[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Die 4090 FEs sind, abgesehen von den kleinen Stickern auf der Seite der Verpackung (die man abreißen muss), nicht weiter verpackt, da gibt's keine Folie, kein Papier, kein garnichts; dementsprechend ist es sehr schwierig, hier Versandrückläufer zu erkennen. Soweit die "neu" verpackt werden (Sticker erneuern oder neue Verpackung), hat da man (abgesehen von Spuren auf der Graka, die abgewischt werden können) - wenn keine Schäden dran sind - keine großen Chancen, sowas zu erkennen. Andere Grafikkarten sind von Werk aus verschweißt bzw. so zusammengepresst in der Schale, dass man die nie wieder ordentlich rein bekommt, ohne dass das auffällt - das ist bei der 4090 FE nicht der Fall. Die liegt einfach nur "nackt" in einer Kuhle.
Doch die Umverpackung von Foxconn ist auch komplett zu und muss mit einem Aufreißband aufgerissen werden. Also man kann es m.E. durchaus sehr gut erkennen ob die Karte gebraucht ist oder nicht. Zumdem auf Fingerabdrücke achten. Wenn einer nicht Hände gewaschen hat, sieht man diese klar und deutlich auf Verpackung, Graka und Co..
Können diejenigen mit AB vielleicht noch kurz Ihre Zahlungsart dazu schreiben und obs ein neuer Account war oder ein existierender?
Arbeitsvorbereitung abgeschlossen, nach der Mittagspause wird umgebaut.
Wünsche viel Vergnügen. Hoffentlich lohnt sich für Dich der ganze Aufwand überhaupt, die überdimensionierten Luftkühler sind allesamt so riesig und potent genug, dass ich mir diese Generation so einen Aufwand bestimmt nicht machen werde für nur minimale Vorteile^^
Ich hoffe jetzt wirklich das die Gigabyte erträglich ist... War meine heimliche Hoffnung - und zum ordentlichen Preis erwischt. Die MUSS jetzt in Ordnung sein.
Hab auch die Gaming OC, läuft absolut leise, kein Fiepen, kein Rattern. Wenn auch bei dir alles klappt, hast du ne gute Karte zu nem annehmbaren Preis.
Die FE wird mit OC etwa 10-15C° wärmer ... Beispiel die Strix kannst du mit 100% Lüfter bei 45C° (im Benchmark halten) die FE landet trotz 100% zwischen 55 und 60C°
15° könnte sich schon lohnen.
Ich glaube dem RAM könnte es auch gut tun.
:oops: Da fehlt doch der Drehmoment Schraubendreher um Gottes Willen :ROFLMAO::ROFLMAO:
Das Fräsbild (da kommt der alte Zerspaner in mir durch) sieht aber nicht besonders aus :-( bei dem Preis ...
Mit welchem Drehmoment zieht man denn an? Der Schlüssel bringt nur was, wenn man die Werte kennt. Sonst ist er eher gefährlich.
Ich drehe immer so stark bis das Gewinde knackt/durchdreht und dann mache ich eine halbe Umdrehung zurück^^
Denke nicht dass das nen Unterschied macht, aber Account mehrere Jahre alt und Paypal nach einloggen bei NBB, keines der Express Dinger
An die erfolgreichen FE Käufer: Wie habt ihr euch darüber benachrichtigen lassen bzw. welchen Bot genutzt?
0,35-0,5nm manche machen auch 0,6nm mehr würde ich aber in keinem Fall!
Wichtig das du eben alle gleich anziehst!
Natürlich geht auch ohne, aber sowas sollte wenn möglich gleichmäßig sein, daher könnte man schon mit einem Drehmoment Schraubendreher arbeiten.
Das mit dem knacken und zurückdrehen war hoffentlich ein Witz, oder?
Ob nun 45°C oder 60°C macht den Kohl auch nicht fett. 60°C sind bei weitem besser als damals die über 100°C bei der 3090
Die Temperatur hängt ja so stark von dem verwendeten Gehäuse und der Lüfter ab. Vergleiche unter Users hinken da.
Würde mich aber freuen wenn die FE unter sag ma mal 70 Grad bleibt.
A propos:
FE in Versandabwicklung. bezahlt mit PP !
Die Gigabyte scheint ne ordentliche Karte zu sein und vor allem auch selten/wenig Spulenfiepen zu haben. Wenn du nicht grad ein Montagsmodell hast wird das schon passen. Die Kühler sind bei ALLEN 4090 völlig überdimensioniert und mehr als geeignet um 400W zu kühlen.
Kreditkarte und Account (mit einigen Ampere FEs).
Invitatio Ad Offerendum googeln. Gängige Praxis im Recht, der Shop/NBB ist absolut auf der sicheren Seite.
Mir gehts ums Spulenfiepen. War schon drauf und dran eine Zotac zu nehmen. Lieber etwas lauterer Lüfter als Kopfschmerzen von den Spulen. Das war echt so ekelhaft...
Wegen der Temperatur mache ich mir keine Sorgen. Bei mir sollte nächste Woche eine Fractal Torrent ankommen. Da müssten meine drei Trümmer reinpassen und gut durchlüftet müsste es auch sein.
Jetzt noch nach einem ordentlichen Netzteil schauen wegen dem Kabelwahnsinn und dann ist erstmal gut. Dann wird der CPU Unterbau doch etwas nach hinten verlagert... Passt auch.
/edit: Strix - gefunden auf Otto.de :rofl:
:lol:
Ich würde nen Anwalt einschalten, wenn der Betrag raus ist.
Ehrlich, auf die 150 € SB geschissen.
Dann muss die Karte nachgereicht werden bevor neue Drops stattfinden.
Dieses Fehlverhalten seitens NBB kann nicht rechtens sein.
Naja NBB ist ja ziemlich klar das eine Eingangsbesätigung der Bestellung keinerlei Annahme seitens NBB darstellt und erst die AB da bindend ist.
@X909 KK, alter Account mit FE 20/21 drinnen
:ROFLMAO: Welches Verhalten? Das storniert wird wenn mehr bestellt wird als verfügbar ? Besser 3 Wochen einfach auf neue Verfügbarkeit warten..
Wenn das btw. In den AGBS kommuniziert wird. Ist das rechtens.
in 3 Wochen 3 FE Drops ist doch eine gute Quote
Ähnliche Themen
