicht sogar nur eine kleine Gruppe mit einem Kabel das Thema pushen will weil es zu wenig Beachtung bekommt und immer das Kabel weiter gibt? Möglich ist im Netz alles.
Gogo Gadget O Tinfoil
du hast den pc schon neu gestartet oder?^^
Ein Schnapper. Aber Fake. Wie kann man sowas eigentlich melden? ^^
5900x -> 5800x3D
Bericht 1
Vorteile:
Wieviel FPS hast du jetzt aufn Marktplatz in Plague, bzw in Plague allgemein im Durchschnitt?
Ähnliche Themen
