[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Für die Grakakäufer:
19% MwSt. geschenkt bei MediaMarkt - ab 26.10. (= 15,97% Rabatt)​
Gibt es eigentlich hier viele Idioten wie mich, die sich eine verflucht teure Grafikkarte besorgen, nur um endlich vernünftig Cyberpunk 2077 spielen zu können aber am Ende Spiele spielen, bei denen eine 1070 in 4k gereicht hätte???
Ich habe bisher nur Brotato und ein paar Runden Fortnite gespielt. :fresse:
Eigentlich war vorher auch meine 3080Ti gelangweilt.
Das könnte eine riesen Scheiße werden.
Also ich hab das mal bisschen getestet, wenn man den Connector "normal" bewegt passiert da nichts, zumindest nichts erkennbares auf der FLIR. Natürlich ist das ein "kleiner" Connector und dicke Kabel... wenn mans knapp hat zur Seite und man klatscht halt die Seitenwand drauf... ja, dann hat das Potenzial. Den Stecker hätte man durchaus besser platzieren können. Muss man halt sehen wie oft das passiert, bis es einen neuen Adapter für alle gibt :)
Ja, hab eine RX 6900 XT LC, kaum wurde die richtig ausgenutzt, schon hab ich die 4090 am Start und denke mir wie bescheuert bist du eigentlich 💩
In der Vergangenheit gab es diese Aktion schon mehrfach und die Rabatte waren echt. Vielleicht braucht man ja auch was anderes. Mein 42" OLED kam auch von MediaMarkt, ist ne schöne Kombo mit der 4090 ;)
Musst du mich jetzt wieder auf die idee bringen vom CX48 auf den C2 42" umzusteigen? :fresse: Da hätte ich grad gar nich dran gedacht
Komisch ist nur, dass die Adapter ja schon bei den 3090Tis verwendet wurden und da bisher kein Fall aufgetreten ist. Vielleicht liegt es auch an den 600W, die manche Karten ausreizen und zu viel für die kleinen Pins der neuen Adapter sind. Evtl. hat MSI daher ihr PT auf 520W begrenzt, um davor zu schützen?
Active Backplate… habe schon einige Systeme gebaut mit 4 GPUs aber eher funktional im zB. 1000D oder Server Rack und auf Xeon. Habe aber noch ein O11D XL hier stehen und finde den Matrix7 Ansatz mit den standardisierten Abständen und Distros eigentlich ganz charmant. Hier ein Beispiel mit drei Radiatoren - bei mir nur eben mit zwei GPUs.
Zur Not mit zwei Radiatoren (+Mora) aber auf Wasser muss ich die Karten bringen, sonst bekomme ich beide Karten logischerweise nicht rein. Später soll die 3090 einer zweiten TUF mit gleichem Block weichen.
Da ist nichts standardisiert. Das passt in der Form und sonst nicht. Das hat mit Standard nichts zu tun. Genau dieses unflexibel an eine Distro Gebundene möchte ich persönlich nicht mehr haben.
Dazu der schlechte Airflow im O11XL. Ich hatte mit 490 Watt Abwärme Tests durchgeführt. Am Ende konnte ich 11/12K Wasser-Luft halten. Dabei hatte ich drei Radiatoren, zwei davon Push/Pull. Zwei GPU +CPU würde ich nicht versuchen. So viel Kohle für Distro und Zeug und dann 20K als Ergebnis? Ich würde bei so viel Abwärme immer auf extern setzen.
Youtube clickbait. Umso reißerischer, desto mehr klicks = yt money. Alleine schon das thumbnail + title. :rolleyes:
Im ganzen netz gibt es nun wie viele berichte? 2 oder 3? Userfehler zudem möglich, wie in dem vid auch wahrscheinlich ursächlich gewesen.
Die restlichen zigtausend laufen.
Nur weil etwas aktuell läuft, ist es nicht per se auch gut und muss in drei Monaten noch genauso aussehen. ;)
Davon ab braucht man Buildzoid keinen Clickbait unterstellen. Der hat Ahnung, wovon er redet.
