[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Was ist dann?
4090 mit LN2-Pot? :d
Haha, nee, dann geht's erstmal ans "Beschaffen". Die 3090 FE mit dem Superposition rekord hier ist an einen netten Luxxer verkauft. Der 12900k hat bei ebay sein Ende gefunden.
Rekordjagt kommt dann später... LN2 ist eh nicht mein Ding. Da kommt feinsäuberlich ein Waterblock auf ne gute Karte und gut. Vielleicht mal wieder ne Leitungswasseraktion. Dann ist gleich der Loop mal wieder schön durchgespült und ready for Neubefüllung 🤣
@pajonk
welches straight power ist es genau?
Bis zum Wasserblock erstmal provisorisch drin. Meine hat zum Glück kein wahrnehmbares Spulenfiepen. Besser gehts nicht. (y)
andere frage jemand ne idee ob man im fenster von curved die range erhöhen kann? weil bei 3000mhz ist "sichtbar" zwar schluss aber wenn man ne curve verschiebt geht sie höher.
So, Suprim X heute angekommen und eingebaut. Du meine Fresse......was sind das für "Monsterkarten"! Da braucht man ja nen "Hebekran". Also im Ernst, von den Ausmaßen ist hier aber echt mal ne Grenze erreicht. 😱
Aus dem Stand dann timespy (normal) stock 37.523 Graphic Score und rund 76% schneller als die 3090er Strix OC mit moderatem OC. Schon der Hammer. Temps bei lauwarmen 51 Grad. MSI Afterbuner sagt Powertarget max 108%.:unsure:
Das PT VON 8% IST RICHTIG. Hatte gestern die gleiche Frage. Du hast das Gaming bios an das hast 480pt + 8% = 520w. Das SILENT bios hat PT von 450w +16% =520w.
Die LED scheint normal zu sein bei den Asus-Karten, jemand mit der STRIX hat es heute auch vermeldet.
bei mir ist die aus und soweit ich weiss leuchtet die nur wenn stützstrom fehlt..
tobi
Denke ich fahre einfach 70% Power, das Video von Roman ist ja wirklich krass. Der 4-Pin Adapter ist für normale Anwendung ja völliger Humbug...
Aber die Seasonic ATX 3.0 gibt's doch noch gar nicht? Also Kabeladapter brauchst du wohl trotzdem.
aber es gibt 2-3 modelle, die zumindest den passenden anschluss aktuell schon integriert haben.
Hat jemand von euch mit der Suprim X schon die RGB Steuerung hinbekommen? Dieses MSI Center will, wenn ich dort Mystic Light installiert, habe meine GPU anscheinend nicht erkennen. Ich bin mir nicht mal sicher ob Mystic Light richtig installiert ist. Total blöd das man da extra dieses Center für braucht. Eine separate RGB Steuerung wäre besser gewesen.
Frage an die bequiet straightpower kenner. Habe nur 1 y kabel dabei.
Habe 3x pcie anschlüsse.
Am pcie3 ist die cpu.
An pcie 1 habe ich nun das ykabel
Und an pcie 2 ein einfaches kabel.
Somit ist der 4. Stecker der tuf leer.
Wie habt ihr das gelöst?
Wieso hast du nur 1 Y-Kabel?
In dem fall würde ich das Y-Kabel an PCIe2 anschließen und die beiden Solo-Kabel an 1 und 3, damit dürfte eine gleiche Verteilung vorliegen
Hat jemand schon diese rote LED bei der TUF ausgeschaltet bekommen und hat jemand sie in Signal RGB steuerbar gekriegt ?
Also um die RGB zu steuern habe ich ein 2tes Windows. Die Software von Asus müllt dir das System komplett zu. Und wenn die mal nicht funktioniert. Was oft vorkommt. Dann bekommst du den Fehler nicht mehr weg.
Komplizierter vertikaler Einbau im Fractal Design Meshify. Die Karte ist zu breit, stößt am Rahmen an und lässt sich nicht richtig festschrauben. Egal, Riser etwas locker gemacht und mit Draht dabei. Wo sind wir denn hier.
f6956856-11c7-4290-905e-190ce5ce1797.jpg 25c5a99a-fef0-447a-ba63-6ae65327a095.jpg 09f07e44-a313-4800-8888-9a84d88c518e.jpg a900d1d0-f042-4172-8ba4-2396c4674a36.jpg
Kein Spulenfiepen, auch sonst alles Top bisher. Gebencht wird später ;)
Achso, Powerlimit der TUF non-OC ist auch bei 600 Watt.
habe ich über corsair's icue gelöst. AURA bzw. armoury crate oder wie das teil heisst liegt zwar aufm system, aber schläft und tut nix bis man es aufruft.
tobi
laut handbuch sind pcie 1+2+3 für die grafikkarte vorgesehen.
also lieber die kabel auf 1 und 3 verteilen.
Danke. Aber daraus werde ich nicht schlau?
Wie in meinem Bild gezeigt ist PCIe3 schon für die CPU belegt. Somit bleibt nur 1&2 frei. An welchem soll ich denn das Y Kabel anschliessen und an welchem das einfache Kabel?
Desweiteren... Was ist wenn der neue Be Quiet Adapter kommt? Den muss ich ja auch in 2 PCIe Anschlüsse stecken. Wo dann wieder nur 1&2 bleibt. Der dritte ist ja mit MB gekennzeichnet. Wo ich dann davon ausgehe, dass der ans Motherboard zur CPU geht...
es steht doch recht deutlich geschrieben, bei 2 kabeln soll man laut hersteller pcie 1 und pcie 3 verwenden.
an pcie 3 das y-kabel.
das mb kabel steckst du dann um, verstehe das problem gerade nicht.
Ist für mich ein Buch mit 7 Siegeln 😩
Das Problem wäre wohin ich dann das MB Kabel stecke. Demnach dann vermutlich in Pcie2. Richtig?
Ähnliche Themen
Antworten
6K
Aufrufe
392K
