[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Joa dann hoffe ich das mein Adapter von cabrlmod schnell kommt, Igor hat es gezeigt das der Adapter minderwertig ist. Bestätigt mich in meinen Aussagen.. Solange dieses Billo Teil dran ist Vorsicht walten lassen und auch erstmal nicht das PT erhöhen und die karte am besten im UV betreiben..
Fazit: Minderwertiger Adapter von Nvidia, den man am besten austauschen und nicht (mehr) nutzen sollte, weil er einen Konstruktionsmangel aufweist.
@owned139 Ich freue mich wenn nichts an der Sache ist aber das Gesamtbild aus PCI-SIG, Nvidia Statements und Reaktion von Herstellern sagt mir etwas ist an der Sache dran.
Ok das erklärt schonmal warum das NVIDIA Kabel nicht stark geknickt werden sollte. Die Lötkontakte an dieser "Folie" sind beim Knicken natürlich fatal.
Vielleicht schaut sich Igor ja auch nochmal die Terminals an. Die wurden ja von der PCI-SIG bemängelt.
Dann bin ich froh, den NV-Adapter verpackt lassen zu können und mit dem beQuiet-Kabel arbeiten zu können. :cool:
absolut, hier werden native 16AWG-Leitung verwendet, jedoch muss man dennoch die Pins der Kabel im Auge behalten, die können nämlich auch rausrutschen.
uiuiui das klingt heftig. Wie mache ich das am besten? Ich habe kein Seitenteil aus Glas. Am besten einmal täglich das Seitenteil abmachen und nachschauen? Oder besser sogar den PC direkt auf den Tisch stellen das ich direkt eingreifen kann wenn was passiert ?
Ich könnte auch meinen Bruder neben den PC sitzen lassen das er das Kabel die ganze beobachtet und einfach reagiert wenn da was passiert.
Na klasse. Das sind ja tolle Nachrichten am Morgen.
Wäre gut wenn sich das rumspricht. Ltt, Steve und jay
Sehr schön, Igor sagt, dass beQuiet Kabel macht alles richtig (wenn denn kein PIN herausgerutscht ist). Da bin ich beruhigt :).
das Pins am Stecker rausrutschen passiert wenn überhaupt beim anschliessen und nicht während des Betriebes.
wenn ich diesen Kommentar lese, dann muß ich schon festellen, das der absolut vor Kompetenz strotzt.
Du hättest aber auch merken können wie er wirklich gemeint war. Hast du aber leider nicht. Trotzdem danke für deinen Kommentar. Ich denke andere werden dir glauben und aufpassen :)
Habe gerade mit Igor geschrieben. In seinem Video thematisiert er auch dieses Problem. Und ja auch bei den nativen Steckern kann es passieren wenn man im eingesteckten Zustand das Kabel biegt die Terminals ausleiern. Damit sogar an beiden Enden des Kabels. Also erst biegen dann stecken :) @owned139 Demnach ist das PCI-SIG Problem noch da und nicht behoben oder nur ein Gespenst der Entwicklungsphase.
Eigentlich muss Nvidia die Adpater bei den Kunden austauschen.
Besorgt euch alle wenn möglich native Kabel .
Ich finde schon, dass allein die latente Gefahr eines Brandes ein Problem ist, dessen sich der Hersteller annehmen sollte. Je höher der Stellenwert der gefährdeten Rechtsgüter durch eine mögliche Realisierungen der Gefahren ist, umso intensiver hat das Bemühen des Herstellers zu sein, eine Realisierung der Gefahrenquelle zu verhindern.
Ich fände es zynisch zu sagen, bei 10.000 Anwendern sind nur zwei Brände ausgebrochen.
Anscheinend ist die Verlötung der Kontakte die Ursache der Hitzeentwicklung, worauf @so_unnecessary zutreffend hingewiesen hat.
Heut wird uns Igor über die Details informieren.
Was hier manche User leider tun :( Tritt doch nur bei ein paar wenigen Leuten auf, Problem ist doch gar nicht so schlimm etc.
Mich wundert es nur das Nvidia diesem Adapter (der ja quasi fast bei jeder Karte mit bei ist) So wenig Aufmerksamkeit schenkte.
Ein kostenloser Austausch wäre fein und nötig.
Am besten glaubst du Igor und machst das was du für richtig hälst. Hol dir besser keine 4090. Bleibt mehr für andere :) Du hast ja nicht mal verstanden was ich gemeint habe.
Zu spät, ich hab eine Day 1 Suprim und hier berichtet.
Ich hab nicht verstanden, was du gemeint hast? Alles klar. Ich hab nur, was du schreibst.
Nach "Das ist kein grundsätzliches Problem. Das ganze ist einfach durch die Sache selbst ein Problem." braucht man aber nicht weiterlesen.
Hab ich nun nachgeholt. War, wie vermutet, überlüssig.
Kein Streit hier. Wenn alle Adapterkabel im Inneren so aussehen, dann IST das eine potentielle Gefahr. Es muss nicht bei jedem zuschlagen, insbesondere dann nicht, wenn nicht am Kabel gebogen wird. Aber es KANN eben zuschlagen.
