[Sammelthread] DDR5 Info- & Laberthread 2025
DDR5 - Ein Überblick
DDR5 Tests & WWW Reviews
DDR5 Links & weiterführende Informationen
(@even.de)
(@Reous)
  • Preisvergleich: https://geizhals.de/?cat=ramddr3&xf=15903_DDR5
  • DRAM Hersteller:
    - Hynix : DDR5
    - Micron : DDR5
    - Nanya : DDR5
    - Samsung : DDR5
  • JEDEC DDR5 Standard: JESD79-5 (paywalled)
  • Informationen zu den DDR5 Timings und JEDEC Speed Bins: Insights into DDR5 Subtimings and Latencies @ AnandTech
  • Intel Extreme Memory Profile DDR5 Standard: Ver 3.0 (Microsite | XMP 3.0 - Certified Memory List)
  • SPD Fixing (ASUS Method): https://www.overclock.net/threads/corrupted-ddr5-spd-fix-tutorial.1795935/
  • Single vs Dual Rank DDR5 Tested (AMD Ryzen 7 7800X3D & MSI MEG X670E ACE)
    https://www.purepc.pl/test-pamieci-ram-ddr5-single-vs-dual-channel-single-vs-dual-rank-amd-am5
  • OC Guides (general)
    1) https://www.tomshardware.com/how-to/overclock-ddr5-ram
    2) https://www.igorslab.de/wie-ueberta...r-richtig-basic-und-tutorial-fuer-das-ram-oc/ (für DDR4, enthält aber die Basics)
    3) https://github.com/integralfx/MemTestHelper/blob/oc-guide/DDR4 OC Guide.md (für DDR4, enthält aber die Basics)
  • OC Guides (AMD)
    1) https://www.overclock.net/threads/amd-hynix-ddr5-overclocking-guide.1801842/
    2) https://www.igorslab.de/amd-ryzen-7...m-praxistest-mit-benchmarks-und-empfehlungen/
    3) https://skatterbencher.com/2022/09/26/raphael-overclocking-whats-new/
    4) AM5 Memory Performance Scaling @ Techpowerup
  • OC Guides (Intel)
    1) https://skatterbencher.com/2021/11/04/alder-lake-overclocking-whats-new/
    2) https://vintologi.com/threads/ddr5-overclocking-nightmare.1229/
    3) https://www.overclockers.com/ddr5-overclocking-guide/
  • OC Guides (Video)
    1) Intel 13th Gen K series & DDR5 overclocking insights and demos @ ASUS
    2) Finding the timing limits of Samsung DDR5 16Gb B-die at 6400Mbps (Intel) @ AHOC
    3) Finding the limits of Hynix DDR5 at 6666Mbps (Intel) @ AHOC
    4) DDR5-6800 CL34 OC with just 1.45V on the MSI Z690 Unify X @ AHOC
    5) Easy memory timings for Hynix DDR5 with Ryzen 7000 @ AHOC
1) 2x16GB DDR4-4000 CL14 vs 2x16GB DDR6-6000 CL36
2) 2x8GB DDR4-3733 CL17 vs 2x8GB DDR5-5600 CL40 (Patriot Viper Steel vs Patriot Viper Venom)
3) 2x16GB DDR4-3600 CL18 vs 2x16GB DDR5-4800 CL40 vs 2x16GB DDR5-6000 CL36 vs 2x16GB DDR5-7200 CL34 (TeamGroup T-Force Delta RGB FF3D516G7200HC34ABK)
4) 4x8GB DDR4-4000 CL15 vs 2x16GB DDR5-7200 CL34 (G.SKILL Ripjaws V F4-4000C15Q-32GVK vs Trident Z5 RGB F5-7200J3445G16GX2-TZ5RK)
Hardwareluxx: Corsair Dominator Platinum RGB CMT32GX5M2B5200C38-PK1 | G.Skill Ripjaws S5 F5-5200U4040A16GX2-RS5W | Kingston Fury Beast KF552C40BBK2-32 (vs DDR4-3200/4000, Corsair Vengeance CMW32GX4M4C3600C18)
1) Corsair Dominator Platinum RGB CMT32GX5M2B5200C38 (vs Corsair Dominator Platinum RGB DDR4-3600 16-16-16 ???)
2) Corsair Vengeance CMK32GX5M2B5200C38 (vs ADATA XPG Gammix D20 AX4U36008G18A-DCBK20)
3) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs verschiedene Ripjwas V / Trident Z DDR4 in G1/G2)
4) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs Crucial Ballistix Max RGB BLM2K16G44C19U4BL)
5) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs G.SKILL Trident Z Royal F4-3600C16D-32GTR?)
