[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Genau haltet euch künftig einfach nicht mehr an die Hersteller Angaben und testet es an euerer teuren schlecht verfügbaren Hardware ;-) :ROFLMAO:
Mindestens einer ist jetzt traurig das zu lesen.
:ROFLMAO:
Dir ist schon klar das eine 4090 nur mit 850W empfohlen wird wegen 600W Bios ? Und das es auch Karten gibt die nur 450W Bios haben? Und wenn man PT reduziert oder mit UV arbeitet die Karte nicht mal 300W aus der Dose zieht?
Macht euch nicht verrückt wegen Netzteilen: Mein putziges 700W Teil von Seasonic kommt mit der 4090 + 5900X + AIO + zig RGB´s locker zurecht.
Habe extra auf Last getestet die ersten Tage und das sehr massiv und konnte meinen PC nicht zum abschmieren bringen (selbst 1200 FPS bei PUBG, oder auch Quake RTX/Cyperpunk mit Psycho RT/Dying Light 2, Plague Requiem).
Er schrieb was vom 7950X, der frisst locker 100W mehr (unter Volllast), da wäre das 700W auf Dauer überfordert.
Ich habe auch nur ein SF750, allerdings kommt bei mir noch der 5800X3D diese Woche rein und die 4090 wird 55-65% PL bekommen. Ich will mein Setup auf ca 500W inklusive 42" OLED+27"Monitor begrenzen.
Warum? Weils sonst zu warm wird im Zimmer. :d
Es gibt CPUs mit über 300W...von wegen 600W Bios...1000W sind fürs 600W Bios, 850W nur in Stock. Die GPU hat Spikes die nochmal biszu 150W höher gehen. Die CPU hat auch 50-100W Spikes.
Im schlimmsten Fall geht alles aus. Wobei ein gutes 750W Netzteil sollte 900W mit nem Spike aushalten.
ja und ? Es ging doch nur darum das gemeint war das man unterhalb der Herstellerangabe liegt. Selbst wenn ich 300W CPUs besitze, würde ich mit 750W klarkommen bei UV.
Damit widersprichst du dir selber... so redest von 600W Bios bei einem empfohlenen 850W Netzteil und nun redest du von UV.
UV ist nicht Teil der Empfehlung und hat damit nichts zu tun.
Jeder kann mit seiner Hardware machen was er/sie will, aber darum gehts bei der Empfehlung der Hersteller nicht.
Wie ich vorher schrieb, will ich meinen Pc mit 5800X3D und 4090 bei 350-400W betreiben, da reicht auch ein 650W Netzteil. Und mit einem 750W NT wäre auch eine 300W CPU noch dabei.
Mit UV geht das ganz klar, aber das ist nicht in der Empfehlung der Hersteller eingerechnet.
Liest du nur was du lesen willst ? Es ist doch total egal was es für eine CPU gibt. Fakt ist das die Herstellerangabe für die 4090 bei 850Watt liegt weil die Karte eben bis zu 600W Bios haben kann. Die CPU wird dabei doch nicht berücksichtigt von Nvidia.
Meine Aussage bezog sich darauf das man locker unter den 850W bleiben kann weil eben der Verbrauch geringer ist.
War mir neu, dass die Hersteller der 450Watt 4090 nun auch Netzteile mit weniger Watt empfehlen.
Geht doch bitte nicht immer davon aus, das jemand ein Seasonic oder anderes Markennetzteil hat. Es gibt Netzteile die schaffen das nicht auf den verfügbaren Rails. Das kann man nur im Handbuch des Netzteils lesen. Und wenn nicht ist es eben nur relativ sicher bei 850 bis 1000 Watt. Genau deswegen geben das die Hersteller ja als Empfehlung an.
Allein wegen der Fairness (den Leuten gegenüber die nicht so tief in der Materie sind) sollte man nicht sagen „…ach es geht auch ein schwaches Netzteil …“ wie gesagt manche Netzteile reagieren bei Überlastung tötlich für den Rest der Hardware.
War mit neu das die Hersteller der 450Watt 4090 nun auch Netzteile mit weniger Watt empfehlen.
Tun Sie nicht. Es empfiehlt jeder meines Wissens ab 850W. Aus Absicherungsgründen aber nur. Weil dann keiner sagen kann "Ihr seid schuld dass..."
