[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
So, 5800X3D eingebaut und kein CPU-bottleneck + frametime spikes mehr in Cyberpunk im Bereich Toms Diner mit vielen NPCs.
Kannst Du bitte auch mal testen ob der noch ein Bottleneck in Spiderman maxed out macht?
Mit meinem 5900x komme ich da an die 120FPS nicht ran. Die Graka ist nur bis zu 80% ausgelastet.
Und wie ich gerade sehe bremst der auch in palgue of requim auf dem markplatz aus. Das ich so was mal erlebe. Hatte bisher immer nur GPU Bottlenecks :-)
Welche Temperatur die GPU selber hat, ist aber unerheblich für die von mir zitierte Situation: "Wird spannend im Sommer,..." - da wird ja suggeriert, dass ein Wasserkühler mehr Wärme in den Raum abgeben würde. Das ist aber faktisch falsch. Darauf bezog sich mein Text.
Bei der Luftmenge eines normalen Raumes macht ein Wasserkühler keinen relevanten Unterschied nach wenigen Sekunden. Die ersten paar Sekunden erwärmt sich die Luft schneller, weil man mehr Wärmeenergie ableitet in den Sekunden,... aber nur Augenblicke danach verteilt sich diese Wärme im Raum und die Wärme der GPU pendelt sich ein. Ob 450 Watt so oder so abgeführt werden, hat keinen Einfluss darauf, dass es 450 Watt sind.
Ein Wasserkühler kann die Wärme viel besser abführen und dann auf einer deutlich größeren Fläche an den Raum abgeben, natürlich ist die GPU mit Wasserkühlung auch im Sommer kühler. Besonders wenn du einen großen, externen Radiator nutzt
Ah ok, hab es nicht verstanden, weil du auch Vollast geschrieben hattest.
Hab mich mit dynamischem Desktop vielleicht etwas unglücklich ausgedruckt. Ich meine diese animierten Wallpaper, die man mit der Wallpaper Engine von Steam erstellen kann. Die saugen dann im Idle auch einiges mehr.
Alles gut. Also bis auf den Idle-Verbrauch :) Und ich dachte mir schon, Du meinst Wallpaper. Aber nein, nur Windows mit den üblichen Hintergrundprozessen, ohne Bloat.
In 4K maxed out ist das mit dem 5800X3D auch noch so. Absurd wie CPU hungrig dieses Spiel ist. Ich würde das Spiel aber sowieso mit DSR x2,25 (5760*3240) + DLSS2 quality (ohne nachschärfen) + frame generation zocken. Spielt sich super so und sieht nochmal viel geiler aus.
Liegt an raytracig. Abschalten und fps gehen cpu seitig hoch. Dir reflectionen sind ganz nett aber kein gane Changer.
Was fehlt ist rt GI.
Es geht um dem Raum.
Die Temperatur der GPU ist komplett egal. Das ist nur ein Plazebo oder "haben wollen" für die meisten. Die halten auch nicht irgendwie länger, weil man sie auf 40, statt 55 Grad laufen lässt. Die würden auch bei 85 Grad länger halten, als jemand mit Wasserkühlung sie benutzen würde. ;-)
Krass. Dachte da hat die GPU und nicht die CPU mit zu tun. Ja GI fehlt da etwas. Sieht nicht mehr ganz frisch aus das Spiel. Finde da Batman Arkham Night immer noch beeindruckender von der Atmosphäre.
Es hat schon was mit länger halten zu tun aber nich unbedingt bezogen auf Lebenszeit ( die aber auch schon aber das fällt da so nich groß ins gewicht ) sondern auch auf Taktsufen ( Boost mhz )
Wird eine Karte wärmer geht sie in den Taktstufen runter ( boostet die mhz nich mehr so hoch ) .. eine stufe sind 15 mhz und von diesen Stufen gibt es einige
.. daher macht es da schon sinn auf Wasser zu gehen da man so beim takt höher bleibt beim Zocken weil die Karte nich so warm wird und man verliert so weniger taktstufen
und der mhz Boost ist demensprechend höher und stabiler als bei Luft ... und sollte auch beim VRAM OC helfen sowie ein kleines bischen was am Verbrauch verbessern
Aus dem Grund reissen doch die ganzen LN2 ( Liquid Nitrogen ) OC Guys die ganzen Rekorde ein weil sie die Hardware in den Minus Bereich abkühlen und höher takten können.
