[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Hab eben fast einen Herzkasper bekommen^^ Erst doch nicht verfügbar, und jetzt Vorbereitung für den Versand :banana::LOL:
2500€ Karte und 5 Jahre alter Monitor läuft bei dir :ROFLMAO:
Sorry aber es beweist einmal mehr, dass das Groß an Leuten technisch einfach keine Ahnung hat #nofront Aber wer sich nen Ferrari für die 30er Zone holt....
War selten so genervt von einer Serie wie die 40er. Hab mittlerweile 5 Leute aus näheren Umfeld die ALLE auf 4090 gesetzt haben und ALLE auf Full HD oder billigen LED 4K/60hz Ferseher daddeln (Als Alternative, weil sie gemerkt haben dass die CPU bremst^^) und nun abkotzen, weil sie doch so viel für ein anständiges 4K-Display ausgeben müssen...und dann knausern sie trotzdem und rennen bei WQHD schon wieder ins CPU-Limit und heulen einem dann die Ohren voll wie gemein die Welt doch ist:shot:. Immerhin ist es Genugtuung für mich, dass die Leute größtenteils wirklich keine Ahnung haben und blind dem Hype folgen. Die Tests von PCGH und anderen sind nen einziger Witz sind eher als Werbetext wahrzunehmen, Scalper und mieses Preisleistungsverhältnis kommt da nirgends vor. Die Leute wollen 120hz / 4k für welches Spiel? 90% erkennen nichtmal den Unterschied zwischen Gsynch 60-90 FPS und nativen 120hz/120FPS und ich schätze mal für Konsolenports ist das eh zweitrangig und da wo es interessant wird joaa da fehlts dann am Displayport.
Und ja ich hab auch überlegt mir eine zu holen. Aber in meinem Körper windet sich alles dagegen 2k für so eine Karte auszugeben und einen Hersteller in seinem aktuellen Auftreten zu stützen.
Ich hab ne 3080 und es gibt kein sinnvolles Upgrade derzeit in meinen Augen. Außer ich möchte komplett auf 4K Umstellen, wobei dann andere Kostenpunkte vorrangig sind. Denn bekannter Maßen ists die Grafikkarte, welche am regelmäßigten ausgetauscht wird.
Man bedenke nun, einen Monitor hat man in der Regel 5 Jahre. Kostet so um 1000-1300€ UHD-Bereich
Dann hat man was zum Aussitzen und sogar bessere Bildqualität als die FHD-Experten mit ihrer 4090.
Die Preise fallen schön und schwupsdiwupps hat man ne Potente 4K-Karte für unter 1K. Einmal Windows auf UHD umstellen und 1000€ Konsumhype gespart und sogar noch die bessere Bildqualität erlebt UND für die Zukunft auch gewappnet.
Der Kommentar bezieht sich nur auf Normal- und Geringverdiener, mir ist klar dass nen Juppi genug Erbe hat sich alles auf einmal zu leisten und dem auch die Sinnhaftigkeit dieser Investition wumpe ist.
Danke für eure Aufmerksamkeit, habt maximalen Spass mit der Gerät!
Die KFA2 SG ist zu 99% ein Referenz Board mit 18GPU und 4 Memory Phasen. Such einfach mal nach der Galax 4090SG, da gabs schon LN2 Tests und die ist baugleich. Da kannst PCB mit der Inno3D vergleichen. Selbes PCB nur mehr Phasen bei der KFA2. Hab seit Release ne 3080 von denen unter Wasser. Kein Coil Whine und nur leichtes Buzzing. Auf ne 4090 kann man das natürlich nicht übertragen aber Referenz Boards neigen in der Regel weniger zu Coil Whine als viele Customs und 18 Phasen sind auch ausreichend.
Laut Support darf man auch den Kühler wechseln, muss das Teil aber wieder zurück bauen wenn man die Karte einschickt. Bisschen Grauzone weil die solche Fälle trotzdem auslegen können wie sie es wollen, aber das handhaben ja die meisten Hersteller so.
