[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Was haltet ihr von meinem Anschluss?
Sicher oder problematisch?
Sieht denke ich in Ordnung aus. Geht ja darum, dass die Kabel am Stecker nicht zu sehr geknickt sind, was bei Dir ja nicht der Fall zu sein scheint. Im Video wurde gesagt, dass es vor allem darum geht, die Kabel nicht horizontal zu sehr zu knicken, d.h. nach links oder rechts.
Nunja, ein Pin der nur ein Kabel hat und nicht 2-4 ist deutlich unanfälliger.
Der Stecker der RTX 3000FE war genauso, aber da hat man eigentlich keinen Mucks von gehört...
Das ein 8-Pin nur 150W kann stimmt so nicht. Corsair hat seine 8-Pin (bzw 6-Pins) bis auf 300W gespecct. Deswegen gibt es von denen auch einen 2x8-Pin auf 12+4-Pin Adapter. Von dem laufen nur 12 Kabel +2 Sensor vom Netzteil zum 12VHPWR Stecker.
Am Ende wird es einen Ansturm auf Cablemod geben, wenn der Wickel-Adapter verkauft wird...
Sollte ich tatsächlich das SF750 holen (was sehr wahrscheinlich ist), hoffe ich mal das Kabel kann man etwas mehr biegen als den Nvidia Adapter, ansonsten hab ich potenziell ein Problem:fire: haha
Hat jemand einen Tipp wo man eine Gigabyte RTX 4090 Aorus Master für um 2300€ bekommt?
2300 keine Ahnung
Aber habe einen anderen Tipp für dich.
1.Lüftersteuerung Fail
2.Karte hat gefiept
3.Material sieht total Billig aus
nun sind sie wieder Günstiger geworden ( die Strix von 2500 Euro wieder auf 2377 Euro ) ... wie gesagt normales verhalten vom Asus Shop .. geht rauf und wieder runter und wieder rauf und wieder runter und war auch schon 2020 so .. warum die das so machen kein plan.
Jetzt muss es die Strix nur auch mal in solchen Mengen geben wie die TUF oder die Gigabyte Gaming oder die Zotac Trinity von den Karten kommen pro Tag ja viele aber die Strix hat sich seit mehr als 1 Woche sehr rar gemacht in Deutschland.
Ja seltsam wahrscheinlich ist denen langweilig :d
Weiß jetzt nicht, ob das was mit der GPU direkt zu tun hat, aber crasht bei euch auch A Plagues Tale Reqiuem jedes Mal wenn der Name des Studios im Intro erscheint?
(Und bitte keine krummen Bananen-Witze dazu!^^)
Hast du mit dem Laden schon Erfahrungen gesammelt? Wie ist das bei einem Defekt?
Vermutlich nicht besser oder schlechter als bei einem Laden in D oder Ö. Ich weiß trustpilot sagt nur bedingt was aus, hat aber gute Bewertungen. Gruppe hat etliche Filialen in FR, dürfte etwa wie MM sein. Auf mails in englisch reagieren sie freundlich und in angemessener Zeit.
Wird schon passen denk ich :-)
Also ich zock jetzt einfach mit der Karte und genieße die Leistung. Hab den 4 Zack dran, hab stundenlang und mehrfach auf 7680x1440p mit hoher Auslastung gezockt, nichts brennt und alles läuft einwandfrei. Gigabyte gaming oc mit nem Dark Power Pro 11 850 Watt. Mit einem Game ein Problem gehabt, alle anderen laufen einwandfrei. Man darf sich von einer Meldung auch nicht verrückt machen lassen. Natürlich melden sich die mit Problemen gehäuft, aber das ist auch richtig und gut so, um alle Infos zu sammeln. Das Gro der Leute wird einfach zocken oder rendern und fertig.
Der beste Kommentar ist "maybe you pluged in 31 times"...
