[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
An die TUF Besitzer, war bei euch auch keine Folie auf der Karte außer an der Slotblende? 😅
Nur Slotblene und Lüfter ja, gibt ja auch keinen Grund für mehr Folie, ist ja kein Hochglanzlack oder so dran.
Ich find's mal wieder nicht so schlimm 🙈
Handy direkt vor dem geschlossenen Gehäuse, sämtliche Lüfter im Idle, volle Last @520W. Wenn ein bisschen was los ist höre ich das nie im Leben unterm Tisch raus.
Corsair-Kühler für die FE liese sich nun vorbestellen (Erhältlich in 5 Wochen):
Aber 250€ :fresse: Der Kühler für die 3090 Strix wurde damals zu Release mit Rabattaktion für 150€ angeboten, dafür war das P/L Verhältnis auch top. Aber die Qualität ist echt zu durchschnittlich, um 250€ dafür zu verlangen. Ich gehe jetzt nicht davon aus, dass sich da zur letzten Gen großartig etwas geändert hat.
Soo, heute nen Loch in das riserblech von lianli gedremelt und jetzt endlich die Karte testen können. Tolles Teil. Beeindruckend ist, das die Karten quasi alle etwa gleich schnell sind.
Jetzt hoffe ich nur noch auf nen Wasserblock für die gaming Trio so schnell es geht.
Ich brauch jetzt aber echt einen Kühler um die 4090 unter Wasser zu setzen. Selbst ohne Adapter und mit dem Kabel von be quiet krieg ich das Seitenteil beim O11D XL dann definitiv nicht zu, dafür ist die Karte einfach viel zu breit.
Vertikal wäre aktuell noch eine Möglichkeit, dafür müsste ich aber den aktuellen CPU-only Loop erst öffnen. Will ich eigentlich nicht. :fresse2:
Hab meine vertikal drin, gleiches gehäuse, aber der Abstand ist nur noch 1cm zur Scheibe. Auf Dauer find ich das auch nicht prall.
Scheint bei dir besser zu sein, Serienstreung?
Wurden ja einige von den Dinger "Massen" Produziert..
Ja klar, habe die 3090 zurückgebaut und da habe ich sofort PCIe 4.0
dass du dich damit überhaupt aufhältst.. schmeiss weg das ding und nimm die alte wieder.
btw,
mein board kann das nicht mal.. hier ist bei PCIe x16 3.0 schluss.. z370..
tobi
Ich denke nicht, dass es großartig anders ist. Einfach der Unterschied zwischen offen gefilmt und durch ein dickes Gehäuse abgeschirmt.
Hier nochmal geöffnet und direkt an der Karte gefilmt:
Ich sag ja die Bauart des Gehäuses macht viel aus.
Unabhängig der lauten Lüfter finde ich die Karten faszinierend. Hab jetzt ne Weile Assetto Corsa Competitione mit 7680x1440 triple screen gezockt und mit der 3090 mussten mit dlss paar Regler nach links das man auf 80-105 FPS kam. War immer voll ausgelastet mit 390 Watt. Jetzt limitiert der 12700 k bei ca 110 FPS mit alle Regler rechts und 30 Autos gleichzeitig und die 4090 gondelt out of the Box mit 60-70% Auslastung rum und 280 - 300 Watt. Wahnsinn ich fress gleich den Besen - perfekt.
Ich wollte noch mal zwei Bilder von meiner Kiste euch zeigen 😛 @Suprim X
Das ist Time Spy Extreme bei offenem Seitenfenster aus ~20cm Entfernung. Ich hab lange versucht, was hörbareres hinzukriegen, aber... will nicht. :d
Wird vom PaceLight-RGB kompensiert :p
Ist für mich ja erst ein paar Stunden mit der neuen Grafikkarte. Wohlgemerkt das "günstigste" Modell ASUS TUF non-oc aus dem eigenen Shop für 1949€.
Kollege hat das Top Modell Strix OC und es stellt sich gerade heraus... die beiden Karten sind gleich schnell und knacken problemlos die 3-Ghz Schallmauer.
Aus der Hüfte: Speed Way https://www.3dmark.com/3dm/80996019?
Wohin geht die Reise? Ich würde es gern testen, aber selbst der Afterburner limitiert hier aktuell. https://i.imgur.com/FjzVtGa.jpg
Absolut krankes Stück Hardware diese 4090. Sprengt bisher fast jeden Rahmen.
  • Danke
Reaktionen: A6
btw,
tobi
Naja, wenn ich schon über 2k ausgebe möchte ich auch alles ausschöpfen was die Karte kann.
Ärgerlich das mir so etwas passiert. Dort werde ich nie wieder etwas kaufen. Als der 11900K am Markt kam, kaufte ich auch dort ein und die Cpu war auch im Arsch.
Ständig Bluescreen konnte kein einzigen Bench laufen lassen.
Nächste Woche bekomme ich noch eine aus dem ASUS Shop, hoffe die geht dann..... ich werde berichten.
Bin jetzt mit der TUF bei 0,940 bei 2760Mhz.
Kein Performanceverlust aber kühler und viel weniger Verbrauch.
Die Karte ist der Hammer.
