[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Leute beruhigt euch :d
Hab übrigens noch keine Stornomail von NBB, nur im Account steht storniert.
Achja, Alternate verkauft B-Ware exakt zum Normalpreis. Gibt noch ein paar Zotacs ;)
Woher weißt Du das es B-Ware ist ?
Habe gerade eine Zotac OC gekauft.
Das Geheule und Beleidige kommt doch meist eh nur von irgendwelchen Boomern die einfach zu langsam sind und deshalb noch keine Karte haben. Da ist der Frust natürlich hoch wenn man beim Drop erst mal seine Hornbrille aufsetzen muss und anschließend am Fettfingern ist und dann den Kaufabschluss versemmelt. Sehts ihnen nach.
Hey! Ich sehe mich nicht als Scalper.
Scalper kaufen andere Leuten gezielt Produkte weg. Ich habe nicht versucht eine 4090 FE bei NBB zu kaufen.
Mein Kumpel, der die TUF OC haben wollte, hat bei Alza eine Gainward Phantom GS für 2039 € bestellt. Angeblich sollte sie gestern versendet werden und stattdessen steht da jetzt "Verfügbarkeit hat sich geändert". Laut tel. Auskunft soll sie jetzt morgen versendet werden. Ich denke, er wird nur hingehalten - typische Masche halt.
Ich hatte zwei TUF Karten! Eine für 1.949 und eine für 2.299 € - habe die bessere behalten und die etwas schlechtere zum Preis der anderen teureren veräußert. Eine einmalige Aktion und der Käufer hat es mir gegönnt.
Am Ende habe ich 1.999 € für 4090 TUF geblecht und er 2.249 €, da ich mangels Käufer 50 € runtergegangen bin.
Wer mich jetzt als Scalper für diese einmalige Aktion bezeichnet, hat einen Dachschaden und fertig.
Für mich ist das auch weit weg von Scalping.
Weiter hast du es hier im Forum angeboten mit Transparenter Beschreibung.
Du hättest die Karte sicherlich für mehr Geld auf EBK wegbekommen.
Stattdessen hast du es hier ins Forum gestellt.
Ich finds daher eher sogar gut so!
Und am Ende muss es keiner kaufen :) wer nicht will.
Keep cool :)
Finde die Doppelmoral hier so wunderschön. Wenn man dem Miner was abknöpfen konnte und von 3060ti zu 3090 gekommen ist war alles in Ordnung. Wenn man nun selbst in der Problematik steckt sind alle asozial (gilt nicht für alle, aber viele). Deswegen sollte man halt einfach dazu stehen. Ich hab bei Ampere auch ein zwei Karten abgedrückt und stehe dazu ;)
Welches Spiel ist gemeint, was besser aussieht als Cyberpunk? 😁
Witcher 1 mit Laserpistolen
EKWB block + active backplate am 10/25 bestellt, heute versandt worden.
teuerster block den ich mir jemals gekauft habe, 436$ :bigok:
active Backplate kann man sich getrost sparen, meine VRam Temps erreichen gerade mal max. 60Grad beim EKWB Block.
ich hab die schon vorher nicht richtig verstanden mit der 3090 :) dort hatte ich auch max 62 64 im gaming und 82 im Testmining.
Die normale 3090 hatte einen Teil des Vram Speichers auf der Rückseite, da hat es schon Sinn gemacht, erst bei der 3090ti viel der Speicher auf der Rückseite weg.
Ich ahne böses bei Alternate : "Der Rechnungsbetrag wurde noch nicht vom Zahlungsdienstleister überwiesen."
Per Paypal bezahlt, wie immer (Keine Finanzierung oder ähnliches)
So sieht die Verpackung bei meiner FE aus... irgendwer hatte da nochmal nachgefragt zwecks Umkarton usw... biddeschö
PS: Das iPhone gab's nicht dazu, das dient hier lediglich dem Datenchutz... Wasserflasche 4 Scale
Hatte bei der 3090 max. 74°C Vram Temp mit passiver Backplate @ Watercool Heatkiller V .
Aktive Kühlung war da auch nicht notwendig.
Hätte alledings jetzt hier mit weniger Vram Temps mit dem EKWB Block geschätzt als 60°C
Hab im Gaming bisher max. 66°C Vram Temps gehabt mit der TUF OC .
Wakü bringt es diese Generation immer weniger , weil meine Spulenrasseln hat man trotzdem.
Da muss man auch dafür sorgen das man aus dem Case heraus nichts hört.
Hatte heute 2 x eine im Warenkorb. Bei der ersten ging die Bezahlung gleich nicht, bei der zweiten bin ich bis Paypal gekommen.
War bereits angemeldet usw. Keine Chance durchzukommen.
War gestern mal bei NBB. Dort lagen 4 Karten zu Abholung seit ein paar Tagen. Heute wird die erste frei, Aber 2350€ für die
Zotac ist mir zu viel. Frei verfügbar war auch eine Inno3D ichill zum identischen Preis. Allerdings ist mir das zu viel Geld.
Dann warte ich noch …. vielleicht klappt es ja noch.
Die Karten im Outlet sind als B-Ware gekennzeichnet. Falls Du "normal" eine gekauft hast, dann ist die auch noch versiegelt.
20 Grad Differenz von WaKü zu Luftkühlung soll wenig bringen ? da bin ich aber anderer Meinung ;)
Bin echt so froh, dass ich instinktiv sofort nach Verfügbarkeit das Corsair Kabel geordert hatte. Zu diesem Zeitpunkt war ich nichtmal sicher ob ich eine 4090 kaufen würde :fresse:
Ähnliche Themen
Antworten
7K
Aufrufe
471K
