[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
so einfach mal lesen .... 1 - 8PIN hat eine SPEZIFIKATION von 150 !!!!! WATT NICHT MEHR NICHT WENIGER
2 x 8 pin 300 watt ..... und so weiter .... ohne worte das hier einige diese tatsache klein oder wegreden wollen
Die Kabel sind für mehr als 150W spezifziert. Das sagte selbst JonnyGuru, der NT Designer bei Corsair, vor kurzem.
Siehe auch hier:
Wie kann ein 6 Pin Stecker nur 75W liefern, wenn 2 zusätzliche Pins diesen Wert bereits verdoppeln?
@Brainscan1979 Fiept die Karte unter Last?
Ich kann dir da nicht wirklich eine Aussage geben. Da ich mehr oder weniger Schwerhörig bin :( und mein PC in 3,5m entfernung steht. Also ich kann dir leider nicht sagen ob da SpuleFiepen vorhanden ist.
"Der Idealzustand wären eigentlich getrennte Kabel, also für jeden PCI-Express-Anschluss jeweils ein eigenes, separates Kabel. Damit umgeht man ziemlich elegant auch alle Ärgernisse, die bei so hohen Stromstärken und schnellen Lastwechseln auftreten können. In die gleiche Kategorie fallen dann auch kombinierte AWG-16-Kabel mit 2x 8-Pin und mindestens 8-poligen Netzteilsteckern, die sehr gut zu gebrauchen sind."
Klingt für mich jetzt nicht wie "Wenn ihr 8 Pin am NT auf 2 x 8 Pin für 300W benutzt seid ihr alle doof", aber generell sind getrennte Kabel natürlich "the safe bet"
Ich hasse dass, ich kann auf der DHL-Karte sehen, dass der Zustell-Wagen etwa 500m von mir weg ist.
Aber die Lieferung erfolgt erst zwischen 1200 und 1400. Das ist UNERTRÄGLICH^^
Ein Glück: Homeoffice^^
ohman... offiziell 150 watt !!! wenn ein ingeneur von irgend ner firma sagt, dass da mehr durch kann ist das seine persöhnliche meinung und das gilt vielleicht für corsair (intern) aber eben nicht für sharkoon oder china mist ....die werden ihren kram so bauen, dass dort die offizielle spezifikation von 150 watt (dauerleistung) anliegt .... wenn corsair meint hier mehr bereitzustellen ist das so aber eben nur inoffiziell .... du kannst auch ein komplettes haus mit einer stromleitung versorgen .... das entspricht nur leider keinerlei VDE NORM !!!!!!! gehen tut es .... punkt verstanden ? das risiko liegt dann eben bei EINEM SELBST !!!!
Das kenn ich, der beste Moment ist aber, wenn er nach dem nächsten Update schon vorbei gefahren ist und man nichts bekommen hat
Wie sieht man das? EXPRESS Option? Fahr doch einfach hin :)
dieses hier:
oder direkt aus dem be quiet! shop:
Bei dem Kabel versteh ich nicht so ganz die Zuordnung zu den Netzteilserien von bequiet.
Unter der Kompatibilität taucht das hier auf:
Kompatible Netzteil-SerienDark Power 12 series / Straight Power 11 series / Pure Power 11 FM series
Das Dark Power Pro 11 aber nicht. Dachte immer die Stecker sind netzteilsetig kompatibel zueinander.
gestern bei caseking meinte der verkäufer am tresen auch, das sie heute karten von zotac und asus bekommen :)
D.h. wir sind uns am Tresen begegnet? *gggggg*
Neiiiiiiin. Ich war von 1000 bis 1100 am Tresen.
Beim Tracking von DHL. Sobald Du Deine PLZ eingibst erscheint bei mir so ne kleine Google-Maps-Karte mit einem Icon von meinem Wohnort und dem Fahrzeug^^
Ich soll zum Liefer-Fahrzeug fahren?
Neiiiiiiiiiiiiiiiiiiiiiiiiiiiiin^^
Mit Ausweis zum Auto gehen..
Echt jetzt? Hast Du sowas schon mal gemacht? *gg*
Antwort von be quiet!
