[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Was heißt lange ? Bisher noch nicht dort bestellt, aber mit 7-14Tage würde ich schlimmstenfalls rechnen. Dürfte ja aus England kommen.
Naja hatte halt am 18. dort bestellt und es steht halt die ganze Zeit auf "processing".
England?
Zoll nicht vergessen :fresse2:
Naja das habe die in der Rechnung schon aufgeführt und berechnet.
Achnl gottchen ist dieser jay auf das Thema aufgesprungen der hat sowieso keine Ahnung und von diesem anderem zoid Typen hatte ich mehr erwartet, es gibt Bilder von dem abgerauchten Stecker aber keiner der beiden hat näher nachgeforscht, nachgefragt einfach mal ordentlichen journalismus betrieben ob da vieleicht noch was anderes dahinter steckt...
Jay ist nirgends aufgesprungen, der hat im September schon ein Video zu dem Stecker gemacht und seine Bedenken geäußert.
Außerdem, was soll mehr dahinterstecken? Zotac sprach offiziell schon von nicht mehr als 31x (?) an-/abstecken. Biegen soll man es offensichtlich nicht (was bei Kabeln absurd ist) und die PCI Sig weiß ebenfalls von Problemen. Ich habe da so eine Ahnung, dass das bei den nicht gewinkelten Steckern über die Monate bzw. Jahre noch zu vielen solcher Beschwerden bzw. tatsächlichen Vorfällen kommen wird. Weil nicht jeder ein Nerd ist und sich informiert, wie er ein Kabel ordnungsgemäß zu verlegen hat. Bei einem PC geht man zurecht davon aus, dass man die ganz normal knicken kann. Steht ja auch kein solcher Hinweis direkt bei den Karten dabei, dass man es nicht tun soll...
Es wird derzeit ALLES weggebottet. Ich frage mich zwar warum, ich kann mir nämlich nicht vorstellen, dass das Weiterverkaufen gut funktioniert, aber es scheint trotzdem so zu sein.
Im Alphacool Forum habe ich nach einem ASUS Strix/TUF Kühler gefragt. Sie haben Interesse aber leider keine Karte zur Vermessung. Es wurde angeboten meine Bananen TUF für die Vermessung einzusenden und im Gegenzug einen Wasserblock für lau zu bekommen. Was meint ihr, machen?
Ja, nachdem die PCI Sig davon berichtete. Bei New World hat er auch ordentlich Clickbait betrieben und behauptet, dass auch andere Karten betroffen waren. EVGA hat alle zwölf!! betroffenen Karten ersetzt und man hat nie wieder davon gehört.
Nun gab es 3 User mit verschmorten Kabeln, bei zig tausend verkauften Karten. Es gab bei den alten Steckern ebenfalls Berichte über verschmorte Stecker wie z.B. hier: https://www.hardwareluxx.de/communi...ollten-vermieden-werden.1325528/post-29512518
Vielen Dank für den Verfügbarkeitsbot! Dank dem könnte ich Freitag eine ASUS TUF 4090 OC bestellen. Schon Montag zur Abholung im örtlichen nbb-Store gewesen – der Mitarbeiter war ganz neugierig, wie ich die aus dem System bekommen habe, die kommen mit der Bestellung für den Ladenverkauf wohl nicht durch weil sie immer sofort weg sind^^
Ein Glück sind die Lüfter in der Front bei Lian Li zum Einhaken – da hätte ich nichts mehr geschraubt bekommen nachdem die Graka so genau passt.
Mit dem Umbau auf Wasser lasse ich mir Zeit bis die Blöcke getestet und günstiger sind – nie über 60°C ist wirklich entspannt. Lüfterdrehzahl bei 35% ist zwar lauter als die Wakü aber nichts schlimmes.
Und nun zu der Gretchenfrage: Ja, die ASUS TUF (OC) hat hörbare Spulen. Bei dem riesigen Resonanzkörper auf der Karte ist es auch kein Wunder, dass man alles hört. Man stelle sich vor, die hätten es jetzt noch mit dünnen 1 mm-Wärmeleitpads angekoppelt und nicht die viel kritisierten dicken genommen.
Meine MSI Ventus 3X 3090 war unter Luft etwas leiser, unter Wasser aber fast unhörbar. Die 2070 aus gleicher Serie war schlimmer vom Coil Whine, etwas leiser aber höher als die 4090.
Die 4090 jetzt gibt nur ein tiefes Surren von sich, es ist aber recht laut und wechselt extrem mit der Last.
Die Taktraten waren mit 2680 MHz in Games nicht überragend aber solange keine Volllast anliegt geht da auch 2800+.
