[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Will nicht wissen wie viele Leute ein Invite bekommen und nichts damit anzufangen wissen und wir lecken uns hier die Finger danach.
Mein Sohn hat seit gestern auch GE auf seinem Rechner:-)
Frage mal die ganzen Leute die letzten Dienstag eine 4090FE bei NBB gekauft haben...das sind alle restlichen von den invites.
Ich schicke meine TUF OC Morgen an den ASUS Shop zurück. Dann sollte schon vor dem 11.11. wieder was reinkommen. :d
Vielleicht kann mir hier ja jemand helfen. Ich hab das Problem mit der 4090 TUF und der 4090 FE das wenn 3x 4k 120hz monitore angeschlossen sind windows leicht ruckelt und ich in z.B. League of Legends nicht dauerhaft 120 fps erreiche wenn VSync an ist und wenn VSync aus ist die VPS beim über die map fahren zwischen 100-700 fps schwanken. Das ist extremst nervend weil sich das spiel so anfühlt als würde ich auf einem Notebook bei 20 fps spielen. Mit dem gleichen Treiber und einer 1080ti tritt das Problem bei selben setup nicht auf. Bin schon mit DDU drüber und Max Performance erzwingen das die Karte dauerhaft max takt fährt hilft auch nicht.
Kann das irgendwer hier reproduzieren?
Hab Heute Morgen meine KFA2 bekommen und die ist traumhaft leise was Spulenfiepen angeht. Bin damit für diese Generation bedient.
Und das alles ohne Marketing blabla HCI Spulen wie bei MSI oder Militärqualität ASUS bullshit.
Wie verhält sich die KFA2 von der Lautstärke der Lüfter unter niedrigen Drehzahlen und Last?
Wolltest du nicht auch auf Wasserblock gehen? Ist dir was bekannt ob für die KFA ein Block kommen wird?
Vielleicht kann mir hier ja jemand helfen. Ich hab das Problem mit der TUF und der FE das wenn 3x 4k 120hz monitore angeschlossen sind windows leicht ruckelt und ich in z.B. League of Legends nicht dauerhaft 120 fps erreiche wenn VSync an ist und wenn VSync aus ist die VPS beim über die map fahren zwischen 100-700 fps schwanken. Das ist extremst nervend weil sich das spiel so anfühlt als würde ich auf einem Notebook bei 20 fps spielen. Mit dem gleichen Treiber und einer 1080ti tritt das Problem bei selben setup nicht auf. Bin schon mit DDU drüber und Max Performance erzwingen das die Karte dauerhaft max takt fährt hilft auch nicht.
3x 4k 120hz Monitore? Nutzt du einmal HDMI 2.1 oder nur DP 1.4?
DP 1.4 läuft ja nur mit Einschränkungen auf 4k 120hz.
Wenn du diese Einschränkungen nicht einstellst, kann der keine 120hz.
ich habe da mal ein paar Fragen zur Gainward 4090 Phantom (non-GS).
Ich habe die eingebaut und läuft alles super. Mitgeliefert worden ist ja ein Adapter mit 3 Anschlüssen, also 450 Watt. Auch laut GPU-Z max. 450 Watt.
Wenn ich mir nun ein neues Kabel (600W PCIe 5.0 12VHPWR Type-4) kaufen würde, würde diese Limitierung dann aufgehoben werden?
Und ganz doofe Frage ... wo schalte ich das BIOS um? Hatte so beim Einbau nichts gesehen, oder klappt das auch per Software?
Moin zusammen,
nach langem "stillen" mitlesen habe ich mich dazu durchgerungen auch mal ein Account zu erstellen.
Hab bereits zwei mal versucht die FE zu bekommen (12.10. und 18.10.). Leider bin ich beides mal leer ausgegangen weil andere schneller waren :heul:
GFE benutze ich seit 2016, und hab leider noch kein Priority-Invite von Nvidia bekommen. Spielen tue ich in WQHD mit (wenn im Spiel möglich) RTX On (EVGA RTX 3080 FTW3 Ultra).
In CP2077 habe ich (alles auf max was geht, DLSS Quality und Sharpness auf 0.4) so 30-60fps (je nach Region/Distrikt)
Nachdem EVGA leider weg vom Fenster ist, ist die FE gesetzt.
Nvidia, gebt mir einen Invite, ich bin Zahlungswillig! :fresse2:
Grüße aus dem schönen Niedersachsen nähe Hamburg!
Meine 3090FE dreht grad noch paar Benchmark loops in meinem Rechner. 8-)
Hab die Karte heute von Wasser auf Luft zurückgebaut bevor sie den Besitzer wechselt. :sneaky:
so vergeht die Zeit in der man wartet am schnellsten. :giggle:
Was für Einschränkungen? Meinst du DSC?
So habe Antwort vom Asus Support erhalten, die bekommen frühestens wieder am 11.11.2022 Karten rein, zumindest die TUF OC. Jetzt kann sich jeder der noch was offen hat überlegen, ob er dran bleibt oder storniert.
Hab eben noch eine Gigabyte OC bei MM geschossen, sollten die mir heute noch ne Versandbestätigung dafür schicken, dann geht meine TUF OC in den Storno. WaKü Blöcke wirds ja auch für die Gigabyte geben.
die gaming oc habe ich mir auch bestellt. die rog strix hat schlimmes spulenfiepen. werde gaming oc behalten. 2149€ -60€ cashback = 2089€ ein netter preis. nur 139€ über dem uvp. die gaming oc ist sowieso kühler als die fe und hat weniger spulenfiepen und beim benchen soll sie genauso gut sein wie die fe
Da hab ich dir ja einen guten Tipp gegeben mit der kfa2 :)
Du hast nicht zufällig Hörgeräte? :fresse:
Nein ganz im Gegenteil, ich bin sehr geräuchempfindlich und höre wie ein Luchs! 8-)
Sollte Referenz PCB sein, dafür gibts Blöcke. Wollte zwar einen von EK aber wirds halt diesmal Alphacool.
Kann ich Heute Abend im Detail nachgucken. Macht aber ein guten Eindruck. Nicht schlechter als die TUF. Was VRAM Temps angeht sogar fast 10°C besser als die TUF.
So jetzt Gainward Kreischlüfter zurück an Alternate, FE nicht geklappt, Bestellung Asus Shop für nichts und jetzt eigentliche Wunschkarte Gigabyte Gaming OC bei MM mit Lieferbestätigung, wenn das nix wird dann halloooo zur 12700k iGPU. Dann hab ich echt keinen Bock mehr.
Moin zusammen,
Zumindest sollte dich "beruhigen", dass du bei Weitem nicht der Einzige bist, der leer ausgegangen ist. ;)
Grüße von nebenan aus Rosengarten. :)
Welche Maße Treffen denn auf die reale Karte jetzt zu?
  • Dimensions(with Bracket): 352 * 153 * 74 mm
oder
  • Dimensions(without Bracket): 336 * 138 * 74 mm
@SH wie schneidet eigentlich die gaming oc im 3DMark Speed Way benchmark so ab? bisher sehe ich nur die fe, msi und asus im benchmark. wirst du die gaming oc ebenfalls testen?
Hi!
Ich glaube die non-GS hat keinen DualBios-Schalter.
oder
Kann ich später mal nachmessen.
Hab grad nem Kumpel seine Suprim X eingebaut:
2880 bei 1,1V
2790 bei 1,05V
@Stock
Läuft grade ohne Mucken bei ~3120Mhz durch 3Dmark. Fiept aber wie Hölle.
Ähnliche Themen
Antworten
6K
Aufrufe
409K
