[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Also für dich wäre das auch vollkommen okay, wenn sich hier weitere "User" melden die von abgerauchten Karten berichten ohne Proofs zu liefern? Na dann mal Gute Nacht :rofl:
Bitte?! Du liest scheinbar was du lesen willst.
Ich sagte der User entscheidet wann er was postet und nicht du!
@owned139
In der Entwicklung ist ja auch ok. Aber warum gelangt ein Problem aus der Entwicklung vor dem Release "aus versehen" an die Öffentlichkeit und 2 Wochen nach Release tritt das Problem welches laut Nvidia gefixt sein sollte bei Usern auf? Warum warnen Hersteller wie Zotac die Kunden und limitieren Garantiebedingt die Anzahl der Steckzyklen, warum entwickelt Seasonic einen 90° Steckerkopf, warum gibt es Bedingungen wie ein hoher Biegeradius obwohl dieser normalerweise nur bei Faktor 3 des Kabeldurchmesser liegen muss? Natürlich können das alles nur Nebelkerzen und Panikmache sein aber einen faden Nachgeschmack hat das Ganze schon!
Das Karten/Stecker (whatever angebliche Gerüchte meinen) bei der Entwicklung einfach "abfackeln" ist also normal? :d
So langsam ergibt sich ein Bild.
Stellt euch doch mal die Frage warum z.b eine MSI Suprim 26 Phasen hat bzw warum die Partner Karten so auf Power/Kühlung ausgelegt sind diese aber nicht genutzt werden kann?
Weil PT und Voltage "künstlich" klein gehalten wurden.
Warum sollte man dann auf Power und Oc entwickeln.
Dies macht doch alles keinen Sinn?
Außer wenn es bei den größeren Karten einen zweiten Stecker hätte geben sollen.
Einfach weil der Stecker die limitierende Komponente ist. Die Bilder der PCIE-Kommission zeigen es deutlich, diese Information liegt uns doch auf dem Tisch.
Wenn der Stecker bei hoher dauerlast schmilzt, muss man eben hergehen und das Power Limit und voltage künstlich beschneiden.
500-600 Watt max unter Dauer und deren Lastspitzen sind wohl jetzt doch ein Problem geworden.
Die Karten sind dennoch schnell, nur für Übertakter oder Benchmark Rekord Jäger gerade zu sinnlos.
Ich bin echt gespannt, wie es weiter geht, das Thema wirft schon ein paar interessante Fragen auf ..
Ich kann es selbst erst später testen. Berichte dann
So hat gefunzt. Gigabyte hat mal einfach die Bios'e vertauscht oder im Readme. Also A flashen fürs Silent und L fürs OC.
@cHio @sontin
Edith: Neue Bios-Versionen geaddet / jetzt erstmal weiter arbeiten
@bigdaniel warum wiederholst du Fragen, welche schon beantwortet wurden?
Warum legst du Spekulationen als Fakten aus und postest sie, ohne Beweise, in anderen Foren?
Dir geht es gar nicht darum zu diskutieren, sondern um die Bestätigung deines Narrativs.
Für dich ist der Fall schon klar, aber was machst du, wenn sich herausstellt, dass die 3 Stecker nur Montagsmodelle waren und für die restlichen keine Gefahr besteht?
@Chaund ja, deswegen nennt man es "Entwicklung". In der Entwicklungsphase treten Fehler auf, was auch völlig normal ist. Die Phase dient dazu, sämtliche Fehler auszumerzen und das Produkt zu finalisieren.
Glaubst du ernsthaft, dass der erste Prototyp des Airbags einwandfrei funktioniert hat?!
Es ist egal, ob die Karte während der Entwicklung schmorte, in Flammen aufging oder explodierte. Was zählt ist, dass die Ursache erkannt und behoben wurde und im fertigen Produkt nicht mehr auftritt.
Und nein, wir wissen deshalb noch lange nicht, ob der Stecker grundsätzlich ein potentielles Risiko ist.
Oder weil es sich gut vermarkten lässt? Die Highend AM5 Boards sind auch absolut overkill. Wieso, wenn es nicht benutzt wird?
Meine ist nun auch angekommen. Sorry für die Frage aber was soll das denn bitte für ein Kabel sein, was man auf dem Bild sieht?
Ich habe auch irgendwie kein Anschluss gesehen, dachte ja schon beinahe was wäre der neue 600 W Stecker nicht das sonst zack, boom folgendes passiert:
Fuck, meine 4090 TUF ist gerade beim Warzone 2 zocken abgeraucht. Es stinkt alles verschmort und die Sicherung ist geflogen.
Ne ernsthaft Leute, was soll das bitte für ein Zubehörkabel sein, weiß das jemand?
Noch nie einen RGB Stecker gesehen? Damit kannst du die Beleuchtung deiner Karte mit dem Rest synchronisieren. (afaik)
Ich tippe auf RGB um das geblinke übers Board zu steuern :d
Den RGB Stecker in den 5 Pol in der Graka Stecken, neben dem 12 Pol
Eine Theorie.
Aber Igors ist auch eine plausible.
