[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Grüßt euch hat wer auch das Problem das seine Gainward RTX 4090 Phantom Lüfter Geräusche macht ? Bei mir ist es der erste Lüfter von Rechts der sich komisch anhört aber mehr nach Motorgeräusche also ob der Motor ein Defekt ist ?
Ich glaube 4 incl. mir selbst. Als ob nen Wolf im Case sitzt und heult😂 ich hab Alternate angeschrieben gerade aber vor Montag vermute ich kaum eine Antwort.
ja bitte SN noch zu mir. gainward ist schon informiert je mehr modelle ich sammel desto eher kann die kaputte charge festgestellt werden
Also ich habe auch eine Gainward (keine Golden Sample, aber ich bezweifle das es hier einen Unterschied gibt).
Ich konnte bisher keine ungewöhnlichen Geräusche feststellen - es gibt hier ja einige Meldungen. Allerdings habe ich auch mein Gehäuse direkt zu gemacht. Ich würde sagen sie ist eine ganze Ecke leiser als meine 3090 FE.
Okay RDR2 war in Sachen Spulenfiepen bis jetzt wohl einfach worst case. Bei allen anderen Spielen (Dying Light 2, Cyberpunk, Division 2, FH5 etc.) ist das trotz gleicher FPS (100+ FPS) teils erheblich anders. Wenn ich das Case dann mit neuem Adapter auch komplett schließen kann und mit Ton spiele, sieht die Sache sowieso anders aus. Habe bei der TUF nun auf den Quiet-Modus umgeschaltet. Total geil, dass die Temps so niedrig bleiben und die Karte einfach total leise ist. Ein Unterschied wie Tag und Nacht bzgl. meiner vorherigen Karte (Palit 3080 gaming pro). Auch wenn das Case natürlich momentan ein Stück offen ist :d
Nochmal zu Cyberpunk: Ich glaube ich habe hier bei der Location "Tom's Diner" und um den Markt herum einen CPU-Bottleneck sobald viele NPCs da rumlaufen. Sehe direkt wie die GPU-Auslastung und FPS runtergehen. Die gleiche Location zu einer anderen Tageszeit ohne NPCs und GPU-Auslastung ist bei 99%. Ich nutze einen Ryzen 3900X. Könntet ihr mal testen was für eine GPU-Auslastung ihr da habt? Ich spiele in 4K mit allen Settings auf Anschlag und DLSS quality. Ich hatte mir gestern den Ryzen 7 5800X3D bei MF bestellt. Mal gucken, ob das dann einen Unterschied macht.
Hi, genau gleiche Situation bei mir nur dass ich noch Guthaben bei den Amazonas hatte und den 5800x3d daher schon drin hab, aber auch wegen rebar und cpu Effizienz. Ich teste später mal CP. Ich denke, dass es wahrscheinlich nicht viele Titel betrifft, aber hier und da....
Das heißt, wer eine NON GS hat bekommt keinen Adapter und kann die Karte gar nicht nutzen???
Nein, bei der Non-GS ist ein Adapter mit nur 3 x 8 Pin dabei, zumindest hatte das heute jemand hier geschrieben. Ob das wirklich notwendig ist bei lediglich 90MHz Unterschied ist die andere Frage. Vielleicht ist das Powerlimit unterschiedlich? Die Gainward GS geht bis auf 111%.
Meine suprim ist auch da, nachdem ups es gestern nicht geschafft hatte.
Bin leider aber etwas überfragt mit dem beiliegenden Adapter. MSI empfiehlt alle 4 Stecker separat anzuschließen. Nur habe ich bei meinem Corsair rm850 nt keine 4 sondern nur noch 3 separate Anschlüsse. Kann ich einen mit y anstecken?
Kannst Du, darfst aber nicht das Powerlimit erhöhen um in den Spezifikationen zu bleiben.
Wenn Dir auch 450W PT reichen (was ich bei dem Netzteil dringend empfehlen würde) oder Du eh PT Reduzierung planst, dann müssten auch drei Anschlüsse problemlos gehen. Das mit dem Y-Adapter würde ich lassen, Du riskierst einen Kabelbrand oder Abschaltung des Netzteils wenn der Y-Adapter für den 4. Anschluss bzw. Netzteil keine ausreichenden Reserven dafür haben. Im jedem Fall müsste es ein vollwertiger Y-Adapter sein (dann bestände das Risiko nur am Netzteil und da hat man normalerweise Schutzschaltungen), keinesfalls einen der den Split erst ganz vorne an der Grafikkarte durchführt, das ist ein Rezept für Ärger. Ich würde es lassen und bei drei Anschlüssen bleiben, dann solltest Du keine Probleme bekommen.
Alter. Ist das ein Brummer. Ihr dürft lachen.
Ich bekomme mein Gehäuse nicht zu.
REIN .. ist kein Problem. Aber durch den dämlichen Strom-Stecker (der ja auch mit Wakü an seiner Stelle bleibt) und dem nicht biegbarem Kabel.
Keine Chance.