Aber Cyberpunk zwingt auch diese noch bei UHD in die Knie. Wird wohl doch irgendwann eine 5090 werden...
So wie es aussieht haben die Gainward/Palit Karten nur 16 Phasen ! und die anderen um die 20-24
Ist das jetzt ein großer Nachteil ?
@Youngtimer
Meinst Du die Y-Achse?
Schau mal in Post #7.550
eine strix hat in erster linie mehr blingbling als TUF.. also mehr RGB und zwei 12V anschlüsse für weitere lüfter.. davon beeinflusst aber nichts die performance. die reise geht auf 3.1GHz. das war zumindest das was ich meiner karte gestern entlocken konnte und was man so im orb in den top20 liest. 3.1GHz GPU und 1.5GHz RAM.
tobi
Um das Hobby geht es mir nicht, sondern um die dummen benutzten GPUs die ich dann geliefert bekomme, weil Du sicher nicht alle 10 behalten wirst.
mit Geld zuwerfen kann ich die auch, aber deswegen bekomm ich keine neue GPU wegen so Ungeduldigen Leuten.
ist leider wirklich so war bei ampere auch so einige schmeißen sich mit zig karten zu dazu noch scalper andere schauern monate in die röhre.
Teste mal ein DX12 Spiel wie Shadow of the Tomb Raider oder Horizon Zero Dawn. Im Bench macht meine Karte auch sehr viel, in echten Lastszenarien ist dann aber nicht mehr so viel mit "problemlos 3 GHz" :d
Also doch nicht das PT, sondern die Kurve?
Ich hab mal schnell AC Valhalla mit 80% PT und mit 133% PT getestet. Nen Unterschied gibts da nicht, obwohl es nicht nach CPU-Limit aussieht, die Karte liegt zu 99% bei 96% oder mehr Last.
Ist der Graph bei euch auch so voll mit Spikes? Ich hab leider keinen alten Screen mit der 3090 gefunden, aber ich glaub bei den ganzen AC-Games war der Verlauf nie "glatt".
@syntrax007 Es ist auf jeden Fall ein interessantes Phänomen bei dem ich noch Chancen sehe das es durch ein BIOS-Update in Zukunft fixbar ist. Ich wüßte gerade nicht wie ein Hardwaredefekt das auslösen könnte, ich glaube kaum das jemand einen falschen Chip verlötet hat. Da sind nocht einige Probleme im Busch was die 4090er angeht, für die AM5 Plattform gab es ja auch direkt BIOS Updates, ich kann mich nicht erinner, daß dies bei den 2000er oder 3000er auch so war. Vielelicht hast Du also Glück. Bin echt gespannt ob es bei einer anderen Karte auch auftritt, ich drücke Dir die Daumen.
Ganz interessantes Video gefunden, nimmt sich aber wohl nicht viel.
GeForce RTX 4090 | Undervolting vs Power limit
Anhang anzeigen 802636Anhang anzeigen 802637
Powerlimit runterziehen ist kontraproduktiv da die karte dann permanent den Takt drosselt wenn sie in PL läuft.
Beim undervolten bleibt sie smooth beim gleichen takt.
Hängt natürlich von der auflösung und der FPS ab welchen Takt man bevorzugt.
Höher takten als 2760 verliert dann aber die effizienz.
Wenn die 0,94v bei mir nach einigen Stunden zocken stabil bleiben kommt der ram dran. Habe ihn jetzt 750mhz erhöht. Bei 1000 ist die kiste einmal abgeschmiert.
Für den Stabilitätstest würde ich die den Metro Exodus Benchmark maxed out empfehlen.
Wenn der durchläuft hast schon mal nen guten richtwert.
Die Karten rennen immer ins Voltlimit statt ins Powerlimit. Deshalb ist undervolten sinnvoller. Dann rennt sie in kein limit und bleibt smooth.
ich wollte damit eigentlich sagen, dass es shice-egal ist was da steht. die karte hat soviel ram, dass du nie in die verlegenheit kommst, dass sie über ihr interface auf den langsamen systemspeicher swappen wird. warum das bei dir so angezeigt wird, kann etliche ursachen haben.. von softwarefehlern bis kontaktschwierigkeiten oder stromsparmodi.. solange es die performance nicht beeinflusst, würde ich es schlicht ignorieren. oder stellst du dir echt vor, dass du damit irgendwo die 11000 schaffst, wo jetzt bei 10700 schluss ist? die chance besteht.. die graka könnte aber auch schon mit dem nächsten treiber von ganz allein dahin kommen..
btw,
ich hatte gedacht, die können alle schon PCIe 5.0
edit
tobi
Interessant wird es bei Wakü...
Wenn sich die Strix da auch nur kaum bis garnicht abheben kann, ist die TUF Non-OC top
Oder man müsste 10x TUF Non-OC gegen 10x Strix OC antreten lassen
Kann sein, dass 7 von 10 Strix OC top laufen, während nur 3 von 10 TUF Non-OC gut laufen
Die Spikes kommen von deiner CPU :d
Da steht doch CPU Frame 25ms bzw 58ms max...DAS sind die Spikes.
Ähnliche Themen
Antworten
7K
Aufrufe
470K
