[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Leute, ich bräuchte eure Hilfe. Ich habe doch das Problem der Bananenkarte. Ist eine palit gamerock. Ich hatte bei MF angerufen und der meinte, email an reklamation@mf… Das habe ich getan. Habe aber nur eine automatische Mail zurück erhalten mit dem Reklamationslink. Dort sollte ich dann alles ausfüllen und Umtausch oder Reparatur wählen. Die Grafikkarte hab ich seit Freitag.
Hatte Zeit zum überlegen. Ich wollte jetzt die Karte nur noch zurückschicken und widerrufen. Keinen Umtausch oder Ähnliches. Sondern nur noch Geld zurück. Da würd ich lieber auf was anderes warten. Kann ich überhaupt noch widerrufen? Oder muss ich die RMA durchziehen?
Die Karte lief ja ansich gut. Aber ist halt ne Büchse der Pandora… :(
Bild der Karte. Das Ding ist auch stabil, weiß gar net wie man sowas hinbekommst. Da sind alle Schrauben an der richtigen Stelle. Irgendwie scheint das falsch montiert worden zu sein, im Werk. Im Nahen, sah es so aus, als wären die Finnen zu lang hinten und deshalb geht das so weg. Und oben sind so Plastikstäbe die auf den Finnen sind anstatt so in Einkerbungen.
Keiner mit einer FE der mal sagen kann was die Max Load Lüfter RPM macht?
@Queue
Innerhalb 14 Tage nach erhalt kannst du Widerrufen ohne Angabe von Gründen. Das schlimmste wär, dass du den Rückversand zahlen musst…
Also wenn man den Thread dazu anschaut und die Rückmeldungen hier, dann sind genau die genannten Hersteller bis Dato immer davon getroffen. Von den Karten der 3090 FE gab es da auch Audio/Video Beweise oder nur mündliche/schriftliche Aussagen? Da die Wahrnehmungsfähigkeiten bei Menschen nicht immer gleichermaßen ausgeprägt sind, kann hier schnell mal eine Falschaussage getätigt werden. Die Erfahrung habe ich den letzten Jahren hier gemacht.
Ja und die Leute hier im Forum bilden jetzt paar Tage nach Verkaufsstart der 4090 wahrscheinlich weit weniger Käufer ab als 0,1% an verkauften Exemplaren. Daraus lässt sich höchsten ein Fazit ziehen, die Wahrscheinlichkeit das eine Karte von Hersteller X fiept ist hoch. Jedoch nicht das sie pauschal davon betroffen sind.
Selbst Audiobeweise ohne entsprechendes Equipment sind nicht 100% Aussagekräftig. Deshalb hab ich ja schon oft gesagt, es ist eher subjektiv und nicht für jeden Nachvollziehbar.
Ich hab von der 3090FE zB selbst jede Menge verbaut für den professionellen Einsatz. Natürlich war auch die Anzahl im Verhältnis zu allen produzierten klein aber es war eine Dimension aus der man zumindest im geringen Ansatz statistische Wahrscheinlichkeiten ableiten kann. Die Chance da eine fiepfreie Karte zu bekommen war auch klein aber sie besteht.
die einzigen 3090 etc die nicht gefiept haben waren EVGA
Rip EVGA -.-
@Queue
Drehen die mir auch kein Strick draus wegen der bananenform? Wär halt echt blöd
Also das Reklamationsformular muss man so oder so ausfüllen. Habe mal das FAG bei MF genutzt und war etwas aufwendig aber schlussendlich alles anstandslos erhalten.
ich würde es je nachdem wie wichtig dir dein account bei MF ist eventuell auf die nette art versuchen. wenn du mit dem modell an sich zufrieden bist würde ich sie eventuell tauschen lassen
gamerocks scheinen nicht solche einhörner wie strix und master zu sein. die kommen ja ständig rein
Wie sind die Gigabyte in Bezug auf Coilwhine? Oder haben nicht viele eine Gigabyte Karte?
@SH - Du hattest / hast doch eine, oder?
Die xtreme Waterforce war bisher die beste Karte. Ab 300 FPS erst minimales Coilwhine mit der Hybridkarte.