Und in dem Fall empfinde ich es als hämisch denjenigen noch als quasi doof hinzustellen. Jeder hat um die 2000€ für seine Pixelschubse zahlen müssen. Das will man erstmal geschützt sehen. Mit dem Adapter ist das aber leider eher gefährdet als geschützt. Und ich denke genau daher kommt die Aufregung. Die wenigsten hier sind "AMD-Fanboys", die nur auf nVidia einprügeln wollen, sondern es sind Leute die viel Geld für ein nVidia Produkt ausgegeben haben und jetzt enttäuscht sind.
Ich meine schon auch, dass hier nachgebessert werden muss. In Ordnung ist das so einfach nicht.
Falls es jemanden interessiert, ein kleines Update zu TUF/Strix Wasserblöcken: EK hat gestern eine Mail an Vorbesteller verschickt, dass es bis Ende November dauert, EZModding hat mir gestern geschrieben, dass die Bykski Blöcke schon nächstes Wochenende eintreffen könnten.
Wie sind eure Erfahrungen mit Stornierungen bei computeruniverse? Hatte vor über einer Woche storniert und mein Geld immer noch nicht zurück.
Hat eventuell noch jemand ein be quiet 12vhpwr Kabel übrig, dass er/sie mir abtreten würde?
Die sind aktuell ziemlich überlastet, wohl krankheitsbedingt, hab gestern angerufen 25 Minuten Warteschleife.
Alles verzögert sich lt deren Aussagen leider massiv.
"Es verteilen sich insgesamt vier dicke 14AWG-Leitungen auf insgesamt sechs Kontakte, wobei die beiden äußeren Leitungen an jeweils einen Pin angelötet werden und die beiden mittleren an jeweils zwei Pins. Lötbasis ist eine lediglich 0,2 mm dünne Kupferfolie mit 2 mm Breite pro eingehender Leitung, was für die mittleren Anschlüsse dann 4 mm pro Paar ergibt." IgorsLab
Reicht Dir das als Beleg? :)
Auch wenn gewisse YouTube-Größen da anderer Meinung sind, weil man im 12VHPWR mal wieder ein williges Hassobjekt gefunden zu haben scheint: Dieser Anschluss ist an sich nämlich durchaus sicher, auch wenn es nachvollziehbare Bedenken hinsichtlich der Handhabung gibt.
Das der Anschluss an sich sicher ist, (wenn man es richtig umsetzt) steht doch außer Frage.
Nur weil der Adapter Murks ist, gilt das ja nicht für den Anschluss ansich. Korrekt und ausreichend verkabelt, sollte das kein problem sein. Adapter nicht nutzen und entsprechendes Netzteil mit be quiet o corsair Stecker nutzen. Fertig...
Und was mach ich jetzt bis das gammlige CableMod Kabel ankommt? :ROFLMAO: Morgen is MW2 MP Release :cry:
Grafikkarte nicht nutzen, oder das potentielle Risiko (das ich bei anderen nicht einschätzen kann) tragen und auf das Beste hoffen. Ist wie immer im Leben: Freiheit bedeutet eigene Entscheidung ;-)
Es geht hier ausschliesslich um den Nvidia Adapter. "Anschlüsse" im Zitat bezieht sich auf die Kontakte in diesem Stecker.
Werd ich wohl Mut zur Lücke haben.
Der Innenaufbau des Steckers ist wirklich ein riesen Pfusch. Wenn man schon 4 Leitungen auf 6 Kontakte verteilen muss, dann hätte man doch die inneren beiden Leitungen an jeweils 1 Kontakt und die äusseren dann an 2 Kontakten anlöten können. Da beim biegen ja eher die Leitungen aussen abreissen hätte man dem etwas entgegen wirken können.
Mich würde mal interessieren, ob das aufteilen der Leitungen beim Dreizackkabel für die 450W Karten wenigstens geklappt hat. Da man hier nur 3 Leitungen auf 6 Kontakte auflöten muss sollte das kein Problem sein. Wobei hier hat wahrscheinlich die mittlere Leitung 4 Kontakte zur verfügung und die äusseren wieder nur jeweils einen.
Es muss auf jeden Fall so schnell wie möglich ein anständiges Ersatzkabel her bevor hier noch wirklich mehr passiert. Glaube da kommt jetzt einiges zu auf Nvidia und das völlig zu recht.
Also nehmen wir an, das folgendes passiert, lt Igor
  • Die innere Brücke zwischen den Pins ist zu dünn (resultierender Querschnitt), um den Stromfluss auf zwei oder drei statt vier angeschlossener 12V-Leitungen zu kompensieren.
    Gemäß dem Fall Bruch, wäre es gut die Karte zu undervolten und nicht das PT zu erhöhen, Karte versuchen bei ~300 Watt betreiben.
Ich denke damit fährt man am besten.
Also aufs Spielen möchte ich doch ungern verzichten.
Rekord Jagd und Max Settings ausloten ist erstmal vorbei, bevor der Cable-Mod Adapter nicht da ist.
Bzw auch im Standard und bei hohen Auflösungen sind eben doch teilweise 400-500 Watt möglich, dies gilt es eben zu vermeiden, wer auf Nummer sicher gehen will.
Speicher OC würde ich vorerst auch nicht mehr durchführen, das zieht auch unnötig Leistung. und bringt nur 1-2 FPS im MAX
Gute Settings sind 2600Mhz@089 mv z.b 1-5 FPS Performance Verlust max, bei dennoch brachialer Leistung
Ähnliche Themen
Antworten
7K
Aufrufe
477K