6) G.SKILL Ripjaws S5 F5-5200U4040A16GX2-RS5W (vs G.SKILL Trident Z Royal Elite F4-3600C14D-32GTESA)
7) G.SKILL Ripjaws S5 F5-5200U4040A16GX2-RS5W vs G.SKILL F4-3600C14D-32GTESA @ i2hard.ru
8) Kingston Fury KF552C40BBK2-32 vs G.Skill Trident Z RGB F4-3600C16D-32GTZR @ Guru3d
9) Corsair Vengeance CMK64GX5M2A4400C36 vs Corsair Vengeance LPX CMK32GX4M4K4000C19 - Linux Performance @ Phoronix
10) G.SKILL Trident Z5 F5-6000U4040E16GX2-TZ5S (OC 6200 CL38) vs G.Skill Trident Z Neo F4-4000C16D-32GTZNA(?) @ CapframeX (mit AMD Vergleichswerten für 5900X & DDR4-3733 CL14)
1. Analyse @ TechPowerUp
2. Cooling DDR5 Server Memory with a Corsair Vengeance Airflow @ Phoronix
Die ist eine verkürzte Schreibweise, mit der man sich auf einen bestimmten IC Typ bezieht.
Zusammensetzung (am Beispiel von H16M): DRAM Manufacturer (Hynix) | IC Denisity in Gbit (16Gbit) | Die Revision (M-Die)
Häufig verwendete Kürzel:
M16A - Micron 16Gbit A-Die
H16A - Hynix 16Gbit A-Die
H16M - Hynix 16Gbit M-Die
S16B - Samsung 16Gbit B-Die​
Die Kürzel können auch generationsübergreifend verwendet werden. Dabei wird die DDR-Generation vorangestellt. Beispiele:
4S8B = Samsung 8Gbit B-Die DDR4
4S16B = Samsung 16Gbit B-Die DDR4
5S16B = Samsung 16Gbit B-Die DDR5​
CorsairG.SKILL
Ver3.43.01 = Micron 16Gbit A-Die (Q1 | Q2 | Q3)
Ver3.43.02 = Micron 16Gbit B-Die (Q1)
Ver3.43.04 = Micron 16Gbit D-Die (Q1)
Ver3.53.02 = Micron 24Gbit B-Die (Q1)
Ver4.43.13 / .02 = Samsung 16Gbit B-Die (Q1 | Q2 | Q3)
Ver4.43.19 = Samsung 16Gbit P-Die (Belege gesucht)
Ver5.33.01 = Hynix 16Gbit A-Die 8Gbit Downbin (laut OC-Test @)
Ver5.43.01 = Hynix 16Gbit A-Die (Q1)
Ver5.43.13 = Hynix 16Gbit M-Die (Q1 | Q2 | Q3)
Ver5.53.13 = Hynix 24Gbit M-Die (Q1)
What integrated circuits ICs are used on my Corsair memory?
Lot Code
-88... = 8Gbit Downbin eines 16Gbit ICs, -8821A entspricht also einem 5H16A Downbin
-S810B = Samsung 16Gbit B-Die (Q1)
-S82*A = Hynix 16Gbit A-Die (Q1)
-S82*M = Hynix 16Gbit M-Die (Q1)
-S83*A = Micron 16Gbit A-Die (Q1)
-R810B = Samsung 24Gbit B-Die (Q1)
-R82*M = Hynix 24Gbit M-Die (Q1)
-R83*A = Micron 24Gbit A-Die
KingstonPatriot
Production Code: ETM[M][08]A2104
H - Hynix
K - Chips wurden relabeled / ICs have been relabeled by Kingston
M - Micron (Spectek)
N - Nanya
S - Samsung
04/08/16 = Anzahl der auf einem Modul verbauten DRAM Chips.
Daraus ergibt sich auch die Organisation:
04 = 1Rx16
08 = 1Rx8
16 = 2Rx8
Nach aktuellem Stand hat sich Patriot offenbar dazu entschieden den, von den DDR3 und DDR4 Modellen
bekannten, seitlichen Produktionscode auf dem Label zu entfernen. Die bisher abgelichteten Kits hatten
statt dessen an dieser Stelle alle nur noch fünf Sternchen (*****). Damit ist also an Hand des Labels keine
Identifikation der ICs mehr möglich.
Update: Bei neueren Modellen sind auch diese 5 Sternchen nicht mehr vorhanden.