Ich gehe davon nicht aus. Mir ist durchaus bewusst das viele mit dem Superflowerpower Fluffy Netzteil im PC unterwegs sind. Wenn jemand auf die 4090 will ist es auch okay wenn er sich ein Netzteil kauft das empfohlen wird. Es muss aber nicht zwangsläufig sein.
Ja CPU wird nicht berücksichtigt, aber was passiert wenn du alle Kabel vom Adapter einsteckst? Die Karte zieht trotzdem 450W, das PL verändert sich nicht. Nur kannst du es manuell auf 600W erhöhen, aber die Empfehlung ist mit Sicherheit für den Stockbetrieb und nicht mit OC. SO meinte ich das.
Das Seasonic ist nicht zu empfehlen, es kann warschienlich nur 225W maximal pro 8-Pin ausgeben. Das Thor möglicherweiser auch. Beide haben zumindest keine Daisychain-Kabel mit 2x8-Pin.
Beim Seasonic gab es das Thema vor kurzem, das der 12VHPWR Adapter zwar 600W kann, aber das Netzteil nur 450W mit 2x8-Pin.
Das HX1000I hat Daisychain Kabel, sollte also 2x8-Pin auf 12+4-Pin gehen.
Wenn du allerdings einen 4x8-Pin Adapter nutzt, ist das egal :d Hast aber dann 4 lange Kabel rumhängen...
Ich selber würde auf dieses hier warten, wenn ich eines bräuchte:
309€ ist aber sportlich... (Vorbestellung)
Das TX ist soweit ich weiß im prinzip auch ein Corsair AX 1000 Titanium.
Das Corsair verwendet lediglich einen anderen Lüfter und eine andere Lüftersteuerung.
Laut Corsair sind für die regulären 8 Pin Kabel bis 225 Watt möglich.
Die Anschlüsse am NT selber können bis 300 Watt .
Also mit dem neuen nativen Kabel von denen mit 2x8 Pin auf 12+4 Pin sind 600 Watt möglich , weil da halt der Kabelquerschnitt höher ist . (AWG 16 statt AWG 18)
Die Buchsen am NT gibt das auch her wie gesagt .
Dazu ein bisschen geht auch über den PCI E Anschluss auch wenn es nicht mehr so viel wie sonst war ( 66-75 Watt je nach Boardpartner Karte)
Daher sehe ich das auch bei Seasonic eher entspannt und werden sicher ein ähnliches Kabel wie Corsair bringen.
Im Alltag volles Power Limit fahren mit 1,1 V muss jeder selber wissen , aber die regulären 450 Watt mit max. 1.05V tut es vollkommen meiner Meinung nach.
Das ist ja echt klasse also entweder ich verkaufe die 4090 wieder oder muss bis Dezember/Januar warten... Das ist echt einfach nicht zu fassen.
Ich baue diesen mitgelieferten Mist nicht ein, ich MUSS es sonst sehr stark knicken und brauche einen gar 180 Grad Winkeladapter
Ich habe extra bis heute gewartet, um das Cable Mod Kabel direkt mit dem rechtwinkligen Adapter mitzubestellen, weil ich nicht 2x 15€ Versandkosten zahlen möchte.
Und ich sehe es kommen: Wenn man den Adapter in ein paar Wochen bestellen kann, ist das Kabel gerade nicht verfügbar oder so.
Also ich hatte heute Nacht um 3 uhr schon ~3h schlaf.
Wie ging es euch mit dem Adapter? :fresse::shot:
Spaß beiseite... Der 180 grad Adapter schaut nice aus bei ner TUF/Strix denke das wirds bei mir werden falls mal verfügbar.
Ich verwende immer noch den Adapter der bei der Grafikkarte dabei war. Ich habe auch noch kein Be Quiet Kabel bestellt, warte da auf das Dark Power 13 Netzteil. Karte läuft noch. Und ich sehe keinen Grund warum sich das plötzlich ändern sollte.
Oder, die Adapter werden bei Verfügbarkeit direkt "weggebottet" und landen für 3x-UVP bei EKA :ROFLMAO:
So einen Scheiss hatten wir auch noch nicht... :rolleyes2:
Könnte "biblische" Ausmaße bei Release der 4080 annehmen :fresse:
Also, jou, Empfehlung ist 850 Watt. Die müssen aber auch alle Gurkennetzteile dort draußen mit beachten.
Bei mir gibt es mit dem BeQuiet dark pro 10, 750W keine Probleme.