Hätte ich gewusst, worauf ich mich einlasse, wäre ich wohl nie zur 4090 gewechselt :d
Ich durfte meine ganze WaKü umbauen (Block für Grafikkarte fehlt ja noch),
Gehäuse geht nicht mehr zu (O11 Dynamic XL)
Selbst bei späteren Umbau auf den Wasserblock, werde ich die wohl Vertikal einbauen müssen. Denn an den Anschlüssen ändert sich ja nichts.
So wurden aus geschätzten 60Minuten Umbau (Hatte vorher eine Wassergekühlte Grafikkarte drin), 3 Stunden Bastelspaß.
Jetzt geht es erst mal ans Testen des Backsteins
Benutzt ihr eigentlich den HWL bot oder wie hats bei euch geklappt?
Bei Alternate waren ja gerade wieder zwei Gainwards, ich hab instant auf die Telegram Benachrichtigung geklickt und beide male war schon wieder vergriffen. Sind das Checkout-Bots oder ist der API-Checker hier nicht schnell genug?
Hat einer seine Subriem X vertikal verbaut und wo hat er das Kit gekauft hält , es denn auch vom Gewicht her mein Gehäus ist ein Fractal design meshify 2xl gibt es denn große Temperaturunterschiede
Lg
Aber gibt's dazu iwo ne Rezension?
Aber die sollen wenigstens nicht fiepen, oder? Sind die anderweitig auch leise?
Was ich bisher an Nutzerreviews gelesen habe sollen sie wenig fiepen, aber evtl. Probleme mit den Lüftern haben.
Bei meinem Glück werde ich vermutlich genau so ein Modell erwischen 🤣
Bisher noch nicht da bestellt. Hat aber durch die Bank sehr gute Bewertungen (Trustpilot usw.) und ist wohl einer der größten Hardware Händler in Frankreich (ähnlich Mindfactory). Viele Journalisten usw. werden in FR von denen wohl beliefert.
Bez. Garantie läuft laut Website usw. alles genauso wie bei uns. Denke mir da gar nix.
Aloha. Hab da mal eine Frage. Bei mir werkelt eine 4090 zusammen mit einem 5800x. Spiele auf 1440p. Nun hab ich spaßeshalber mal in Cyberpunk alles auf Maximum gejagt und hatte so um die 70-80 FPS. Dann aktivierte ich DLSS in verschiedensten Konfigurationen, aber irgendwie bringt das nicht besonders viel. Eventuell einen Unterschied von 5-8 FPS. Woran kann das liegen?
Jo musste aber französisch studiert haben, sonst biste raus.
Update: Hat sich erledigt. In dieser Minute sind welche bei ldlc auf Lager gegangen. Die liefern auch nach DE - zusammen dann 1942 inkl. Versand. Falls noch wer eine braucht - schlagt zu!
Ich drück dir die Daumen, dass es klappt. Aus persönlicher Erfahrung kann ich sagen, dass ich mehrfach bestellt habe und die Sachen dann obwohl auf Lager, nicht auf Lager waren :P
Lg
Vertikal im Dark Base verbaut. Musste das Cablemod Bracket allerdings auch etwas modden damit die 3-Slot Suprim passt.
Temps sind im Dark Base sowieso immer höher als in anderen Gehäusen aber ich finde es halt zeitlos schön.
Du bist wohl im CPU Limit. Afterburner an uns Auslastung der gpu>98%?
Lg
Jupp, hab ich gemacht im Meshify S2.
Von CableMod das Vertikal Mounting Bracket + 15cm PCIe 4.0 Riser von LinkUp.
Musste bei dem Bracket aber noch eine kleine Ecke rausflexen, weil das Bracket nur für 2 IO Slots ausgelegt ist.
Die Karte kommt durch das Bracket nochmal 2,5cm Richtung Gehäusefront, sitzt dafür aber schön tief im Gehäuse so dass ca. 5cm Platz zur Seitenscheibe ist. Temperaturen unter Last ca. 64 Grad, horizontal verbaut hab ichs nicht getestet.
Die Last auf den Riser ist gering, weil das Hauptgewicht vorne von den 3 Slots auf dem Bracket getragen wird.