CrucialMicron
Zusammensetzung: SKU.Suffix
SKU: CT16G56C46U5 - Part Number des Moduls
( Hier eines von zwei Modulen aus einem Kit vom Typ CT2K16G56C48U5. )
Suffix: .M8G1
M - DRAM Manufacturer: (M)icron, (H)ynix, (K/S)amsung
8 - Anzahl ICs: 4 = 1Rx16, 8 = 1Rx8, 16 = 2Rx8
G - Die Revision: A (Rev A / "A-Die"), G (Rev G / "G-Die")
1 - PCB Revision
Die Speicherdichte lässt sich aus der Kapazität des Moduls und der Anzahl der DRAM Chips ableiten. Ein 16GB Modul in 1Rx8 und ein 32GB Modul in 2Rx8 Organisation sind beispielweise aus 16Gbit ICs produziert.
Beispiel 1 (32GB UDIMM): MTC20C2085S1EC56BG1R = Rev G (DDR5-5600)
Beispiel 2 (32GB UDIMM): MTC20C2085S1EC48BA1R = Rev A (DDR5-4800)
Beispiel 3 (16GB UDIMM): MTC10C1084S1EC48BA1R = Rev A (DDR5-4800)
Speed Bin | Die Revision
Micron Part Number Decoder (für IC Codes):
Der DRAM Hersteller ist üblicherweise in das SPD programmiert und wird von CPU-Z (SPD Tab) angezeigt. Wenn die Die Revision programmiert ist, kann sie per Software z.B. mit HWiNFO (ab 7.26), Passmark RAMMon (ab 3.0) oder Thaiphoon Burner* ausgelesen werden. Ist sie nicht hinterlegt, wird im entsprechenden Feld je nach Programm nur "0.0" oder "N/A" (not available) angezeigt.
corsair-ddr5-7200-cl34-hwinfo_1920px.png HWInfo64_DRAM_Stepping_7.40.5000 [2].png
*Die Verwendung erfordert unter Windows 11 zur Zeit die temporäre Deaktivierung der Windows Kernisolierung und Speicherintegrität (02/2023).
So, hier noch die versprochene Excel-Tabelle. Einfach den gewünschten Takt eingeben, und die Primarys, dann rechnet es die anderen aus. So mal als Hilfe. Kann auch gerne in den Startpost angepinnt werden.
Download Im Anhang.
Code:
https://www.dropbox.com/scl/fi/tgtf06sufmnwuf833fo53/DDR-5_entry-guide-by-pakhtunov.pdf?rlkey=bvfwi5sj1hy1g0mzsnh1ws20v&dl=0
Das Original ist nicht mehr verfügbar. Eine Übersetzte Fassung gibt es zum Download bei Overclock.net (Link).
Vereinfachte Übertaktungstabelle DDR5 (erste Version):
Hinweise
tCL - beliebig, aus dem Intervall 22 bis 66
tWR - ein Vielfaches von 6, aus dem Intervall 48 bis 96
tRTP - gültige Werte 12, 14, 15, 17, 18, 20, 21, 23, 24
CCDL - beliebig, aus dem Intervall 8 bis 16
CCDLWR - entspricht dem Doppelten von CCDL, ergo nur gerade Zahlen aus dem Intervall 16 bis 32
Micron DDR5 Table.png DDR5_Performance_Preview.png ddr5_micron_infographic.png Intel XMP 3.0 Standard.jpg GSK_DDR5_Lot_Code_RCR.jpg Kingston_DDR5_Lot_Code_RCR.jpg AMD-Roadmap-Leak.jpg Intel Alder Lake Mobile Lineup.jpg PDF Final Intel ISC June 18 Deck for Press Briefing -page-017.jpg JEDEC_DDR5_10.png JEDEC_DDR5_RDIMM_12.png JEDEC_DDR5_09.png
Einige Informationen noch vorläufig. Bitte tagged mich für Korrekturen/Ergänzungen zum Startbeitrag und verlinkt immer auch die originale Quelle. Danke!
  • simpletable2forDDR5.zip
Ich teste ganz in Ruhe alles im 2en Rechner aus, bis das OC und die Ram Timings stimmen, da meine Wasserkühler von ALC und EK für die neue Karte eh noch nicht da sind. So habe ich Zeit das alles perfekt läuft wenn ich das in den Hauptrechner umbaue.8-)
Kann mir zufällig jemand sagen ob SP 114 für den 7950X gut oder schlecht ist? Hab da nix gefunden.
Der läuft nur mit -25 im Curve Editor stabil.
Wenn man 2 PC hat ist das natürlich super. Denn Luxus habe ich leider nicht. Naja mal schauen ob sich noch andere Melden und ihre SOC bekannt geben mit 6000er Ram.
