[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
2 Tage warten und dann bestellen, die kommen überall wieder rein die nächsten Tage.
Beste Grüße
  • Danke
Reaktionen: SH
Ja, dann hast du das alte. Es soll nicht nicht funktionieren, man sollte es laut be quiet aber nicht nutzen.
Man kann das alte nutzen und es ist technisch möglich, es wird nur nicht empfohlen.
Wie gesagt meine 3090ti zieht bis zu 500 Watt beim benchen und das Kabel wird gerade mal handwarm.
Die wollen sich mit den dickeren Querrschnitten nur absichern. Klar werde ich mir das neue Kabel auch besorgen, aber am Anfang
reicht auch das EBN016.
Wenn der Asus Webshop gedenkt zu stornieren dann hoffentlich früh damit ich mein Glück woanders versuchen kann. Irgendwer hat auf jeden Fall in der Nacht den Preis für die Non-OC TUF von 1949 auf 1969€ angehoben. :confused:
Hab bis jetzt auch noch keine Versandbestätigung für die TUF OC .
Caseking soll wohl morgen ihre TUFs bekommen und dann geht vielleicht auch dann im Asus Shop los mit versenden .
EBN016 war die Artikelnr.
Funktioniert astrein an meiner 3090ti und die zieht teilweise bis 500 Watt.
Warum sollte es dann an einer 4090 nicht funktionieren ?
Im Moment finde ich das Kabel allerdings nicht mehr im BeQuiet Shop.
Bei der 4090 werden halt zum ersten mal die zusätzlichen 4 'Data' (Sense) Pins verwendet.
Und wenn die beim Adapter nicht belegt sind startet die Karte überhaupt nicht.
Zum Starten der Karte muß Psense#1 auf Masse liegen und damit statt 450Watt 600 Watt freigegegen werden muß zusätzlich noch PSense#0 auf Masse.
Igor beschreib das hier incl. wie das Nvidia mit den Stomadaper gelöst hat:
Also ganz einfach alte Adapter funktionieren nicht mehr.
Ich probier es mal und falls es nicht geht kann ich immernoch den 4 Zack benutzen........
Wobei ich mir eigentlich geschworen habe das dieses Teil nicht in mein Gehäuse kommt.
Sieht ja verboten aus.........
Hast Du schon Volt erhöht und geschaut wieviel Saft maximal gezogen werden? Gerade auch bei dem neuen Benchmark. @SH
Schicke Ergebnisse und Erkenntnisse! Danke
Ja habe schon Voltage mal erhöht gestern. Punkte wurden aber weniger bei mir durch höhere Temps. Mehr Saft wurden auch gezogen. Also Wakü scheint doch was bisschen zu bringen.
IHR SEID LIVE DABEI. Erste 11.000 Punkte Score in Speed Way :)
Ich habe wohl ein GOLDEN MEM Chip erwischt. +1600 gehen ohne Probleme!!!
Genieße deinen Rum solange er noch hält, spätestens heute Abend wird der Score geknackt :d
  • Danke
Reaktionen: SH
Da kann man ja beim Corsair-Kabel nichts verkehrt machen, da es nur 2x 8Pin mit jeweils 300W gibt :d (y)
Hab die Gamerock im bei Alternate im Korb, haue die aber wieder raus. T -1 min :d
Warum gibt es bei MF keine asus?
MF hat vor 4-6 Jahren Asus komplett ausgelistet verkauft also seitdem keinerlei Produkte von Asus mehr.
Grund sollen angeblich die von Asus diktieren Verkaufsbedingungen wie mindest Preise sein.
Aber wahrscheinlicher ist Asus einfach nicht weit genug bei den EK Preisen entgegen gekommen.
Was halt erstaunlich ist das dieser Privat Krieg inzwischen schon so lange geht, meistens einigt man sich nach einigen Monaten.
Ok ich habe Bestellbestätigung 17:50 Uhr.
Mal schauen ob heute Abend was raus geht .
Die Frostbite soll doch erst ende Oktober oder anfang November kommen.
Die Frostbite war nicht erhältlich gestern, siehe.:
Ähnliche Themen
Antworten
7K
Aufrufe
472K