Zumindest das PCB scheint nicht verbogen zu sein bzw. noch im Rahmen. Der Rest ist natürlich unterirdisch. Für 2k€ darf sowas einfach nicht sein.
so wirkt es nochmal krasser :oops:
Das Bild habe ich heute erst im Video gesehen. Puh wo war das ... scheint fast normal zu sein diese Biegung am ende.
Tante Edith hat es gefunden :
also das in dem video ist wirklich sehr minimal.
beim kollegen hier ist die karte schon heftig schepp
Also das Kärtchen ist laut geht aber zumindest gut :)
2022-10-16 19_22_15-NVIDIA GeForce RTX 4090 Grafikkarten Benchmark Resultat - Intel Core i9-10...png
RMA abgelehnt, gewollter "Future Knick" :ROFLMAO:
Ey, das kann doch wirklich nicht sein, solch eine Biegung. Das kauft doch keiner mehr ab.
Naja, ok.. aber nicht für 2000€ ... in 2 Jahren wird sich keiner erinnern.. oh.. das ist ja die Palit Gamerock.. mit Future Knick.. für optimierten Luftstrom um direkt in die CPU zu Blasen.. Da sagen die zweitkäufer eher.. Ey, die ist schief.. 300 euro weniger.. oder kaufen gar nicht.
Rip EVGA -.-
Kann ich so nicht bestätigen aber zum Großteil ist das so. Ich habe 8x Strix 3090 damals gekauft für zwei Rendernodes à 4 Karten unter Wasser. Von diesen 8 Karten fiepten fünf und drei waren / sind gänzlich geräuschlos. Die Quote scheint bei den 4090 jedoch nicht besser geworden zu sein.
Ich würd lieber Geld zurückhaben wollen und dann doch auf die FE warten.. die ich die ganze Zeit wollte. Ich bau gleich mal wieder auf meine 3090FE um. Die andere Karte mach ich fertig ... dann mach ich das RMA Formular und erklär das ich keine Ersatzkarte sondern bitte das Geld zurückerstattet haben wollte. Dazu erklär ich das das schon so war beim auspacken und ich das vorhin erst auch einem Video bei wem anderes gesehen habe und ich das für eine 2000€ karte nicht für angemessen halte. Da kann ja MF nix für.. sondern Palit.
Das ist der Knick um GPU-Sag zuvorzukommen...
Warum ich gerade eine FE will? Alle anderen sind zu groß für mein NR200P... Ja es gibt Karten, die würden der Länge nach reinpassen...aber dann sind die so hoch, das der 12+4-Pin Stecker nicht mehr passt ohne die Tür aufzulassen :d
Wobei, wenn ich die Maße auf techpowerup vergleiche, könnte die krumme Banane reinpassen...aber ich bevorzuge eine gerade GPU...
Ne MSI könnte auch passen, wenn die Maße stimmen...
Ich habe mich auch umgeschaut nach einem neuen Gehäuse für eine Transplantation.
Das Asus Prime AP201 sah gut aus, hier ein Screenshot mit einer 4090 Strix (Von einem Youtuber):
Ich wiederhole: NICHT MEIN PC :d
Hab Heute Mittag meine TUF eingebaut, die fiept auch aber ist etwas erträglicher im Vergleich zur Suprim X.
Ist aber alles Glücksache. Man kanns weder am Hersteller noch Modell festmachen.
Was machst du denn damit die fiept? Ich hab auch eine und da fiept nichts
Er wird nichts machen. Das ist halt einfach von Modell zu Modell unterschiedlich. Oder du hast einfach schlechtere Ohren und hörst manche Frequenzen nicht. Ich höre bei jeden Lüfter das Lager auch Noctua ect für mich ist das schwer da ich jedes noch so kleine Geräusch höre. (Soll kein Angriff sein, kann aber vorkommen das es jeder anders war nimmt).
Aber durchs UV wurde es deutlich leiser.
Cyberport hat mir übrigens heute diese Mail geschickt:
_________________________________________________________________________________
Artikel Bezeichnung Stück Liefertermin
2E07-560 ASUS STRIX RTX4090 GAMOC 90YV0ID0-M0NA0 1 Liefertermin ist
derzeit unbestimmt
Gesamtauftrag: voraussichtlich verfügbar ab:derzeit unbestimmt
Denke ich storniere da, denn die haben das Geld bereits vom Bankkonto abgebucht
Ähnliche Themen