Mit 120 Hz G-Sync-Monitor @4K verbrauche ich jetzt 40% weniger Strom als mit der 3090 davor und habe teils Temps wie bei der 3090 unter Wasser. Das ist echt beeindruckend.
Allerdings ist das Teil echt unmöglich auszulasten – gerade in Blender oft nur bei 44-50% GPU load...
Hab die Non OC seit Release, meine war auch fleißig am kreischen und singen, das hat sich aber mittlerweile deutlich gebessert und ist quasi gar nicht mehr vorhanden.
Bei meiner OC ists auch besser geworden, aber es geht nicht weg. Deshalb geht sie heute auch zurück. Selbst wenn ich keine mehr kriege, aber ich kanns nicht mit meinem Kopf vereinbaren 2299€ auszugeben und dann Kopfdruck vom Coil Whine zu kriegen. Wenn es komplett weggehen würde oder nur gaaaaaaanz leise wäre so dass man das Ohr ans Gehäuse legen müsste. Aber so... nee... ich hab mir echt Mühe gegeben mich daran zu gewöhnen, aber es geht nicht. Ich kanns nicht. Selbst mit meinen alten Ohren nicht.
Wenn Du auf die Karte verzichten kannst für die Zeit why not. Können Sie ja gleich umgebaut und getestet zurück schicken.
Täuscht das oder drückt die Stütze die Karte nach oben? Ansonsten top. Soviel Leistung auf so wenig Raum. (y)
Meine 6800XT hat mich was Coilwhine angeht abgehärtet. aber ich hör das mit Kopfhörern auf auch nicht, und die nutze ich beim zocken sowieso immer :d
So jetzt bitte ein Paar Strixx Drops das Geld von der RTX4090 Master möchte wieder ins System fließen.
Das Bodenblech ist an der Stelle sehr flexibel, im Stehen mit der Last der Karte ist sie halbwegs plan.
Fürchte ich muss mich jetzt ans Tunen mit dem 12700K machen, der Dark Rock Pro 4 hat noch Reserven und die CPU auch 8-)
Hier ist angeblich auch eine vorrätig wieder.
Gainward Phantom
Diese einzelnen RTX 4090 Grafikkarten die dann bei den Händlern aus dem Nichts verfügbar sind, werden wohl Rückläufer der Kunden sein, die Innerhalb der 14.Tägigen Rückgabefrist die Grafikkarten zurücksenden. Da werden halt von manchen Käufern drei oder vier verschiedene Modelle gekauft dann ab durch die OC Tretmühle und die "Gurken" die das eigene Anspruchsdenken was OC betrifft nicht erfüllen, gehen dann an den Händler zurück. Tolle Sache für den, der eine solche Grafikkarte kauft! :unsure:
Ich bekomme mein Silent Base 800 mit der 4090 TUF nicht zu.
Hoffe der 90 Angel Adapter löst das Problem.
Kb neues Case zu kaufen und alles wieder umzubauen.
Nice die Karte!
Hat die eigentlich auch ne minimale Biegung hinten?
Hast du es mal mit UV probiert? Meine ist jetzt bei 900mv und 2645MHz nicht mehr zu hören.
Welches Case passt denn am besten für die 4090 ohne Kabelknickbull.hit und Riserkabel?
Spiele mit dem Gedanken auf die WaKü zu verzichten und den 12700K wieder mit Luftkühler zu betreiben.
Schau dir mal das Raijintek Paean Benchtable an. Ein Unikat von Glasgehäuse. Hab es liegend bzw horizontal bei mir mit dem zusätzlichen Seitenteil. Ein Augenschmaus.
Nein, habe ich nicht probiert. Aber bei dem Preis darf das auch nicht notwendig sein mit Workarounds zu arbeiten. Da muss die Qualität aus dem Stand passen.
Schließlich "brauche" ich sie auch nicht. Gerade für Cyberpunk u.ä. wäre sie brauchbar gewesen, aber genau da war eben coil whine am Schlimmsten.
Hach ja, immer gut wenn man eigene Theorien hat die man nicht ansatzweise belegen kann. 😏
weils mir gerade einfällt: am 10.11./11.11/12.11. rum könnte vielleicht bei Cyberport etwas droppen.
Jedenfalls soll da meine Bestellung vom 12.10. bedient werden können.
Und einem anderen User ist mitgeteilt worden, das am 11.11. wohl wieder die TUF im Asus Shop reinkommen würde.
Ähnliche Themen
Antworten
6K
Aufrufe
399K