Brauch ich wohl das (sauteure) Ding vom Bauer, um ein 90° Winkel zu bekommen.
Einmal lachen bitte :-)
Lässt sich doch super anpassen das Corsair Kabel ganz vorsichtig die Kabel entspannen .
Also meine TUF singt schon ordentlich vor sich hin, hab alle vier 8 Pin dran, glaube nicht, dass es mit drei in irgend einer Form besser wird :ROFLMAO:
uv probiert? das hat bei mir mit ner 3080strix ti immer gut geklappt
Aua, der Biegeradius wäre mir zu eng aber ich verstehe dich. Meines habe ich auch schon vorgebogen aber erst 4 cm hinter dem Stecker oder so, mein Gehäuse hat kein Problem in der Tiefe, nur in der Länge wegen dem AGB meiner WaKü, Ich habe das Kabel einfach ein wenig warm gemacht und dann vorsichtig an zwei stellen gebogen (einmal in Steckernähe und ein weiteres mal dort wo es dann unter den Lüftern Richtung Netzteil muss. Alles Trockenübnungen bisher, ich bin echt gespannt ob mein simulierter Einbauplan A den ersten Kontakt mit dem Feind überlebt :d
Das macht garnichts, solange man keine Litzen aus den Crimp-Hülsen zieht und der Stecker nicht an der Karte ist
So, die OP ist gelungen und der Klotz ist implantiert
Erster Bench out of the Box
ASUS 4090 TUF NON OC
Ja mit dem 3x8 Pin geht das Powelimit im Afterbunner nur bis 100% mit der Non-GS.
Ich habe mich jetzt mal nah ran gesetzt, Fenster zu gemacht und muss feststellen, dass meine Phantom GS auch ein gewisses Brummen auf den Lüftern hat. Ich glaube es ist nicht so schlimm wie im Video von @memphis@mg aber definitiv vorhanden. In einem geschlossenen Case würde ich es aber wahrscheinlich nicht mehr wahrnehmen, daher weiß ich nicht wie sehr mich das tatsächlich stört. Also da es ja öfters vorkommt anscheinend, ist ein Austausch wohl aktuell eh nicht das Wahre. Im Zweifel wird es dann schlimmer.
Dann stell mal im Afterburner verschiedene Werte bis 100%Lüfter ein dann hörst Du es. Hier auch nicht so krass wie im Video aber es heult schon gewaltig
Ok die Gaming trio ist da nette Karte. Erstmal mit dem Adapter am laufen lässt witzigerweise mit dem Adapter 7% zusätzliche Powerlimit zu. Hat jemand auch ne MSI und hat mystic light zum laufen bekommen?
Hat man erfahren können, woher das seltsame Geräusch von der FE bei Steve stammt?
Im Video vermutet er nur, dass evtl. 2 Metallteile ungünstige zusammenkommen
NBB hat wohl keine Gigabyte Aorus Master bekommen??
Hat die noch wer am 12.10 bestellt und nicht versendet bekommen? Da tut sich nichts.
...Hoffentlich kein Cyberport Fall wo man Monate warten muss...
Verstehe ich das richtig, dass es um die Lautstärke bei 100% Lüftergeschwindigkeit geht? Ich konnte bisher bei mir nichts ungewöhnliches feststellen. Ich habe mal die Lüfter auf 100% gestellt und ich würde es als lautes rauschen bezeichnen - aber das ist bei 100% ja auch normal?
Oh man, bin so gespannt ob meine stark fiept^^
Grad heute habe ich noch soviel ätzende Kunden das es später wird.
Warum so heiß auf die Karte? ich mein, ich finde die auch geil, aber hast du einen speziellen Grund?
Und weiter gehts mit selektieren :)
Morgen kommt noch eine und dann reicht das erstmal. Ich darf das Kabel ja nur maximal 30x rein und raus stecken 😂
Das habe ich, dieses eher hochfrequente "Heulen" habe ich gar nicht, es ist nur ein Brummen, wie ein Motor. Am besten hörbar bei 40%. Wenn man darunter geht auch noch hörbar aber dann wirklich nur wenn man ganz nah ran geht im offenen Gehäuse. Wenn die Lüfter höher drehen ist nix mehr hörbar. Stelle jetzt die Lüfterkurve auf 20% bis 40 Grad und dann würde mich es definitiv nicht mehr stören. Aber verfolge das gern wie Gainward das jetzt handhabt. In dem Video hat es sich schon übel angehört und da würde ich wahrscheinlich auch austauschen.
ne frage da die 2sensor pins ja eigentlich nur auf masse gehen schon wer probiert mal nen 4 stecker die masse zu nehmen das auf den sensor pin zu brücken bei einem 3pin anschluss? um dann der karte das freigeben zu lassen? müsste doch der wildest weg sein erstmal den 450w cap zu umgehen
Nein um die Geräusche Lagerschaden wie in dem geposteten Video. Also das hast beim Anlaufen und während dessen...
das gibt hier nur haue jungs :d
Ähnliche Themen
Antworten
7K
Aufrufe
471K
