[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
nein brauchst du nicht
nimm ein seasonic Focus GX/PX 850 und schließe die karte mit 3x8pin an.
und peile mal eventuell den 90grad adapter an + ein cablemod kabel
da würde kein atx3.0 helfen
Danke dir! Das von dir genannte NT hatte ich mir auch ausgesucht.
90 grad + cablemod Kabel hole ich mir erst, wenn sich alles beruhigt hat / respektive verfügbar.
wenn igor morgen die bombe platzen lässt und er nicht übertreibt ist der adapter bei cm am montag instant weg xD
So, meine Gainward Phantom habe ich nun auch eingebaut und getestet.
Also die Karte ist an für sich halbwegs leise, ja.
ABER: Das surren hört man selbst aufm geschlossenen Gehäuse, aber nicht wirklich aufdringlich, aber man merkt es.
Schlimmer jedoch ist, das man ein gepfeife/schleifen der Lüfter hört, die unregelmäßig sind. Also hochfrequent. Das hört sich nicht gut und gesund an. Sowas darf ne billige Karte haben, aber keine 2K Karte.
Die geht wohl auch Retour zu Alternate. Schade um den tollen UVP Preis ;)
Im übrigen, läuft die Karte mit meinem 700 Watt Netzteil perfekt :d
Gesamtlast System ca. 600 Watt, CPU (AMD 3700X) saugt meist nur 60-70 Watt.
Bemerke aber öfter mal, das die Graka in 4K/Ultra Details teilweise einfach nicht ausgelastet wird. Metro Exodus, Abschitt "Wolga", nur 60 FPS, GPU Auslastung 50%.
Gleiche in Far Cry 6, meist nur 60-70%, und auch nur 70-90 FPS im Schnitt.
CPU zu lahm? ;)
Eigentlich wollte ich heute vernünftig dokumentieren was passiert ist und wie der Händler reagiert hat, damit andere auch etwas davon haben.
Aber nach den Kommentaren habe ich keine Bock mehr mich zusätzlich zu dem Ärger und dem Schaden auch noch zu rechtfertigen.
Aber natürlich lieferst du deshalb keine Fotos und nicht, weil du gelogen hast und vermutlich nichtmal eine 4090 besitzt :lol:
"phantom"
CPU zu lahm? ;)
ja
kurze Verständnisfrage dazu. Ich habe im Hinterkopf das G-Sync nur mit Displayport funktioniert. Ist das mit HDMI 2.1 jetzt anders ? Hab ich das verpasst?
Da hat sich viel getan, eigentlich ist es jetzt so wie es immer hätte sein sollen. Über HDMI 2.1 läuft VRR wahlweise mit Freesync oder G-Sync inzwischen problemlos. Ein OLED Display am PC flasht aber meiner Meinung auch noch mal ganz anders als im Wohnzimmer.
CPU zu lahm? ;)
Graka langweilt sich: CPU zu lahm, oder Regler nicht richtig angezogen. Beide Wege führen nach ROM
Tipp: Benenn doch mal deine CPU, Gedankenlesern ist nicht gerade verbreitet 😏
Wenn die Graka sich langweilt, brauchen wir keinen CPU-Namen^^
Anhang anzeigen 808255 Anhang anzeigen 808256
Deswegen ist derzeit der LG C2 42" für etwa 1050€ ne gute Wahl :d
4k 120hz....perfekt mit einer 4090 in Cyberpunk 2077
Also der P Mode bei der Strix läuft bei mir nicht richtig, Lüfter verhalten sich komisch und ich habe Abstürze.
Ich habe nichts verändert, ausser das offizielle Bios Update drauf gemacht.
Seitdem steht beim Powerlimit nicht mehr 90% sondern 100%, hab Abstürze und kann im Afterburner immer noch nicht das Powerlimit erhöhen (was ich eh nicht machen würde, aber komisch ist es trotzdem).
wie sie auf einmal alle im cpu limit hängen......im magischen "always GPU limit 4k " 8-)
Was meint ihr, ist das safe so?
Das Kabel liegt direkt an der Scheibe an. Es ist aber keine Spannung drauf, wenn ich die Tür schließe. Es passt quasi gerade so. Und bei dem Adapter, das helle Stück rechts, ist das normal? Ich habe die Karte heute bekommen und bin im Zuge der "Vorfälle" echt super vorsichtig gewesen mit dem Biegen...
Schau Dir die Screens an.
In schweren CPU-Limits über 100% und zwar nicht nur bei den MAX-FPS, auch bei den Min-FPS geht es höllisch nach oben.
Ich bin begeistert.
Ich habe einen 5950X drinne, aber nutze noch UV...
Ich bin echt am kämpfen ob ich nicht zum 5800X3D umsteigen soll....die 16 Kerne brauche ich jetzt nicht unbedingt, da ich am PC nur zocke...
Damit ich mir ein besseres BIld machen kann suche ich einen direkten Vergleich vom 5950X zum 5800X3D in 4k und mit einer 4090...aber ich finde keinen :d
Finde nur in 720p, 1080p oder 1440p...
den findest du in 720p benches :)
reicht doch. solange die gpu nicht am limit ist, siehst du den unterschied zwischen den cpus und genau das ist doch das was du wissen willst.
in 4k wirst du den gleichen unterschied auf den cpus haben. die auflösung hat keinen einfluss auf die cpu
Ich bin ja mal gespannt wie ein Flitzebogen wie sich der 5800X3D im Vergleich zum 5900X schlägt. Bei 5120x1440 hänge ich bei so vielen Spielen im CPU Limit, hätte ich nicht gedacht. Freitag soll das Teil kommen.
Den findest Du in 720p Benches.
Was die CPU nicht vorbereiten kann, kann die Graka nicht rendern.
Schau dabei auf die Auslastung Deiner Graka JETZT.
Voll ausgelastet? Mehr FPS gibt es nicht.
Nicht voll ausgelastet: Maximal das was in 720p zu sehen ist, ist möglich (oder auch nicht wenn die Graka vorher einknickt).
So einfach isses. Dafür gibts die 720p Benches.
Argh, schade das du nicht in 4K zockst, dass wäre ansonsten tatsächlich hochinteressant geworden 😕
finde das mehr als in ordnung. das muss ausreichen
Ähnliche Themen