Wollt erst noch schwarze Hartplastikabstandshalter oder schwarze Legosteine direkt unter die PCIe Halterung klemmen, aber das war nicht nötig. Sitzt da bombenfest.
Auf was du noch achten müsstest, wäre ob deine Slotblenden im Meshify 2XL frei sind, oder ob da noch Blechstreben dazwischen sind. Dann müsstest du da auch eine rausflexen, damit du bei vertikalen Verbau hinten die Anschlüsse noch gut erreichst und vorallem ein Kabel reinbekommst.
Auf was du noch achten müsstest, wäre ob deine Slotblenden im Meshify 2XL frei sind, oder ob da noch Blechstreben dazwischen sind. Dann müsstest du da auch eine rausflexen, damit du bei vertikalen Verbau hinten die Anschlüsse noch gut erreichst und vorallem ein Kabel reingekommst.
Slotblenden sind frei.
Lg
Einige bestellen sich 5 Karten und suchen sich die Beste aus....... Ich versteh schon, 2000 € sind viel Geld und da erwartet man Qualität, aber was manche hier betreiben ist "Cherry picking" in Reinstform
Schau mal hier in den Marktplatz da werfen einige mit einer ganzen Sammlung so um sich, finde ich noch viel schlimmer.
Da ich beim Homesetup erstmal Vorhandenes nutzen möchte, weil weder zweiter Block noch zweite TUF 4090 zeitnah zum guten Kurs realisierbar, plane ich gerade einen etwas abenteuerlichen Loop mit einer 4090 TUF ABP Block (bestellt - auch, wenn nicht unbedingt nötig, da Abwärme über BP vernachlässigbar) und 3090 Strix mit ABP Block (weil vorhanden) in Kombination wie folgt einzusetzen. Terminals sind leider leicht versetzt. Freue mich über regen Austausch, Einwände oder Verbesserungsvorschläge.
Mainboard crosshair viii hero Wifi, O11D XL (ja, ich weiß - langweilig :-) ), Reflection2 Distro, Vector2 CPU Block, 3x P360M Radiatoren etc.
Tubing mit Quantum Torque Fittings. 14er Tube
Wenn hier unerwünscht, schiebe ich den Beitrag in's Wasserkühlung-Forum.
Ich kann dir nur dazu raten das Vorhaben bleiben zu lassen. Das O11XL ist sehr restriktiv bei Einbau von drei Radiatoren. Es macht keinen Spaß.
Was ist ein ABP Block?
Also mal abwarten . Es kommen ja noch die anderen 4000er Karten und RDNA 3 und der Markt ist noch voll von Ampere sowie der Gebrauchtmarkt.
Als Ampere kam gabs ja wirklich garnichts zu kaufen. Da konnte man 2000er und 1000er Serie für viel Geld verkaufen.
Aktuell kann man ja Karten wie so ne 6800XT für 633€ kaufen die ja auch garnicht so schlecht sind.
Für 1150 € rum ne 3090 ist ja auch nicht schlecht .
Damit kann man auch was anfangen .
Das es tatsächlich so viel Leute allem anschein gibt die mal 1950-2500€ locker machen für ne 4090 hätte ich so auch nicht erwartet :d
Aber es ist wirklich so , dass es die erste Karte ist wo ich für UHD Gaming wirklich zufrieden bin .
3090 war nicht schlecht , aber hatte schon hier und da in UHD bei manchen Titeln etwas geschwächelt ^^
Ich meine sogar, dass die 4090 überfordert ist mit 4k. Einfach auf STALKER 2, Atomic Heart, Witcher 3 usw warten, dann gehts zur Sache. (y)
Das wirds wohl sein. Ist meine erste Karte, welche DLSS unterstützt. Daher muss ich mich erstmal da ran tasten :d Danke!
Nutzt ihr eigentlich den Adapter der den Karten beiliegt oder eher zb das ne quiet Kabel? 12VHPWR , viele Grüße
cpu limit kannst du ja testen.
auflösung runterschrauben und schauen was für fps rauskommen.
Ähnliche Themen
Antworten
7K
Aufrufe
475K