[/URL]
Und es kommt immer noch auf den Anschluss am NT an. Also, bitte erkläre warum 2x 8PIN Corsair NT Seitig auf 12VHPWR geht und für 600W freigegeben ist.
Beste Grüße
Beste Grüße
Ist bei beQuiet das selbe aBeR dIe SiNd NuR fÜr 150W SpEzIfIzIeRt!11!
weil corsair hier lügt und sich ausserhalb der spezifikation bewegt.... evtl haben die aber hier wesentlich dickere querschnitte in ihren kabeln UND ihren netzteilen, und die RAILS sind so ausgelegt, dass über 1 8 PIN 300 watt dauerhaft gehen. das garantiert dann aber nur corsair so ..und gilt sicherlich nicht für alle anderen ...
ich würde dieses Kabel NIE verwenden,
Ja perfekt grade ist die DHL Lieferung von Samstag auf heute Freitag umgesprungen. Wurde ne Gainward GS. Nachdem ich keine Chance bei der FE hatte und bei den Customs keine Präferenz hatte außer es soll bei 2k bleiben, waren nur die und ne Tuf zur Auswahl. Da hatte mir die GS besser gefallen. Nachdem eh alle ähnliche Werte haben dachte ich mir hey so what...meist ist der erste Schuß der beste und bevor ich jetzt ewig rummache. Mal schauen was das Teil bringt. Zudem ist sie über 400g leichter als die Suprim.
Es gab schon oft Tage, da bin ich einfach mit meinem Auto 20 Minuten durch meinen Ort gefahren um den Postboten zu suchen und um das Paket Stunden vorher zu bekommen :) Ging immer ohne Probleme.
Wenn Livetracking funktioniert bin ich schon oft dem Fahrer entgegen gefahren bzw. wenn ich zur Arbeit musste.
Hab mein Paket immer bekommen und die Fahrer sind dann sogar froh weil sie dann einen Stop gespart haben.
Das Livetracking is aber nicht immer ganze "live" ;) Manchmal steht das Lieferfahrzeug ganz woanders :)
Ja das sollte gehen. Hab ich mit der 3080ti auch gemacht weil er zu mir nach Hause kommen wollte statt auf die Arbeit direkt gegenüber.
Und als er mich mal nicht angetroffen hat bin ich mit dem Auto hinterhergefahren bis er angehalten hat. 😅
Hihi. Wildwest auf deutschen Straßen. Wie geil ist das denn?
Naja, ich sitze im Home-Office und hab die Handwerker hier ... ich werde das einfach aushalten^^
@Holzmann hat über 800W durch seine 6900XT geprügelt und es gab auch keinen Kabelbrand ;)
3x8 Pin + 75W PCIe ergeben aber nur 525W. Wie geht das also?
Und dein Chinaböllerargument ist ja wohl ein schlechter Witz?
Wir sind hier in einem Thread, in dem die meisten 2000€+ für ne Graka ausgeben. Wer von denen hat denn bitte einen Chinaböller im Rechner?!
Einem Chinaböller würde ich nicht mal ne 3080 bzw. die 150W pro 8 Pin Kabel zutrauen, aber das ist auch kein Maßstab!
Der Typ 4 Stecker am Corsair NT hat z.B. 4x 12V, also 1x mehr als der PCIE 8PIN benötigt. Der 12PIN benötigt 6x 12V und wenn die Kabelquerschnitte ausreichend sind und die Rails es zulassen, spricht nix gegen 2x 8PIN NT seitig auf 12PIN Adapter oder 12PIN direkt.
Aber einfach so raushauen das dies auf keinen Fall funktioniert ist einfach Falsch. Wenn es vorher mit der 3090 lief, läuft es auch mit der 4090 und wird sogar weniger belastet.
Beste Grüße
Ach Leute. Immer diese schnöden PSU-Themen. Sagt mir mal lieber wo ich zu humanen Preisen ne Suprim bekomme. Hab keine Lust 2700€ dafür abzudrücken.
Ähnliche Themen
Antworten
6K
Aufrufe
409K