Meine TUF 4090 OC kommt am Wochenende ich hoffe ich bleibe von den Schmorproblemen verschont. Und warum hat NVIDIA nicht von vornherein abgewinkelte Stecker entworfen? Der Stecker ist jetzt mittiger als früher bei den Karten. Ich weiß jetzt schon, dass das Kabel bei mir mit dem Lüfter in der Seitenwand kollidieren wird.😅
Äpfel mit Birnen, MSI könnte locker für diese Karte ein 600 Watt+ Bios bringen, wieso passiert es nicht?
Wieso ist selbst das Perfomance Bios beschnitten, normalerweise bei so einer Art von Karten sind solche Biose teilweise komplett offen.
Ich kann mich dabei nur zu gut an ein LN2 Bios auf meiner damaligen KingPin erinnern.
@owned139 Ich wiederhole diese weil du meine Aussagen nicht im Kontext siehst. Für mich ist das Gesamtbild der bisherigen Erkenntnisse entscheidend. Genau genommen bin ich hier in die Diskussion eingestiegen weil du hier mit Fantasiezahlen jongliert hast. Ich freue mich wenn nichts an der Sache ist aber das Gesamtbild aus PCI-SIG, Nvidia Statements und Reaktion von Herstellern sagt mir etwas ist an der Sache dran. Leider habe ich das Gefühl du wirst hier deine RTX 4090 bis aufs Blut verteidigen bis ggf. deine Karte brennt.
@EleCtricStream @Chaund @bigdaniel wenn es eine Fehlkonstruktion ist und grundsätzlich das Risiko besteht, warum betraf es dann bisher nur 3 Personen?
Warum können sämtliche Tester/Influencer das Problem nicht nachstellen, selbst wenn sie das Kabel direkt am Stecker knicken?
Das ist jetzt nicht dein Ernst? Du postest auf CB, dass es hier auch wen mit einem Defekt gibt, aber hast absolut 0 Beweise. Seine Aussage glaubst du blindlinks, aber wenn ich mit 10K Karten und 3 Defekten komme, sind die Zahlen auf einmal Fantasie?
Das wir bisher 3 defekte Stecker haben ist keine Fantasiezahl, sondern Fakt und die 10K ist viel zu niedrig gegriffen.
Hier: https://twitter.com/CyberPowerUK/status/1580256992198729729
Das ist NUR CyberPowerUK und nur die MSI Suprim X 4090. Kannst jetzt selbst hochrechnen, wie viele Karten EIN Shop im Schnitt bekommt.
Genau weiteres Indiz, ist diese Schmal-Lippigkeit der Hersteller. Meistens bedeutet das nichts Gutes ..
Ne mit RGB kenn ich mich nicht so aus
Aber danke an alle, wieder was gelernt
Aber ich kann jetzt die Bedenken einiger sehr gut nachvollziehen, über diesen filigranen "Pimmel" Stecker sollen 600 W gehen?
Wenn man mal das live sieht, wirkt das schon ganz anders:
Die 3x 150 W 8 PIN Buchsen machen da schon einen wesentlich solideren Eindruck, wie man es gewohnt ist.
Vorhin gabs nen MediaMarkt TUF OC drop (oder vlt nur eine, kA), die nicht via der Verfügbarkeits-Telegramm-Gruppe gepusht wurde. Was da los, wie kann das sein?
nope wenn du nur ein 3 fach Kabel hast, gehen da 450 drüber
nur die 4x Stecker können theoretisch 600
Erst durch wirkliches Spielen und Ausprobieren kommst du dazu.
Wie gesagt meine Theorie ist.
Kabel mitunter zu stark geknickt, Power-Limit auf max, Voltage auf max, max Settings und hohe kontinurliche Dauerbelastung gaben diesen Steckern den Todesstoß.
Eventuell ging man davon aus das unter guten Voraussetzungen dieses Phänomen erst jenseits der 600 Watt auftritt. Deswegen Limitierung des PT um eventuelle Lastspitzen abzufedern.
Nun hat dies wohl doch nicht so wirklich gereicht, man hat sich schlicht und einfach etwas verzockt.
Wie gesagt die Lösung wäre so einfach gewesen, 2 Stromstecker auf die Karte und fertig, wäre aus Platzgründen immer noch besser als 4 Native 8 Pin PCIE Stecker zu verbauen.
Aber nein man wollte es wohl nicht, es wären durch 2 Stecker theoretisch auch 1200 Watt möglich..
Vielleicht sitzen auf der 4090 Super dann zwei 12VHPWR Buchsen nebeneinander :d Ein schöner 8 Ender quasi ein Kunstwerk :d
Vielleicht gibt's noch nichts Substantielles zu berichten.
Ich glaube schon, nur man hält sich bedeckt ^^
Aber schauen wir was da noch so kommt.
Wer auf Nummer sicher gehen will, der steckt vorerst nur 3 Kabel an den Adapter, oder lässt seine Griffel weg von dem PT oder der Voltage :geek:
Ähnliche Themen
Antworten
7K
Aufrufe
477K