Ich konnte zb mit dem Wasserkühlblock meiner 3080 Strix die GPU Temp von 71-73 Grad auf 48-51 Grad runterbringen und sie hällt nun besser den Takt
Kältere Karte = höherer Boost Takt = mehr FPS
Ja...? Dir ist schon klar dass 450 Watt den Raum nicht so stark aufheizen, dass es ins Gewicht fallen würde... Die Temperaturdifferenz zwischen Luft und dem Kühlmittel ist zwar relevant, aber trotzdem kühlt die Wasserkühlung bei angemessen großem Radiator immer wesentlich besser als eine Stock-Luftkühlung
Es geht mir vor allem um die Lautstärke, mit einem Mo-Ra kann ich die GPU auch im Sommer bei <20 db betreiben, da ist die meine Klimaanlage lauter :) Hätte ich nur den Stock-Luftkühler würde es mich stören, wenn die Karte manchmal laut wird
Besonders als ich die Karte noch zum Mining benutzt habe war mir aber auch wichtig dass der GDDR6X Speicher nicht dauerhaft über 75 Grad warm ist
Hattest du jemals Wakü? Ich seit mehr als 17 Jahren. Also hör mir auf mir irgendeinem Lehrbuch-Geschwafel. Die GPU-Temp ist mit Wasserkühler niedriger, als mit Luftkühler und du weißt genau warum, wenn du verstanden hast, wie man Wärmeenergie verschieben kann ;)
Nein…
Es ging um das, was DU von @HisN zitiert hast und NUR darum! ;)
Ein Glück ist Herbst. Bin auf den Hochsommer gespannt. Und was Wasserkühler so bringen werden.
Wo du richtig liegst, das die an den Raum abgegebene Wärmeenergie, egal ob Lukü oder Wakü, die Gleiche ist. War aber nicht das Thema - Punkt ;)
Habe jetzt mal 2 Stunden Bf 2042 gespielt.
GPU hat im schnitt 300 Watt gezogen und ist bei 55°C geblieben .
Framecap 138 FPS (Reflex) 4k max. ohne RT.
Die AIO´s von heute sind aber auch nicht schlecht.
Habe fest 850 U/min eingestellt bei den Lüftern und Pumpe bis sie leise war und hatte 52-59°C bei ca. 120-130 Watt CPU Package Power.
Was man merkt höhere Ram Temps ca. 50°C . Mora hatte natürlich den Vorteil die Wärme bleibt außerhalb des Cases , aber geht schon , wenn die Belüftung stimmt.
was mich halt jetzt an dieser tabelle interessiert ist, ob diese tabelle einfach nur marginale Unterschiede aufzeigt oder sprechen wir hier über Phasen und MOS die wirklich ausschlaggebend sind und Unterschiede beim zocken oder beim benchmark aufzeigen können?
Ist die suprim x die stärkste karte was benchmark angeht und das mit einem pt von 520W? Das man als tuf oc besitzer 300€ zahlt und sich von einer fe einholen lässt werde ich auch nicht verstehe. jemand hier der ahnung von phasen und mos hat. würde mich echt freuen wenn mir da jemand erklären kann, was es mit dieser tabelle auf sich hat.
Es sind schon große Unterschiede, aber für alles außer Extreme OC mit Spannungsmods ist das völlig irrelevant.
Die Chips rennen @Stock hart ins Volt Limit, kannst das Powerlimit gar nicht richtig ausreizen, geschweige denn 70A ziehen :fresse:
Für alle, die sich überlegen eine MSI Liquid X zu holen. Die gemessenen VRAM Temperaturen sind katastrophal!
Kann wer mit seiner Liquid X die Temperaturen des VRAMs bestätigen? Weit über 80 Grad sind wirklich ungenügend!
Die Founders Edition schneidet dagegen immer besser ab! Schade, dass man sie kaum bekommen kann.
Bin ich mal gespannt ob auf meine heute auch noch der Aufkleber drauf kommt. Status ist den ganzen Abend schon: Versandabwicklung
Bei mir auch. Ich werde die FE sicher nicht mehr diese Woche bekommen. (y)
Bei der TUF wird der VRAM auch nicht so gut gekühlt. Asus setzt hier wohl auf (zu?) dicke Pads um Kontakt mit der Vaporchamber herzustellen. Gigabyte hatte in dem Test die deutlich bessere Lösung und über 10°C weniger. Vielleicht hat ja jemand noch einen Link zu dem Test. Ich habe ihn leider gerade nicht zu Hand.
