[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Es gibt hier im Thread Leute die nennen Jayztwocents die "Bildzeitung" und haben die Power Adapter Sache anfangs versucht klein zu reden und die schuld versucht auf den Nutzer abzuwäzlen
ich dagegen finde genau richtig was er da tut sowie auch anderen Tech Youtuber ( Igor is ja zb auch einer ) ..... Nvidia muss da nun handeln und zwar besser früher als später
Wir haben nun 13 Fälle in 17 Tagen gesehen und wer weiss wie das in weiteren 2 Wochen aussieht und wie die Dunkelziffer aussieht.
ich habe ein bequiet mit 3x pci e, die Pinbelegung hatte mich etwas irritiert, deswegen war ich verunsichert
Ist das ein ATX 3.0 Netzteil von BeQuiet? 🤔
Also bei mir würde das Cabel nicht passen bei meinem Seasonic PX 1300 Watt Netzteil...
von be quiet gibt es noch kein atx 3.0 netzteil.
das von seasonic kommt auch erst noch... bisher gibt es von seasonic nur ein passendes kabel was direkt ans netzteil angeschlossen werden kann.
offiziell nur für 1.000 und 1.300 watt modelle.
Ich finde gut das du der einzige bist der das Thema immer wieder anspricht weil offensichtlich dieser komische Megathread auf Abo bei dir liegt. Sonst würden hier das ja alle vergessen und einfach mit der 4090 in Ruhe zocken :)
In Deutschland nirgends Bus jetzt gesichtet.
Ist halt echt wild. In Deutschland ist nicht ein Kabel verfügbar. Man muss mindestens 3 bis 4 Wochen warten bis man da was tun könnte wenn man wollte. Bin mal gespannt wann sich diese Lage entspannt.
Ich habe ja gestern eins beantragt bei Seasonic, da ich letztes Jahr ein PX 1300 Watt Netzteil vorsorglich geholt hatte nur weiß ich nicht wie das Kabel aufgebaut ist. Ob es nun 2 8-pin oder 3 oder 4-8pin Stecker sind die vom 12VHPWR Stecker abführen.
Weist du wie es aufgebaut ist?
Jetzt mal echt ey, kann mir das jemand erklären?
Das ist mein Video, ich hab das hoch geladen.
Achtet mal auf den bist takt der Grafikkarte
ich gehe davon aus, dass es an 2 stecker angeschlossen wird am netzteil, aber das ist nur eine vermutung.
Und das soll bei bis zu 600 Watt ausreichen? Gibt's etwa die Möglichkeit mehr als 250 Watt über einen einzigen 8-pin Stecker zu schleusen? Dachte es wären immer nur höchstens 150 Watt möglich...
Genau das mache ich nächste Woche (5800X3D ist bestellt).
Mit ein wenig Glück verkaufe ich meinen gebrauchten 5950X für 450-500€ auf Ebay. Das Geld wandert dann in die 4090 >_<...
Ich selber zocke und surfe nur mit dem PC und ich kann die 16 Kerne nicht ausreizen. Er war damals ein Fehlkauf für mich... das war noch vor dem Release von Intel 12th Gen und dem 5800X3D...
Da ich den 5950X mit UV auf 4,2Ghz laufen lasse, werde ich vermutlich >20% mehr FPS haben...
Warum taktest den 5950x nicht einfach höher statt den 58003d zu kaufen?
So wie ich das verstanden habe, ist es bei guten Netzteilen möglich 300W auf 8pin zu haben. Aber sic
So wie ich das verstanden habe, ist es bei guten Netzteilen möglich 300W auf 8pin zu haben. Wobei ich denke das mehr besser ist als weniger, wegen der Verteilung
Das aktuelle ROG Thor P 2 1200 hat auch 2 x 8 auf 16Pin und auf der 16Pin Seite ist 600 Watt aufgedruckt, also dürfte das 2 x 300 Watt drücken. Ich sollte mal langsam umbauen und das Corsair AX 1000 aus dem System nehmen, da hängt noch der Vierzack dran.
Ja das ist auch meine Frage... Mir wären 4 x 8-pins am liebsten bei meiner Version der Gigabyte Gaming OC, die bis 600 Watt ausgelegt ist. Wäre echt gut etwas konkretes zu wissen.
naja, wenn der hersteller es so freigibt...
Laut PCI-Sig ist 8pin PCIe Power auch nur offiziell bis 150W spezifiziert. Was Netzteil Hersteller bauen ist natürlich ihre Sache, denn laut Molex Spezifikationen kann eine 8pin PCIe Power Steckverbindung von 252W bis 300W max. je nach Leiterquerschnitt standhalten. Die PCI-Sig sieht einfach einen größeren Puffer vor und deswegen haben wir auch in den letzten zwei Jahrzehnen auch so wenig Probleme damit gehabt, es war halt noch genug Luft nach oben vorhanden..
verursacht der Controller Last auf die CPU? Schaut für mich aus, als wenn dadurch ein krasses CPU-Limit entsteht und die GPU dann halt runtertaktet, weil sie nicht mehr viel zu tun hat.
Ja es hat was mit du Bluetooth Verbindung zu tun. Ich muss aber erlich sagen ich finde das schon recht krass.
witzig. ich dachte ist nur bei mir so aber der sound kratzt wenn ich mit dem joystick am xbox controller langsame lange bewegungen mache.. quasi gehen und dabei umschauen kratzt es im 20 sekundentakt. vl. bluetooth
@tekniq
Wahrscheinlich noch ein Treiberseitiges Problemchen, was sicherlich bald behoben wird.
hmm. ich hab bluetooth LS dran aber gestern waren die nicht verbunden. ich teste mal mit deaktiviertem BT aber ich glaube mein system muckt da nciht^^
das sage ich auch gleich zu dir, man man
warum? takt ist nicht das resultat sondern eine komponente.
dachte das thema hatten wir bereits vor 12 jahren beendet
Also wird der 5950x nicht schneller wenn er ihn statt 4,2 auf dem standardtakt von 4,9Ghz laufen lässt?
Meiner meinung nach kommen da 10% mehr raus. Stattdessen hohlt er den 58003d der dann max noch in 3 spielen 10% schneller wäre aber dafür in jeder multithreadanwendung eine krücke isr.
Ähnliche Themen
Antworten
6K
Aufrufe
392K
