[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Im Idle habe ich sie bisher nicht zum drehen gebracht. Beim zocken drehen sie so bis 1500/1600 upm maximal. Eher im Bereich von 30-40% bei 1350-1450 upm.
Kommt natürlich auch immer auf das Case und die Belüftung an. Die Karte geht Lautstärketechnisch im allgemeinen Lüftergeräusch des Systems unter.
Beste Grüße
Das allein wär schon ein riesen Fortschritt zur 3090 Ventus. Die dröhnt halt schon wie ein startendes Flugzeug.
DIese Karte irgendwo zu sehen bedeutet nicht, dass sie auch erfolgreich gekauft werden kann. Lese hier oft genug, dass einige beim bezahlrn dann in einen Fehler laufen, Stornos bekommen oder die Lieferzeit dann doch auf zukünftig verschoben wird.
Das ist klar, daher habe ich auch getestet, ob ich diese Grafikkarte auch wirklich in den Warenkorb legen kann und das war der Fall, der ein und Andere hat sich auch gefreut !!! 😉
Danke dir. Ok, das hört sich gut an. Meine Lüfter sind bis ca. 52-53% quasi nicht hörbar, danach wird "hörbar". Ich habe es bei mir so eingeregelt, dass bei 70°C 53% die Fans drehen.
Yep, hier wird es wirklich hochgradig individuell, denn was noch hörbar ist hängt ja von der eigenen Gehäuselüftung ab und auch ob man mit Kopfhörer zockt wie ich oder nicht und wie sensibel man bei dem Thema allgemein ist, da muss man wirklich seine eigenen Settings finden. Daher werde ich beim Thema Lüfter wahrscheinlich keine weiteren Aufwände betreiben ;)
Also bei 75% Powerlimit und Framelimit auf 118FPS in AC Valhalla Preset Extrem hoch in UHD, immer noch 2835MHz Takt rauszudrücken von der SuprimX ist schon echt beeindruckend...
Und es macht bei diesen Karten schon viel Sinn die genaue und bestmögliche Verkabelung am Netzteil vorzunehmen. Konnte heute morgen mit der optimalen Verkabelung am PSU das Spulenfiepen deutlich senken. (Fractal Design ION+ 860W Platin)
Kann ich die tuf mit 3x8 anschließen am seasonic?
Sicher das nicht dein Netzteil auch fiept/gefiept hat? Wenn du jetzt zB alles nur an Rail 1 angeschlossen hattest und es nun auf Rail 1+2 aufgteilt hat, kann das was bezüglich Netzteil bringen. Aber das es ein impact hat auf die Grafikkarte selbst, ist sehr unwahrscheinlich.
4 neue Karten und viele bekommen garkeine Karte / ist wohl bei den meisten hier so das Sie mehr bestellt haben als Sie brauchen /
Hab gehört evga meint auch das nvidia Karten zurück hält das Ihre Board Partner die Karten überhaupt teuer verkauft bekommen :)
mal schauen ob nvidia die 4090 am 3.november immer noch zurückhält wenn amd droppt
Ok das klingt gut wird nämlich echt langsam zu viel im case....
Der letzte Leak war nicht so schlecht.
Aber auch dort wird es wieder eine begrenzte Anzahl geben.
Aber ob AMD endlich bei RT konkurrenzfähig ist - wird sich dann zeigen.
Hätte nicht gedacht, dass da noch mehr geht. Jetzt noch voltage unlocken und das Asus Strix BIOS Flashen auf meiner MSI Karte und dann vielleicht nochmal 3 Plätze hoch 😃
Ich glaube, dass ich diese Karte behalten werde.
Hat jemand seine 4090 mit einem fractal ion+ 860 befeuert?
Im Lieferumfang sind 3x 6+2Pin Y-Kabel für PCIe dabei.
Ich könnte somit 3 Anschlüsse vom 12VHPWR Adapter anschließen (450W).
Meint ihr man könnte den 4ten Anschluss mit einem 6+2Pin Y-Anschluss nehmen, dann wären 2x 8Pin Anschlüsse an einem Strang vom Netzteil. Oder lieber zusätzlich ein neues 6+2Pin Kabel kaufen?
Iich hab bei mir das ION+ 760 und eine Palit Phantom, bei mir kein Problem, das NT wird nicht mal warm und aus der Dose sauge ich so ca 600W beim Gaming in 4k mit 450W PT.
