[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Wow wurde gar nicht vom bot erkannt oder?
Doch. Deswegen habe ich sie auch gekauft.
Ja merke gerade der push geht bei mir am Handy net mehr 😅
Hier mal meine Erfahrungen zu meiner 4090 FE im Vergleich Luftgekühlt vs WaKü.
Coretemps delta Luft bei 450W ca. 40Grad bei UV 300W ca. 25-30Grad
Coretemps delta WakÜ bei 450W ca. 18Grad bei UV 300W ca. 13-15Grad
Core OC Clock Luft +140 mit Wakü bis +235
RAM OC Clock Luft gingen bei mir +1000, mit Wakü bis +1800
235 ? 140 ? ... vertippt oder? ;-)
Leider glaube ich nicht das die Ergebnisse stimmen ... bzw. 210 oder 225 oder 240 wären auch unter Luft gegangen.
Beim RAM wären vermutlich auch ~ +1500-1700 gegangen außer es gab ein Problem bei den Wärmeleitpads zuvor.
Sind leider nicht ganz reale Angaben .... Zumindest hast du Speed Way damals mit 3030MHz laufen lassen jetzt mit 3045 ... da passt das nicht mit 140 Luft / 235 Wasser nicht ganz zusammen.
Machts halt leider auch irgendwie unglaubwürdig wenn es keine 15'er Schritte sind.
Hat eigentlich jemand mal nen wirklich Vorteil gehabt zwischen die 15MHz Schritte zu gehen?
Mal eine Frage in die Runde: Wie hoch ist die Default Spannung bei euch?
1) meint ihr es reicht mein 750 W 80 Plus platinum Netzteil mit 3x 8 PIN?
Es wird ja min. 850W empfohlen, aber mit meiner 65W CPU reicht es denke ich easy, da ich mit 3x 8 PIN max. 450W habe. 100 W mehr als aktuell mit meiner 3080 ti.
5600X
2x 16 GB DDR4
9x Lüfter 900-1200 RPM phanteks t30
1x Pumpe D5 EK
1x SSD SATA
1x NVMe 4.0
2) Ist es immer noch so, dass bei 4K gaming die CPU egal ist?
1) Mit dem 5600X definitiv. 750W ist kein Problem.
Lüfter sind max 1,5-2W/Stück, Pumpe vielleicht bis 20W oder so. Sata und NVME ca 5-10W Stück. RAM ca 15W. Wären ca 75W zusammen.
CPU hat ca 90W +50W Spikes zur Sicherheit einrechnen. Also sind beim Netzteil noch 510W über für die GPU. Man sollte da eigentlich nochmal 100W für GPU-Spikes einrechnen, wären 40W zu wenig... :d
Aber das ist natürlich wenn alles am Anschlag läuft UND CPU+GPU gleichzeitig spiken...die Warscheinlichkeit ist fast 0.
Außerdem können gute 750W Netzteile locker bis 850-900W liefern.
Ich würde nur kein OC empfehlen :d
2) Mit einer 4090 wird die Leistung die man braucht um Limits zu erreichen höher.
Der 5600X erreicht immer noch GPU-Limits in ein paar Spielen, aber nicht mehr in allen.
Selbst ein 13900k kommt manchmal ins GPU-Limit.
P.S. AMD CPUs immer TDP mal 1.35. Das ist dann das Powerlimit das beinahe überall eingestellt ist.
Und ich werde meine 4090 auch mit einem 750W Netzteil betreiben, aber mit einem 5800X3D. Dafür nur 6 Lüfter, aber je 2 NVME und Satas.
Ich geh kaputt, erst heute morgen den Ticker deaktiviert, da ich seit fast 1 Monat nichts mehr vom Asus Store gesehen habe.
Und dann kommt heute Nachmittag etwas, dass Universum gönnt mir keine TUF zur UVP 😂
Und ich glotz den ganzen Tag drauf und während -> 5 min im Bad <- bin, droppt die TUF :cry:
Braucht DLSS sehr viel/so viel CPU-Leistung?
Ich habe mich gerade um einen Heul-Thread in zwei anderen Foren gekümmert. Der TE erzählt weinend, dass er seine 4090 in FC6 nicht ausgelastet bekommen in 2560x1140p und Ultra Settings.
Und später erzählte er was von Metro Exodus.
Ich hab das übliche erzählt: Wer seine Graka nicht ausgelastet bekommt, der hat das Gesicht seines Vaters vergessen (die Regler).
Ja, der User hat recht, in 2560x1440 in Metro Exodus langweilt sich die Graka im CPU-Limit mit DLSS.
ABER sobald ich DLSS abschalte ...... geht nicht nur die Auslastung hoch, sondern auch die FPS. Und zwar gewalig. Fast 40% mehr FPS wie mit angeschaltetem DLSS.
Und jetzt die Frage an euch: Kostet DLSS tatsächlich SO VIEL CPU-Leistung?
Metro Exodus. Taiga-Level 1. Bild nach Intro-Sequenz. 2560x1440p Ultra-Settings. DLSS AN
DLSS AUS
DLSS AUS
strange. kann das gerne mal in anderen games testen aber ich glaube dass das nicht so ist. bin aber net sicher
war cb sicher? da wird einem ja auch schon seit jahren erzählt das 4k die cpu egal ist. dann kaufen die leute anhand dieser "infos" auch entsprechend und nun geht das geheule los
ich finds lustig xD
Die Verfügbarkeit scheint ja immer besser zu werden bei der 4090. Bin gespannt ob überhaupt jemand in Deutschland die 4080 kauft. Die macht nicht wirklich soviel Sinn, oder?
wenn die mehrleistung zu gering ist und der preis viel zu hoch dann ist das ein rohrkrepierer. amd kann hier jetzt marktanteile gewinnen wenn sie es ordentlich anstellen
Ich dachte mit der Agesa Version wäre PBO und CO möglich?
Ght das nicht? Muss man da die Software PBO Tuner nehmen?
Doof.
Bei mir ist PBO erst gar nicht verfügbar im BIOS mit dem X3D. CO ja, aber nur negativer Offset.
Hab den aber auch erst seit Freitag, soweit bin ich damit noch nicht wirklich.
Ähnliche Themen