An die RTX 4090 Besitzer:
Besorgt euch ein "Infrarot Thermometer" und lasst den neben der Grafikkarte immer griffbereit liegen, zum Überprüfen der Temperatur des genialen "12VHPWR" Stecker's.
Angenommen verfügbar, dann eher RTX 3090 FE oder Asus TUF (non OC)?
Die FE hat das bessere PCB mit entsprechenden Bauteilen .Die Karte passt mit Luftkühler in mehr Gehäuse .
Die TUF hat den besseren Luftkühler und ist auch recht einfach auf Wasser umzubauen .
Asus bietet drei Jahre Garantie auf die Karte .
Aber nur über Händler und daher habe ich bewusst im Asus Shop geschaut .
Umbau auf Wasser kein Problem angeblich , wenn man wieder vernünftig zurück baut, wenn ein Garantie Fall Eintritt .Ein Garantie Siegel konnte ich aber auf einer Schraube entdecken .
Nunja, ein Pin der nur ein Kabel hat und nicht 2-4 ist deutlich unanfälliger.
Der Stecker der RTX 3000FE war genauso, aber da hat man eigentlich keinen Mucks von gehört...
Das ein 8-Pin nur 150W kann stimmt so nicht. Corsair hat seine 8-Pin (bzw 6-Pins) bis auf 300W gespecct. Deswegen gibt es von denen auch einen 2x8-Pin auf 12+4-Pin Adapter. Von dem laufen nur 12 Kabel +2 Sensor vom Netzteil zum 12VHPWR Stecker.
Am Ende wird es einen Ansturm auf Cablemod geben, wenn der Wickel-Adapter verkauft wird...
Einige Seiten zurück und bevor cablemod den 90 Grad Adapter angekündigt hat hab ich gefragt warum keiner einen 90 Grad Winkel Adapter bringt und man sich diese Gen damit eine goldene Nase verdienen könnte und zack cablemod bringt den Adapter
Ja der Kerl ist wie die Bild Zeitung, lebt nur von Angst! :)
Also das Kabel des zweiten Falls sieht nach dem Ausbau so von der Biegung her aus, ähnelt meinem :d
Allerdings lassen die Bilder auch hier Vertical Mount vermuten, wenn man sich das 3. Bild Anschaut :d
Ist keine "auf alles" Aktion und daher leider ne ziemliche Mogelpackung mit den ganzen Ausnahmen.
Ausgenommen sind folgende Marken: Apple, Blink, Amazon, Microsoft, Xiaomi, Microsoft, Sonos, Liebherr, Miele, ok., KOENIC, AVM, alle Konsolen, Tonies Starter Sets, ausgewählte TV-Geräte der Hersteller LG, Sony Philips, ausgewählte Samsung / Google / Smartphones, Samsung Wearables, Drucker, Scanner, All-in-one-Geräte von HP, eBook-Reader, Galaxy Buds 2, Roborock S7 MAXV ULTRA, Sony HT-A3000, Canon CP 1300 Geräte, GoPro Hero 9 Black, ausgewählte DSLR von Sony / Canon EOS RP + RF24-105mm, EOS 2000D 18-55, Vorbesteller-Artikel, alle Download-/Content-/Gaming-Cards, Games & Software, Tchibo / Caffissimo, Nespresso Kapseln, Fotoarbeiten und -Bücher, PC-Komponenten, Verträge von und mit Drittanbietern und alle Fundgrubenartikel.
Wird keine "billigen" 4090 vom Blöd Markt geben.
Quelle:
Achja das Kleingedruckte mal wieder. Was bleibt bei den Ausnahmen eigentlich noch übrig? :ROFLMAO:
Denke Igor sollte sich nochmal investigativ mit dem Thema beschäftigen. ...
Hier :) Return to Monkey Island :d Lief auch mit der IGP meines Ryzen 7900X ohne Probleme :d
Das Kabel Problem ist natürlich scheisse...... Komisch das Intel bei den ARC Karten auf den alten Anschluss setzt.
Die wissen schon warum :d
Nachricht gelöscht
Hier:
Perfekt, um GPU und CPU ins Schwitzen zu bekommen.
Ähnliche Themen