Und wenn AMD die Karte dann für 2/3 des Preises von nvidia, also für ~1500 Euro bringt, wäre das ein richtiger Schlag in die Fresse von nVidia :d
Denn da positioniert sich aktuell ja die überteuerte 4080 16GB.
Bin absolut zufrieden. Boostet standard bis 2760Mhz, die non OC ging bis 2700Mhz. OC je nach Benchmark von 2960Mhz bis 3070Mhz. Mem geht bis +1480 durch alle Benchmarks.
Finde für den Kurs eine sehr gute Karte. Kein wahrnehmbares Spulenfiepen, wie die non OC leichtes Rasseln an manchen stellen in den benchmarks aber nichts dauerhaftes.
Beste Grüße
Super, danke! Hört sich gut an. In Tests schneidet die wohl auch gut ab.
Allen Unkenrufen zum Trotz bin ich mit der Palit (Dacia) Game Rock (non oc) auch sehr zufrieden.
Meine macht Stock 2800 Mhz in Games, hat keinerlei Spulenfiepen, nur die Lüfter sind leicht am rasseln (sind glaube ich nicht die Lüfter sonder die Motoren oder so).
Hab sie für 1.949 € am Releasetag gekauft und habe keine Ambitionen auf ein anderes Modell zu wechseln.
Die Non OC hat halt nur drei Stromanschlüsse und keine Option für 600 Watt, wie das bei der OC ist weiß ich nicht.
Ich würde lieber noch 500,00 Sparen, bevor ich mir die völlig überteuerte RTX 4080 16GB kaufen würde. Die RTX 4090 ist ein Brett in allem viel schneller und dazu nochmals 8GB Speicher oben drauf, für mich ist die RTX 4080 16GB von der Leistung in Bezug zum Preis absolut enttäuschend. :unsure:
Wenn ihr euer Netzteil mal in Dauerlast testen wollt:
Metro Exodus Enhanced Benchmark
20x Loop
6k (DLSS-Super Resolution auf einem 4K Monitor)
Extrem, DLSS Quality, etc…
580 Watt kommen da bei meiner 4090 an, wobei GPU Out (oder so) auch mal 650 Watt anzeigt :-)
Läuft an einem BeQuiet Straight Power 11 Platinum mit 850 Watt und die Asus „low power LED“ blinkt danach nicht.
3090 mit XOC Bios war härter fürs Netzteil.
Erstmal unabhängige Tests abwarten, sah nämlich so aus das die 4080 16GB gar nicht so weit weg ist von der 4090, daher ist die vermutlich auch so eingepreist seitens NV.
16GB reichen aber völlig aus, die 24GB sind doch zu 99% gaga, die brauch Otto-Normalo selbst in 4K oder 5K nicht.
20x Loop
Was heißt sie blinkt danach nicht? Wann blinkt sie denn?
Doch, ist weit weg.... :d Die 4080 16GB hat weniger Cuda-Cores als die 3090...
In den Nvidia eigenen Tests war die RTX 4080 schon sehr weit weg, siehe hier:
Und das sind die Benchmarks von Nvidia, da können unabhängige Benchmarks eigentlich nur nach unten korrigieren, nach oben eher sehr unwahrscheinlich! Ich kann mich nicht erinnern, das der Abstand von einer
RTX XX80 zur RTX XX90 schon mal so weit auseinander lag. Und was VRam betrifft, kann man doch nie genug haben, wer weiß was noch an Grafikintensiven Games kommt! :unsure:
Ne ne, ich hatte ja meine Lauscher extra überall dran ;) Also Gehäuse vorne und hinten komplett aufgemacht, dann mehrmals den normalen TimeSpy laufen lassen, da ist bei mir das Fiepen am extremsten, vorallem bei Grafik Test 1, wo ja teilweise 250-260FPS zustande kommen.
Und es war und ist ausschließlich die Karte. Das Netzteil ist still,kein Surren,Fiepen,Zurren, bin direkt mit dem Ohr am Netzteil mehrere Durchläufe dran gewesen.
Das Fiepen kommt also eindeutig von der Karte, da war ich ja auch direkt mit dem Ohr dran und ich hab ja auch nicht gesagt, dass es komplett weg wäre nach dem Umstecken der PSU Kabel, sondern dass es nicht mehr ganz so hochfrequent ist und dadurch um einiges erträglicher.
Ähnliche Themen