Der Alphacool Wasserblock kommt z.b. nur mit 1mm dicken Pads für den VRAM.
EDIT: Hier das Video von Hardware Unboxed mit den dicken Pads der TUF und den nicht so optimalen VRAM Temperaturen:
Wenn ich den Verfügbarkeisthread anschaue, war ich wohl der letzte, der eine TUF non OC ausm Asus Shop bekommen hat am Donnerstag. Seit dem wurde da wohl nichts mehr gelistet oder hat da noch jemand eine bekommen?
Jemand hier mit nem Dark Power Pro 11 850W ne 4090er befeuert?:LOL:
@Joey: Und funktioniert einwandfrei mit dem Dark Power 11?
Habe die Karte an einem Straight Power 11 750W (3 Strecker angeschlossen) und bisher läuft alles top.
Hat jemand ne Idee wie man die Beleuchtung der TUF ohne das Asusprogramm ändern kann?
So liebe Kollegen.
Eine Woche am Stück laufen lassen, und schauen ob das Spulengeräusch verschwindet^^
Hatte jetzt ein paar Tage hier nicht mehr so mitgelesen und gestern Abend dachte ich mir also irgendwie ist das Spulenfiepen leiser geworden naja vielleicht Einbildung und heute lese ich hier von deinem Versuch dann bilde ich mir das nicht ein, dann scheint es so zu sein. Also je nachdem was du jetzt festgestellt hast.
Probier mal OpenRGB (eventuell noch irgendein Plugin notwendig). Ist ganz cool, man kann RGB und FAN Speed anhand der Sensor Daten steuern. Ob es bei einer GPU geht, weiß ich leider nicht.
Der Vorteil ist doch gerade, dass eine Wasserkühlung mehr Wärmeenergie an die Raumluft abgeben kann...
Diese Aussage ist halt so einfach überhaupt nicht richtig.
Der Vorteil einer Wakü liegt zum einen darin, dass das Temperaturdelta zwischen zu kühlenden Komponenten und dem Kühlmedium (Kühlflüssigkeit) aufgrund des deutlich kleineren Wärmeübergangswiderstandes deutlich kleiner ist und weiterhin darin, dass der Wärmeübergang im Radiator an die Umgebungsluft aufgrund der dort möglichen deutlich größeren Fläche ebenfalls mit einem deutlich kleinerem Temperaturdelta klappt.
Aber egal, ob Wakü oder Lukü. Steht da ein Rechner, der 600W zieht, so werden diese 600W den Raum gleich stark aufheizen.
Davon ab diskutiert ihr gerade vermutlich einfach nur völlig aneinander vorbei.
@Tech Enthusiast
Los gings wohl mit der Aussage von @HisN ?
Kannst Dir sicher sein, das dieser nicht davon ausgeht, das sein Zimmer mit Wakü kühler bleibt als mit Lukü
Es war sicher eher so nach dem Motto: Sollte das Temperaturdelta der Wasserkühler nicht besonders niedrig sein, dann wirds mir im Winter eh nicht auffallen, da der Raum da ja kühler ist und das Temperaturniveau drückt. Spannend wirds dann im Sommer, weil da dann der Raum auch von außen her auf ein höheres Niveau aufgeheizt ist.
Tatsächlich ist bei meiner "alten" 3090 Strix der anfangs sehr starke Coilwhine im Laufe der Zeit weniger geworden...
Bei meiner leider nicht.
Hab das nach einem Jahr nicht mehr ausgehalten und die Strix gegen die Suprim getauscht und die hört man zwar immer noch aber lange nicht so massiv. (benchtable)
Das ist also leider kein generelles Rezept.
Ich werde die SuprimX auch sofort auf Wasser umbauen, sobald es einen Kühler gibt. Finde sie zwar nicht laut, aber ich habe nichts gegen niedrige Temperaturen und vor allem ist sie mir zu groß im System.
Und zwei Mora nur für die CPU wären dann auch übertrieben. Die wollen ja auch genutzt werden. :)
Ähnliche Themen
Antworten
7K
Aufrufe
441K
