[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ok.. Danke für das Teilen. Habe mal reingeschaut.. hab wieder zurückgestellt erstmal. Wenn das FrameGeneration an ist, fühlt es sich beim ansehen zwar schneller an, aber die Bild-Fehler sind für mich deutlich sichtbar. Überall leichtes Flackern bei Zäunen. Obwohl ich Vsync nicht an habe und unter 120 Hz bin, hab ich im Oberen Bildschirmbereich teilweise so eine Art Bild-zerreissen. Wenn ich mit dem Caliburn rumfahre und seitlich draufschaue.. Je nach Blickwinkel, gehen die Felgen.. übelst ab mit Fehlern und Ghosting. Das hab ich auch sehr oft beim drehen. Besonders bei dünnen Linien oder Zäunen. Bei der Jig Jig Street, sind die 30FPS mehr zwar schön, aber trotzdem seh ich das Microruckeln durch das CPU Limit (I7 8700k). Vielleicht bin ich auch zu empfindlich. DLSS auf Quality reicht mir.. das FrameGeneration ist irgendwie nichts für mich bei Cyberpunk. Mal sehen, vllt mit dem Update, wenn Raytracing aufgebohrt wird.
Dann opfert man die Qualität durch neue schönere Features.. :)
Hatte CP 2077 auch getestet und DLSS Performance waren bis 120 FPS und Quality irgendwo über 80 FPS in UHD mit RT und den ganzen kram.
Wenn man das vorher mit den Einstellungen mit einer 3090 durchgezockt hat ist man ganz zufrieden mit der Leistung die durch die 4090 zur verfügung steht.
Denke eh in den nächsten Monaten wird Treiberseitig noch einiges verbessert .
Was man aktuell mit der 4090 an Leistung hat kann man wirklich nicht meckern.
Also ich kann am Dienstag eine 4090 FE abholen (EKA); war vermutlich dein Verkäufer, der eine Abholung vor Versand bevorzugt :d
P.S. Der hat nicht zufällig auch einen BeQuiet Adapter mit angeboten? ^^
2 Probleme:
526.61 Black screens in Windows (HDMI LG C2)
Da hat doch schon mal wer was geschrieben?
UPDATE:
Bin doof -> man muss ja die Exe direkt starten und nicht über Steam…RTFM
DLSS Frame Generation in Cyberpunk
Ich kann DLSS nicht aktivieren mit dem Press Build? HAGS on und off probiert…?!
Habe auch den LG C2 und den aktuellen Treiber. Bei mir waren die "Probleme" nach dem TV Update weg. Nutze ein HDMI 2.1 Kabel.
ich glaub du hast den falschen zitiert eben. :)
Wenn ich das richtig sehe, nach wie vor keine FE? Oder gibt's davon einfach zu wenige in freier Wildbahn? :d
Berechtigte Frage ... is wirklich auffällig bisher das da nich eine FE bei ist ... wir hatten das damals ja schon angesprochen wo ich dann noch scherzhaft meinte
das Nvidia seit jahren ja schon versucht den Costums das Wasser abzugraben und nun absichtlich den Partnern Faulty Adapter zuschustert .. is natürlich nur ein scherz meinerseitz.
Aber ja .. is dennoch auffällig das da bisher keine FE bei is.
<-- hat seine TUF jetzt mal übers verlängerte WE falten lassen.
3 Tage lang 24/7 ...
Die Graka, die Stecker und ich leben noch.
Außerdem hat das Spulengeräusch nachgelassen.
Dann kann der Wasserkühler ja kommen.
Aber jetzt die Frage, wenn ich das Kabel jetzt nach unten gebogen haben möchte (weil da jetzt Platz ist) und nicht mehr oben rüber (weil es vorher kaum anders ging) ..... zerstöre ich beim Biegen um 180° nicht gleich das Kabel? Ob ich mir nicht sofort ein weiteres bestellen sollte? Oder den Gedanken lieber gleich ganz fallen lassen?
I'm walking down the streets of paranoia *sing*
Ja, und es tritt genau erst jetzt mit 526.61 auf?! Aber irgendwer hatte es anscheinend ja schon letzte Woche vor diesem Treiber Update. Komisch…ich teste mal 526.47 erneut.
VRAM oced?
Wir hatten das damals ja schon angesprochen wo ich dann noch scherzhaft meinte
Wow. Dir ist für deine Panikmache hier echt jedes Mittel recht scheinbar. Das wird immer wilder was du Orakelst. Kann man bald nichtmehr lesen.
