[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Und wie viele Punkte gab es bei dir?
Das ist an die Güte des Chips gekoppelt. Die GPU hat eine Qualitätsmerkmal von Werk aus und daran bemisst es sich.
Güte = X MHz
TUF / TUF OC Bios = +0 MHz
STRIX OC Bios = +45 MHz
Nun muss man herausfinden, welche Karten "mogeln".
also liest der chip das selber aus, und generiert dann eigenstöndig die Curve ?
Ich hab 240/1800MHz geschafft in SpeedWay ohne Absturz und das mehrmals :)
nur knack ich die 11k nicht :(
Hätte die Karte, die ich bei Platz 2 auf dem Benchaufbau hatte, nicht geschafft. Fehler und Abbrüche bei mehr als 1575+
Und die Karte war im PL mit 600 Watt wäre vielleicht mehr gegangen.
ich hab mir dein resultat letztens angeschaut, krank aber ich glaube bei dir ist es die cpu die da nochwas raushaut, aber bei @SH ist es der gleiche cpu :) und ich würde so gerne die 11k sehen, hab aber alles versucht, die karte ist aktuell mit dem 520w bios mit 240/1800 am ende. wobei die 240 auch ned stable sind, +210 lüft die kiste eindnwafrei bei +240 muss ich schon was glück haben, mal laufen 3 benches durch mal crasht das ding in sek 3 oder so.
Ich verstehe es trotzdem nicht. Es muss einen Trick geben oder einen Hebel um mehr Punkte zu bekommen :)
Ich habe mehr Core Takt und mehr Speicher Takt. Temps sind gleich. Aber du hast knapp 7% mehr Leistung.
Was hast du denn für Treibereinstellungen geändert? Muss ich irgendwie die Windows Auflösung niedrig machen? Irgendwas muss es doch sein :d
Hier gibt's die Asus RTX 4090 TUF zum bestellen:
ich tippe hier auf die CPU, vergleich doch mal unsere ergebnisse und sag mir wieso du mehr pkt hast als ich :)
Er hat einen 12900KS, du nur KF, Problem gelöst.
/Spaß bei Seite, ist es nicht so, dass der Speicher seit paar Gens ne Fehlerkorrektur hat und deshalb teilweise bei höheren Taktraten langsamer ist, weil mehr Zeit für die Fehlerkorrektur draufgeht.
Oder dein Windows ist einfach zugemüllter als seins.
sag ich doch seid 4 threads, das es die cpu ist : )
Full HD
Sind zu geheim die Einstellungen … TOP Secret ;-)
Spezial Auflösung und eine Spezielle Uhrzeit und dann ein kleines Tänzchen vor der Benchtable und erst dann klappt’s ;-)
Full HD
haha :d Das hab ich mir schon gedacht. Na kommt. Sagt es uns :d
Ich möchte gerne auch da oben stehen :)
Full HD
gib zu, du hast sie gestreichelt :)
Also wenn es wirklich das CPU Limit ist, sollte ich morgen mit dem 13900KF und den 6GHZ genauso viel Punkte haben. Ich bin gespannt :)
Wie schon gesagt … war nix … auf dem Rechner ist der sogar icue und der Asus Käse mit drauf gewesen. Die habe ich davor halt beendet inkl. der Services. Und es ist aus Platzgründen nur ein kleiner FullHD Bildschirm mit 60Hz dran. Windows lokales Profil… aber echt nix was nicht bekannt ist. Wie schon gesagt war mit dem Takt höher und bin runter und Zack das war’s …
Schöner Text :)
Ist aber richtig so.
Die Suprim X hat im Gaming BIOS 480W Standard TDP
480 / 100 * 93,8 ~ 450W
Die kannste jetzt auf 108% erhöhen und kommst dann bei 520W raus.
Das heißt, es ist kein Fehler? Dann sind 93,8 Powerlimit? Warum komme ich dann nicht auf 100? Liegt das an den Adapterkabeln? Es sind alle 4 Stecker am Netzteil angeschlossen. Netzteil ist ein Corsair HX 1500I W. Treiber habe ich schon mehrmals mit DDU neu gemacht, hat aber nichts gebracht. Gibt es noch mehrere mit diesem Problem?
Hier im Forum gibt es jemanden der mit der Asus Karte so ein Problem hat.
Sorry hab im Eifer des Gefechts schnell geschrieben
LG
Der 3Dmark erfasst halt nicht die effektive Taktrate.;)
LG
also 93,8 % ist falsch riecht nach ne kabel sache, haste mal am NT die stecker gewechselt ? oder mal ausgetauscht ?
Hat jemand die TUF und kann mir mal dazu sein case sagen und wie gut das mit dem kabel geklappt hat? gerne mit fotos.
brauch anregungen
ich such mir nen wolf.
Wenn man sie hochkant einbaut passt sie in jedes Case, siehe :
ich bin ja gerade kurz davor ne 2 win instalation zu machen und nur msi afterburner graka treiber und 3dmark druf zu klatschen ob ich da näher komme :)
aber dann passt kein luftkühler mehr. aio kommt mir nicht mehr rein ;)
kann mir einer sagen ob der nvidia bug in der windows 11 22h2 gefixt wurde ?
die niedrigen PLs kommen zustande, wenn das maximale powerlimit kleiner ist als das default. steht im bios etwa das enforced limit auf 480W und das maximale ist auf 450W begrenzt (nur 3 von 4 leitungen angeschlossen oder bios fehler), dann ist im arschbrenner der schieber bei weniger als 100% zuende.
@flashen weil es alle viele tun
-> nicht selten funktionieren die bildschirmausgänge nicht mehr korrekt nach einem crossflash. das war
auch in der vergangenheit schon immer so. ich wage zu bezweifeln, dass jeder, der von "flashen klappt problemlos" berichtet, das überhaupt testen kann.
tobi
Ähnliche Themen
Antworten
7K
Aufrufe
472K