Hhm... gibt's PCB Pics? Dann wäre das ja die Karte für mich wenn FE nicht zu erhalten ist.
Direkt auf deren Homepage steht folgendes:
Reign with the dominate 16384 CUDA cores, 22-phase power design and the all-new PCIe Gen5 16-pin connector, KFA2 GeForce RTX 4090 Serious Gaming
Von 600Watt Bios steht da aber Nix
Naja es ist ein 4x8 Pin dabei, also höher als die 450 Watt sinds safe und ich meine auch schon wo gelesen zu haben dass es 600W sind, aber zur Not kann man ja flashen
Hab meine signatur im Bezug auf den Monitor noch nicht geändert. Kommt bald ein 4K OLED ;)
Mein Grafikschinken sitzt jetzt auch endlich im Nest :)
Musste allerdings vorher von dem CableMod Vertikal Mountig Bracket noch etwas wegflexen, weil das Bracket nur für zwei Slots an der IO der Karte gedacht ist. Aber jetzt passen auch 3 IO Slots aufs Bracket.
Für die Kurvaner unter Euch:
Stock default voltage curve
1,05V = 2835MHz
1,10V = 2910MHz
Auch das erste Mal, dass ich im normalen TimeSpy "Legendär" angezeigt bekommen habe ^^
Jetzt hoffe ich nur noch das Fractal Design sich auf meine Anfrage äußert, ob die ähnlich zu be quiet! auch einen 12VHPWR Kabel für ihre Ion+ 860W anbieten werden.
Bissel Spulenfiepen hat meine SuprimX, hörbar ab 230+ FPS, ohne G-Sync aber nicht mehr ganz so stark.
Hat da schon jemand Erfahrungen gemacht, ob sich das Spulenfiepen ändert/reduziert, wenn man statt des Vierzacks das neue be quiet! 12VHPWR -Kabel nimmt? Würde mich stark interessieren.
hast du das quiet bios oder gaming bios genommen ?
Das ist schön :)
FYI LG bringt demnächst einen OLED mit 27" raus. Wenns passt werde ich mir den holen, weil ein OLED steht schon seit 2020 bei mir...ach ja stimmt den hatte ich damals Geholt als die 3080 rauskam :d
Ich hab für beides 2600€ bezahlt :poop:
Das ist schön :)
ICh sag nur LG 77 OLED ist das beste ^^
ist schon extrem spannend, das die gleiche karte wie in meinem fall 75mhz weniger auf der Default Curve hat.
krass: "With more OC-focused variants such as GALAX's HOF which is said to come with dual 16-pin connectors and an XOC BIOS over 1000 Watts, we can see even higher numbers & better stability"
Karten mit noch mehr als 600W alleine bringen bei der 4090 nichts, da muss man erstmal die Spannung erhöhen können.
wenn du 4m vom Fernseher weg bist schon. Bei der Größe würde ich aber zu Sony's A95K greifen, hat einfach ne bessere Homogenität und ist auch ab Werk besser kalibriert.
nicht ganz 4m, sind nur 3,5m
Nene du mir machste meine LG nicht schlecht :)
ich hab auch nen LG und bin höchst zufrieden. Pixelresponstime macht den Fernseher zum absoluten Gamingmonitor^^ nur leider zu groß für schnelle Shooter wie Apex und co.
Und der Sony kostet auch nen Tausender mehr :d zumindest war das mal so^^
ich hab schon seit 3 jahren nen 65" LG OLED mit G-Sync...
viel besser gehts nicht
So langsam scheinen die Angebote an guten Karten weniger zu werden, kaum noch was bei normalen Händlern erhältlich. Nur Kleinanzeigen und eBay sind voll…🙁
seh ich auch so, hab mir letztes jahr nen 77er B1 gekauft mit HDMI 2.1 mehr braucht ein zocker nicht :) also zumindest ich nicht
Treffen der Strix 8-)
rip, strix war gestern.
die karten kriegen dann leider auch nur selektierte user
Ähnliche Themen
Antworten
7K
Aufrufe
472K