Und die Customs mit Refernz PCB wurden verschont oder was?
Denk drann du wurdest schonmal hier Gestern verwarnt und hast die Gelbe Karte von dem Mod bekommen wegen deinem Verhalten anderer User gegenüber hier im Luxx
Hier geht es 0 um Panik mache ( das schrieb ich dir schon mehrmals weil du mir schon mehrmals Panikmache vorgeworfen hast ... übrigens als einzigster )
sondern hier gehts um eine normale Fall zählung die ja auch auf Reddit gemacht wird ( Heute nun Fall Nr 25 von verschmorten Power Adaptern )
Und das mit dem Absichtlich Faulty Adapter unterjubeln war ein scherz von mir wie auch in meinem Beitrag geschrieben ( interessanterweise hast du das natürlich absichtlich weggelassen
was du da von mir Zitiert hast .. naja wobei zumindest den ersten hinweiss das es ein scherz is hast du ja drinn gelassen ) ... der Rest passiert nur in deinem Kopf.
Und ausserdem warum sollte ich da ne Panik Mache durchziehen wenn ich doch selbst ne 4090 Strix haben will ??
Also nimm dir die Berichterstattung der verschmorten Power Adaptern nich so zu Herzen und lass die Leute halt einfach darüber berichten.
Wenn du bei Gelegenheit mir die Software Version sagst, dann wär ich dankbar.
Meine war 3.95.20 (auf jedenfall die 3 zahlen…Reihenfolge weiß ich grad nicht mehr…pc ist schon aus).
Mit 522.25 und 526.47 hatte ich das jedenfalls nicht.
Eventuell hätte sich das Problem durch einen power cycle am TV und am PC gelöst…bleibe erstmal bei 526.47
Ja, aber lief so ja auch die letzten Tage/Wochen.
Werde mal sehen ob mit dem 526.47 beim gleichen OC auch nochmal black screen in Windows sind…sonst ist es wohl echt so ein Treiber Ding das da rum spinnt.
Erhöhe den VRAMoc und check ob die sich black screens dann häufen. Versuch gleich +2000.
Hat hier jemand aktuell seinen 5950x oder 5900x mit einem 5800x3d getauscht? Macht es sinn. Google seit tagen und finde immer unterschiedliche aussagen.
Alle die hier eine RTX 4090 am laufen haben, mit welchen Netzteil hab ihr eure RTX 4090 am laufen? Und läuft alles in Ordnung mit den 12VHPWR Kabel ohne anbrennen etc.?
Straight power 11 850w. Nvidia adapter. Alles tutti.
Dann solltest du auch vssync einschalten! Wie kommen einige darauf es auszuschalten? Vsync gehört mit gsync zusammen.
Ich habe das gemacht. 5950X auf 5800X3D zum Release vom X3D. Ich merke ehrlich gesagt nicht wirklich einen Unterschied. In 4K 120Hz ist man dann doch immer noch recht selten CPU limitiert. Kommt denke ich aufs Spiel an. Bei Escape from Tarkov oder Hell Let Loose könnte das Upgrade was bringen. Aber in den meisten Games eigentlich nicht, zumindest in 4K.
Was kein Wunder ist, denn die Leute bewerten das ja aus ihrer Sicht. Mit ihrem Softwaremix, ihren Settings und ihren Ansichten gegenüber FPS. Das muss Deinen Softwaremix/Settings/Ansichten über FPS ja nicht mal tangieren was die da "beobachtet" haben.
Dachte da jetzt an cpu limitierte spiele wo man keine 120fps erreicht. Spiderman, farcry z.b. oder plague of requiem markplatzszene. Und wie sieht es nit low fps aus? Weniger einbrüche?
Ja, Plague ist echt Krass. Marktplatz Szene nur 60FPS mit der 4090 und meinem Ryzen 3700X ;)
Aber die Frage ist, 5800x3D, oder lieber auf 7800X3D warten ^^
Meiner liegt seit gestern auf'n Tisch. Hatte noch keine Zeit aber bin sehr gespannt auf New World, Star Citizen und alle andere CPU limitierten Games.
tjoa..
diese 580W täten mich interessieren
Da fehlt mir mittlerweile der direkte Vergleich ein bisschen. Der Tausch ist ein halbes Jahr her. Habe den Eindruck mit dem X3D läuft alles ein bisschen stabiler aber einen großen Unterschied merke ich jetzt in meinen Games nicht
Ähnliche Themen
Antworten
6K
Aufrufe
392K
