[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Auf ebay bricht der Scalpermarkt langsam ein. Die Preise der Gewerbescalper gleichen sich langsam an die der Elektromärkte an. Die Privatscalper versuchen durchzuhalten, korrigieren aber immer weiter runter...
Der gute "alde_9813" Privatscalper ist mit seiner Gaming OC seit gestern noch immer dabei. Musste Federn lassen und von 3,4k nun auf 3,1k runter ...Sein Gewerbescalper Gumpel "daja-computer" ist ebenfalls wieder im Ring und korrigiert von 2,7k auf 2,6k runter ....Sehr erfreulich! :popcorn: :popcorn:
By the way. CSL scheint noch diverse 4090 zu haben... u.a.
Völlig risikolos. Wenn die Käufer ausfallen innerhalb von 14 Tagen, wird die Shice eben dank dem FAG zurückgeschickt und gut ist. (y)
Die die schon ne Suprim X haben, geht bei euch die beleuchtung ? Hab MSI Center Aktualisiert, und Mystic Light auch. Bei mir taucht die Karte nicht auf
Starte mal neu, ging danach bei mir. Kurz zur info. 4090 Suprim eingebaut. Hörbares Spulenfiepen auch bei 80% PL, und die Karte taktet mit OC nur bis maximal 2900 MHz. Scheine ne Gurke erwischt zu haben. Bekomme Samstag noch die TUF non OC, würde mich nicht wundern wenn die besser geht, und das bei 300 Euro weniger.
Wie warm wird der Chip da?
Das mit den Spulen ist echt seltsam. Meine 3090Ti Suprim ist flüsterleise, sie hat 0 Spulenfiepen. Meine 3090 Strix dagegen hatte auch etwas Spulenfiepen.
2900Mhz bei der Suprim X ist natürlich eher etwas mager, auch wenn die Leistung mehr als ausreicht!
Karte kam heute an. Erstmal direkt einen Ghetto-Mod durchgeführt :devilish:^^
Immerhin werden inszwischen mal halbwegs anständig fette Kühler auf die Karten verbaut.
@BHouse noch ne frage, mein Bios ist die 46 am ende laut techpowerup hat die nen PowerTarget von 480(ist mir übrigens neu ) und kann nur +8 erhöhen auf 520Watt. Meine aber gesehen zu haben das sie ein ein PT von 450W hat und 16% erhöt weerden konnte ( kommt zwar aufs gleiche raus, aber mir war echt nicht bekannt das die Standrd nen PT von 480W hatt ). Kanns du mir sagen was du an PT hast ?
Bei meiner Rog Strix geht das Fiepen auch mit Powerlevel 70% nicht weg. Und man hört es deutlich auch schon bei 100FPS…
Ich glaub ASUS-Karten sind da echt berühmt für. Hatte 3 ASUS Karten aus der 3000er Serie und verglichen mi den anderen Karten die ich hatte, waren die fast unerträglich mit Coil-Whine.
Aber das Licht am Ende des Tunnels, 2 der Karten waren nach ein paar Monaten Zocken quasi nicht mehr wahrnehmbar vom Coil-Whine (geschlossenes Gehäuse)
Naja sind bei Asus ja auch exakt die gleichen Spulen drauf wie bei der Ampere Gen. Fand das aber nie so dramatisch wie einige hier.
Ist auch sehr subjektiv, wie alles was Geräusche betrifft. Mich z.B. triggert sowas extrem und ich kann es auch nicht ausblenden.
Ich habe das .45 BIOS (Silent Bios). Power Limit geht bis 115%, angeschlossen mit 4x PCIe 8Pin. Power Target liegt bei 460 Watt.
Hab von Asus 3 Karten der 3000er drin gehabt und eine 6800XT. Jede einzelne hat fröhglich vor sich hin gefiept, lediglich die 3060 Ti TUF war erträglich mit UV.
Ich glaube das hat aber halt auch viel mit der Abschirmung durch das Gehäuse zu tun. Bei offenem Aufbau habe ich es auch eindeutig wahrgenommen, aber mit geschlossenem Gehäuse nicht mehr. Ich hab aber halt noch so einen alten Panzer, wenn das Gehäuse gefühlt nur aus Glas und Mesh besteht ist's halt schwieriger.
Ne GPU Stütze, richtig. ist bei fast allen 4090 dabei weil die so riesig und schwer sind
Das finde ich aber jetzt SEHR Intressant. Wieso geben es 2 Bios ?
Gerade bei PowerTechUp geguckt einmal das 45 und 46
Suprim X GPU+200MHz//RAM+500MHz auf 3030 Boost
Hier siehts Du den Markt bei der Arbeit. Angebot und Nachfrage und so :d
Krass wie die Preise jetzt wieder anziehen. Die Shops scheinen echt ausloten zu wollen wie viel sie verlangen können. Kann mir keiner erzählen, dass dieser Preisaufschlag nicht zu 100% an die Händler geht
Und warum dürfte das nicht sein? Auch hier arbeitet der Markt. Angebot und Nachfrage. Wenn man was Begehrtes auf ebay vertickt freut man sich doch auch wenn sich Leute gegenseitig hochbieten oder man einen besseren Preis bekommt weil man wenig Konkurrenz hat. Händler leben nun mal davon. Ich habe bisher keinen dieser bösen "Scalpershops" irgendwo ganz oben auf einer Liste der Reichen und ganz schön Reichen finden können. Also scheint das Geld nicht einfach nur in irgendwelche Taschen von Leuten zu wandern die eh schon viel zu viel haben, sondern eben auch in die Gehälter von Angestellten, in Rücklagen für schelchte Marktzeiten und Investitionen in die Zukunft des Unternehmens, Marketingkampagnen die einem den nächsten Schnapper ermöglichen usw.
Ich sehe da echt kein Problem, ich habe eigentlich keinen Bock wieder die kommunistische Planwirtschaft einzuführen.
@Brainscan1979
2 versch. Targets
Weiß jmd, welches Fremd-BIOS auf die 3090 Suprim ging?
600W wären schon nett zum Benchen. Bin mega-überrascht, das die FE mit 600W daherkommt
Hab mit moderaten 500W PL gerechnet...
Noch mal zur Sicherheit: an diesen Stromadapter müssen vier separate Kabel dran, die dann in vier Anschlüsse ins Netzteil kommen? Es reichen nicht zwei Kabel mit jeweils diesen Doppelsteckern?
Wenn ich mich nicht täusche erwähnt Igor das in seinem Stromadapter Video.
Bei 13:55
Das wird der Ursprung der zwei Versionen sein.
Gerade bei #eBayKleinanzeigen gefunden. Wie findest du das?
Was sagt ihr dazu ? Gutes oder eher ein schlechtes Gefühl ?
Preislich durchaus „in Ordnung“ aktuell der Lage aber Vorbestellungen und direkt schon Geld bezahlen….ich weiß nicht 🤔
Das ganze läuft über Käuferschutz ab und der Herr ist wohl gerade dabei, seinen Laden neu zu eröffnen.
Hat 14 Karten der Suprim X bekommen …
Du musst min. 3 Buchsen am NT belegen. Und KEINE Kabel mit 2 Steckern an 2 Buchsen am Adapter anschliessen. So hast du max. 450W
Erst mit allen 4 Kabeln (also 4 Buchsen am NT) stehen 600W zur Verfügung
Ähnliche Themen
Antworten
6K
Aufrufe
392K