Sys:
  • intel I7-8700K ~4,9GHz
  • 9 Lüfter
  • 32GB Ram
  • 4090 FE
Mit 133% PT, also max 600 mögliche Watt an der Grafikkarte, hab ich für das Gesamtsystem bei hohem OC, teilweise die 650-700 Watt gesehen. Die Karte selbst hatte da so ~500 Watt im Aferburner. Denke mit Spannungsspitzen könnte das Eng werden. :d Aber bisher keine Probleme. Das Netzteil hat ja auch die 3090 überlebt. Denke mit einem heftigerem Prozessor, könnte es auch eng werden. :) Denke mit Furmark und gleichzeitigem CPU Benchmark, wird das System in die Knie gehen. Aber beim Spielen, bei moderatem OC, kein Problem.
edit: selbst bequiet sagt in ihrem Beitrag, Ist halt mit anderen Serien nicht getestet.. man soll in den Spezifikationen des Handbuchs sehen. Wenn ich dort reinschaue, seh ich auf der einen Rail 25A(300WATT - 12V1,12V2) und auf der anderen 30A(360WATT - 12V3,12V4) und darf insgesamt die auf der 12 V Schienen max 744Watt haben. Schaut halt in eure Spezifikationen eurer Netzteile.
Ein kleiner Extremtest mit dem Adapter. Morgen gibt's die Ergebnisse^^
TL/DW (watch, nicht read, hust): biegen, knechten, zerren, gewichte dran, danach 1500W durchgehender load für einen Tag.
ich bleibe bei meinem Moddiy 3x 8 Pin Kabel. Mach mir doch kein Stress und steh wegen einen Scheiß Kabel, doch nicht um 2-3 Uhr Nachts auf!
NIE IM LEBEN! Verrückte Welt
Sys:
  • 9 Lüfter
  • 32GB Ram
  • 4090 FE
Wollte grade sagen, bei so einem alten und "sparsamen" Prozessor (86.2W at full load, gem. Reviews die ich grade geschaut habe) hast Du ja das Equivalent von einem aktuellen 4-6 Kerner drin (Wattwut).
Aktuelle CPUs fressen locker mal das zwei bis dreifache, dann wäre 850W das Minimum^^
Du hast auf jedenfall gewaltiges CPU Limit, macht da die 4090 überhaupt Sinn vs eine 3090?
Selbst mein 5950x limitiert in CPU intensiven games wie Anno oder Spider Man meine 4090 merklich, die geht häufiger nicht über 80% Auslastung. Ein 8700K dürfte da wohl Meilen von entfernt sein^^
Das wäre doch mal eine "Qualitätskontrolle" vor der Auslieferung. Jeder CableMod-Mitarbeiter bekommt beim morgentlichen Mitarbeiter-Gruppen-Sport Adapterkabel zum Seilhüpfen in die Hand gedrückt :haha:
Vielleicht für den ein oder anderen interessant.
Die 4090 soll laut Igor keine lastspitzen mehr haben nach oben.
Klar macht das Sinn, wie @HisN immer schön schreibt, Es ist überhaupt kein Problem ins Grafikkartenlimit zu kommen. Hauptsache ich komm am Ende über 60 FPS im CPU Limit, dann gibts auch keine Mikroruckler.
Klar, in Cyberpunk muss ich die Menschenmassen auf mittel stellen. Manchmal hab ich nen Drop auf 54 FPS in der JIG JIG Street. Ansonsten immer im Grafiklimit.
Spiele die ich so spiele:
Horizon Zero -> DSR bei 6K
Cyberpunk
Witcher 3 -> DSR bei 6K
usw... zur Not wird halt PT runtergesetzt, sodass es passt.
Habe vor den neuen 7800x3D zu holen von AMD oder den 13700k, wenn ich nen guten Deal machen kann. Aber noch ist kein Spiel draussen das mich so ins CPU Limit schmeisst, dass es keinen Spass macht. Mit DSR ist so viel möglich. Die brachiale Leistung der 4090 ist einfach geil. Sobald Witcher 3 mit Raytracing kommt, siehts vllt anderst aus. Aber dann, gibts auch DLSS3 denk ich mal. Ansonsten Upgraden. :) Mein BeQuiet DarkBase 900 hat noch Platz
Edit: Denke der OC 5,1Ghz, All Core auf dem I8700k rettet mich manchmal noch. :) Aber ja, denke mit ner neuen CPU sollte auch ein neues Netzteil rein. Vllt dann nen ATX3.XX nächstes Jahr von BeQuiet..
Ähnliche Themen