@Scoty Das ist immer ganz nice. Hier mal das Test setup.
Alles weitere poste ich ggf. im
[Sammelthread] ASUS ROG Strix X670E-E Gaming WIFI​
sonst wird das hier zu off topic.
Gibt es einen groben Erfahrungswert, ob eher günstige Z690 Boards wie beispielsweise das MSI Pro Z690-A für 6400er DDR5 taugen?
Laut Spezifikationen bei 1DPC 1R maximal 6400MHz. Bin jetzt in dem Thema DDR5 nicht so drin, aber wenn ich das richtig verstanden habe sind diese Module aktuell meist M-Die und bislang konnte ich nicht so richtig rauslesen, ob die nun DR oder SR sind?
Natürlich mal ausgeklammert, dass der IMC das auch mitmachen muss.
Die Z790 Boards haben teils deutlich höhere Angaben, aber ich habe keine Ahnung, inwiefern das am Ende nur Marketing ist.
Mfg
Kiryu
Ist gestern vielleicht etwas ungegangen, aber der Weltrekord für den höchsten Speichertakt wurde ebenfalls verbessert (auf 5564.8MHz):
bekommt man irgendwo schon 7200/7600 lieferbar?
Bei Alternate in 10 Tagen der G.skill, für früher halt täglich Geizhals checken. Hab den günstigeren G.Skill 6600 mit A-dies, der geht auch 7600, aber habe es noch nicht MemTestPro/Karhu stable auf Z790, benchen geht aber schonmal wunderbar.
ja den ab ich schon gesehen, danke
Es konnten bei Alternate wohl auch schon welche die 7600er abholen obwohl da was von 11 Tagen steht vllt bei Interesse einfach bestellen.
Gibt es eine Liste wo man sehen kann welche Kits Hynix a dies haben?
Tests sind im Startbeitrag gesammelt. Wenn darüber hinaus auch noch Interesse an einem eigenen Sammelthread mit SKU-Liste (Foto/Screenshot/OC-Ergebnisse) besteht, wäre ich bereit das zu übernehmen. Vorausgesetzt Ihr helft beim Zusammentragen der Informationen selbst aktiv mit, so wie anfangs bei der B-Die Liste.
7200er Teamgroup waren vor einigen Tagen auch schon mal sporadisch bei ein paar Händlern (in kleinen Stückzahlen) zu kaufen, die habe ich drin. Sind auf jeden Fall A-Die (FF3D532G7200HC34ADC01). Laut Seriennummer war die Herstellung 2 Wochen zuvor, die Riegel sind also relativ frisch. Ich denke in den nächsten Wochen werden noch einige Kits verfügbar und kaufbar sein.
Sind nicht mehr zu bestellen. Scheinen aktuell auch keine mehr da zu haben. Warte noch auf weitere Bearbeitung.
Alles über 6200 hat ziemlich sicher Hynix M-Die das wäre so mein Minimum to go.
Ansonsten gibt es je nach dem was es für Cl Werte unterschiede da gibt es auch spezielle Konfigurationen mit Samsung Chips.
Ich würde da gern noch mehr raus holen, nur mangelt es mir an Ahnung...
Kann ich diesen Ram: F5-6000J3038F16GX2-TZ5NR ...auch mit einer Intel 13th Gen CPU nutzen oder hat der nur EXPO und kein XMP?
Du kannst ihn mit einem Intel System benutzen, aber er hat kein XMP sondern nur EXPO.
ist es egal ob es rbg, silber oder schwarz ist? ist da immer der gleiche chip drauf?
( https://geizhals.de/g-skill-trident...t-32gb-f5-6000j3636f16gx2-tz5rk-a2663294.html )
Bisher sind für dieses Modell nur S16B bestätigt, langfristig kann sich das aber noch ändern.
wie sieht das bei ddr5 aus? gibt es da auch einen "spezial"-guten-chip?
Jain, das hängt stark von der Plattform ab. Für Intel und RAM-OC vorzugsweise H16A, für AMD eher H16M (oder S16B). Bis auf M16A hat also jeder IC Typ seine Nische.
also ist es bei ddr5 eher plattformabhängig und es gibt nicht DEN riegel, den man empfehlen kann. verstehe.
denke ddr5 ist da noch relativ weit am anfang der entwicklung. ddr4 ist im grunde fertig entwickelt. da gibt es wenig potential.
Es ist allgemein nicht unbedingt die Regel, dass ein einzelner IC eine ganze DDR-Generation (über Jahre hinweg) dominiert. Das war bei DDR4 mit 4S8B definitiv eine seltene Ausnahme. Natürlich könnte es einen ähnlich erfolgreichen IC auch für DDR5 wieder geben, doch das ist ganz sicher keiner der bisher verfügbaren.
irgendwas wirds bestimmt geben, was gut Takt mit niedriger Latenz fahren kann, ob das ein einziger IC sein wird, bezweifel ich mal. S8B war schon ein Einhorn. Aber auf ein paar wird man sich bestimmt früher oder später einschießen.
4s8b... weiß nicht, was du damit meinst.
hab mal 2 bilder meiner riegel angehängt.
ist dies der 4s8b bzw. der gut gehende ram?
klasse. danke.
habe mal versucht weniger als 1,35v zu geben mit 3200. da gibts nen blue screen. also undervolten bei stock leistung scheint schlecht zu klappen. scheinbar sind sie dafür weniger geeignet.
ich lese immer wieder: xmp einstellung kostet leistung. man sollte manuell nachjustieren. was ist da dran? wieviel bringt manuelles einstellen?
Ja, sieht man an den timings. 3200 C14-14-14-34 kann nur S8B
Das war die längste Zeit richtig, stimmt genau genommen aber nicht mehr. Die praktische Relevanz des zweiten IC Typs ist für uns in Europa aber kaum (nicht) vorhanden. Trotzdem der Vollständigkeit halber:
Der eine oder andere hat es vielleicht schon mitbekommen, aber es gibt inzwischen Berichte über einen IC von Changxin (CXDQ3A8AM-CQA), der - wenn ausreichend selektiert - typische S8B Specs clearen kann und auf einer Limited Edition der Netac Shadow RGB verwendet wird. Unter den angekündigten Spezifikationen befinden sich z.B. NTJYD4P32DP-16SL mit 2x8GB DDR4-3200 14-14-14 1.35V.
NETAC NTJYD4P32DP-16SL (NJYSU1BD4163200HC8DP) [3d].jpg NETAC NTJYD4P32DP-16SL (NJYSU1BD4163200HC8DP).jpg NETAC NTJYD4P32DP-16SL (NJYSU1BD4163200HC8DP) [IC-photo2].jpg NETAC NTJYD4P32DP-16SL (NJYSU1BD4163200HC8DP) [SPD].png
Quelle:
1) https://news.mydrivers.com/1/800/800021.htm
2) https://news.mydrivers.com/1/800/800077.htm
Sollten die Kits tatsächlich im Handel auftauchen, sich die Berichte bestätigen und die ICs auch von den anderen Herstellern verwendet werden, werde ich die Liste einfrieren bis nähere Information zum Scaling und Möglichkeiten zur Unterscheidung beider ICs in der Praxis bekannt sind.
Mir sind nach wie vor keine Berichte bekannt, dass eines der gelisteten S8B Modelle auch mit CXDQ3A8AM-CQA produziert wurde. Die ICs selbst werden allerdings auch von anderen Herstellern wie z.B. Silicon Power verwendet.
Auf Grund der typischen Skalierung sind S8B sehr gut auch für Undervolting geeignet, man sollte nur diese nur verstehen um passende Einstellungen zu finden. Ich hab in meinem User Reviews auf Nachfrage aus dem Forum zum Beispiel DDR4-3600 CL18(-18-18) mit 1.2V gezeigt. Die S8B Übersicht hat im Startbeitrag auch ein Diagramm dazu.
Da dies jedoch ein DDR5 Sammelthread ist, nun bitte wieder zurück zum eigentlichen Thema!
Habt jemand eine Empfehlung für mich?
Suche 32gb Kit für ein Z690 Formula bis ca 250€, ab 6000er für einen zukünftigen 13700k
Groß übertakten möchte ich nicht, dazu ist das Formula ka auch nicht so gut geeignet, gegen etwas Potential bei den Timings hab ich aber nichts einzuwenden. ;)
@ernsthaft Bei 250 Euro fängt es für Kits mit besseren Timings gerade an interessant zu werden. Habe hier deshalb mal für unter 260 gefiltert:
Bei beiden Herstellern kannst du die Kompatibilität auch direkt auf der verlinkten Produktseite prüfen.
@mischi71
Also preislich schon mal Top, sollten auch SK Hynix M-Die sein, etwas potential haben, optisch passen die halt nicht so gut. Schon mal vielen lieben Dank.
@emissary42
Danke dir emis, du bist wie immer eine große Hilfe. Sind das nicht vermutlich alles B-Die? Das heißt wie immer viel tweaking bei den sub timings benötigen nicht wahr? Um sie überhaupt zum Laufen zu bekommen?
